Advice information for classes in other projects [message #40426] |
Fri, 27 August 2004 02:18 |
Originally posted by: solomono.yahoo.com
It appears that the outline view for an aspect only shows classes that are
advised which are in the same Eclipse
project. Is there a way to show advised projects in other
projects
Solomon
Re: Advice information for classes in other projects [message #42287 is a reply to message #42089] |
Tue, 05 October 2004 09:46 |
Originally posted by: adrian_colyer.uk.ibm.com
Geir Ove wrote:
> I have the same question !! Please help !
> Anybody reported this as a bug?
> Geir Ove
> "Solomon Obi" <solomono@yahoo.com> wrote in message
> news:cgm5gh$u1u$1@eclipse.org...
> are
> > projects
> > Thanks
> > Solomon
There have been a set of related questions around this topic recently.
Rather than answer with all of the details inline in each thread, I've
created a short piece describing the use of classpath, inpath, and
aspectpath and what they all mean when working across multiple projects in
AJDT:
http://www.aspectprogrammer.org/blogs/adrian/2004/10/three_p aths_sta.html.
Hope this helps to clarify things a little for you. Advised types from
entries on the inpath should show as "binary type" links in the outline
view.
Regards, Adrian.
Re: Advice information for classes in other projects [message #42636 is a reply to message #42287] |
Tue, 12 October 2004 00:37 |
Originally posted by: geirAoves.online.no
I am sorry, but your blog in paths does NOT solve the original problem!
Also, the examples on path usage need to be more concrete to be useful: E.g.
Should BOTH projects be AJDT projects? I have ONE AspectJ Project A and one
Java Project B: I want project B to be woven with the aspects in A. I have
managed that (although I do not now if it is done correctly), but I still do
NOT SEE the affected Methods in neither Project A or B.
Geir Ove
"Adrian Colyer" <adrian_colyer@uk.ibm.com> wrote in message
news:cjtqhi$7md$1@eclipse.org...
> > Geir Ove
that
> > are
> > > projects
> > > Thanks
> > > Solomon
> AJDT:
> view.
> Regards, Adrian.
Re: Advice information for classes in other projects [message #42728 is a reply to message #42636] |
Tue, 12 October 2004 13:55 |
> E.g. Should BOTH projects be AJDT projects? I have ONE AspectJ Project A
> and one Java Project B: I want project B to be woven with the aspects in
> A. I have managed that (although I do not now if it is done correctly),
> but I still do NOT SEE the affected Methods in neither Project A or B.
Both projects need to be AspectJ projects. In order for aspects to be
woven into the classes in project B, project B needs to be built with the
AspectJ compiler, and project B needs to have an aspectpath setting
telling it where to get the aspects from. Both of these conditions require
project B to be an AspectJ project.
Could this be the cause of the problem you reported in bug 75594?
Matt.
Re: Advice information for classes in other projects [message #584096 is a reply to message #42287] |
Geir Ove
> > Geir Ove
that
> > are
> > > projects
> > > Thanks
> > > Solomon
> AJDT:
> view.
> Regards, Adrian.
FUDForum. Page generated in 0.05101 seconds
