| Cannot find the declaration of element ... [message #392101] |
Fri, 01 April 2005 15:06  |
Ed,
Let me wrap up my previous questions there were about the same questions and
articulate my problem:
See the code below - I am creating an instance document of this extract.xsd
schema which makes use of two namespaces.
The instance document is written into c:\temp where the schema is in a
different directory.
The instance documnet now declares the namespaces and the schema location
<ClinicalDocument
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns="http://www.ibm.com/research/hii/extract" x
mlns:hl7="urn:hl7-org:v3"
xsi:schemaLocation="http://www.ibm.com/research/hii/extract
extract.xsd">
But when I select it using from the eclipse Resource persective, right click
on it, and select "validate xml file" I get the error message
cvc-elt.1: Cannot find the declaration of element 'ClinicalDocument'.
You insights are highly appricaited :-)
- Iris
----------------------------------------- code to set DocumentRoot and write
the Resource -------------------------
String targetFile = "c:\temp\test.xml";
com.ibm.research.hii.extract.DocumentRoot dstRoot =
ExtractFactory.eINSTANCE.createDocumentRoot();
dstRoot.getXMLNSPrefixMap().put("",
"http://www.ibm.com/research/hii/extract");
dstRoot.getXMLNSPrefixMap().put("hl7", "urn:hl7-org:v3");
dstRoot.getXSISchemaLocation().put("http://www.ibm.com/research/hii/extract"
, "extract.xsd");
Map options = new HashMap();
options.put(XMLResource.OPTION_SCHEMA_LOCATION, Boolean.TRUE);
Resource eResources = (new ExtractResourceFactoryImpl()
.createResource(URI.createURI(targetXMLfile)));
eResources.getContents().add(dstRoot);
eResources.save(new FileOutputStream(targetXMLfile), options);
eResources.unload();
| Re: Cannot find the declaration of element ... [message #392106 is a reply to message #392101] |
Fri, 01 April 2005 15:23  |
Iris,
This is really a question for WTP. You need to give the full absolute
address of extract.xsd. A relative URI is resolved against the URI of
the document containing it, so if the document's URI is
file:/c:/somewhere/file.xml, this .xsd will resolve to
file:/c:/somewhere/extract.xsd. If that's not where the schema is, it
will fail. So you should use something like
file:/c:/whereTheSchemaReallyIs/extract.xsd as the URI.
Iris Eiron wrote:
>Ed,
><ClinicalDocument
>extract.xsd">
>- Iris
>, "extract.xsd");
FUDForum. Page generated in 0.85124 seconds
