Home » Archived » OHF » uuid and oid
Re: uuid and oid [message #40367 is a reply to message #40336] |
Wed, 23 January 2008 02:13 |
Jesse Pangburn Messages: 166 Registered: July 2009 |
Hi Sarah,
Thanks as always for your help.
As UUID stands for "universally unique identifier", it would seem to me to
be sufficient for uniquely identifying a document inside and out of the
registry. I saw (after sending an OID incorrectly) that the registry does
require UUIDs, as you said to reference stuff internally. So then I
wondered why bother with OIDs since we're already making a unique ID for a
doc in a registry.
Maybe someone thought since UUIDs are only guaranteed unique if properly
generated they should use OIDs. Oh well, I guess as you also said, it's
not "particularly satisfying". Probably one of the initiators had some
odd reason they found compelling...
thanks,
Jesse
Sarah Knoop wrote:
> Hi Jesse,
> Some good questions. This is a combination of factors ... none of which
> are particularly satisfying. the UUIDs come out of the choice to use
> ebXML. The ebXML structures for document entries, folders and submission
> sets all require the use of an 'id'. This 'id' is used in ebXML to
> reference these objects internally with in the registry. Thus a UUID in
> XDS can be described as an id that is unique with-in the registry. But
> this is not necessarily useful or meaningful out side of the registry.
> That is why they have the unique ids. These are intended to be globally
> unique and are to mean something outside the bounds of the registry.
> Hope this helps,
> - Sarah
> Jesse Pangburn wrote:
>> This is kind of a noob question, but can anyone explain the purpose of
>> uuid and oid in XDS?
>> I see that when you submit a document you generate a unique oid value to
>> submit as the document's oid. When the Provide and Register transaction
>> finishes, it returns a uuid value. Why have two unique id values for a
>> given document?
>> Using the bridge, when you want to provide a parent document id to
>> deprecate you specify the uuid. Maybe this has something to do with why
>> there needs to be two unique ids associated with one document?
>> thanks,
>> Jesse
Re: uuid and oid [message #40397 is a reply to message #40367] |
Wed, 23 January 2008 17:14 |
Matthew Davis Messages: 269 Registered: July 2009 |
> to be sufficient for uniquely identifying a document inside and out of
> the registry. I saw (after sending an OID incorrectly) that the
> registry does require UUIDs, as you said to reference stuff internally.
> So then I wondered why bother with OIDs since we're already making a
> unique ID for a doc in a registry.
haha, I said the same thing when it was explained to me, too :)
Ah the world we live in.
-Matt
> Sarah Knoop wrote:
>> Hi Jesse,
>> which are particularly satisfying. the UUIDs come out of the choice to
>> use ebXML. The ebXML structures for document entries, folders and
>> submission sets all require the use of an 'id'. This 'id' is used in
>> ebXML to reference these objects internally with in the registry. Thus
>> a UUID in XDS can be described as an id that is unique with-in the
>> registry. But this is not necessarily useful or meaningful out side of
>> the registry. That is why they have the unique ids. These are intended
>> to be globally unique and are to mean something outside the bounds of
>> the registry.
>> Hope this helps,
>> - Sarah
>>> of uuid and oid in XDS?
>>> to submit as the document's oid. When the Provide and Register
>>> transaction finishes, it returns a uuid value. Why have two unique
>>> id values for a given document?
>>> why there needs to be two unique ids associated with one document?
>>> thanks,
>>> Jesse
Re: uuid and oid [message #40429 is a reply to message #40367] |
Wed, 23 January 2008 22:30 |
No real name Messages: 292 Registered: July 2009 |
I understand ... and have no further justification to offer other than
HL7 loves OIDs and maybe they are someone else's favorites too:-)
- Sarah
> Hi Sarah,
> thanks,
> Jesse
> Sarah Knoop wrote:
>> Hi Jesse,
>> the registry.
>> Hope this helps,
>> - Sarah
>>> thanks,
>>> Jesse
Re: uuid and oid [message #584444 is a reply to message #40336] |
Hi Sarah,
doc in a registry.
thanks,
Jesse
Sarah Knoop wrote:
> Hi Jesse,
> Hope this helps,
> - Sarah
>> given document?
>> thanks,
>> Jesse
Re: uuid and oid [message #584456 is a reply to message #40367] |
-Matt
> Sarah Knoop wrote:
>> Hi Jesse,
>> the registry.
>> Hope this helps,
>> - Sarah
>>> thanks,
>>> Jesse
Re: uuid and oid [message #584462 is a reply to message #40367] |
- Sarah
> Hi Sarah,
> thanks,
> Jesse
> Sarah Knoop wrote:
>> Hi Jesse,
>> the registry.
>> Hope this helps,
>> - Sarah
>>> thanks,
>>> Jesse
Current Time: Thu Sep 26 03:48:15 GMT 2024
Powered by FUDForum. Page generated in 0.04242 seconds
