| Plugin vs. Application startup sequence [message #39854] | Tue, 06 April 2004 14:37  |  |
| Eclipse User  |  |  |  |  | I have a plugin the that implements the org.eclipse.core.runtime.applications extension and also provides a
 startup class.  This is to allow the plugin to either host its own RCP or
 run within another RCP (I assume this is acceptable).    When running in
 another RCP, the Workbench is created before the plugin is started.
 However, when running in its own RCP, the startup sequence is:
 * Create Plugin startup class instance.
 * Call the start(BundleContext) method on that startup instance.
 * Create and run the IPlatformRunnable instance.
 In such a case, the Workbench is not created until after the plugin is
 started.  Unfortunately, the plugin assumes that the Workbench has already
 been created before it is started (a natural assumption, I think.)  While
 I could trigger some type of secondary startup upon Workbench creation,
 this seems unnatural.  It also requires separate implementations for self
 hosted RCP vs. inclusion in another RCP.  So, my questions are:
 * Is this startup sequence correct?
 * Is the a better way of accomplishing what I'm trying to do?
 Stephen
| Re: Plugin vs. Application startup sequence [message #40762 is a reply to message #39854] | Mon, 26 April 2004 15:15   |  |
| Eclipse User  |  |  |  |  | Originally posted by: jeff_mcaffer.REMOVE.ca.ibm.com
 Not sure I fully follow what you are doing but will take a stab. The
 application is the thing that "eclipse" runs in its main thread after it has
 finished initializing the framework/runtime.  In any given install, there
 are many applications (10-15 in base Eclipse I think) but only one of them
 is chosen for any given run.  When that application finishes, Eclipse exits.
 Typcially you are running some app which draws the UI and then reads and
 dispatches UI events to drive the UI.
 The calls to start() are done either when a class is loaded from a plugin
 for the first time or explicitly either by user control (e.g., on typing
 start N on the console) or by the framework if the bundle is listed on the
 osgi.bundles list.
 Jeff
 "Stephen Goldbaum" <stephen.goldbaum@lehman.com> wrote in message
 news:c4utd8$ltp$1@eclipse.org...
 > Stephen
| Re: Plugin vs. Application startup sequence [message #40885 is a reply to message #40762] | Wed, 28 April 2004 07:14  |  |
| Eclipse User  |  |  |  |  | > The calls to start() are done either when a class is loaded from a plugin > for the first time
 For this to happen you need to specify "Eclipse-AutoStart: True" in the
 bundle manifest
 Sten
 "Jeff McAffer" <jeff_mcaffer@REMOVE.ca.ibm.com> wrote in message
 news:c6jmog$uvc$1@eclipse.org...
 has
 exits.
 > osgi.bundles list.
 > Jeff
 or
 already
 While
 self
 > > Thanks,
 > > Stephen
FUDForum. Page generated in 0.02684 seconds
