Home » Modeling » EMF » Resolving Containment/Container Proxies and Cross Resource Containment
Resolving Containment/Container Proxies and Cross Resource Containment [message #396129] Tue, 11 October 2005 16:08 Go to next message
--------------010801080305030803080503
Folks,
We've prototyped a way to generalize EMF's containment references to
support proxies and to support breaking the containment tree across
resource boundaries. Patches are provided in 105937
<https://bugs.eclipse.org/bugs/show_bug.cgi?id=105937>.
The basic idea is that for containment EReferences for which
resolveProxy is true, the Resource's.getContents/EObject.eResource
association will be treated as bidirectional *non*-containment rather
than as a bidirectional containment as is currently always the case.
Comments and feedback would be much appreciated. Questions are okay
too, since I haven't explained much.... ;-)
<html>
<head>
</head>
Folks,<br>
<br>
resource boundaries.&nbsp;&nbsp; Patches are provided in <a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=105937">105937</a>.<br>
<br>
association will be treated as bidirectional <b>non</b>-containment
rather than as a bidirectional containment as is currently always the
case.<br>
<br>
Comments and feedback would be much appreciated.&nbsp; Questions are okay
too, since I haven't explained much.... ;-)<br>
<br>
<br>
<br>
<br>
</body>
</html>
--------------010801080305030803080503--
Re: Resolving Containment/Container Proxies and Cross Resource Containment [message #396137 is a reply to message #396129] Wed, 12 October 2005 06:42 Go to previous messageGo to next message
Originally posted by: marchign.fastmail.fm
Ed Merks wrote:
> Folks,
Seems really a lot of work, thanks!!!
I want to study it carefully, at the moment I cannot compile library2 due to
XMLResource.OPTION_CROSS_RESOURCE_CONTAINMENT cannot be resolved
Also, library2.test seems emtpy, is it correct?
Could you suggest which is the best way to deploy it? Do you have some
build script to deploy/install/run the whole EMF? Maybe some short doc I
could read?
Sorry, I do not know the whole eclipse plugin-development stuff, so
probably my questions are a bit ridicolous.
Davide
Re: Resolving Containment/Container Proxies and Cross Resource Containment [message #396139 is a reply to message #396137] Wed, 12 October 2005 07:55 Go to previous messageGo to next message
--------------060409010403020403050509
Davide,
Yes, it was a lot of work. Thanks for ruining my whole long weekend!!
Just kidding. ;-)
Sorry, I misspelled the library2.zip example zip file and as a result
zipped up an older correctly spelled one. I attached the proper example
a little while ago.
This document describes how we set up a development image of the source
by extracting it from CVS:
http://eclipse.org/emf/docs.php?doc=docs/cvsdoc/emfcvsug.htm l
If you do that, you can apply the patches and then the example
(LibraryExample.java) should run in your workspace.
Davide Marchignoli wrote:
> Ed Merks wrote:
>> Folks,
> due to
> I could read?
> Davide
<html>
<head>
</head>
Davide,<br>
<br>
Yes, it was a lot of work.&nbsp; Thanks for ruining my whole long weekend!!&nbsp;
Just kidding. ;-)<br>
<br>
zipped up an older correctly spelled one.&nbsp; I attached the proper
example a little while ago.<br>
<br>
by extracting it from CVS: <br>
<blockquote><a
href=" http://eclipse.org/emf/docs.php?doc=docs/cvsdoc/emfcvsug.htm l"> http://eclipse.org/emf/docs.php?doc=docs/cvsdoc/emfcvsug.htm l</a><br>
</blockquote>
(LibraryExample.java) should run in your workspace.<br>
<br>
<br>
<blockquote cite="middiipdu$9qn$1@news.eclipse.org" type="cite">Ed
Merks wrote:
<br>
<blockquote type="cite">Folks,
<br>
<br>
resource boundaries.&nbsp;&nbsp; Patches are provided in 105937
<a class="moz-txt-link-rfc2396E" href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=105937">&lt;https://bugs.eclipse.org/bugs/show_bug.cgi?id=105937&gt;</a>.
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
<br>
<br>
<br>
due to
<br>
<br>
<br>
<br>
<br>
I could read?
<br>
<br>
<br>
<br>
<br>
<br>
Davide
<br>
</blockquote>
<br>
</body>
</html>
--------------060409010403020403050509--
Re: Resolving Containment/Container Proxies and Cross Resource Containment [message #396162 is a reply to message #396139] Thu, 13 October 2005 11:19 Go to previous messageGo to next message
Ed,
I'm writing test code for your patch in order to understand it (and
well.. test it). If you think it can be of some use I will post it or
put it wherever it should go.
Anyway my understanding of your work at the moment is rather shallow, I
though that:
- eInternalContainer() did not resolve
- eContainer() did resolve.
But testing it I find that, in the following code:
Book book = LibraryFactory.eINSTANCE.createBook();
Library proxyLib = LibraryFactory.eINSTANCE.createLibrary();
((InternalEObject) proxyLib).eSetProxyURI(proxyUri);
proxyLib.getBooks().add(book);
book.eContainer();
the last statement does not trigger proxy resolution. Is it by design?
Is it a bug? Would you explain?
I think the following is a minor bug: if you modify LibraryExample and set:
branch.setName("branch");
resource.setID(branch, "branch");
root.getBranches().add(branch);
you obtain in output the following non well formed XML:
--file://c:/MyBranch.library--
<?xml version="1.0" encoding="ASCII"?>
<library:Library xmi:version="2.0"
xmlns:library="http:///library.ecore">
<Library href="My.library#root"/>
name="branch" <writers href="My3.library#/"/>
<books title="The Book: 2"/>
<books href="My2.library#/"/>
<books href="My4.library#/"/>
</library:Library>
Davide
Re: Resolving Containment/Container Proxies and Cross Resource Containment [message #396164 is a reply to message #396162] Thu, 13 October 2005 11:41 Go to previous messageGo to next message
--------------000108010605030401070004
Davide,
The design is still open for review and feedback. ;-)
It would be good to see your complete example. For example, I don't
know the value of proxyUri.
One reason that proxies won't always resolve in containers you can see
in the following code.
public EObject eContainer()
InternalEObject result = eInternalContainer();
if (result != null)
int eContainerFeatureID = eContainerFeatureID();
if (*eContainerFeatureID > EOPPOSITE_FEATURE_BASE *&&
result.eIsProxy())
EObject resolved = eResolveProxy(result);
if (resolved != result)
NotificationChain notificationChain =
eBasicRemoveFromContainer(null);
eBasicSetContainer((InternalEObject)resolved,
eContainerFeatureID);
if (notificationChain != null)
notificationChain.dispatch();
if (eNotificationRequired())
eNotify(new ENotificationImpl(this,
Notification.RESOLVE, eContainerFeatureID, result, resolved));
return resolved;
return result;
Notice the guard on the eContainerFeatureID. This is basically saying,
unless you are in a named container feature, don't bother resolving
proxies, or even checking. This might not be a good design choice, but
I did it for efficiency because that guard is very cheap to test
(cheaper than checking for a proxy) and unless we are in a named
container feature, I don't expect the container to be a proxy since the
container reference won't be serialized in the instance. Changing it to
this would always try to resolve so you might want to try that out, but
remember you can only resolve if your object is already in a resource in
a resource set:
if (result != null)
if (result.eIsProxy())
if (*eContainerFeatureID > EOPPOSITE_FEATURE_BASE &&*
return resolved;
return result;
I'd especially like to see the example that produces the ill-formed
XML. That's very very strange! Ideal for me would be if you provided
your own version of LibraryExample that would reproduce any issues you
are seeing...
> Ed,
> I though that:
> book.eContainer();
> set:
> xmlns:xmi="http://www.omg.org/XMI"
> </library:Library>
> Davide
<html>
<head>
</head>
Davide,<br>
<br>
The design is still open for review and feedback. ;-)<br>
<br>
It would be good to see your complete example.&nbsp; For example, I don't
know the value of&nbsp; proxyUri.&nbsp; <br>
<br>
in the following code.&nbsp; <br>
<blockquote><small>&nbsp; public EObject eContainer()<br>
&nbsp; {<br>
&nbsp;&nbsp;&nbsp; InternalEObject result = eInternalContainer();<br>
&nbsp;&nbsp;&nbsp; if (result != null) <br>
&nbsp;&nbsp;&nbsp; {<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; int eContainerFeatureID = eContainerFeatureID();<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; if (<b>eContainerFeatureID &gt; EOPPOSITE_FEATURE_BASE </b>&amp;&amp;
result.eIsProxy())<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; {<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; EObject resolved = eResolveProxy(result);<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; if (resolved != result)<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; {<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; NotificationChain notificationChain =
eBasicRemoveFromContainer(null);<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; eBasicSetContainer((InternalEObject)resolved,
eContainerFeatureID);<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; if (notificationChain != null)<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; {<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; notificationChain.dispatch();<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; }<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; if (eNotificationRequired())<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; eNotify(new ENotificationImpl(this, Notification.RESOLVE,
eContainerFeatureID, result, resolved));<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; return resolved;<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; }<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; }<br>
&nbsp;&nbsp;&nbsp; return result;<br>
&nbsp; }</small><br>
</blockquote>
Notice the guard on the eContainerFeatureID.&nbsp; This is basically saying,
proxies, or even checking.&nbsp; This might not be a good design choice, but
I did it for
efficiency because that guard is very cheap to test (cheaper than
checking for a proxy) and unless we are in a named container feature, I
don't expect the container to be a proxy since the container reference
won't be
serialized in the instance.&nbsp; Changing it to this would always try to
resolve so you might want to try that out, but remember you can only
resolve if your object is already in a resource in a resource set:<br>
<blockquote><small>&nbsp; public EObject eContainer()</small><br>
<small>&nbsp; {</small><br>
<small>&nbsp;&nbsp;&nbsp; InternalEObject result = eInternalContainer();</small><br>
<small>&nbsp;&nbsp;&nbsp; if (result != null) </small><br>
<small>&nbsp;&nbsp;&nbsp; {</small><br>
<small>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; int eContainerFeatureID = eContainerFeatureID();</small><br>
<small>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; if (result.eIsProxy())</small><br>
<small>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; {</small><br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; EObject resolved = eResolveProxy(result);</small><br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; if (resolved != result)</small><br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; {</small><br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; NotificationChain notificationChain =
eBasicRemoveFromContainer(null);</small><br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; eBasicSetContainer((InternalEObject)resolved,
eContainerFeatureID);</small><br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; if (notificationChain != null)</small><br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; {</small><br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; notificationChain.dispatch();</small><br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; }</small><br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; if (</small><small><b>eContainerFeatureID &gt;
EOPPOSITE_FEATURE_BASE &amp;&amp;</b> </small><small>eNotificationRequired())</small><br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; eNotify(new ENotificationImpl(this,
Notification.RESOLVE, eContainerFeatureID, result, resolved));</small><br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; return resolved;</small><br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; }</small><br>
<small>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; }</small><br>
<small>&nbsp;&nbsp;&nbsp; }</small><br>
<small>&nbsp;&nbsp;&nbsp; return result;</small><br>
<small>&nbsp; }</small><br>
</blockquote>
XML.&nbsp; That's very very strange!&nbsp; Ideal for me would be if you provided
are seeing...<br>
<br>
<br>
<blockquote cite="middilu1d$aap$1@news.eclipse.org" type="cite">Ed,
<br>
<br>
<br>
<br>
though that:
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
book.eContainer();
<br>
<br>
<br>
<br>
<br>
set:
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; branch.setName("branch");
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; resource.setID(branch, "branch");
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; root.getBranches().add(branch);
<br>
<br>
<br>
<br>
<br>
&lt;?xml version="1.0" encoding="ASCII"?&gt;
<br>
&lt;library:Library xmi:version="2.0"
<br>
&nbsp;&nbsp;&nbsp; xmlns:xmi=<a class="moz-txt-link-rfc2396E" href="http://www.omg.org/XMI">"http://www.omg.org/XMI"</a>
xmlns:library=<a class="moz-txt-link-rfc2396E" href="http:///library.ecore">"http:///library.ecore"</a>&gt;
<br>
&nbsp; &lt;Library href="My.library#root"/&gt;
<br>
&nbsp;name="branch"&nbsp; &lt;writers href="My3.library#/"/&gt;
<br>
&nbsp; &lt;books title="The Book: 2"/&gt;
<br>
&nbsp; &lt;books href="My2.library#/"/&gt;
<br>
&nbsp; &lt;books href="My4.library#/"/&gt;
<br>
&lt;/library:Library&gt;
<br>
<br>
<br>
Davide
<br>
</blockquote>
<br>
</body>
</html>
--------------000108010605030401070004--
Re: Resolving Containment/Container Proxies and Cross Resource Containment [message #396168 is a reply to message #396164] Thu, 13 October 2005 15:10 Go to previous messageGo to next message
--------------020705020608090301030901
Ed,
I'm sending you my tests. It is work in progress and not that
meaningful, it simply test some basic invariant but there is no inteded
usage.
In order to make clear for both the intended usage so to help in
deciding design questions like the one below, I plan to write some more
test case.
More precisely I mean to send you a toy implementation of Resource that
uses another Resource as backend and fulfills some of the requirements
previoulsy outlined in the thread.
I think it will help in recognizing which are the real needs for
persistency and possibly will help me in realizing how some of the
features may be implemented.
> if (result != null)
> result.eIsProxy())
> return resolved;
> return result;
I saw it, I did not understand the rational so I asked.
> Changing it to
> a resource set:
> if (result != null)
> return resolved;
> return result;
I must confess this is what I was expecting and I prefer this second
solution. I do not see how in the first case one can trigger load on
demand of the container. Maybe it will become more clear with an
implementation of Resource.
> are seeing...
Here is it (in the attachment).
Bye,
Davide
Content-Type: application/octet-stream;
name="library2.tests2.zip"
Content-Disposition: attachment;
filename="library2.tests2.zip"
UEsDBBQACAAIADeQTTMAAAAAAAAAAAAAAAAaAAAAbGlicmFyeTIudGVzdHMy Ly5jbGFzc3Bh
dGidjz0LwjAURWcF/0PIbqqbQ2sRqaBDlVJnqcmjjcaXmA/Rf29Vii46uL17 OZzLi9PrSZEL
WCc1JnTMRpQAci0k1gndlovhhKbTQT/mqnLOVL5pQ++dAL29kaNEkVBnOSWP 8nVG30musSO1
rRlwJY0DdhCeqSogb9p1tiqy3Xydl7NlnhV/2IwAxrUFZuEcpAWxUaGW6H6p dPAm+M62l/iE
4+jz+ztQSwcI1Ryc0qUAAAAzAQAAUEsDBBQACAAIADeQTTMAAAAAAAAAAAAA AAAYAAAAbGli
cmFyeTIudGVzdHMyLy5wcm9qZWN0vZLPSgMxEMbPFfoOZe8mtScP6S60xZsi VB8gTcY1Jf+Y
ZIu+vUmaVZZS8CDe5vtmvvwmIaz7MHpxAgzK2XVzR5bNAqxwUtl+3by+PNze N107v2Ee3RFE
3EEQqHxM08mdMcsNtFodkOPnikQIMawYLW5uC2cM2NgyOlbZrWeFIuhEHQal 5d6DyKrKbYpy
K4tTiQ57AkIrH4AcZSTCYSr4iZcA4M8KKcGxHzI7VE2nBqMXlF9xvQTyyK16 S5fe/C92L97B
8D+BVmd88sSLA0KdPovrr33u5wXK3LVMXvlZD72yTxeBsc7E778w/WVfUEsH CHsLp57tAAAA
pAIAAFBLAwQUAAgACAA3kE0zAAAAAAAAAAAAAAAAJAAAAGxpYnJhcnkyLnRl c3RzMi9NRVRB
LUlORi9NQU5JRkVTVC5NRn2QzU7DMBCE75HyDr5wwxb06KoHQNwoqqjE3XG2 YcE/Yb2uGp6e
pEZpkBA3WzPzzdhbE/AAieUrUMIYtLhVN3V1n0PrQG5/1FlczdKz8aDFVe9y h2G6zMp+8E10
aIvDYUOGhpXikZPWImHoHPAI2zDlS2rZv1jw4ExKO8NvWqiFN7SRpnaKR2yB fvU/RWscfhk+
48rAuno89ZFY7oz9MN1lV5lVVy/wmZFAFoYWkToF1mGfQNlIoCgHRg/XdTU/ aX3EhA065EFv
CODcMBmWYfCH8TwRTh7/TbzngPynY1xfaPIuc9yzIdai/N43UEsHCBtk7Szs AAAAwAEAAFBL
AwQUAAgACAA3kE0zAAAAAAAAAAAAAAAAMAAAAGxpYnJhcnkyLnRlc3RzMi9i aW4vbGlicmFy
eS90ZXN0cy9Cb29rVGVzdC5jbGFzc21UXVPTUBA9F0rThpSP8qkioIC2RSkq fiBYhEIRLX2Q
ggM+YCiXEigJc5MK/CJfBRVQZ/TRGX+U4970gxbal7vZe3L27NlN//778QvA CBYV1DF05owN
oYujqMNtx47OWNZumiIFHobunbxpONEtoe/xA0vsRuVNXLc5g7JlHDp5QVFT ssQg352gq0xO
t+3BUYbW5I7+UY/mdDMbjcsk3fqXjkxnmztGhsGzpxsmSQi9rwAuOcIwsxPh FbqPW5vcD6qh
QYHPh5YLvSOu3pGSXhVBtCtoY2i+VFNDBzqlYEukqA+GoVCNaleUKuhm6L3I piw3P8u3Elbe
3JwTwhIqrqNHwQ2GtgtgeltYB/pGjmu4iV4GNcudRW7bepZqt4fCV4ur6EK/ hlu4zeCdNMjy
GENHLZUrKgZxR8EQQ1dhNg6nMRjuYN7mTZMLDXcRYqgXeVOWu9JXeEVBhKH/ Uj5lOYW+DjN8
3zEserk5aZg8ld/b4CIt+2EIJq2MnlvRhSGfi0mPLrI2OVBjhirq0S/n90BD A7yEdbYNwnYn
ay8drYfHdGcUvEpGTtrcSZTWrjVUvXdyX6TVZUALWX1pMxuIYHmfzAm56HKv toJY1QzLN368
xIyC6YrvJFk4E3rGscSRhjhmaav5QmopPZ2Kz1V2Vw2daCSyhIZ5jFPxjOC6 w6UwlQxa0PAE
Txl8DtfFrHVA9qtLVl5keMKQJgdKFo1IkbQq1AR9xHXwSGMp8skPhLJ+yJ+X ThWN9KzR0xph
GZ2DJwis/kHPu2DzOVpXvyDwCc0/0bW2foprZ+j7fY6BY0L6EEA7wsQ+TG+p dAIhDFDmHkVa
gQv36S8EFNPaFuvME1JiGyPDZ4hG2DeMHrsiJU2TK/gRye0jyjGXqrMAx0PK w43G8JjIPNKM
ImmsSOqNDFfxFWTFiG+qgstb5vK6xjDKPsN4kStKpxTfEPmK0c9lKq+bXKjo rqFI48FzTBBq
0o0ZXrg0MiNRgcgJpr6DRn6KV5eVpQm6XEEZKFO+rkE5VqT0RlgNrnUS9KGC q9QlwxsXmfwP
UEsHCOspX1gUAwAA1AUAAFBLAwQUAAgACAA3kE0zAAAAAAAAAAAAAAAAOAAA AGxpYnJhcnky
LnRlc3RzMi9iaW4vbGlicmFyeS90ZXN0cy9MaWJyYXJ5MkFsbFRlc3RzLmNs YXNzfVHLTttA
FD2XhDxc8wpNIDxTysIJEpZaxIIgpKoSGywWBIEQqwkdwlDHkcZj2v5Vu6Jq pX4AH1X1jp12
kVpYI9+5r3PvOfP0+8cvALvYLmOKsBGqvhb6i29kbGI/yLw378Lw3AbKKBKa 90mkjH+rxVB+
GumPvk31EmUkoTgUKiI0vOvgXjwIPxTRwO8ZraJBt33B+fejD9IBoerCwQvC dJw1LnvtIA+3
62AGc2XMEpayvJGfTaLS5FkSRVK7mMcCoaATnrzn5cPko5/JOAlNlzAXqEie JsO+1OeiH/JC
tWB0I8ILoZX1x8Gi0IOYsJjDroIlwuxfwVqpXJZo08UKVgmlQ8Xzjwh1L1+a 1dwNU11ZhAKa
PN7cKR7fCp5/JeZTjBjEkvhvFMHpjRJ9I4+VZVSfbN61HXjFmxdgvwKqmEaJ /TJ7+2yJbeW7
Pe7lN75PocZ/hy2wwVWbWOSbm9XhJepsq/a1xxgHjGlz7k/QVa3xiOWTztcJ HI9t+x+OjTlY
Y4+smGOcI47a2lJn5xHrk5u85a33UoRGVsW7baaMSmil/Ahbac/rP1BLBwij 35YcqAEAAAQD
AABQSwMEFAAIAAgAN5BNMwAAAAAAAAAAAAAAADYAAABsaWJyYXJ5Mi50ZXN0 czIvYmluL2xp
YnJhcnkvdGVzdHMvTGlicmFyeUV4YW1wbGUuY2xhc3PtWXl4FFW2/52u7qrq 6uoEE7cgQtg0
JITI5pJo2GQPixBBFh06SZE0drpjdweIoDiKwoj7wqKOKxJ3ARVoogzjNurg uDvDuOAyM/qe
Mzg6M0/HGXTOrape002C3/e+7/3x+KNz695zbv3Oued3zrnFK9/v3gNgCL2i wEHoFfDXhX3h
toqoEYlGKmqsp/HLfc0tAUOBk9BjiW+pryLgCzZWzKhbYtRHCfKZ/qA/Wk2Q SgbNITjHhRoM
DRLcOlyQCfk1/qAxvbW5zgjX+uoCBqGgJlTvC8zxhf3i2Z50Rpv8EULvmsNh qGK5Zp8/SDi2
ZEFNEsvsaNgfbKwaNEfBUYThoXBjhVEf8LdEjAqjeTGPQ2GjImxEQq3heqPC z1tVzLKfZhvR
yfysoQfcHhyNYxUcQyjtYosUbR3H4XhCz0YjGp+d4KuPhsJts4xGfyQabiOc WTKopps7DrCV
B8S1qzzoiV4KTiCc/mP30HEiehOOZ4zjl0eNYMQfCtaGbKlpvhbCUYzQ9Gdr 1B+o4KkqFcUE
KlXQj3By/FDMVftMMqy1vNhXeHEgTlZwEsGbtqOOEgziMGlp5ag5vaQmM5Sq Os8M6jwlzqhM
x2CUcyCxPTN99Rf6Go2kr8ty+nq8LZt0rYoKwjFN0WhLZUVFhW3kEFPajaEY rmAYh1rceNtu
excdIzCS4DYmT59dO2b6uPHs35rsogz6NOGS09mT3YSmoJIPJem/Sb5IE/tQ wxlwqziLcPRi
f8Bg1PWVFdPahtjv1TAKYxSMJvTJfE99qLk5FLQ2O3fWZB1jMY7R14cNX9Tg CcLIkiyM6uTK
jH3M8xivYwImEvKs3eKBQagp6VK/28SoUsAgB2aXXt7srzhvWk1c1o2pmKag pvPh2cEqDm96
lgOzl9mqqZip4xzM4ii2rLIlCIUcYBlqHEi1nJrCoVDUgzk4T8FcTnwZQjrm YT5BiRjR6b5m
9s4x2Rw+x4NJWKjjfFxAcLHs5LMJIzr70Y6bztRJ22iRDh/qCB5myrhQkKkf 5SQ7MAtFUs9l
fA3HIPugAYsVMNC+XQrraEQTc9vX0JBhV5zJ81Us4WLBngjWNwknBXQ0x6GN NWeNiIqQcFCL
Ue/3BYTQRTrCYMQyO2JMkJ3frytPCLunolXHUiwjaNbZjQ2FLuTilXJwYoZP jXf01DYZxeKx
snioBytwiYKVBD1VUMel4uRUBlHrjwYMFZfx2dTxylAB8nIdVwhLVGEJT7IZ V6btO0zFGluB
hz9LWxuuYp29Nlwgv1bHdbieAVjI54b9USPMqS4FuzXH6G9kA62H4hlBw4Ob ReTdwjxMlxQL
l6vYwK5dZk6YqDfpuE2g1hi1Jce47+DTS00sw+KZRcWdGUvDk0t3ZyyNSC7d y5Uxdck66fi6
B5uxSMH9OfNipyygop3jMXXH2Va0pG+s4kF2gx1I5fGga8DDOh7Bo6KLCC01 RBcxeXKWGuPG
49imYGtavzO7LRI1mnVsxxMc6CFRxI6xVP2hipnMuSgzz/A1c556infOJOTY 1sWLjbCKnQRH
ebmGJxETDdJ8wdIOHU/jGY5yPgozFffvgqAicYotfqFjL37Jir6WFiPI1Buc jXqdkoOFxdzh
ObHD8xmKieR/GMUXdfwKL3HQR0PWGpekks4aLPsK9in4NefNLM7S8aqZE1vE VCAonPGajtfx
Bh9RxCeOqKQk4eQZrVHuHWwvZ3QrVrp7S+i+LdiSZXkzOsTPa+LnLQ378Z6C 36fAmjxj/PJ6
oyXKvZGO983WtcVCyrW5NuwTZeVxfKjjgBkBRphP82PG3r9//0DI1yAK4ac6 /oA/WjktWQWn
dV0F53e/DGr4DP+l4HMOv6SN40KBAJ81Q4/o+G98wZU9wt4PGNFQUIRTzqgw tbmL5W3/gi8V
HCQMyI7ESvZieC6PdPwVX/GRs6FjAoGZ4VCLEU4WmHGp/k9iy2Zmqidqw4Yx mRORj2swl5+/
4R8K/s4h0F0dHf+DbzhygsbyaGY42mar+CcL9B9VXSz2/5eOf+MQn2GTLzLd VOJLDFeqH4RM
3+pilYjpWlrKziFJJ6cwOc8yOW6sQnLOrmQyi4SDvoBdm8QuKjuO3IQ5uepY 5wM/Eqep5BHQ
RwvoXramvLzaQy7K16kH8c0o3zjbH2YkydgccQQ3k7g5ojOgQp2OJr4pSewO UfKz5VGVjmM0
1dXFjKbIHAm3r6ATdOpFJ3LpMYQX+T4nKlzf3H17ovVfQX10Kqa+zNq4ajMf wgSulK1htmZA
7j1mGZy5jCD7U6X+FpZqseFAnU6ik0Ufn3RK7itE59Nh2tMgnUpFKdVTaB9R abBIDsPM5KDQ
EMKJhzXPQ+V0ggiRoRxoNCxr85zujyNiE0fBCJ1GCpg9jHHhUCSS8EhEnOdp Op1OZ3A+99sq
ojqmJomUraqYmHQmp9nOq2LxX9xe0Anip4/4GajSWOGJ4aYnhIVn6zSeJvAh 1IdauAMb3WVP
18W6QpMIvQ9/sxLu7SN+GA7fCxS7KffQRJqu0wyaaTF7/LiALxLxL/aLkDyt Wzci+z1JRcbD
14Zeh5NTqdZu+iIeOofm6DSXzmMaCQT8otZ6jmdfIBHX1UcCpJN+lTB7vk4L aCH73JgoCFud
0+ed1bMwWyG+neQlj1/cATx0PhUq5GMexEvqBO7TNFqEGP9Qg06GSLayP2LP U6NOTaKJyBc5
tS4SCrRGjZm+aBPfY2mJTheKK6p9/RIqXClVahaHx4FkNBS7KUQXKdSSpUSk 1Kyz/b7GYCgS
9XMvGNQpTFyg1OSlvTSHIzrrVmn8vladlhLfLNSlvoC/gYERJh95/KbyNPkO Pqg2WqHQxYST
uqeh00q6xOo3ZhtLDW7j28waxn5aRYAGop/qdDldEW9mkqqEsw7fl6Tgyna9 VIkvOT248tcF
jOZiQW2eL9ZoDfdVtJbb/qTOrNZg1N9sJNorjkJfuJGPoTDLRzy2Jpz8usad aXdTsehiODZC
5ivE5inJy/58wutqOJHmT86xc8bHBFY6qtOFn+MyknrxYDak3y3ZN5kXNi4y 8Zdzeu9+iUnR
G54yHpEyHpkyPlUUs6Srk5eUlAaX98wLGstmpTqa/NnIkLOisKuN+Dfggs4Z Ird7M7oisVEg
/m3FWWfe1GkJt2/Zao9ppl222LSGtqCv2V+f/rWNUNzFB0Depk8XlGUMfA9z ioumONrUhMZr
UmuYndW3y7aeW5yGFMJ1m29cPWpy00fcqehJnZ4SVyeXSWuROHbqtEskU3Gh n2ZEImbRa6Pd
OnXQ0/YnoCZ/oIGdZ31PSE/fVSJ/n6bRL+iXCu1Nv/qazNTpWXqOD4sTX6sx YzHnqG5dNrnf
eoGb6OJikfmDDdyupcdLgvbabOtzsunywvQP/0OEPPqCXQ/xT+KRCzL/KvxU wX8528FVuhPq
Nh44OPPBXAZGwsO/uiXAf73814085FvKxwBO9ADyTupAj3k7GVpZDIWEGLhj LejTgb482T+G
ARLm8kopTw7ZjlNiOJUnOnAGr1ZNK91zm7esrODMXaiO4WwHX6knTd+OKTHM IFQ6i5wFs2M4
14Fya7RAQnkMPyEUOWOod2BuQtRV5Crw26LmiEWFEFOiyJUhKxfJBUFTtshZ JMfQ4oC5xu6t
VIqUguUxXCz2UQpWWfvwBj/lfZSUfYSsWqQWrLZl1YKr0mTVDFl3kbtgrS3r LrjalDUXr+FF
rUgruCGGmxiQFsOtyVeV88L6xL4byVwXC2UFt8c9VukpK/h54kEvK7gr8eAt K7gn8ZBXlBfD
fUl3lBVsSazlF+Vba7K1VpTP58BeesB6t8datEEVea1Ht/1oWxx/1K1VLW3V KcXwkCT88VgH
npxXsGMndvFJ7ibswJ6CHTvw7A68sAMvl7MAxfAbPmf+86Y4mKSCMOCdTI2i PEvlXcaZx39/
m6GTn00nP6mTn0XHk03Hk9TxZNHRs+noSR09i443m443qeO1dNqhTi/fgd9t xwcFH7GITbfp
5TnpVp5Jt3KTYcyHTySmVfku/EnahT9XutrRX5zQ14IVcWjfCmgyo7IB8fp3 hNt+2C/UnDnV
vs+lZgswVCHhzGazk2UGWzY7zfCRdpFDvOYk+zV7ydU1wHdtZefhlHPBZGV+ qSL0TsuiV0ha
XLGQdEbOVKE805CMjV6ImxCjApHP5phJKPEkMpVJifjMCs5H6SSxH10JAYVP 3gJxrAChJF6a
mD/enI9RzxREnRZ7Z1vsZy8OSFksj1EJw7Hfv7lStSZciQm3NSEnJrS0uM55 xlZcp8mq2WTV
7LLubLLu7LJaNlktIZvCqUIq+7GkuieFVD8qzC0HEruzwgz6U3500Kdv5bS3 augOBfgYuTuO
0ami/onXczhUWjpqmo6a1GGRs6zXx4FszIz7Sld62LpyRCaHVXXOsOXFUTnD lhdHZ1Dw/4n1
f4lYY7pFLCbULhq3lyZyZbI5JiztRDFXOsVc2YC4khRzJSuJLKJaTjBBSSOV ksqEOKlcyUqS
S/n7LpQTjBTMSw0zOUckySZ1cy9OzhlmvDgllQhykbOQpsZomnj/OYU0O0bc 7cZonng+n4H9
xAKmHFYSDZLTJs7hN3QlNlTTLVVzGKMezlL1cJaq6ZZmEsqdSSgtk1CetGDO GUP/uyQ5km6z
HS+ZhGrHXqm6HU910KJ5pdKwnVQn7kc7qH4T8sTfxbvI3w43LzFjKl1lRS6b NskWJpCehkXE
3peS+MsSiV8cJAX5+Cgqbi4xWk7YBE+Ru5Au3UWXJbL/G+3ol7L/6sz9d9BV qyU6sXTPPT9M
3cZ3yNFSnVSH/VKjvINJsF/u0PK1fOzXjvYu8i7Cfu8t3kPeQ7TGuoVKe/Al 3zjHQsUEFGIi
XzgnoReP+6EGJZiGUkxHOY+H4xxUYQ5GYz5mYAHmYSHqcD4CuAAXYxFWw4dr eWYD6rEFBrZi
MeehRjwLP/ZhCd7BhTjA0gcRxLcIEaGFPLiIeiJCA/j2Vo5WOg3LaAyW0xS0 0TysoHqspDAu
pVVYRdfgMtqEy2kLrqCncCU9i6voDayhA3yVO4gNdAgbHTpuc5yAux2l2OyY gvsdtdjiWIB2
x0o84FiDBx3X4yHHVjzs6MAjjufwqOMPeMzxJR53fIOt0vHYJvXHdqkMT0g1 eFKai6fYizul
esSkRuyRQhwZy/C8dDlekFbjRWkdj2/EK9IG/FrahH3SHTy+l+9UW/G69Aze lF7EW9IHPP6M
w+vv+J10CPudR+NdZ2+87xyND5xTccC5AB87G/GJ81Ier8UfnRvxmXMzPnd2 8PgFfOF8HX9x
vo+DLie+cOXhK9cQfO0ajb+5ZuAfLh++cbXhW9d6/NP1BL5zvY5/uz7GIdfX +F6WyCEPIEmu
IJc8k2R5ASnySlLlNeSWHyCNI0aXd1Ke3EGF8vN0jLyPiuTfUk95P50gf8Tj P1Ef+c9ULB+k
vvJXPP6G+isuGqCcTAOVYXSyMpMGKQupVInw+BIqV26nCqWdTlH20FDlNRqu vEcjlK95/G8q
V2U6Qz2eqtRT6Ex1Gp2lLqFqdQ2NVjfRGPUBGqfupvHqmzRB/ZImunWa5B5E U9yVNNU9lWrc
C2mm+xI6x72WZrsfpFr3k3Su+x2a4/6I5mpE52n5NF/rQQu1o2mRdiLVaQNp sXYKNWrDqEk7
g8ejaIk2hYLaTApps6hFq+XxfAprTRTRrqaodist1e6n5do2atNe4vGbtFL7 hC7VDtIqj4tW
evLpCk9futJzBl3lmUNrPBFa67mBrvbspms8H9N1uodu0PvTjfpoukk/n27W L6Zb9XW0Xr+D
NuiP0u36b+gOfT/dqX9Hd3lddLf3JLrHO5Tu9c6i+7yL6H6vj9q9TfSYt5me 9LbRU95bqMN7
Fz3t3Ul7vS/Rs9636Tnvh/S893N60ftXnjtEr3h/oH15x9Greb3osbyBzAAP 4Hgfk8UXIvoZ
Xc1cVvN60zrmC6HK+wVdS9cx02dIhXQ93QAJ8yQ3aulGOLHa8SGW8MiFrY7t dBOPZOxzrGee
3QwF3zqWMLtuhkoDHNVYxyM3jXH0ZabdAo1W0ad0K62Hh66hd2kDj3TaRC/T Rh55aQs9zU/r
kUfP0t10G4/ymUdOup3ugCQtk0bRzxmfJG2VZEa1nlvH3SinO+kuuJg3x7HO PZClrxJzh+Jz
zvNwijXHvBFz9/LcrYm5zYm5VzHGnnsfJdacawitpfuEva7RtJQ2s0Wyy0fn mrYpzJ13TItU
ZtDzpkVuWcITpkWavDOOXt4njbPQKy5Js9Ar0+IIlIVxBMpGBO25dpxrz+1j ufs5gynKeyzX
znMqc+MbCxUzwkbFnLBRuSvjqNxT46jcC+OotB5xVNpAqcpCpU2RjqUH6EE4 tSbHtyY+l3av
jU/Wttn4FO1AYu5gfM7T1zGKsTwEmSN8C2N5CArHuMDyEFR9nY3Frd9hY9H0 R20sHq8vjsW7
BB2888M8auPK9wg9Cqf3Fqylx+hxuLx34QITlex9ASMtb3jfRi9GwO/wfogC 2krb4Pb+gBN5
v+0ck+Z/ENmfUu/kuBWfWGu4HJbtoCf4T2mMdojK/jIPYqLQPkOY1o7+g+0y 2ybKZtku2sN1
s5Cet6o/19fBdnn9ffKLbE9+G+gDKPQht9EH0I8+xlj+O5U+Nb/SFlvvNhHC HL1Iv2JkfTCY
Ld7CuxC9JHajl/8DUEsHCPGq9fGKEwAAuy4AAFBLAwQUAAgACAA3kE0zAAAA AAAAAAAAAAAA
NwAAAGxpYnJhcnkyLnRlc3RzMi9iaW4vbGlicmFyeS90ZXN0cy9MaWJyYXJ5 RXhhbXBsZTIu
Y2xhc3OdWAl4VNUV/s+8mbyZ5MmSgDIIEvaQZBgFUUwQAQkSnCQIEQTrMkke yeBkJs68IJTW
aqVaa2ur1FotUrFqrLuRBoYoLl1QW+uCrXVprd0sdWlra7Gb9L9v3mSZTEi+ wse89+4959yz
/Ge5PPfJvv0AZssKHS7BxGikIRFObAlaZtJKBkPpr6rN4da2qDlHh1swamN4 UzgYDceag3UN
G81GS5C3IBKLWAsFWsmsNQL3mfEmMx8afAY8yBOMDEViZm17a4OZqA83RE1B YSjeGI6uCSci
6ttZdFstkaRgUuioSlSSsDUciQmOLTk/1KvMaisRiTVXzlqjY7RgbjzRHDQb o5G2pBk0Wzfw
PZ4wgwkzGW9PNJrBCGUFVzlfq02rmt/5GAVfAcbgWB1jBaVDiOjDbeA4jBOM bzatzOqycKMV
T2xZZTZHklZii2BByazQMCVOc5inZbgrCzAeE3QcL5j//8owMBEnCMZRx6rN lhlLRuKx+rhD
VRNuE4ymhrY/261INMilSi+KBVKqY4pgZiYq9q4TlCxr016crLw4HTN1zBAc 00+igRLMIk7a
2gmb+SWhbCxVDlyZNXBJxajMQDkCRBLtWRluvCTcbPb6umxQX1c5tL2u9SIo GNtiWW0VwWDQ
MXK2Te3DSZirYw6hljHesduRYuBkzBP4zOra1fWLa8+son9DuUmp9KnKJfPp yWGqpqOCQen1
3/JwsoU+zMdp8HlxumDMhkjUpNaNFcGaLbOdc/NxBhbrWMREyj6nMd7aGo+l hZ27qtrAEpxJ
7RsTZtgyuSCYV5Ijowa4MkuOHY8qA8twlmBEWloGGIJQyZD8w06MSh1Ucnpu 6s2tkeB5NaEM
rQ9no0ZHaGDwHLCq4NXmCJizTavOxkoD52AVUZy2yqEQFBFgWWwEUr1Ad1YL sBxrDKzFeQJP
kvVlqeDkgZ5wIj8Q/D3VTAlab+B8fEpQQKyfGY8xeS3Wyek5QN7Xs1UhoohW XIiLdVwkmDwk
sYEwGpid4aYmpkSO7Jy1XjmlyYCJDYL8tFOWxOOXsC308YhaoTtaqHF9i1ms PiuKTyrARkR1
kNboS2igFSzmXjqpPmKpPjA2FwjXeMES5WkgByUlYOmgD0ZmBcFAu3KUl45S spNeXNZPiTle
bHGkzFGmbDXwGXyWGqVNWZuIWGaCRaWPMek1mvM5Wpz+KK6LmQW4Elfp+DwR 35/SwDZlj057
asOtNp3lxTVcuczet7W/1sCXlKL5VDTNRlW/TNP7ZvSc2T1guhDXG/gqvqZ6 X3yTqXpfdXWO
yujDjfi6ju392vTqLUnLbDVwE77B4MZV6R2bZo3EgyvpXotONsOtzK5vUnK2 75e0b9hgJry4
VeAKlObjZuxQfT2mkLnTwLdxOycA2mEXkKlDgFKluxJxh4Hv4E4yhtvazBjh Vp4LbgNwkNaF
wbhbKRNQku5Rkr6bJaCndA0iQDHeZ+B+PECwWPH0HgtqyUAO0j6ER3Q8zKzP 4TQDnXa429RS
1HbKbgPfQxdDlQyrUJWU9Di7rt1i53O8ndVr06m+V/GmFAJzbHdjp47HBm0g A8ql4titfvbm
40k8reOpPjZU11VtbjTbLI4BBr5vj2ltabPYhuoTYVVBb8QPDfzIho2ZIASe oaFTp06NxsNN
quY/Z+DH+Em6LvUW/JqhC/764Vd8L37KUJeWKjPWq0R4ycDLOEiNeKiqFbnS QCn3MwM/Vylm
9FGOSfYLJS2g43XuZFyxjEmXj9ewQ/380sCv8BaRGUmqdXuoXa823jbwG4WX kRS4uCEZj7Zb
5sqw1aIa7u8M/F71UqdPKEba6cU7dFiI3jKbipXuhwz8Ce8Scirjw+wyKpH7 Dl3VzjoteB9/
1vEBkTBw18Bf8FfiK2ZutrJB63hAx984zR+13fjwEQ7r+AcRmpvOPnNpJNwc iyetSGMkTKB8
jH9S/d5xp3SQQA7kZR59hH8b+A/+SwmbwtFIEz0lqB6qKx69oPSeQZ8dEdE5 sGLG8DgMcYmW
hu9qc5PJOrzFDne1VzwC5IPiDPGKL5MbvayC048O8z565W7r70uBIYZCmt4S TtYylF4Zwbq9
MhHnbai1WCUZaYvzZRRTV3inGd8rZ1V7zIq0mj0ZTDCEE81siEU5rkS0MNF7 V2GlHG7ykZrM
etw+QgkPDRhGue9N9KT+zEEkZ41m6gqXiMepyugBUxT7af85gi7J7sWcWTNn cjYffi1Rk3qv
x3p7YJ9SqM6PmZet6usvd4M94UiE/9ji3BvssjAi1Ld8kE9rT5Bi8pDFj1I2 MmtzZT2dbWYu
1ZOGSAsOD0194DhsNAomhAYHkup2MseQuaqpeWzQq7SaZ8gpqvapeaXGTCZ5 TVHL8w05TSqc
wbQlEm1KmLH09NRrXHoKlQU4pAvvLCP67+TLGbJYl0X9BxYbt4YsEZZUnaWi 3azjvDljWCNC
pVdYl1zFxaqEx5o4K6v/bsiRFPmr01dXO5pjsv6XYbZi4E2WYYX6o/HNgzz+ 6vwKQlUZwFO6
B95H+OJisYC9DcxFAX+NNAGfx/DpwwiMTDPnTYNbUWuPdWPUuj3UrSyFIkEK fio6qRuTuTg1
hWka1nKnlIuzO3FiCqdwoRuncbeypnT/ra6nywoX7MXCFJa62N2X13ZiRQp1 ggp3wO8uXJ3C
uRoCKawT+N0pXODCWpuCWKnw+D2FzSlEXAjwLW6TKqJLSevJos3z5xVucmjz Cjf3o83rQ/tp
0up+vfDyFK5wwa+n8IVeaQFuXN3D+kWx99VGWeF1GRsqvI5Yt5bCVzQl9oZu 3Lyu8JY9+BYN
uU3QhV2Fd3Whowv3duHBAAnKU3hUQ4byrqNQik0Z4GOPqx+D35vCvmwOvzfN 8jg19vK534UO
eGsDXXiiEz8oPEASJ3y1gUHDF8gOX8COGK18VmOYMko8r5Rw51LCnbbw8bTb XiAYU3hRRTuh
Qmg7K7OykYHy9HMfT3+FX85+d4WeOe/VYZzXz0GD0spAWj0Xrd5D24EDthM7 8IS2sAO7u/Ha
ulJtzh68UeH2u7vw5i0YoZ6/3ovfdsDHLTqswlPm9zhey8uc9gd1mocHOWfk 2Q5K4Y8Khx0o
U5q8J7T8wwrG8u9+bxf+VeHz+1L4RHALCvy+InHvlTzSSb7g1iMvdWBKj/gi OSZbfpeM3KbJ
xNL9u46EHmFBWCSd0oknZY/rsOswntTKtO3adjZruxbIMpzDvF8EL5aiCFUY i2WYwPcpWIES
3jxLEUKA73NRh0rUk/I8vq3j3/Vo5HX/UlyArRwZt+EiXI+LcRsa6LxGPIwm 7OP9+1k04yBa
8CYieBeXcLaKiptFezQul2JcIYtwpazg9XQjrhIL22Qr03EHrpYOXkU7ca08 iutkDy+UT+BG
OcAJ/2XcLK/w/vcG39/GDnmHWXQIO+U9vn+I213ALtdk3OEqx52uhbjLtRJ3 uy7CPa423Ou6
Afe5duB+1+N4wPUMHnIdwsP0SKfrY+x2HUG35sZTGocYrQzPaKcwijV4XrsQ L2gb8aJm4SXt
chzUrubadryq3YTXtAfwutZJvm5O4qqWfohxql5KoRTxy6vtljEyltW0UrtS jpXj6PE6aZRx
4mdU1sk6GS/Hs8ZulVPRJhNYgzukgNf+CazPB/EW7Z8IzlPYJSfIJHjpCbcU y2RockBOlCmU
rNHaw5Q3CW7amkI95XlocYdMVVJo8zU2r04LHV6Okftkmkzn2yjcITNkJvOw jHQlMgseWn2B
LS9POx/zpFTKoNP6CVIuAdpjoVBmSxA+Wj+R8k6kpvbc6bSbnbRGtaEQwVnW JSfxUZqSk1Wa
PciXUwl7YUOr6cDUcgf0RxSIy/bKQqK4SJamU5FoL3fA/npv1xrP08B7iU4c FeE9IvQDLOHz
bN4ylPeL02fbGsJ+WyZnUbNJKKfFZZQislxJk+r/AVBLBwgB18PQfgsAAE4Y AABQSwMEFAAI
AAgAN5BNMwAAAAAAAAAAAAAAADcAAABsaWJyYXJ5Mi50ZXN0czIvYmluL2xp YnJhcnkvdGVz
dHMvTGlicmFyeUV4YW1wbGUzLmNsYXNznVgLfFPlFf+f3LQ3aa88CqhBkEJB StsQeSm0iLyK
VNKWQQXBqdymt22kTWqS8piPbSo+5nRuujEfw6HTDnVOQAuBiY9NZbjNOYdO Nh9zbk7nnDIf
m5uy/3eTNGkaaH+DH7n3ft/5znfO//zPOd/Hgc/37AMwWep1OASj24KNETOy 0RezorGoz5/4
qt5gtne0WdN0OAVDLjLXmb42M9Tiq2+8yArEBPmzg6FgbI5AK520QuBcEG6y CqDBbSAP+YLB
/mDIqutsb7QiDWZjmyUo8ocDZtsKMxJU38lBZ6w1GBWM8R/TiCoKtpvBkOD4 0vP8aWOWxyLB
UEvVpBU6hgqmhSMtPivQFuyIWj6rvZnv4Yjli1jRcGckYPmC1OVblvxabsVq +F2AIXAXYjiO
1zFCUNaPiozVBk7AiYKRLVYsNbrIDMTCkY3LrJZgNBbZKJhdOsk/QI3jk4vH p1ZXFWIkRuk4
STDz/9VhYDROFpxIG6s3xKxQNBgONYSTUrVmh2AoLbTx7IwF23wcqnKhWCBl OsYJJqaiYs8m
g5LlbQLFsQrFCZio4xTBcb00GijFJPKko5O0mVnqz+ZSVd+RSX2HVIzKDVTA SybRn6VmYK3Z
YqWxLj8q1tVJ2TS0LvgEI1pjsY5Kn8+XdHKyLe3GFJD0U0m1lPNJv5NaDEzH DIHbqqlb3jCv
bkE18fXnFqXRpytIZhLJAZqmo5JBSeO32Iy2EsMCzILbhTMEw5uDbRatDlT6 ajdOTu5bgDMx
T8dcJlL2PoFwe3s4lFB2zrIaA/OxgNYHIpYZszggmFGaI6P6QJmlx45HtYFF OEswKKEtRQyB
v7Tf9QNOjCodNHJCbukN7UHfubX+lKwbS1Crw983eEmyquDV5QhYcppeLcFS A1/AMrI44VVS
QjCMBMtaRiI1CPTkaCEWY4WBlThXkBdlfVkomN4XiWTk+5K/p5opRasNnIcv CgrJ9QXhEJM3
xjo5IQfJM5Gt9pNF9OICrNFxoWBsv8IGTDQyO82mJqZEjuyctNoFTuXTxVCg tRDNaNXRwgKf
hYWBYMre+baoFVVorjXQhnZBQQLN+eHwWvaTDCjVCHEMc2lDq1WsPiuLpxTi YkR1RARGpqCB
GDoFLqLbEIypBjIiF3tXuLCeMWjkiinKYhr3JWWcSxnHwagLl/bab6oLlycX TFVWf8XAV3EF
N09YvTISjFm0pSjD7sQYLb+KziU+iutDViGuxrU6rmFW9JY0cJ0yXafpdWa7 LbfRha9zZL09
bxt6o4FvKEMLaGhiGU39Jr3MzPqpk3sIdwFuNnALvq36Y3idpfpjTU2O6unG Ztyq47u9Wvny
jdGY1W7gNtxOAoRVeR6RWBoM+5YSyRjxtMx2ZuD3qDkb5vmdzc1WxIU7BQ5v WQHuwFbV+zsV
e+828APcQ9bQD7vIlPRDXFUSlIouAz/ENi40OzqsEHlXkYuSfUKesIXBuF8Z 41WafqQ0PZil
oKe8HUWBWviQge3YQbLEwok5Ft3Sviso+zC6dTzCypADNAO77HB3qKG2kAIl bmAP9jJUUVOF
qrS0B+z6zhi7YxLtrH6cKAePqrX7FANzTD+Ou3U8cdQm06ekqhVx9fNoAZ7C MzqezvChpr56
Q8DqiPGoYGC/fZTrSLjFVtUQMVWV3YwDBp61aWNFSIFf0tGSkpK2sNmk+sJz Bn6N5xO1IN0U
avtvCqsH3hVceIGhLitTbqxWifCigZfwO1rETVVZyJUGyrhDBn6vUszIMI5J 9orS5tXxGmdS
UCxi0hXgVWxVP28Y+BPeJDODUTVuH3xXq4m/GHhL8WUwFc5rjIbbOmPWUjPW qpry2wbeUf02
2UvUQvrpwrsEzE+0rKZiZft7Bv6B90k5lfEmO5FK5MyDWU1ynB4cxoc6/kkm 9J018BE+Jr9C
1oZYNmmTCOj4F0/8x2xJbnyK/+r4DxmaW87ec2HQbAmFo7FgIGiSKJ/hc5qf PhKVHSWQfdcy
jz4l5iLCu4hrndkWbCJSgpr+OuexC0p6j6pCcUq+LnmCUwa2whBdXAn6LrfW WazDG+1w17ik
QIACiBiGHCeDUrmRXio449g0z7Ard+s/LEMMGaqYprea0TqG0iXDWLeXRsK8 MbUXqySjbHGB
jGDqyvG8gqT1LOsMxYLtVk8GkwxmpIUHh2E5rk30MJK+z7BSDjT5KM3Fetje Qin39zmwct4V
6Un9iUfRnHV8U9e8SDhMU4b2OWmxn/Y+MhCS7F7Mc21qT57fB15L1Gk+jVi6 B2aUQrV/yFq/
LBMvZ6N9mJEg/7HFOZvtsjDIn1k+uE7rjFBibL/Fj1ouYtbmynqCbaUu3mP6 SQseHpoy6Dhg
NgpG+Y9OJNXt5HRDZqqmlmeTXqVVpSFVqvap80qtFY3yKqOGzzBkjpyZPLy2 BtuaIlYocXpK
O5c4qco8vKfLfMLWe6ZAFsoiXap7H1hs3hpyliwmIiwVnVZ9M7N6QEeEKpec zRpfXKxKeKiJ
52n1XxI5kqJgeeJ6a0dzeNb/RExWC3jbZVih/mh8y0M+f3V++fhkgUBe2S64 tvPFwWIBexqY
hkL+GgkBPo/j041BGJxYnH8ZnEpa+2AvhqzaRdvK42Dix+GhoWP2YiwHS+IY r2ElZ8o4OHkH
To3jNA7sxSzOVtWW7bvN8Ul50ezdmBPHQgd74+K6HTg7jnpBpdPrcRYtj+Mc Dd44Vgk8zjjO
d2Blj0Se15NXFLAl1Bz99+RliJCelfme/KJQHB0OePm2LiFLoQ2Uzc+S1T16 0SVJWb3osl6y
eobslynr8riKroxjkwMeVxxfS2vzcuL6nqU3iD2vJsqLbkq5WelOqnVqcXxL U2q/sxd3rCra
sgvfp693Cbpxb9F93XigGz/uxk4vBSri2K0hJXnfMSTFlvTy8RNHrwUedxyP Za/wuBNLnqTF
bj5/6kAXXHXebvxsB35e9AuKJCNc5z1qhL3ZEfbaQWVQfqUxkikjfqOMcOYy wpnw8MlEJH9L
vsZxUBGiuTJPgWVljuQrsDekRy5m6PJ7AUp7XuZXcv7xSlfKgj8MwIJekB1V VvrKunLJunpk
u/CMDWsXHtPmdOHhvXh1VZk2dRder3R6nN34460YpJ5/3o2/dsHNKUJYmVfu yUvimJ/a7W9q
tzxulNwj34Ysjr8rFnehXNH1A6HnnyjP/+1xdeMISeeOiya4FYUe9zBx75ZC yslgwW1Hnu/C
uB71w6QoW3+3DL9Kk9Fl+7Ye8W9nFZkrB+UgnpJDWoVWgae0Ndp+bT87vF1A ZAXOYbGYCxcW
YhiqMQKLMIrv43A2SnldLYMfXr5PQz2q0EDJc/m2in9XI4DzeJc+H5fwnLkJ F/K2aGILGgle
gPecJhV/HEALXkArXuEd/l2sxce8sx/hrX0Qr+UnokMm8iI+HVfKAmySAK6W dt5vb8C1shnX
yRYm62O4Xg7wLnsQN8qLuEkO8Ub6BjbLO7wifIQ75BNeID/H7Q4ntjoKcJfD wN2OwXwfgXsc
JbjXsRBdjnpsc5i4zxHF/Y5NeMBxCx503IOHHE9ju+N57HAcxk7HZ3hEOxnd RGi35sUebTqe
0GbhGa0a+7U1jOhaPKddgRe0m3FQuxMvatvwkrYTL2t7ObYfr2gH8Jr2Bl7X 3uK69/GmKsiS
j5Gq6MoJ9BRwaW+LR0ayJFdp3XKSjGIE6uVqGS0nM0qr5FIZI8Us1JfIajTx LQ9b5HSsl7Es
8gekEJfzTSd+rxGNcXARta1SIuPhJi5OmSCnQJN32O8mcg/NUSJuah4PJz1/ Fg1KH/2P25rz
iUKXlCp9xOEaW4uLXie1aKdhj0ySMr5Vs2qVSwVzdQ3lvDIZeUTifFtzvnYT ZohPToVOREbJ
FJlKLdtQJNNom5uIjKa+GbTePtAm+9gWeqj6m58ELu+W0/goi8sslYo7+TKb qSFzeaPrQklF
IjHEqYhevlsWkOnDpCaRrsyIimRCHEq3w5HcDXifO31ANh8miz/EfD6XEDfV IosTe9sWwn5b
In5aNgYV9PhUahGpVdqk7n9QSwcIUCWeYskLAADLGAAAUEsDBBQACAAIADeQ TTMAAAAAAAAA
AAAAAAAzAAAAbGlicmFyeTIudGVzdHMyL2Jpbi9saWJyYXJ5L3Rlc3RzL0xp YnJhcnlUZXN0
LmNsYXNzdZRbU9NAGIbfhbYpIZXzSRBQQEtRiooHLIJYKKKlF1JwwAsMZSnB kjCbVOAXeSuo
gDqjl874oxy/TUMpbe3N7n777vMd0z9/v/8EMIpFBTUMXTljQ+jiMOpw27Gj ycIpTQcFPobO
nbxpONEtoe/yfUu8j8qbuG5zBmXLOHDygnZNyXOI9zxGt5mcbtuDY/J2R/+g R3O6mY3GpZFu
65YOTWebO0aGwberGyZDe/htiXDJEYaZjQ2v0H3c2uR1YLiiQUEwiMaLqEfd qEdLolbRjFYF
LQwNZW41tKFdhm2JFGXDMBSu4rAiWAWdDL0X1pTl2mf5VsLKm5tzQlhCxVX0 KOhmaLkQpreF
ta9v5LiGa+hlULPcWeS2rWfJd2t4uNK5ig70a7iOGwyBSYMKP8XQVi3KFRWD uKlgiKGj0CGH
UzMMtz2v86bJhYZbCDPUirwp3VXkNbyiIMLQX2ZPWU4hr4MM33MMix43JA2T p/K7G1ykZT4M
zUkro+dWdGHIs2f06SJrUwWqtFFFLfplC+9q8CNAWmfbIG138r/TR0PiM902 NVfyqJg2dxLn
80fZlQ+gHBxZ8KKmhQpeOaV+wizvUZXC7oNi0raCqUvNLN7U4RmeK5ihgS3D JfSMY4lDDXHM
0oTzhdRSeiYVn6OPqNyzJ43VEyyhYR4TDKGM4LrDPYVKxVrQ8BCPGIIO18Ws tU+tUJesvMjw
hCEL3lhSrlEZKk0OpUIfdw18ss60C8pPhqx1kL8ArSrq6azRaY20jNbBY4RW f6PnTXPDGZpW
PyP0EQ0/0LG2foKuU/T9OsPAESmDCKEVw0QfoVcqrUAYA2S5TTutwMId+msB 7WmKPT/zpJTa
+sjIKaIR9hVjR26QEnPFDfg+hdtHyHEX1V6Q4x7Z4e7G8YBgPlkPDzrlQQOR kUu8QlhTxJsu
YQWKrIBbGEbWx5jwWFFaZfD+yBeMfSqiAq5xoSQ7v4fx4QlipJp09wxPXYy0 SFUocozpb6DG
n+BFeWRpki6XIENF5MsqyHEPGYiwKqx1CuhdCes8S4ZXrjL5D1BLBwjF8kfV EwMAAOwFAABQ
SwMEFAAIAAgAN5BNMwAAAAAAAAAAAAAAADQAAABsaWJyYXJ5Mi50ZXN0czIv YmluL2xpYnJh
cnkvdGVzdHMvTGlicmFyeVRlc3RzLmNsYXNzdVHLTttAFD2XhDxc80gogQDl vXCohBcgFg1i
U6kbLBYEgVBXExjCgONI4zGUv6IrEEj9gH4U6h07QhUYa+Q793XuuWf+vjz9 AbCJ9TJGCHOh
6mqh73wjYxP7QeYdWaeMIqF5lUTK+Bda9OXtQF/7NtVJlJGEYl+oiNDwfgZX 4kb4oYh6fsdo
FfXarWPOfx+cSweEqgsHnwijcdY467WCPNy2gzFMlDFOmMnyRv4yiUqTh0kU Se1iEjVCQSc8
edvLh8lHP5RxEpo2YSJQkTxI+l2pj0Q3ZEL1YHAmwmOhlfWHwaLQvZgwlbNd BTOEsaF0y6la
ds+miznME0q7isfvEaa9fGXmcwmmsrIGBTR5urlUPH0h+PiBeJVixACW/7sx BKczSPSZ/KHs
MrX/GzdtNVaYcQH2K6CKUZTYL7O3w5bYVh7tcU9+830Edf47bIFFrlrCFN/c rA6fMc22ah95
iPGNMW3OfQad1hsPmN3fuH+D47FtveLYmIMF9siKOMTZ46itLW18fcCXt0y2 mPV2itDIqpjb
UrpRCcvpfoTVtGftH1BLBwiRCq5nogEAAPcCAABQSwMEFAAIAAgAN5BNMwAA AAAAAAAAAAAA
AGAAAABsaWJyYXJ5Mi50ZXN0czIvYmluL2xpYnJhcnkvdGVzdHMvVGVzdENv bnRhaW5lclBy
b3h5UmVzb2x1dGlvbiRSZXF1ZXN0UmVjb3JkaW5nUmVzb3VyY2VTZXQuY2xh c3OtUl1v0zAU
PW7LsrVZOzo2PlrYCgPaTloeeCxCgsJEpYihrgzRNzcxxVMSDydF9F+BBKoA iR/Aj0JcJxGf
0uCBh9j35p5zfO+xv3z9+BnAHjoWCgz7gZxorudOIuIkdka09lWUcBkJ/Vir 1/OhiFUwS6SK
dobi5YzqQ+Ep7ctoakoz7YlDkVgoMdxSeuoIL5AnsXBE+NwxQOHoHObI8CRw fiINKGdY1Zms
8J8MBzHDmnvMX3GHjgwcV8ZJj2Hptoxkcoeh2O4cMZT6yhdlFFGxYWHZwirD +g/SXa353DDL
sFFZAUnaOIMlhppLYz2ahROhR3wSCIa6qzweHHEtTZ7/LCUvJDXy0P0/3tAA 5alIHhxMjoWX
MPTb7u9GeSoMVZS1Ty70xp0/IJmXuUivggu4ZOEiQ/VXt2w00CSjuO8zbLQz LwMeTZ2c2Rkb
567Y2MAm4WZaMrT+2hCDHSjuH0T3RcgjkmZjmuowHXFfGtNap9mzZ9ogjUFE tX7A41jEFm4y
dP/dYobGKSZjm+65SA+bWjOXTVGBPnoelK9QdI+qjPa17gLl7ifYzxaovkft bYo8S2s15W+i
RN7WaK9TZmccrONcqk2m5XojQht8vfsOtd0POF/A0+5uc4HLb74rltMeGqig maptZ4xczURb
ad8mauEqoQu4lrJ3cD3lm2luoI3lb1BLBwjAdM4SAwIAALcDAABQSwMEFAAI AAgAN5BNMwAA
AAAAAAAAAAAAAEQAAABsaWJyYXJ5Mi50ZXN0czIvYmluL2xpYnJhcnkvdGVz dHMvVGVzdENv
bnRhaW5lclByb3h5UmVzb2x1dGlvbi5jbGFzc7VWWXcb1QH+rq1EtjyUEALE BAhpnESKF0Gg
QONsjpETEdkJtmNjNxDG0rU9jqRxZkZJzJpC0oRSoFDasnUvSxe6QE8TlXN6 eO7v6FtPT/9B
2+/OjK5lSV54iHU8292+7S7/+O/f/g6gB59H0SSwO29NOaazkPSk67nJUV77 7aJnWkXpnHDs
CwvD0rXzJc+yi1FEBDbPlYqWl5x2zII8bztnghamKwXW77NYdECgOZ4YE4j0 2zkZQzNaDazD
eoGbM+x0qFSYks6oOZVni40ZO2vmx0zHUu/hx4g3a7kCXZm1I+sVuE3V6ssV LM8vywRtW7EB
G6O4ReD2Sm9hyYCZ9WxnwcCt2CTQKtNDI6N9Q/0pMsw0rtrbxs5uN3AHNgvc lHWk6cmwhsCt
8URts94o7hTYYTszSZnNW/OuTMrCNJ9tRybTRU86RTOfOj41J7NeC+5SxEkh hntwbxRbBbbW
tszahYJdTJJxPnlyOG1gG74usCFAckRSFivL7wIT8cycec5M5s3iTHLEc6zi TO9aviQyqwxJ
CdrRYWAHdgoYckQGYvuDdsRXbZ0Ya0Mcu6NIMAw1ahnoRJdAzJWeFnVTvE7T xFgro3tfFMl6
S0+Y2TPmjFSW3t/AxrCYHHrwgIEH8Q0GcEYPd1oP2xGvFyJwLTUsp6Uji1nV SxwPG3gE36Rx
VN8TOFivQNiM+payXskx8wP0quTI3slElfxBBpgX5vjuZboI6rRhL/YbOICD Ai0y7fry+xNu
MgaBPgOH0U8VTdeVjjfqlNR8ik+q6dhMOQRuqVOUHc2HM0bgjqWzSM83FX0G 7jEcY+dB4A7b
9hmmryr36ouvy6CBIRxnx1RXfeRs3tFA0+p4pDKW67Hx4xiJYlhg26qVDYzi JGmZuRxnf7xe
zsSkSuu4gScwQadlSIZBD03gGrO80/WWqdx8y8AplZsNVbnxGSr1nzJwGk9r 9Ue4QgrsaoCs
AdYxhXXKQBY5hbWyPGgDBBLLYq1ZS/xJup++T/kOfW2pPwJblMcpJnbAzLvy UVu6Q7bnr6Xn
iLfDL60bf2m1KNjxwNrX545hebbE8mEFOEcHVFHJyaoVJIY5tEZRFLivMT0n rJu0CvP5ZKVl
mi8xFDCvNpedqhPHgKtSZ9CbSi23lQUlA+dwnmu2E6CQOS5GzOSGwAc/UmH8 FvBsFM9QtKUl
Bp5TMy5quanCvMcJ1+Sw/dGvsEOtpAA9EcrgZezV/CtNWH+XGpEWDtv24pAN /IzhZVyO4hJ9
bdx5MJ/U40k+GfgOrgTpXtIzV5Zl17YwdJPLzqSwgkC7H60lkQphtuG7+F4U r9K86rAaeA2v
cz7JKiDblp+yVfH/voE38Zba1xc3qO2rLEHB/raAtw38UK0sLdlgVDdEfkRP +SXI43jHwLsq
eG1quXPMYnZWum14Hz+J4gNatUZXDfy00omiK4ueqzr/uYFfqANHbKZqY9za yP4qVMr2Xysz
PxQ4tJpzqxt3lxou7fZx33N5EqqP2CcGfoPfEqSlK60hMqvh8re03xv4VG1p bcGi6mec3uTI
WqHimCO+fAOWOjtuW2kO9qhJzYiliyzrz6sO6e2WFWYmT1jcYaD+2vjEUyyv Ub4leRe8r9t9
DS1/5kMTYryu9z9uYmXACCrwfhPvXFJ043cQ8Tsd+Aw3l3GbQKbyMNj1Jdo3 blG/67i7jO1N
6OwqYxdvn6G7jD1EU8ZDzfgSe8vYJ3AdhxZHv5MjANvRig5s5BmtAzt5qNqF FGOkEN0bjBoi
asV+PMoybjc8Cw3wqYnPRzTKT0OU4z64oyujJMiMQGcZJ5ow3sniMnjk8DFP KpRPBt+ofhmy
BvY9/nCdBNRNKD2EncT9/KWwB2N4oAr6uIY+hGnM+NBTGvqsht7pC87/Wmce rnJGaGcs3fBf
9Gsd76UvMDdxDfnMFyhMKJ6CRK/BHuz8K852BSwrsgxVZNkbaY/UCdMe8ZXp Dtp016rQ+Rd4
ZVyoUWS3f92LFvRiM/bR0gPowiE8hD6kecIbp3GzZO2RuyL0YAA6JNTCXfF5 vEBKm/EkXsRF
9trFdkqxZvZx0FcswvJva+L/DIkXbxTx5ut4qT2igrAC4zSxP0bUx8h4kJiP E+0Jfn2cjEdg
8sBXwMkqxkXNeFozHtOMD2vGj2jGVzXj/4SMF24U4zJe4cZRoezXL+MNZf0P mhqRf4I0Jkhg
kuRPEf5TBH6a5J8m+Sn+sriAXBX5BU3+rCZvavKDmny/Jv8jTf5/IfnLayVP zkPddYwX5SDb
HwtfAdWELd9bfFP3n1GXUInu5YXo8enNkNIsyVgU4gyp5Jn+Io7CprdnKYHL Jw+XmPdFMS5r
MZ7XYhS0GBO+BM3sI1jylBi/1GL8OxTj/I1KwnX86ivk4AJJLBD+M6T/HMG/ QA9fZA4uMgcv
MQ0v8zB7qYr6eU3d1tRPa+rHdA76dA4+qlAX60PqV28Q9fYIyX9cs85V2gdF v2u8IOwhK+AK
WV0ln1eoxatk8xp5vE4t3qAWb1KLtxiOt/Esz2tXmO5FTa5qTS5qTea1Jqe0 JsNakz+svnl8
3mDzaMIf/eufoGqr88oc1L7X8n9QSwcI3KBeppAHAABmEwAAUEsDBBQACAAI ADeQTTMAAAAA
AAAAAAAAAABeAAAAbGlicmFyeTIudGVzdHMyL2Jpbi9saWJyYXJ5L3Rlc3Rz L1Rlc3RDb250
ZW50UHJveHlSZXNvbHV0aW9uJFJlcXVlc3RSZWNvcmRpbmdSZXNvdXJjZVNl dC5jbGFzc61S
W2/TMBg9bsuytVk7OsZtg20wIO2k5YHHAmJ0TKoUMdSVIfrmJqZ4SpzhpIj+ K5BAFSDxA/hR
iM9JxFVcHniI/X3xOcfHx/70+f1HADtoWSgx7IVypLmeuqlI0sQd0NiNVSpU +lDHL6d9kcTh
JJWx2uqL5xNa7Qs/1oFUY7M00b44FKmFCsPNWI9d4YfyJBGuiJ66BihcXcBc GZ2E7nekHvUM
izqXFcGjfi9hWPKO+Qvu0pah68kk7TDM3ZJKpncYyk7riKHSjQNRRRk1Gxbm LSwyLH8j7WrN
p4ZZhY3aAkjSxinMMTQ8qcSDSTQSesBHoWBoerHPwyOupemLn5X0mSQj+97/ SIbsV8civX8w
OhZ+ytB1vJ9j8uMoilVunjLoDFu/QPIkC5FODedx0cIFhvqPWdlYxRrFxIOA YcXJkwy5GrsF
szU0uV22sYKzhJtoybD5V0MMdhjz4EDtiYgrkmZDOtVhdsR9aSJb/304O8YE KfSUErob8iQR
iYUbDM6/xsuw+oeAsUE3XKYHTbbMNVNVoo8eBvULVN2jVUbzUnuGavsD7Ccz 1N+i8TpDnqax
nvE7qOA2GjQ3qbNzDpZxJtOmwAq9AaENvtl+g8b2O5wr4XF7e22GS6++KlYz D3dRw26mtpEz
CjVTrWe+TbWJK4Qu4WrG3sK1jG9Ocx0O5r8AUEsHCFE0mVEDAgAArwMAAFBL AwQUAAgACAA3
kE0zAAAAAAAAAAAAAAAATgAAAGxpYnJhcnkyLnRlc3RzMi9iaW4vbGlicmFy eS90ZXN0cy9U
ZXN0Q29udGVudFByb3h5UmVzb2x1dGlvbiRTYW1wbGVNb2RlbC5jbGFzc51V W3PbRBT+1rlI
sbdJqtISeovdJMV2miipQ1rqckncBAKuU2rjlHKV5a2jVJYykgLklT/AO/+B BxiYjnlg+txX
/gPvvDMdzkqyUZLplMEa7fl09pyzZ8+3e/zs+W+/A1iEqyDFsGJbLc/wDvVA +IGvN2isuE4g
nOCe5357eF/4rn0QWK4zWze6+7a467aFrWCYYXLP+NrQbcPp6NutPWEGDMOe 65I4Xe0HrUay
zDBKwDF3GU75+8K0DHs9/h5pue7jZYbxgdM6KcrxxPVYlhiUbzwrEB6ZTg5M d0JVeTBJ5qO3
LccK3mYYyhealFKFEk5jCK9wTOL0GM5hSsGrDOeO5bhpmIHrHXK8hvMMY2Kr Vm+s1SobDFPH
txObljMU7CLHJVymbZmeMAIRWzCcyRdOVGEMDFmOEYxKdIVDidAsh4pRGe0q x+vIM6SjaLIS
tN1EqLA20qfIMYa0RNc4MhFa5OBIyzhLHMugYvAoTlQmBi0RKS6d9FvhOIVx iVY5JjCuYiSD
N1FWcIth4tguOG7jLSq4L4Ka0RUMZ/PVf09CPfAsp1MuNGWAdzjexRpDpiOC iG7hM8xREq7X
0YVpW/u+0EX3kW663a7r6HTQbH2javkB1baCDQV3GHIvNebYxHtEuNFuH0sn OpjlwkOZzhbH
B/iQTgilvuYQR1fyJxIRpusJfaPv11ShSNcax7bciSp3QhT4UvkRx32pTJMy qqavQlXxMe24
sSuy0vBWdjmDHXyi4AGxkWSR46Gso0rJNKzAFio+O+J3XcUXRxQlFV/RYtFK 2W1HZNCSHJl0
d46SKidqxFzVckTtoNsSXsNo2USVVnVNw24aniW/Y+VwsGsRLavV/9MJ6Oql 6+6BZ4pNSwab
frHboqSFirDlOMKr2IbvC19BlyH/XxemciSWRpYO7BC1MpVeulOQPyWWaizp joQyE0seSzrv
oZwIJaOHmgONGn08QYoQ2HLxCc4Uf8bZHi4w/IrpBM4l8EyE5yQuJPB8Ai9E WJe4lMBvFH/B
tHajh5spSNgDdS4CuR7WU9iRKnpneng/nM9p1b4pWdwNTQsD04Fq/qRqIam6 F6pKA9WMVu+H
LWiNHpohnNc+7cMF7fM+LGlf9mCk4gDtZAo/USlTEDS2MEXjDIZxngp7ARfp yVOjXMFlagnT
qBJ5D5BDG7NwMYfvcBXfk8UPKOBHFPEU8/gD1/An/U/9hSX8Tc1MwQrTsMou 4QZbwk08CukM
iUIHu+HaVjju4THJdEirDQfqP1BLBwgO5mQCtAMAAPQGAABQSwMEFAAIAAgA N5BNMwAAAAAA
AAAAAAAAAEIAAABsaWJyYXJ5Mi50ZXN0czIvYmluL2xpYnJhcnkvdGVzdHMv VGVzdENvbnRl
bnRQcm94eVJlc29sdXRpb24uY2xhc3PVlwtwVNUZx/9n87i7yeVhIECggOEh GyCsUqRKlHdi
Q5dAkwCSlurN5iQsbHbD3V1IhLZKqFoVFLXKq/jAgtqK5SGwUBHbQrWPaTvT OnVabTvt1L5H
Ou20nT7s/9y9e9g8SNLp6Fgy5N577nfO/b7f//u+c/LNf58+C2AGXjXgEfBH wo22ZXcEEjKe
iAfq+XtRLJqQ0cRyO9beUSvjsUgyEY5FDeQKjFqXjIYTgWbbapWbYvb6tL0V lwL5N4T5aq5A
jr9spUDuoliTLEAOfCbykC8wJBiOyppka6O0663GCGcUBWMhK7LSssPq2R3M TawNxwWmBgfq
V4WAt4lvlJ3AWHVZ0NQaTpu5U5ZF68LRloj04QoMM1AkMCKzfDB9rbJCiZjd YWI4igV8srqm
rn5BzaJKhhzs3bSikIuNNDEKJQKDQra0EtK1EBjmL+s+rcLAGIHJMbslIEOR cFtcBmRrM+9j
tgxU0007akUqlzWuk6GEF2MVCYZSgPEoNXClwPjuM0Ox1tZYNEAIkcCK2moT EzBRYGjak5tk
VNrhEMcFVvuD66yNViBiRVsCdQmbKCoGMlIW7OeTRDAak01chSkCpqyTaejO Ryf5+51dtrIQ
ZZhmYCqzoxstE9NRzqSKy8SCKIFO6LlcmpxLjIv5EMA1Bq7uKe5yK7TeapFK 3Jm9COq+ZjQB
zDJxLWYLDG6RCff1LY4Dk/w9cbge1MpmactoSK1QhutMXI85lI8aMCHnXdZx Uk6GEknbilRR
saQtKxrKskRw4zJwA7O6z9gLUYG5JuZhPktBVscdEZw6bCiAwEITi7BYoMCK x6WdqLeTqsz8
DU6V2rEYnbyiR7JypTa1DJ8FxlymqJZa0Q4V8hITH0FQoJDQFtpWNLRWsoQn 90IsOwUqg+F4
gshqsNzAMoHSfo1NfBS1DMxqahIo9veEVdZgoF7gqr5WWmjFwyFnuQLUYaWJ VbiZ0TaqYUex
Yn91Lzq4FCppUmVF4nJxTMZrYgmnD22UBj4msHigLWtSrdyQ5NtaJWMTS029 StohVUEFaIDP
wCcEru5ddNu1DYRb2yKBzMxqPhRgDW5V3XaKWqTRREiJYlKUjFW8EBItBpoF pvSzemaKibUZ
ad1g4l6sE8hTQc70IqKKNNnIPFGZEDURQxuHmIZ1Cmb5f5H+ZQ0++m2biIMz B9lpSLKJvYLp
NDStiaOhmzkb0W5gE4u16xsTHaoUjHC8srUtwUrw2JxfNeAdpS95mAfCFrhc L+iBj/Y+4uGn
na5Y2m9TFBit/FvopmPXNOOeqV664+6g4t5pYhs+Q+4tbr8svXy7chNa4bvL xN2qorwhgrDC
UWIaoT6gKHb/SA3uNXGfqpWcFqXsBKcpRCKZrOilKry4ny2mMRZbr/bKnSYe xEPsQ+kdaiGH
qWrWRqlGnBb6OROPqKTzqn7CwXgBdmGPgd1sw70Hle4R6nYF70zsxb50D89y UCDY3ybS0HfH
qrelrOZGbXH/p6P78biBx6jJpfTLvDXxBJ5k7FHZTlTD/b00FDX/KRNfcFJ1 rRWvoalq14dM
PI1nWLfpdl25IUmwrDd/dbXq2IbC6eSSz2nQaYyDu0Jkkkb5n0YizM8HezpI k1FOP8vQ6ZZQ
x0wcVxL4ZMZAZcAJEydxisKE3WWYL5nYui6vsuu0iTP4CinEw7dJZz9S5wL1 VRZcm7TdlXtJ
HKX3SybOKRWHp1XsMiXuHvS6DmaFwCyrc+qvKqwOleMvX+wzlPOkXR3lgWlR REGPG7ggMGvA
7aLOYvOVS3neZTMs7PI0po9WglKqnQP1z+QdD8n8bfApwKvgNW/qSXiP8MaD Av7OdwZHotCd
QANeB/FK/fXkac4z/3efaGVNFHriED1xF3Idb6qOYmgKI1gtmZul089hdNEH 1M8pjEthkgfT
pqfg5+UoZqTwQYaRwodyqFdFCjcKnMKCS18fzS8ATfBx6ylCMyahhU6uRSXC jkdXpr/qeuTD
jXxTRZ+KMAs38c7D+w9rL/e5Xi4ZkJcpMOPo6lIPVqUfzqEu5wRW9OFphD60 8utRehrDNWhD
NTZkebpEe7pAe3qd9nR1xlMx2lEU2HEGDatP4uPBM1izWnkn6N5J3LJ02glY rm+ZGGr4zKNN
eXqUxuGi9bSek5sxmJNXkscwS3Kd+MpL8hwZyrvKsEo/p9CqIj+ODSkku0U7 24kiAS+S/Btm
IyainWfuDh5eN2MxtrDaP8nd+NNoxO2wcQd/tmI7Oh0Sc9ORuSS8uBO3cZZw 1tnCeR6u1OjQ
yeFaS/AprpPLFec7nPJoebvmVOhy6nwXOTnSK1jKvDw7ES4DZyZDA8Py4i4G dTfh3MOQ7iWc
7QxoB0O5n3B2Mo0fZMgPEc3DWWA6NZjNGsx6DWaVBjNPg7lWg7lDg4ELpv09 SKAUtop0oqg3
d3p6o/Eo49nFSHaTxl7GsY809jOKx+j/46TxJCU/wKJ+Cpu4q12i0a5ptGka t2oaQU1jlqYx
VdP4rKZhujS2vbdpwoq6x9MfmacZ2zOM6lmS+RJjeo5knmdEX2YsR0jmGPPk OMvsBWbGiSwy
2zSZLZpMRJO5WZOZr8nM1mS2azKP8Fn5cuHdI+MY7FAG+Y7BAzQwSgxlkN89 kR4mQiO9bs5s
b3nOKTw6x3cIg0t8KXyeSbbNK9TtAYE97/yx2Jt3Cgd7r8Fa/rkOtjAvTpPL GbJ9kVTOku05
MnmZNL5Ktl/ntnKejfoC+b1Cvq+yKr/Favw2c/M7OMjrMXyXq3yPVt932Den aWn2ZzX7w5r9
Hs1+q2bf7rKX3Eqf5Vg+v7oKX6TiBr83k6of5mp7uc7zVN7HFY9ojc67Gl18 X2qUwlG1V7zA
GQNSKsXTivvgFsVuFDtP+e6TkXsIuTld5FyJYv7+ARH9kIheo5w/IujXKeeP ifknBPwG5fwp
8f6MYH9OSX5BOX9JOX9FvG+xrfyaqN+in7/FS/gdhf093sYfsiS9qCX9jZb0 dS3peS3pc1rS
A1rS+7SkW7Wka1xJn8iS9MX/n7I7+7+U3duM+yLj/hN1+jPp/YU6/ZXs/kZq f6dO/yCzf5LW
v8j5HXRys9opPHQiB/tFLg7yekzkM1EMnBfe97jsXtYaHXY1evN9qVHuADUa eI052vFE5eV2
OUoMwkQxBNPFUFwvirBYDEONGI4GMQJSjERMjMJmnlI7xRhqN5bOjaN246nd OGpXSu0m4A0x
MUu7N7V2r2ntLmjtjmrt9mjtHtDadWjtYlq7JT2087Clq1i+xrYOnqs9rFqB b9CmgddX4P0P
UEsHCCqxtlidCQAAvRgAAFBLAwQUAAgACAA3kE0zAAAAAAAAAAAAAAAAMgAA AGxpYnJhcnky
LnRlc3RzMi9iaW4vbGlicmFyeS90ZXN0cy9Xcml0ZXJUZXN0LmNsYXNzdZRb c9JAGIbftUAg
DaK0th6qVtsqUG2q1iOKB1q0mnIhFEe90BS3NEoTZ7NY+4u89Xyc0Utn/FGO 3wYKtCA3u/n2
zbPvdwh//n7/CWAGSxp2MeyvOyvCFpum5L70zQfCkVyUaa8hRKfPG64jzVVh r/MNT7ww1Une
9jmDtuq8lg1Buz3WFqP5dpYOq3Xb9ydnGfZaz+1Xtlm33ZqZV0E6jZU2XbnG pVNlCK3bjssw
knrcJSxJ4bi1bLpC53nvGY+BYbcBDdEo9nQ8zwSeZzqedSQxrGGIIbHjVgP7 MKJMe6JIuTBM
pfrc1+NVw36GI51o0Qvi83y14DXcZwtCeELHQYxpOMQw1BGW14S3Ya/UuYHD OMKg17hc4r5v
1+ju4VS693Idoxg3cAzHGSJXHSp7jmFfP5cVHZM4oWGKYbTZH8mpFU7QnPsN 1+XCwEmkGAZE
w1XX9eSVrmjIMIzviBc92czrdZW/lI5HLycsx+XFxvoKVVjlw5C0vKpdr9jC Uc+tYMgWNZ8q
0KeLOgYwrjp4xkAYEdLKNYe0B63/jR6NSMgNupTsxVEtfS4LW8M3lNo5fWpq VLnbkiSVu2dC
wwRZfkklSgX6dsa+hty2TrZPYriBWxpu0rBu0azmWrCr0hObBvKYp+nmi8VS +WYxv0CTavWX
ZgcJVjBwG5cZjKrgtuRNazoVatHABVxkiEpui3lvg9qgl7yGqPKCo4qd6JRq RhmloaFE6KPe
hZAqMe2i6mOhaAzqF6FVxyA9G/T0iLSM1sn3iD/8jbEHycRX7H34AfE3SPzA 6KMnn3HgC47+
+oqJd6SMIo5hpIk+TW/ptAIpTFDkFO2MJgun6S8FtKcBbt1zm5RKO5iZ/gIz wz5h9l1gUmF2
B4bPkd2jhJwLUCNNOc5SHMFuDucJFlLlaEFzLWgkM72N17SVI971LlakzYoE hWEUvYTLLZZJ
qzIfznzE7Ns2KhIEF7uyC7cwIVxBllRXgz3DtQCjIkoVz7zH9W+gtn/GnZ3O yiRd7kLG28i7
fZBzLWQkw/qwnpChp12srSwZ7gVK6x9QSwcIvgJEQRcDAADkBQAAUEsDBBQA CAAIADeQTTMA
AAAAAAAAAAAAAAAgAAAAbGlicmFyeTIudGVzdHMyL2J1aWxkLnByb3BlcnRp ZXN1jsEKwjAQ
RO8L+w+B9qibH6iCB4Ue6smjF02WGkmbsElA/97UW0HnNvNgZhrVmRDf4sZH 3iM0qtMrv0Rt
b1sEhLubyc3GF8tJ7RRtrghqreF4OWz780n/YNGXsTa8Jv8fRgmRJTtOCM+b JDJhis4zBbEs
yyhCCkUME1WXxGiEUHIs+RvUi/oDUEsHCD9vucmIAAAA0wAAAFBLAwQUAAgA CAA3kE0zAAAA
AAAAAAAAAAAAIQAAAGxpYnJhcnkyLnRlc3RzMi9wbHVnaW4ucHJvcGVydGll c61RQWrDMBC8
B/KHIYlvwYEeS1II2IVAYgdHH1CsjS3qSEJ24vr3lawW2lsP1mk1szM7Wi2x LbUZrKzq7m0+
W2K7+XP30OogVvOZr3YTHO/DNEotCIKe1GhD9tWjQKKR5QxlzVVF6GqCsZ7u JLW4UtcTKQfL
Fo1UBK6EbwraRRRFSLME+TtYsc8uxz1LE5yL/JwW7JBe4BoWozAOihP/cB5Q 1P+MGaD4ndbg
xpD31mMGX+rbWN5kE8aGiMHHE+NzXP+jDbl/m8bTrW7KT/jPvqZMbppHJVXm FowdjvJquR1e
wKjtWkda/ZSC7Dfd931Mn/xuGoq1rbz8C1BLBwi5/ts7+QAAAKoCAABQSwME FAAIAAgAN5BN
MwAAAAAAAAAAAAAAABoAAABsaWJyYXJ5Mi50ZXN0czIvcGx1Z2luLnhtbLOx r8jNUShLLSrO
zM+zVTLUM1BSSM1Lzk/JzEu3VQoNcdO1ULK34+WysU9NzsksKE5FqDUGqgVJ ASUVdXV5uRRs
kvMLKosy0zNK7EA8fWQuUEDFM0WFl0tXF6KlIKc0PTMPZLI+nMnLBQBQSwcI 3mXzb2oAAACP
AAAAUEsDBBQACAAIADeQTTMAAAAAAAAAAAAAAAAvAAAAbGlicmFyeTIudGVz dHMyL3NyYy9s
aWJyYXJ5L3Rlc3RzL0Jvb2tUZXN0LmphdmHNlNtq20AQhu8FeocpDcQ2SHoA u6apm0Cg5CJO
r0ovVquxvLG8K3ZHdkzIu3cPFlLsOKS0ob2SNJrD//0abTYaxRGMYMJVvdOi XNI0PGfPAz54
dl2cuZssjmrGV6xEqESumd6lhIbMOI7iSKxrpQnuGykoXWi2xq3Sq/TOJsyY weMcwgdqhE+4
baRE3U9p+39RajU+in4L1yvGSemdr8taoA9JAjmWQiaNQZ0UikOSBLgLcHKB WzmwUBpoibBW
BVag8nvkBOcTXE8n+dRNnWT5dJLZ5/O0a4yyOG77uUSrnhEWrUlNXgkOvGLG gOvlGMHi2nID
rSNx9OiEAwTpYDvdWUELYW3RrUARGnTC033qaU54RSwcygUvGKDWiqwDWIRx rYhPIJuqGh/q
/NvDg1+GGNnLRokC1kzIwZy0kOWPn8B0aYYu89FXQbczqW7koLU49Y4Pxy7p 6VDzTElDuuFk
gIHE7YGvsBW09BtRig1KkHaB38vrgNuq3mP6iX1I09SoBz76MtEcLQv9Byvj v5hBugo6Bv0V
6hM5bWm3Wvu7l+Fu0b6T/5ZPbGwoDCs7uj6R9ipfJ/kDWQbx5IH60Rr+vQ5q 3v6JXIX1UKut
gcsHjjUJJftL13E+P2RTvL6Z313czC5TrtHOcbYMhidW872YCZn+qrbyt7C7 ojeSuzOvB/YE
Wdb+rHH0C1BLBwiHIiXTCQIAADoHAABQSwMEFAAIAAgAN5BNMwAAAAAAAAAA AAAAADcAAABs
aWJyYXJ5Mi50ZXN0czIvc3JjL2xpYnJhcnkvdGVzdHMvTGlicmFyeTJBbGxU ZXN0cy5qYXZh
vZJLa4NAFIX3gv/hNARqAjrQbaw0y0JXTXali1FvzDQ6yjyahpD/Xh3zaCNk mZXjmXsP37l3
2HTqe5gizupmp0SxNkn/z/4LThy/5uPuwHyv4dmGF4RSpIqrXWRIGz3zPd8T VVMrgy8rhYlW
ile0rdUmWrYFs5u3CysMDS0M/RgrXMW7lZKUK2En7ocwREqFkKHVpMK8zhCG fYY5Oirozher
WsGsCY8xVUmcJm89+FPM0iRmrfaIqs6pjC62JPOh6UtBLQM3lJ8mYdNSZMhK rjVOrvOy7IA1
WvjWRuMc0Pf2HT/QJ8DNDLiBgmsYOBzgCKQNN+3nuxY5Ki5ksDBKyOLjE1wV etJV7l0XLqON
lJWBm1cwmcy628NdYZfnfQXXgG54x10+Q9J2MOtgdFJcgx71CQBFxirZ994z 1ACw3wBk++r/
xtO2IRU49YJ3AGPXBr73C1BLBwiRdKXWVAEAAK8DAABQSwMEFAAIAAgAN5BN MwAAAAAAAAAA
AAAAADUAAABsaWJyYXJ5Mi50ZXN0czIvc3JjL2xpYnJhcnkvdGVzdHMvTGli cmFyeUV4YW1w
bGUuamF2Ye1cW2/bOhJ+D5D/wLoHqJQ6cmqneWgup2ni7hqb2EHs7hY4OCgU mUmYypIhyW2M
ov99ZyhSoiTqEm+bplgHaC2Jw5lvhsPRDCWqs7W1uUG2yIHjz5cBu7mNjuLz TvYCv/jHYPoH
HnQ2N+a289m+ocRlV4EdLK2IhlG4v7mxucFmcz+IyJ39xbaYb71nLt0vXB2M +vcOnUfM9wqd
FhFzrRPfdamD7eG+pvmfdnh7bs91TYOIBnbkB7q2MxZGqjyJ/p3vf94vXD2L f0sb3tsOyClv
v4htVGz/T8AAZPG6wMhPLmnoLwKHCiGD2dxVkfvBjUUdl81DatHZteX4s5nv xRxOmX3j+WHE
nP1G9H1hlgakk4DSooGreny4HFThpo4fUKt/4tphWM5QUI2u7sAnaskKdi+h u6TXNKCeU0+J
/xdGW0878MA8nu2mYGs6BGKgLTnidRIKHcb0IWKAylW71nlW3D3nWMz26mDG roWHH+CoXsL9
jFkfz8+aWgHJuSofzwdlc6Ujg9uz7W1yRW+Yt70IabA99R2yvR0HumMS2kBP CeJl0ZJc+wGJ
bil5cUBnRwdXR2JyHnSujg46cOkFEbHPSnlTb1rk/PaGejhT6FTGzMWVyxzi oK8TMc3791z6
5sY3ICIxYFIJGVvPfHtKbNflQO3gZjGjXkSuIdQCuOg2BJsRmHghsUPCvDCy wcnh4jWnn/lT
6lqqHA18bHs7twN7hvxD3rHIX3JJVSXD0SS+2MEfoTIgAKchX3w2JTObecY4 Cph389ffnLmJ
lFx/sECHnAQUOBGbSJclIY1I5JNb351yILJByIdO8a/i1QkNHh8Sj34lOZ83 zP24VyL4Eswd
wuyNrTqfB/48YAglAXIdOxgHY3tTMAcOArcLvY9gDPB+lQOlALFuaJTz1Vhm sDRMbOwjkxCY
THzRDjc5aJovopgZIYZkYAkKS7KwTvvvjz+cTT71P076w/FgNGwT2YsboPzO YpgmnzA6Q8g7
PegM2BYBJSwiDFzri81c+wpUny5wMIkLTgm/1eqL2KyoreqWvXFadDj+BG6m qJEnGAzHk+Ph
SV+OZTqe6ZHIFYjP041QeIO4yr0AVIY/0Y6ADCUQWaOLCdjy08nlaDz+dNkf jz5cnvQ/nYyG
k+PB8Lw/nLQJ5A8utT3r/fHZuF/wqwGfdwHOVEo8P5mwYZvQGRjT9jLetgjR 3DMahiLIKNZk
18TAKWO51LuJbsnhIdkx46ZvUm8wqzz8ltpC0Sj150OiamqqY+XwWSibDBgG cQmOjBa6/JtO
x3nTOV9aIkK2THUUxEiRwPdxAmZTpnTgBFPRbKgcsKcFU39oz6jRwrNWplmO D5AMTg1sb5MK
MnC+E9/DSRqC19nTKe+idxwJHv73nNvV4Md9UwXi8yoVYgpQQkeKxgAV3vEm KlWIKauVCOcU
7tfuu/9BlwyLVCVxuQgUKI69pZHppgeJmTe5gv9e1SND2qyJsR8Km7DIBTwT CFdI9Ia8qrQz
dkMz429LM2ZoZ2hLjIx0NfC7K8LvauF36+B3BfxuQ/jdGvi9FeH3tPB7dfB7 An6WMD2KCyTy
lf808IyYPoNO9E2dVfAcebSlo2s+5jl9BAPQSByVDEksX/IXtHoJhUCN3rVa cO7qo3NBQm9l
Cb2GEnZXlrCrl1Ah6/XKskSI0wpMuGvuJVWBuABvb2V440wgrkS5p0FZGpAN bR6wZwofz/QD
Txfn25obVXrU2dIEmovAv1+uEGwMI1dYmwk300Ij8kO0V1Jyov54AQm1Furq xjHhqnTY6tTp
J0BlVFRXDQoKig4/UsdXP05JSFono9NRc241oXK3pFuv2d2rV829p+Guia+d TpUWqUnjATpd
evaMOdxMGvOmzHTSK5lJaGU1S5VFZv4XasC9ZqdkynXGSyjcZpa/iCwoJ7zI 9YzW9laLvMwk
wugyJlxrbW+39FpZoQ2SUm5tWR6p5Fph202FlYvyFq5bTplvrUfxugmM181x vF4VyF4TIHvN
geytCqTbBEi3OZDuqkB6TYD0mgPprQpktwmQ3eZAdnVAvssDx46gFjOUxyCE yiMzmdBK+Z60
xvjHke18ngQ2ZAsa7tUrAQI9DYLUFs+fP8flm5I7ubqu5tGv6mn10lqWzQ9f YouZpsdZbD9i
tQ3/VlxxE4BqV92qbbTi6lu9ZSoX4rjatYtx+NdkQU7rS+oiVPm4NVt3aoOn L6je6XA531Af
WxEmczOZQB27LtyZ5zRI7uLK00crBKu6NPI9IwsTpF7bbghiCbNu7XAI7gmO T8xU9jfVBiJD
pOL3EHp5cReVSheonv95RDBUia5qh++PrXJs6J+u8bOHaazjsdU463lQzvNQ MycG1i9EPtCJ
cgWCYttC7fCL3atW74d40k9R+4E+ttKskso/hWF+m9E3ngdHyhWLnrIAfpPY a9baRC4xi0iM
+MQl00iOSlbg4czYMc3conZ8VZGbrBwgczwx5dsSSllU6KWhqSmdMkuhlYJK 1lJ1adXREeE2
LxSxeuKjlNiiaCqbebisuVpPfMT0Hu6ckDQ0YnGksND7QM0KZZIomeU3dGnE TGWuXY18CLdu
JbfdB3IrWW7QF9dbjevdJ1pc/4qy8fHqwscq/J5uZdddV3bryu73quzyjzeK 9d3vkPAbhszR
SnJgmQKZmZv9U0gVf25FsLJhnnDJIIyQGOAOBCV59Ungh2HytikqyAQdanBX ok5OoaJKgeSo
U+pOp1S1Wgm/bKfvNaPf6TxCGVAhopLxg1N1IaBpyi1rhFXS9XzflRL2hEld yr4upNaF1LqQ
WhdS60IK/x5QQPXWBdSTKKDkvh4yjd+myBYoGJokham8f+HPl4V6p/qt8d+t UNOaY12lrR/L
/F88lnmU6kMqqIiQiq2rj0bVh/qCpGo+HKEwSioE+g+wm2HE+0FNbWTjtyfe zq4ZKNw6S96C
5U1j8GAHtLBdqQ1/1TxsmaZmWDqdphUOoHpUqBzETpuUvFqpGrT3iy26LuTW hdy6kFsXco9f
yIkfCrlafJSwwX2XPBGiBAJpUNgtnRZKaZLOUyiQyDOnHUiCyAFRdlvuk5cv makBjJuWwVd5
mORCwHjJPnK5/5oXapnagEzU3dtQUUQ80Z7irm073W1NfM9d4s5PKDum1PMj GuKWUXoPYR7L
jiLfEW43/cpC2oY+L0Iy5e91AJOMgA+XZyWlCn6zI5Yf17B4zred/rXzt+oL qCaUPkDFMbCQ
E5rkT5KWDXgJfYlTYA56FfruIqIXoBnE0jckW2EoUlI5SrGey0BB2VM6g2KY F19KqcyNDybN
GSerp74aCvSx0ABNiyWOfj7h/nwwM04q6JVVhoP+t+2yKfomeogj0ka5Qd+N eycBqxx+8ZlD
STq60vMGTVpf83Qh/UAE+FxyeEgyH46wkq0wX4QVDO0DlXi3c8oHVRpTmMss glqZPFPZWqN/
mdm+OV0I4YOT9lAYt0mrlRf9XT3VPwERce1y4UVsRiuDWw6OzmUuAv/KpTO5 iKD6TtqxSWRU
MKpBkv+H/5p+Y+ICJYTKOIbkK4NoxDwIQvg9B0ChMqr+iITiDuji6qkfD42V 7RCLERE0kcg9
npMnCy25D20kX54IIFA6GOzUj0/knUDrsG0Sf55CCFY/T5EfOUOQ7OubYWCz /nse7+pPk8js
DMZQmu1wcsvcaUC93BzWleeJi+WVVLRM6vC2NDDc4SEjl3Ckq2xufE8r6+Qb Jf8FUEsHCC4X
BQ7rCgAALUoAAFBLAwQUAAgACAA3kE0zAAAAAAAAAAAAAAAANgAAAGxpYnJh cnkyLnRlc3Rz
Mi9zcmMvbGlicmFyeS90ZXN0cy9MaWJyYXJ5RXhhbXBsZTIuamF2YcVZW2/b xhJ+N+D/MFUK
hHQkKtFjZKd1ZQUVakuGJJ8GKApjRa6ldXkRSMqxEOS/n5nlklySq0tdnx4D FsnduXwzOzM7
XHbPzk5P4AzO3Wi9jcVylX7KnrvVATn448j7kW66pydr5v7Flhx8sYhZvHVS nqRJ//Tk9EQE
6yhO4ZE9MUdEzmfh835jdDQZPrt8nYoobDBtUuE7g8j3uUvzSd8w/StLVjds bZoapTxmaRSb
5q5Fkur6cvS/RNFf/cbodXbdOfGZuahn9/xt5qPm/O+xQJDNcYVRPkx5Em1i lyslo2Dt68ij
eOlw1xfrhDs8eHDcKAiiMJNwJdgyjJJUuP2j6O+mo32iuRvF3BkOfJYkuwUq qsniEZftIFnD
NTvopvyBxzx0D1PSb2NBzLSjEL0fMr8Ee4AhVmvh5ItySEODYcb/jhqk8nXW Q4ufsdfWXrDw
EEzJIT13h3eHNTwHwvlyc32sF4hcmvLlZrQrnLt5/fmh04EFX4qws0l43PEi FzqdrBZdQsKQ
ngPhFekWHqIY0hWHt+c8+HS++KTy57y7+HTexaG3oMqTU8rmodeU/POSh1Qt uJeXtc3CFy64
FOugMnH4LLX3Tk++IRVkiGEvZpq9jpgHzPclUhYvNwEPU3jAcojo0lWCTgPM vARYAiJMUoZR
joMPkj6IPO47uh4Dfpr7ec1iFpD8RDI25edSSlthPJlng126KJsRAUYNPEXC g4CJ0JqlsQiX
f/wphdtEKe1HD3RhEHOUBAzymIWEp5BGsIp8TwLJJ5R+ZMquWlgXNHR/ASH/ CrWgt+x+xlUo
nqK7E0zfzKvrdRytY0FQCiAPWYRJMCz00B20CNIv/DnFNaA9pQZKA+IseVoL 1kxnvLVsmhyS
kASFzCM1jxsRTq03aSYMwMoFOIrCyUU4V8PPl3fX8/vhl/lwPBtNxm3IuaQD dld/y7Zlxpgc
ke/GaDNi28QcRAoCQ+uJCZ8t0HRvQ4sJPgYlXvebr4qzZrZuW3Vzc/h4do9h pplRJxiNZ/PL
8WCYr2W5nuWd2s8hki1BoqJBjRZRgGYrAkJkaaXImdzO0Zn3g+lkNrufDmeT u+lgeD+YjOeX
o/HNcDxvA27yPmeh8/nyejZsBNZIJl5MqcohjIqMTdrAA/QmCyvhtknI3wFP ElVmNHeKB7Ao
Zxyfh8t0BRcX8N7Opr7lhqNf89tvpTM0i8qAvgDdUltfLFemYT5l4TqoIbyz WhTzH7td92P3
ZuuoGtmy9WVQSwVxFFEGVvuacuWUUDVt6RKKPQvzf3RlkaA2tAplJkqMsEEU UiYmGFrM8ySX
OTqoMYMF/nw4DI9oK9gkHwGbi9TnVmuOmUJEH+GDGVlmg2RDI+S1Sog4CT4J ybFLqgPgey8E
3zOC7x0C31Pge0eB75nBZz0qfJWXI7yf0VdMULyEbMwCtEHJnIS8ZaI73rM1 o5UANFvdGQ3P
tOfSFaVZfiMJaQVflng9c+Z1zwxxchtHz9sXxIpl1Vpau5BmO4RX3hK0otkj h9AAEdqmeOoZ
8rSUqjGcdU0e1O1ToCom6v16w0DF8Jo2fng9I3GzmE+uJvrAPnklnMy4q23I AuFKFQZo/0BY
HtI7cqaW/0H0xC3Mmfdm8tkWu4vAiTapg1temPqh1eqcteBdpZCTe20ca3U6 O6oSQy2lrHa+
gevERlWdf64q3Pj+bsr67GEUvWNg9I7H0TMB+Z7fuCx1V2BpJyXYv6o7u1go rXkoZjP8sxQb
sHnMsDwZpO/vQxR6HselL968eUPdY2t/xaRWHls3/XF/Z18V8+odfia0vK9i e41mn/5e2PAr
QAeb/v0+emHzf9gze98DpNkH3wXo75j3AWMs6S3w7nU7ruttY6Rv+KF8P/vf FLhmw61wUW+v
hmxdq1b18cmqlOiiWyBmerDz40OtuDe4DDQHNgBjD1QEur17QXL9O3oro99f odr/HzeWf38T
+Vd2CXXhfsJrb6/0viyP2TlgEMWNY66y+pYVhg7tLNQIAuPofR8v56C9Jffh 3TthGwDTaROu
K6YvtpCkBJ1XnADmB2ey+lcKG8z1Yzcsh6ksER4dt7HymAyi0N/SGzvWTI+H UcoTetXnz1jy
qGY25U7omOCrSHgbed4m4IkYu1EUUlFwN73eUWfpg0imP9sY6VkeF/zx/k89 FshMrNtIJTGI
RBLa8BOUBY+GKJYkBcbV5SKJ/E3Kb9Ey3Do+QrU2alpKPVoHUPG7NPaKB7jD yp1D23+l89Gl
NedU7TTX8R0nbRZa2izR5nyig1V0MyUVclWNkaD/w3zhUWxShLiqlOYnq37G XST3bvgyYPOv
SfCoga+VaKFoMIPg0VmxZIxtCD3YuriKa8uXIq6uWFvzF5tHJ8wEVDnKo32M ueL2AipH/k7x
KvWkvGApDXVxdEpVyiGTZhxzWaS40cMPulhn8ptd5a3ZAiAXp+TQBONLeauu +rv+qD1ot6qu
TTfYzQV8b3GrwTGFDL4fYR8U5B2QHjsl4zGVUcOoF0n5Q//Hfhy4JQ2Jto4J fBVYjUSIRYgO
4hGFLmj/6b8WDhTi+mOULY1TZcjUqApaaJQRL8mLLrH2iaT4ZBBjoXSp2Olf DepBYAzYNmTf
FZRi/btCfeUsRdI3T+PCVuP3JjuNLXvmagZTKa0yDFbC92Ie1nJYGHK4CLG6 kZqVtlCJ284d
jDs8QBH+eaicnnzHUlP9unR68l9QSwcILK2D4PAHAACKHwAAUEsDBBQACAAI ADeQTTMAAAAA
AAAAAAAAAAA2AAAAbGlicmFyeTIudGVzdHMyL3NyYy9saWJyYXJ5L3Rlc3Rz L0xpYnJhcnlF
eGFtcGxlMy5qYXZhxVnrb9tGEv9uwP/DVCkQ0pHIRP0W2bm6soIKZ0uGJPcC FIWxotbSunwI
JOVYCPK/38xySS7J1aOur2fA4mPn8ZvHzs4u3bOz0xM4g3MvWm9jsVyln7Jn t/pCvvxxuPiR
btzTkzXz/mRLDr6YxyzeOilP0qR3enJ6IoJ1FKfwyJ6YIyLns/B5r/F2OB48 e3ydiihsMG1S
4Tv9yPe5R+NJzzD8K0tWN2xtGhqmPGZpFJvGrkWS6vpy9L9E0Z+9xtvr7Lpz 4DPzUM/u8dvM
R83x/8QCQTbfK4zyYcKTaBN7XCkZBmtfRx7FS4d7vlgn3OHBg+NFQRCFmYQr wZZhlKTC6x1F
fzcZ7hPNvSjmzqDvsyTZLVBRjeePGLaDZA3X7KCb8Ace89A7TEm/jYCYaYch ej9kfgn2AEOs
YuHkQTmkocEw5X9FDVL5Ouuh4GfstdgLFh6CKTmk5+7w7rCG50A4X26uj/UC kUtTvtwMd6Wz
m9efHzodmPOlCDubhMedReRBp5PVoktIGNJzILwi3cJDFEO64vD2nAefzuef 1Pw5d+efzl18
9RZUeXJK2TxcNCX/vOQhVQu+yMvaZu4LDzzKdVAzcfAstf90evINqSBDDHsx 0+h1xBbAfF8i
ZfFyE/AwhQcsh4guXSXoNMCZlwBLQIRJyjDL8eWDpA+iBfcdXY8BP439vGYx C0h+Ihmb8nMp
pa0wGs+yly5dlM2IALMGniKxgICJ0JqmsQiXv/8hhdtEKe1HD7jQjzlKAgZ5 zkLCU0gjWEX+
QgLJB5R+ZMquWloXNHR/ASH/CrWkt+xexlUonqC7E5y+mVfX6zhax4KgFEAe sgyTYFi4QHdQ
EKRf+HOKMaA1pQZKA+IseVpL1kxnvLVsGhyQkASFzCI1jgsRDq03aSYMwMoF OIrCyUU4V4PP
l3fXs/vBl9lgNB2OR23IuaQDdld/y7bljDE5Il+N0WbEtok5iBQEptYTEz6b o+mLDQUTfExK
vO43XxVnzWzdturi5vDR9B7TTDOjTjAcTWeXo/4gj2UZz/JOrecQyZYgUdmg 3hZZ4LpqnABZ
WiVyxrcz9OV9fzKeTu8ng+n4btIf3PfHo9nlcHQzGM3agGu8z1nofL68ng4a eTWU8y6mmcoh
jIoJm7SBB+hMFlaybZOQuwOeJKrKaN4UD2DRlHF8Hi7TFVxcwHs7G/qW241u zW+/lb7QLCrz
+QJ0S209Vp6chfmQhWFQr/DOalHKf3Rd76N7s3VUiWzZehRUpCCOIpqA1bam DJwSqoYtXUKx
ZOH0H15ZJKgNrUKZiRITrB+FNBETzCy2WEguc3LkAPE39FavAjEThSCzmypG BEL4fpFDPMeX
UZoRUucIc/z5cBgd0VagST7CNROpz63WDKcyEX2ED2bfKROIjSyga4UwQypN wLECP9EdgN99
IfyuEX73EPyugt89En7XDD9rpOGrvBwRgYy+YoTiJWwjFqAVSuY45C0T3fG+ rZmtBKDh6m6H
6Zn+XL6iNWtoFAuK4ssKRNdcIdwzQ67cxtHz9gX5Ylm1ztsupNkO4ZW3BK3o Sckh9IIIbVNO
dQ31pJSqMZy5Jg/q9ilQFRP1bUXDQMXwmjZ+eD0jXXcfe6k9s+VqG7JAeFKi AcnfEJZncFUc
zMZX49cBm1Vn8wxpVpQgeuIWzsL3ZobpFpuqwIk2qYNLfZj6odXqnLXgXWUB o3DZ+K7V6eyo
dAy1lLLaeWOjExtVdf6+qnDj+7sp66OHUXSPgdE9HkfXBOR7fuOxFFd6Szsg wrZd3dlFoLSm
qRjN8E9T7DtnMcNyZ5C+v/9S6Hkcl7548+YNNc2t/RWYdjDYseqP+zc0VTGv vrHJhJb3VWyv
scehvxfucxSgg3ud/T564Z7nsGf2bn+k2Qe3QPR3zDbImEt66787bsd1+23M 9A0/NN/P/jcF
rtnHK1y0p1GvbF2rVvbxyaqU6MZWoJCQn55WG/eGgKJ9IV56sJuLQ4PpL68f xpasmCf27njm
6ne0esawvcJi8X9cl/75NegfWWTUhfsJr2366ZhBfpzggEkUNw4Hy+JdFig6 6rRQIwjMo/c9
vJyDdrjQg3fvhG0ATGd0GFec/djRkhJ0XnFumh83ysWjUhdhph9WYjVNZYVZ 0CElKw8XIQr9
LR10YMld8DBKeUInJPwZKyaV3KbcMZ2ufBUJbyPP2wQWIsbmGIVUFNxNrneU afqMlOnP1lV6
lqcsv7//Q88FMhPLPlJJDCKRhDb8C8p6Sa8olyQF5tXlPIn8Tcpv0TJceT5C tbRqWko9WgNR
8bs09ooHuEDLhUdbvqXz0aU151TtNC8DO84nLbS0WeHN84mOo9HNNKmQq2qM BP0b88WCcpMy
xFOVOD+P9jPuYnLvhi8TNv8GB48a+FqFF4oGZxA8OiuWjLCLoQdbF1dxbblH 4+qKtTXfZz06
YSagylF+EMGcK24voPKhxCl2dk/KC5bSUBdHh3ulHDJpynEuixT7BPhBF+uM /21XeWu2AMjg
lBya4Da0WnXV3/VH7UG7VXVtssFmMOB7i1sNjillcH+FbVSQN1B67pSMx1RG DaNeJOUP/R/7
SeWWNCRaHBP4KrAaiRCLEH2+QBS6oP3fTLR0oBTXH6MsNE6VIVOjKmihUWa8 JC+azNqHpeJD
S4yF0qNip39rqSeBMWHbkH2NUYr1rzH1yFmKpGcexsBW8/cmO8QuW+7qDKZS WmXor4S/iHlY
m8PCMIeLFKsbqVlpCzVx27mDcYUHKNI/T5XTk+9Yaqrf5E5P/gtQSwcIttTj iB4IAADAIAAA
UEsDBBQACAAIADeQTTMAAAAAAAAAAAAAAAAyAAAAbGlicmFyeTIudGVzdHMy L3NyYy9saWJy
YXJ5L3Rlc3RzL0xpYnJhcnlUZXN0LmphdmHNlFFvmzAQx9+R+A43rVJJJOAD JItWZa1UaepD
kz1NezDmQtyCjewjtKr63WcMBJY0Vaet2p6A8/nu//v7cDyd+h5MYc5V+ahF tqVF+x3/GnDB
s+v0rHmJfa9k/J5lCLlINNOPEaEhM/M93xNFqTTBXSUFRRvNCqyVvo/WNmHJ DB7nED5QJVzC
bSUl6nFKX/9r+5ydWrhinJRb9724Z/oQhpBgJmRYGdRhqjiEYct3AY1i4FYR bJQG2iIUKsUc
VHKHnOB8jsViniy6+vM4WcxjGzqPhtoo0+PKnzO0DIww7a2qklxw4DkzBrpy DSxYblvBQG+N
7z018gFaALDF1lbWRlh/dC9T7GsMBFGXfRoYXpEMh6LByQYotSJrBab7jr2U TyCrPJ8dqv3b
/VvjDDGyj50SKRRMyGBFWsjs+w9gOjOTJvPJ7YJhhCJdyWDkdeTcn8yavOdD 2UslDemKkwEG
Eutjg6EWtHUzkokdSpB2qt/L9BZ6pL3jdU3HtKYqUQcu+jLXCi0R/R8T5E7P IF21UoKDiRpz
NQqjYdK6t5cRb9GuyX9OKXY2tO+XDZhjLu20vs7zB8oM4slL96N1/lvZqnn7 WTU7rJNa1QYu
HziWJJQcD+DRcXa3cITXN6v1xc3yMuIabZ9uOZicmNT3wiZk+ouq5W+RD5ve CN/chSOwZ4jj
0e/rez8BUEsHCBfsgNkIAgAAZAcAAFBLAwQUAAgACAA3kE0zAAAAAAAAAAAA AAAAMwAAAGxp
YnJhcnkyLnRlc3RzMi9zcmMvbGlicmFyeS90ZXN0cy9MaWJyYXJ5VGVzdHMu amF2Yb2SzW6C
QBSF9yS8w6kxEU1gHkAk7bJJV9Vd08UAV5wqA5mfWmN898KA/4lLVwx37j35 zrnDJhPfwwRx
VtU7JYqVSbp/dl1wxeF7PmwPzPdqnq15QdiIVHG1iwxpo6e+53uirCtl8GOl MNFS8ZK2lVpH
i6Zh+vB2boWhewlDf8YK1/FppSTlWtiR+yUMkVIhZGg1qTCvMoRh5+ENLRV0 q4tlpWBWhFFM
ZRKnSQ8eszSJWVMaobcUnXVJ5veqrwU1ENxQfozCphuRIdtwrfHRyba0Gg15 I6Fxcud7+xYe
6PDx0AAeYOAWBA4F6GG04ab5/FYiR8mFDOZGCVl8fYOrQo/bzr2bwjnXSFkZ uLCC8Xja3h6e
Crs4LSu4BXTh9YucQdL2Kudg0C/T9epBBw8oMlbJbuyZfq7YuuAhm5d+6Urb mlTgqme0Axi7
HPa9f1BLBwgz5idwTQEAAJ8DAABQSwMEFAAIAAgAN5BNMwAAAAAAAAAAAAAA AEMAAABsaWJy
YXJ5Mi50ZXN0czIvc3JjL2xpYnJhcnkvdGVzdHMvVGVzdENvbnRhaW5lclBy b3h5UmVzb2x1
dGlvbi5qYXZh7VjfT9swEH4Gif/B2lMiVeEPqPbQrWWqNMHUsufJJNfOI7E7 22Ggif995x9x
nFKaFB7YGFKlJvF9353vPp8Tb2h+TddASnYlqbzLNCitxifHJ8es2gipyQ96 Q7NaszKbSEnv
PjOlxzsG/fN2pOZMZytJK/gl5HV2ibwfqYIW23j8IMT1w6ef3f+jA2c012LP +Bc3rzgkIdcZ
5CXbKMigWmW5qCrBXfhfF/Pxo4aQCwnZ7OLqB+S6z2zONUhOy4HmEpSoZQ7Z wl8MBqBVGVBz
vHkacgl6CNhmaWYuv+KVTeumvipZTvKSKkVsfQXXlHGQX6S4vTMOSoQJTuBW Ay+8EYqA/D45
PsKf0lQHhgX8rHF8YfwVjK+jAAPBVtCWxxAd+ViMCol0RFBgURV5Tzj8IkG7 STrewvhCkTVo
f5kgkNSSjciVECVQTkpBiws+hYryInVejzpuMloUCUIcO47pWnKi6g3ILCK2 pB0ya3/vQ7o3
aTUXPrQbwQpiVuSkqJi2WfXyTnwU/taoH2faXRsZzM+Xl5Pzj7Msl0A1BOw4 hm487aH4JNmS
ehqo0sxUyMaLyTHp9AyfANXBcvPwnZnXuxHp/qeOG6eTKdCNw8BrB1EsIPWl rCFJkuDbQJBf
J90GEE1iHQi/hZmMyIqWClKMeK5swIkL4b6vEEHsTSlMHzOCue5PpDGNhPg3 V6IhMtkzYask
tVo3E01tG2gKssRWn+wIxVpm4POFC/sM/dcSTPKH1Mp7TcfkQfEf89U8j2o0 sL4zVNCZUcRU
gDoX2jaxG2hqfHpKLi+mF3vwD1zvJtrX7GTTtPYY+co3T4gMkHY/GFZtXpel r7VUJu8NRVNp
2ZT5fxf480UXE2GyuzsIU7Nqo3v0ifJcCNHutHu0+iaxf09itoeGtyybqrja FtFsWSPy6Lb4
NG3NOj3rTU2vQ03mcdh9TVM6RDe5g6ldbS+aUJhN2te8fJpeicD+Xpk889ug ozFJef49TL5s
dGPzYwyMtoDrnQaREEtHF716v6AOO231lajxrd31b54vqLq5mnCsGqbz7X3t tUjO6qaVHAsl
DkcWI/d5cOgrWtQ87Sv+bidDM/bEINxxVKzjAleEyZTT7OnpzjpIXHVYg0lZ tjvDuM/6ANMP
VLF8AZW4gTMpqnaBW90Ogy8hagy4SsLNiMR3/qhiPvWLYtA0/HvWcNvgZTgo PkYZiqkwvweA
pFC4K65AArcrvxcxZRJvm14xAGBO61YuoBGRrhv2o3Z8Zw/GHBBc3EKO0j5r 38vdx36/+bLt
qUlzLI8SE5qtWE7NmblyjcbQdLa0eFVBtXK8Kh1s2SbaQfqADraN2rbHeW9A PhPVJmIPrLul
9zqKmiX1F7MG48EPMJ7LtfAREdbKRnlrjMMpPf7/AVBLBwj69SqUGAQAAD4b AABQSwMEFAAI
AAgAN5BNMwAAAAAAAAAAAAAAAEEAAABsaWJyYXJ5Mi50ZXN0czIvc3JjL2xp YnJhcnkvdGVz
dHMvVGVzdENvbnRlbnRQcm94eVJlc29sdXRpb24uamF2Ye1ZS2/bOBA+O0D/ A+FDIaGG2ia3
DXpwGqcw0CaFk2KPC1oeO2xk0SXpPLbIf98Zknr5JTnO7h7sALElcr7hDOeb 4Uie8fiOT4Al
Yqi4eooMaKNP3xy9ORLTmVSG/eT3PJobkURdpfjTV6HN6YrJvgHFjVSr5jym mJmnwkRjxafw
INVddINrfuYaCmxmzZmUd8ujX9332okLHqMl6+e/O5+X5/9UAt0omyrVJII4 ETMNEUzHUSyn
U5k6t864FnGvuiGb5H8M+usFIZYKot7V8CfEG/Q5sX6KZqY8aSiuQMu5iiEa +IvGAJRKclQf
b16GvAbTBGx3qUeXP/DKhmE2HyYiZnHCtWaWJxJ9T813JR+fSH2CIJkyeMTR kRdBKrHfhG5p
w00Ov+ZoA3yTI0jYb/bmiPk/zwqmpDTsE6uSKIL+5fVN9/JzL4oVcAN+OghP lzXgZxrf7qZD
zyAWPDnbQRVlDRvix8d6PMmuBh/vAj55AdhlH3uwXw1Md/LrVTRwYIWK4spz r0SbICReZfMt
IkykwVxiIQvadNcua3LzEzAulqCDMOKjUeBYsiyJmrrpU1AhQGizIJdz0GJN d19d1cvQurjD
+aJEh4Zyxw3lTtbIuV3NJH08FzypeFk4VBluL3pPPpDsjTAJCt/cgmXcH+xj ZQuqYaQ/69VK
5HED5MlK5EkN0vtd+ObJeZXCEjKTrQvaM9Y0+l8sbQP4NcfKN6A6OhLppFR4 89K4UIyJyS1S
1PI8p4OMKacIRnhYacyfFB5Yfu7bPKlg/AHE0G5/GSCQzZXo0M4lwFOWSD66 Ss9hytNR6FZt
VZaxriLEacc5M1cp0/MZqKik2CqtKLPyz96kZ1vwvV33UozYCI8Kamdc1r5/ 32oFwcLJGdqi
H0bQTRJ/smjr5WbpLURtkzCAqbyHCyWnhOQixZqTzpOkIRwjVsLBQ37TYeW7 C6xocwX9cxxu
pLxQuoVsvkpzEBLSo5pjpri/W4CU1HoAY1CQxtAkLudC4W2WEw0AX8AEY2dQ h1Gbk9xDPSob
32ars/EtjEOG2I4I0ylohXXSA2e9RTQQR+W5KVl/hxSTRoxFzKn90q5Qk5q8 faPULWcVtnlO
rw4bSxYb7SB1QAdbRC3Ko99YWnZEFRuxATbADSwiX7uQ0F1iL3YqAfcXvQzj wUsYryuYUTA7
TFopa+UjCWenRbkuUk3sjqbCUcZ7dJVeY5riCedL9Mub4gJrbcKbbfErqJip WuA6/nsNXwC3
WMQ02CYH2x1W/Q6d7nKnlSu1M3iOgjI3ag5BEFRywCV/9eGx5AIG2s/9RVrD DhvzRENIqaxd
krnFm8fiGydFexCJ5e64SVCCoHj29iGqKAqjIc1T1D40DkMPxS8ocOcS9KU0 vkpmYdjUYqms
Vdog5Hc0G2EqhxRP18120R7ufg+1LTNeRbaFypXj3ahje6+i0XGK6UDIe0Dq 9DRt4pCuPrF6
44/pAiG4Uvu/JmhuaeHA+lqwQ9aX8H19vY2GJcZjdKuNstC96czU8PjMU/9A 432icV0h3apk
vg4RPQcPBNwLAq6voxM3U8+q2LXKurTGJn4RlQ8c2yeO1RW5FUKTZgVtS+qV njoPLeM+0ZDM
preyW5lPAG+8/YHELmevmv9Ist5uElkw3Fu4TYUuv3Yu1HpSiNSwFI39YCFj qViQ/d7LBI6v
fSND2vPGmInolutLeCRis/Tdu9C+7xVR6oYyY12e9n7NERakHXb8Sv1ILzPr cGIcUnVfU9U9
mZYiL/xs8EoJ6oeXUlSLv4Gekhtk84rDmL19y9bLZZu4Kfsr728Ph/ahEux7 Jaj7geP/Orrr
cvdwfB+S9pC0m5LWYKL9qzn7Ggc0fv4DUEsHCJD49alyBQAAfCoAAFBLAwQU AAgACAA3kE0z
AAAAAAAAAAAAAAAAMQAAAGxpYnJhcnkyLnRlc3RzMi9zcmMvbGlicmFyeS90 ZXN0cy9Xcml0
ZXJUZXN0LmphdmHNlFFr2zAQx98N/g43VmgSsP0BkoWVrIXC6EPTsYexB1m+ OGodyZzOSUPp
d59sxdhJmtKxle1J9vl09//9dVYyGoUBjGAiTbkllS956t+T/UATPLvOzuqH JAxKIR9EjlCo
lARtY0bLdhwGYaBWpSGG+0orjhckVrgx9BDfuYSZsHicw/jIlWoSbiutkfop bf2vfr0Skg1t
x0ffv5Pi3c6kRfoQRZBirnRUWaQoMxKiyONdQC0YpBMEC0PAS4SVybAAk96j ZDif4Go6Sae+
7iRJp5PERc7jrjTq7Ljw5xwdgWDMWqOqtFASZCGsBV+tJgUH7QpYaH0Jg6da PICXD67WnRO1
UM4cakWqtkQnP94ln6aFVwTDoWRoRAOUZNj5gFnbsBXyCXRVFONDrX+7vXfN smC3rI3KYCWU
HsyZlM5//ARBuR3WmU/NLuimJ6ZKDzqj48b54bhOez5UPTPaMlWSLQjQuDly FzaKl8105GqN
GrQb5/dy3CN3ynewTc8+qq1KpEETfZlqjo6H/4vhaU7OIl95JYP9YepT1fri bsh2Ty8D3qL7
pv81o1q7UNsu7xj7VNQofZ3mD4RZxJMX7Udn+7fSq3n7QdU7nI9kNhYuHyWW rIzuD1/HuX8l
x3h9M7+7uJldxpLQ9fHGDIYnhvS9qBkFfTEb/Vvg3aY3std3YA/sGZKk+3HD 4BdQSwcIWnrD
bQoCAABWBwAAUEsBAhQAFAAIAAgAN5BNM9UcnNKlAAAAMwEAABoAAAAAAAAA AAAAAAAAAAAA
AGxpYnJhcnkyLnRlc3RzMi8uY2xhc3NwYXRoUEsBAhQAFAAIAAgAN5BNM3sL p57tAAAApAIA
ABgAAAAAAAAAAAAAAAAA7QAAAGxpYnJhcnkyLnRlc3RzMi8ucHJvamVjdFBL AQIUABQACAAI
ADeQTTMbZO0s7AAAAMABAAAkAAAAAAAAAAAAAAAAACACAABsaWJyYXJ5Mi50 ZXN0czIvTUVU
QS1JTkYvTUFOSUZFU1QuTUZQSwECFAAUAAgACAA3kE0z6ylfWBQDAADUBQAA MAAAAAAAAAAA
AAAAAABeAwAAbGlicmFyeTIudGVzdHMyL2Jpbi9saWJyYXJ5L3Rlc3RzL0Jv b2tUZXN0LmNs
YXNzUEsBAhQAFAAIAAgAN5BNM6PflhyoAQAABAMAADgAAAAAAAAAAAAAAAAA 0AYAAGxpYnJh
cnkyLnRlc3RzMi9iaW4vbGlicmFyeS90ZXN0cy9MaWJyYXJ5MkFsbFRlc3Rz LmNsYXNzUEsB
AhQAFAAIAAgAN5BNM/Gq9fGKEwAAuy4AADYAAAAAAAAAAAAAAAAA3ggAAGxp YnJhcnkyLnRl
c3RzMi9iaW4vbGlicmFyeS90ZXN0cy9MaWJyYXJ5RXhhbXBsZS5jbGFzc1BL AQIUABQACAAI
ADeQTTMB18PQfgsAAE4YAAA3AAAAAAAAAAAAAAAAAMwcAABsaWJyYXJ5Mi50 ZXN0czIvYmlu
L2xpYnJhcnkvdGVzdHMvTGlicmFyeUV4YW1wbGUyLmNsYXNzUEsBAhQAFAAI AAgAN5BNM1Al
nmLJCwAAyxgAADcAAAAAAAAAAAAAAAAArygAAGxpYnJhcnkyLnRlc3RzMi9i aW4vbGlicmFy
eS90ZXN0cy9MaWJyYXJ5RXhhbXBsZTMuY2xhc3NQSwECFAAUAAgACAA3kE0z xfJH1RMDAADs
BQAAMwAAAAAAAAAAAAAAAADdNAAAbGlicmFyeTIudGVzdHMyL2Jpbi9saWJy YXJ5L3Rlc3Rz
L0xpYnJhcnlUZXN0LmNsYXNzUEsBAhQAFAAIAAgAN5BNM5EKrmeiAQAA9wIA ADQAAAAAAAAA
AAAAAAAAUTgAAGxpYnJhcnkyLnRlc3RzMi9iaW4vbGlicmFyeS90ZXN0cy9M aWJyYXJ5VGVz
dHMuY2xhc3NQSwECFAAUAAgACAA3kE0zwHTOEgMCAAC3AwAAYAAAAAAAAAAA AAAAAABVOgAA
bGlicmFyeTIudGVzdHMyL2Jpbi9saWJyYXJ5L3Rlc3RzL1Rlc3RDb250YWlu ZXJQcm94eVJl
c29sdXRpb24kUmVxdWVzdFJlY29yZGluZ1Jlc291cmNlU2V0LmNsYXNzUEsB AhQAFAAIAAgA
N5BNM9ygXqaQBwAAZhMAAEQAAAAAAAAAAAAAAAAA5jwAAGxpYnJhcnkyLnRl c3RzMi9iaW4v
bGlicmFyeS90ZXN0cy9UZXN0Q29udGFpbmVyUHJveHlSZXNvbHV0aW9uLmNs YXNzUEsBAhQA
FAAIAAgAN5BNM1E0mVEDAgAArwMAAF4AAAAAAAAAAAAAAAAA6EQAAGxpYnJh cnkyLnRlc3Rz
Mi9iaW4vbGlicmFyeS90ZXN0cy9UZXN0Q29udGVudFByb3h5UmVzb2x1dGlv biRSZXF1ZXN0
UmVjb3JkaW5nUmVzb3VyY2VTZXQuY2xhc3NQSwECFAAUAAgACAA3kE0zDuZk ArQDAAD0BgAA
TgAAAAAAAAAAAAAAAAB3RwAAbGlicmFyeTIudGVzdHMyL2Jpbi9saWJyYXJ5 L3Rlc3RzL1Rl
c3RDb250ZW50UHJveHlSZXNvbHV0aW9uJFNhbXBsZU1vZGVsLmNsYXNzUEsB AhQAFAAIAAgA
N5BNMyqxtlidCQAAvRgAAEIAAAAAAAAAAAAAAAAAp0sAAGxpYnJhcnkyLnRl c3RzMi9iaW4v
bGlicmFyeS90ZXN0cy9UZXN0Q29udGVudFByb3h5UmVzb2x1dGlvbi5jbGFz c1BLAQIUABQA
CAAIADeQTTO+AkRBFwMAAOQFAAAyAAAAAAAAAAAAAAAAALRVAABsaWJyYXJ5 Mi50ZXN0czIv
YmluL2xpYnJhcnkvdGVzdHMvV3JpdGVyVGVzdC5jbGFzc1BLAQIUABQACAAI ADeQTTM/b7nJ
iAAAANMAAAAgAAAAAAAAAAAAAAAAACtZAABsaWJyYXJ5Mi50ZXN0czIvYnVp bGQucHJvcGVy
dGllc1BLAQIUABQACAAIADeQTTO5/ts7+QAAAKoCAAAhAAAAAAAAAAAAAAAA AAFaAABsaWJy
YXJ5Mi50ZXN0czIvcGx1Z2luLnByb3BlcnRpZXNQSwECFAAUAAgACAA3kE0z 3mXzb2oAAACP
AAAAGgAAAAAAAAAAAAAAAABJWwAAbGlicmFyeTIudGVzdHMyL3BsdWdpbi54 bWxQSwECFAAU
AAgACAA3kE0zhyIl0wkCAAA6BwAALwAAAAAAAAAAAAAAAAD7WwAAbGlicmFy eTIudGVzdHMy
L3NyYy9saWJyYXJ5L3Rlc3RzL0Jvb2tUZXN0LmphdmFQSwECFAAUAAgACAA3 kE0zkXSl1lQB
AACvAwAANwAAAAAAAAAAAAAAAABhXgAAbGlicmFyeTIudGVzdHMyL3NyYy9s aWJyYXJ5L3Rl
c3RzL0xpYnJhcnkyQWxsVGVzdHMuamF2YVBLAQIUABQACAAIADeQTTMuFwUO 6woAAC1KAAA1
AAAAAAAAAAAAAAAAABpgAABsaWJyYXJ5Mi50ZXN0czIvc3JjL2xpYnJhcnkv dGVzdHMvTGli
cmFyeUV4YW1wbGUuamF2YVBLAQIUABQACAAIADeQTTMsrYPg8AcAAIofAAA2 AAAAAAAAAAAA
AAAAAGhrAABsaWJyYXJ5Mi50ZXN0czIvc3JjL2xpYnJhcnkvdGVzdHMvTGli cmFyeUV4YW1w
bGUyLmphdmFQSwECFAAUAAgACAA3kE0zttTjiB4IAADAIAAANgAAAAAAAAAA AAAAAAC8cwAA
bGlicmFyeTIudGVzdHMyL3NyYy9saWJyYXJ5L3Rlc3RzL0xpYnJhcnlFeGFt cGxlMy5qYXZh
UEsBAhQAFAAIAAgAN5BNMxfsgNkIAgAAZAcAADIAAAAAAAAAAAAAAAAAPnwA AGxpYnJhcnky
LnRlc3RzMi9zcmMvbGlicmFyeS90ZXN0cy9MaWJyYXJ5VGVzdC5qYXZhUEsB AhQAFAAIAAgA
N5BNMzPmJ3BNAQAAnwMAADMAAAAAAAAAAAAAAAAApn4AAGxpYnJhcnkyLnRl c3RzMi9zcmMv
bGlicmFyeS90ZXN0cy9MaWJyYXJ5VGVzdHMuamF2YVBLAQIUABQACAAIADeQ TTP69SqUGAQA
AD4bAABDAAAAAAAAAAAAAAAAAFSAAABsaWJyYXJ5Mi50ZXN0czIvc3JjL2xp YnJhcnkvdGVz
dHMvVGVzdENvbnRhaW5lclByb3h5UmVzb2x1dGlvbi5qYXZhUEsBAhQAFAAI AAgAN5BNM5D4
9alyBQAAfCoAAEEAAAAAAAAAAAAAAAAA3YQAAGxpYnJhcnkyLnRlc3RzMi9z cmMvbGlicmFy
eS90ZXN0cy9UZXN0Q29udGVudFByb3h5UmVzb2x1dGlvbi5qYXZhUEsBAhQA FAAIAAgAN5BN
M1p6w20KAgAAVgcAADEAAAAAAAAAAAAAAAAAvooAAGxpYnJhcnkyLnRlc3Rz Mi9zcmMvbGli
cmFyeS90ZXN0cy9Xcml0ZXJUZXN0LmphdmFQSwUGAAAAAB0AHQA/CwAAJ40A AAAA
--------------020705020608090301030901--
Re: Resolving Containment/Container Proxies and Cross Resource Containment [message #396175 is a reply to message #396164] Fri, 14 October 2005 08:24 Go to previous messageGo to next message
Originally posted by: marchign.fastmail.fm
Ed,
studying your code I gathered a lot of questions.
Are the following invariant valid? Would one want to enforce them?
forall x,y EObject, r Resource
- r.allContents().contains(x) implies
x.eProxyURI() == null
- x.eResource() != null implies
x.eResource().allProperContents().contains(x)
- x.eDirectResource() != null implies
x.eDirectResource().getContents().contains(x)
Is it possible that in such a case also the following should be enforced?
- x.properContent().contains(y) implies
y.eDirectResource() == null
- x.eProxyURI() != null implies
x.eDirectResource() == null
- x.eResource() == r && x.eInternalContainer() != null implies
x.eInternalContainer().eResource() != r
In case of proxy resolving containment which operations the user should
use to move an object from a resource to another (assuming he does not
want to change its container)?
Bye,
Davide
Re: Resolving Containment/Container Proxies and Cross Resource Containment [message #396176 is a reply to message #396175] Fri, 14 October 2005 10:38 Go to previous messageGo to next message
Davide,
Sorry, I've not had time yet to look at your other post. Comments
below. (Good questions!)
Davide Marchignoli wrote:
> Ed,
No. The all contents walk will try to resolve proxies, but resolution
can fail and in that case, the proxy will be returned.
Yes. (As long as x isn't a proxy that resolves during the walk and then
isn't in the tree anymore; there's both a resolving proper content
walker and a non-resolving one, so it's always true for the later.)
Yes.
Yes, this should already be true.
We don't enforce this, but the resource contents list does not resolve
proxies so this would be an odd state.
I don't think is true in the case that x.eDirectResource() == r. I.e.,
x is directly contained by r and is also contained by one of the other
children in r.
> should use to move an object from a resource to another (assuming he
> does not want to change its container)?
Just use r.getContents().add(x).
> Bye,
> Davide
Re: Resolving Containment/Container Proxies and Cross Resource Containment [message #396209 is a reply to message #396176] Mon, 17 October 2005 05:46 Go to previous messageGo to next message
Hi Ed,
from your answer I realized we could have:
- EObject.eDirectResource inverse of Resource.eContents, i.e.
x.eDirectResource() == r iff r.eContents().contains(x)
and symmetrically:
- EObject.eResource inverse of Resource.eAllProperContents, i.e.
x.eResource() == r iff r.eAllProperContents().contains(x)
Is it correct to say that r.eAllProperContents() is the set of attached
and not yet detached objects to r?
if you like these invariants, you will probably want to treat proxy
accordingly, i.e.
- either proxys may have non null eDirectResource and non null
eInternalContainer, and then they appears in eContents in
eAllProperContents and they are attached to resorces
- or proxy always have null eDirectResource and null eInternalContainer
and they do not appear both in eContents and eAllProperContent and they
do not get attached.
I prefer the second choice ;-). At the moment (without your patch) I
think that proxy never belong to resources the second choice would be
conservative in this regard.
In this second case, it is probably pointless having a resolving proper
content, since proxy do not belong to proper content.
In any case I find taht it is a bit confusing notion: should the
resolved proxy belong to proper content? Should it belong even if it
does not resolve? Even if resolution results in an object that belongs
to another resource proper content?
Could it result after an unload?
> children in r.
Yes, I was trying to understand if one wants this. Consider x with
x.eDirectResource() == r, y with y.eInternalContainer() == x and
y.eDirectResource() == r. Does x appear twice in r.eAllContents()?
I do not know how to avoid this anyway. For instance consider
r1
x |
r2 | |
y /
z
where r1, r2 are resources and x, y and z are objects. Then, z seems to
appears twice in r1.eAllContents(). (at least it appears only once in
r1.eAllProperContents()).
Thanks for the enlightening answers,
Bye, Davide
PS: why get*All*ProperContents() and not simply getProperContents()
Re: Resolving Containment/Container Proxies and Cross Resource Containment [message #396212 is a reply to message #396209] Mon, 17 October 2005 06:50 Go to previous messageGo to next message
Davide,
Answers inline.
> Hi Ed,
> and symmetrically:
> attached and not yet detached objects to r?
Yes.
> accordingly, i.e.
> eInternalContainer and they do not appear both in eContents and
> eAllProperContent and they do not get attached.
Previously a proxy was only used as a placeholder for a non-containment
reference and it would only have its inverse feature, if any,
populated. Now a proxy is used as a placeholder in any reference but it
will still have only its inverse feature populated. In the new cases,
the inverse is either a container or containment reference and in the
later case, that inverse will make the proxy appear to be contained
(indirectly) by the resource that contains its parent. So the
eDirectResource is expected to be null in all the cases, but the
eInternalContainer will be non-null for a proxy in a containment reference.
> proper content, since proxy do not belong to proper content.
A proxy will appear in the proper content if it is in a containment
reference and either it isn't resolved or it fails to resolve. A
non-resolving proper content walk will visit proxies. A resolving
proper content walker will try resolve proxies and skip them if they are
actually resolved. We'll want to use them in the resolveAll utility. A
resolving proper walker of the resource set is particularly useful in
that it will visit all the entire demand loaded containment trees while
visiting each object exactly once.
No, not if it resolves to something directly contained by another
resource, which is the expected outcome.
> Should it belong even if it does not resolve?
Yes, because it really is contained until it's resolved.
> Even if resolution results in an object that belongs to another
Once resolved, no, because the resolved result is directly contained by
some other resource. One of the design goals is that we want each
object to be reached exactly once in a proper content walk of the whole
resource set. We also want the proper content walk to visit exactly
those objects for which Resource.Internal.attached has been called.
>> resolve proxies so this would be an odd state.
No, an unload should clear the contents of the resource so its ready to
be loaded again.
>> I.e., x is directly contained by r and is also contained by one of
>> the other children in r.
Yes.
> r1
> x |
> r2 | |
> y /
> z
> to appears twice in r1.eAllContents(). (at least it appears only once
> in r1.eAllProperContents()).
> Bye, Davide
The *All* in each case implies that a TreeIterator is involved. The
new walkers are the similar to the old ones so they have the same name
but with a modifier.
Re: Resolving Containment/Container Proxies and Cross Resource Containment [message #396214 is a reply to message #396168] Mon, 17 October 2005 08:44 Go to previous messageGo to next message
Davide,
I was finally having a look at the attachment. Is there anything
specifically you wanted to draw my attention to?
> Ed,
> I'm sending you my tests. It is work in progress and not that
> meaningful, it simply test some basic invariant but there is no
> inteded usage.
> In order to make clear for both the intended usage so to help in
> deciding design questions like the one below, I plan to write some
> more test case.
> More precisely I mean to send you a toy implementation of Resource
> that uses another Resource as backend and fulfills some of the
> requirements previoulsy outlined in the thread.
> I think it will help in recognizing which are the real needs for
> persistency and possibly will help me in realizing how some of the
> features may be implemented.
>> One reason that proxies won't always resolve in containers you can
>> see in the following code.
>> public EObject eContainer()
>> InternalEObject result = eInternalContainer();
>> if (result != null)
>> int eContainerFeatureID = eContainerFeatureID();
>> if (*eContainerFeatureID > EOPPOSITE_FEATURE_BASE *&&
>> result.eIsProxy())
>> EObject resolved = eResolveProxy(result);
>> if (resolved != result)
>> NotificationChain notificationChain =
>> eBasicRemoveFromContainer(null);
>> eBasicSetContainer((InternalEObject)resolved,
>> eContainerFeatureID);
>> if (notificationChain != null)
>> notificationChain.dispatch();
>> if (eNotificationRequired())
>> eNotify(new ENotificationImpl(this,
>> Notification.RESOLVE, eContainerFeatureID, result, resolved));
>> return resolved;
>> return result;
>> Notice the guard on the eContainerFeatureID. This is basically
>> saying, unless you are in a named container feature, don't bother
>> resolving proxies, or even checking. This might not be a good design
>> choice, but I did it for efficiency because that guard is very cheap
>> to test (cheaper than checking for a proxy) and unless we are in a
>> named container feature, I don't expect the container to be a proxy
>> since the container reference won't be serialized in the instance.
> I saw it, I did not understand the rational so I asked.
>> Changing it to this would always try to resolve so you might want to
>> try that out, but remember you can only resolve if your object is
>> already in a resource in a resource set:
>> if (result != null)
>> if (result.eIsProxy())
>> if (*eContainerFeatureID > EOPPOSITE_FEATURE_BASE &&*
>> return resolved;
>> return result;
> I must confess this is what I was expecting and I prefer this second
> solution. I do not see how in the first case one can trigger load on
> demand of the container. Maybe it will become more clear with an
> implementation of Resource.
>> I'd especially like to see the example that produces the ill-formed
>> XML. That's very very strange! Ideal for me would be if you
>> provided your own version of LibraryExample that would reproduce any
>> issues you are seeing...
> Here is it (in the attachment).
> Bye,
> Davide
Re: Resolving Containment/Container Proxies and Cross Resource Containment [message #396215 is a reply to message #396214] Mon, 17 October 2005 09:03 Go to previous messageGo to next message
Ed Merks wrote:
> Davide,
If you run LibraryExample it should produce the following:
--file://c:/MyBranch.library--
<?xml version="1.0" encoding="ASCII"?>
<library:Library xmi:version="2.0"
xmlns:library="http:///library.ecore">
<Library href="My.library#root"/>
name="branch" <writers href="My3.library#/"/>
<books title="The Book: 2"/>
<books href="My2.library#/"/>
<books href="My4.library#/"/>
</library:Library>
I think it is a problem of XMLResource.
Also testEContainerDoesResolve does fail. This simply tests resolution
for eContainer, at the moment it is not implemented I would choose
otherwise. Which approach did you choose?
I had some other work to do, so did not have time for this, I will
restart working on this asap. If you have time enough I'd like you
looking at an implementation of lazily loading Resource.
Bye,
Davide
Re: Resolving Containment/Container Proxies and Cross Resource Containment [message #396216 is a reply to message #396215] Mon, 17 October 2005 09:33 Go to previous messageGo to next message
Davide,
Doh! Of course that's the problem you mentioned previously. Sorry.
I haven't looked closely but probably what needs to happen is that we
should be respecting the encoded attribute style and either serializing
the container reference as an attribute or as an element (properly,
after all the root attributes are serialized) depending on that
setting. I'll find a better way to do that and update the patches
accordingly.
Thanks for being a tester and a guinea pig!
> Ed Merks wrote:
>> Davide,
> xmlns:xmi="http://www.omg.org/XMI"
> </library:Library>
> Bye,
> Davide
Re: Resolving Containment/Container Proxies and Cross Resource Containment [message #396217 is a reply to message #396212] Mon, 17 October 2005 09:54 Go to previous messageGo to next message
I understand, so the second invariant becomes
EObject.eResource inverse of Resource.eNonResolvingAllProperContents, i.e.
x.eResource() == r iff r.eNonResolvingAllProperContents().contains(x)
right!
Fine! So also proxy will be attached.
>> r1
>> x |
>> r2 | |
>> y /
>> z
any idea for solving the problem above? (note that this is indeed a
tree, becomes a dag only due to the eDirectResource relation). Maybe the
allcontent iterator could keep the subset of eContents that has already
been visited.
Bye,
Davide
Re: Resolving Containment/Container Proxies and Cross Resource Containment [message #396218 is a reply to message #396217] Mon, 17 October 2005 10:29 Go to previous messageGo to next message
Davide,
I don't see the final issue as one that needs to be resolved. An all
content walk will generally not visit things only once...
>> non-containment reference and it would only have its inverse feature,
>> if any, populated. Now a proxy is used as a placeholder in any
>> reference but it will still have only its inverse feature populated.
>> In the new cases, the inverse is either a container or containment
>> reference and in the later case, that inverse will make the proxy
>> appear to be contained (indirectly) by the resource that contains its
>> parent. So the eDirectResource is expected to be null in all the
>> cases, but the eInternalContainer will be non-null for a proxy in a
>> are actually resolved. We'll want to use them in the resolveAll
>> utility. A resolving proper walker of the resource set is
>> particularly useful in that it will visit all the entire demand
>> loaded containment trees while visiting each object exactly once.
> right!
>> by some other resource. One of the design goals is that we want each
>> whole resource set. We also want the proper content walk to visit
>> exactly those objects for which Resource.Internal.attached has been
>> called.
>>> r1
>>> x |
>>> r2 | |
>>> y /
>>> z
>>> once in r1.eAllProperContents()).
> the allcontent iterator could keep the subset of eContents that has
> already been visited.
> Bye,
> Davide
Re: Resolving Containment/Container Proxies and Cross Resource Containment [message #396219 is a reply to message #396218] Mon, 17 October 2005 10:38 Go to previous messageGo to next message
Ed Merks wrote:
> Davide,
Sorry, I thought that at the moment allContents visited each object only
once.
When does happen that the same object get visited twice?
Bye,
Davide
Re: Resolving Containment/Container Proxies and Cross Resource Containment [message #396221 is a reply to message #396219] Mon, 17 October 2005 13:45 Go to previous messageGo to next message
Davide,
My comment is a general one thinking about an all contents walk starting
from the resource set. You're right that from just a resource
perspective, your example introduces another specific case of
duplicates, but I don't see that as a problem that needs fixing since
the walk will also visit things not properly contained in the resource.
> Ed Merks wrote:
>> Davide,
>> all content walk will generally not visit things only once...
> only once.
> Bye,
> Davide
Re: Resolving Containment/Container Proxies and Cross Resource Containment [message #396332 is a reply to message #396168] Sat, 22 October 2005 12:32 Go to previous message
Davide,
I've attached a replacement patch for the XMI plugin's changes to the
bugzilla. It's working better now.
> Ed,
> inteded usage.
> more test case.
>> if (result != null)
>> result.eIsProxy())
>> return resolved;
>> return result;
>> if (result != null)
>> return resolved;
>> return result;
> Bye,
> Davide
Previous Topic:Duplicate descriptors added for collectNewChildDescriptors
Next Topic:Problem about setting the default value of External Edatatype
Current Time: Fri Sep 26 00:54:02 EDT 2025
Powered by FUDForum. Page generated in 0.07082 seconds
