Plugin vs. Application startup sequence [message #39854] |
Tue, 06 April 2004 14:37  |
I have a plugin the that implements the
org.eclipse.core.runtime.applications extension and also provides a
startup class. This is to allow the plugin to either host its own RCP or
run within another RCP (I assume this is acceptable). When running in
another RCP, the Workbench is created before the plugin is started.
However, when running in its own RCP, the startup sequence is:
* Create Plugin startup class instance.
* Call the start(BundleContext) method on that startup instance.
* Create and run the IPlatformRunnable instance.
In such a case, the Workbench is not created until after the plugin is
started. Unfortunately, the plugin assumes that the Workbench has already
been created before it is started (a natural assumption, I think.) While
I could trigger some type of secondary startup upon Workbench creation,
this seems unnatural. It also requires separate implementations for self
hosted RCP vs. inclusion in another RCP. So, my questions are:
* Is this startup sequence correct?
* Is the a better way of accomplishing what I'm trying to do?
Stephen
Re: Plugin vs. Application startup sequence [message #40762 is a reply to message #39854] |
Mon, 26 April 2004 15:15   |
Originally posted by: jeff_mcaffer.REMOVE.ca.ibm.com
Not sure I fully follow what you are doing but will take a stab. The
application is the thing that "eclipse" runs in its main thread after it has
finished initializing the framework/runtime. In any given install, there
are many applications (10-15 in base Eclipse I think) but only one of them
is chosen for any given run. When that application finishes, Eclipse exits.
Typcially you are running some app which draws the UI and then reads and
dispatches UI events to drive the UI.
The calls to start() are done either when a class is loaded from a plugin
for the first time or explicitly either by user control (e.g., on typing
start N on the console) or by the framework if the bundle is listed on the
osgi.bundles list.
Jeff
"Stephen Goldbaum" <stephen.goldbaum@lehman.com> wrote in message
news:c4utd8$ltp$1@eclipse.org...
> Stephen
Re: Plugin vs. Application startup sequence [message #40885 is a reply to message #40762] |
Wed, 28 April 2004 07:14  |
> for the first time
For this to happen you need to specify "Eclipse-AutoStart: True" in the
bundle manifest
Sten
"Jeff McAffer" <jeff_mcaffer@REMOVE.ca.ibm.com> wrote in message
news:c6jmog$uvc$1@eclipse.org...
has
exits.
> osgi.bundles list.
> Jeff
or
already
While
self
> > Thanks,
> > Stephen
FUDForum. Page generated in 0.03413 seconds
