| Home » Modeling » EMF » Invalid EMF references on customized save
 Goto Forum:|
| Invalid EMF references on customized save [message #391149] | Mon, 14 February 2005 18:25  |  |
| Eclipse User  |  |  |  |  | Ive been trying to put together a custom serialization method for our EMF model.
 Currently, we have an EMF model spread across several files in order to
 break down the model for editing purposes.  However, at times we need an
 XML representation of the complete model for XML transformations and other
 needs.
 I have written a custom ResourceImpl and XMLSaveImpl in order to over
 write the Lookup method to redefine containment such that save will put
 all the XML in one document represented by one resource.
 After a little work, I thought all was well.  But soon came to discover
 that some of the references are not correct in the custom serialized
 model.  For example, I might have an XMI reference like (ref=/3 /4)
 point to some nodes that are not correct.  (Either the nodes are not
 there, or they are the wrong type, and so forth)
 I have also noticed that some references appear to point to old resource
 files (the ones that this resource was created with, and should no longer
 be necessary), for example (ref=
 Another_sub_file_from_emf_model.extension#/) when that EObject is now
 contained in the same resource and the hope was that the reference value
 would have changed as well. (Such that the value would be something more
 like ref=/3 where 3 refers to a node in the same resource)
 Or in other words, in
 I have successfully looped through and copied all
 the eObjects to an empty resource.  However, when saving the resource the
 referenced items (some times) do not point back inside the file.
 (Although, they usually appear to do so besides the occasional reference
 that is off a little, possibly these other references are off).  In fact,
 it appears that earlier references in the file are more likely to be
 correct than latter references,
 but Im not sure why!?!?!?
 So here is my question:
 Any ideas why some references are off, while others are fine?
 Ive been racking my brain over this one, but Im afraid Im going to have
 to brute force a custom XML document by looping through the EMF objects
 Any opinion on if that is going to be easier?  This method was very slick
 and perfect for what I need, except for the inaccurate references 
 The blow code shows how I added the resource together:
 private byte[] create(EObject rootObjectFromManyFileModel)
 List<EObject> objectList = new ArrayList<EObject>();
 ByteArrayOutputStream os = new ByteArrayOutputStream();
 addChildObjects( rootObjectFromManyFileModel, objectList );
 URI outputUri = null;
 Resource newResource = new MyResourceImpl( null); // customized
 resource to over write lookup method
 newResource.getContents().addAll( objectList );
 newResource.save( os, Collections.EMPTY_MAP );
 int count = 0;
 for (Iterator iter = newResource.getAllContents(); iter.hasNext();)
 EObject element = (EObject) iter.next();
 return os.toByteArray();
 private void addChildObjects(
 EObject eObject,
 List<EObject> objectList )
 if (!objectList.contains( eObject ))
 // Add the object
 objectList.add( eObject );
 System.out.println("Added object: " +
 eObject.getClass().getName());
 // Add referenced children
 for (Iterator iterator = eObject.eCrossReferences().iterator();
 iterator.hasNext();)
 EObject child = (EObject) iterator.next();
 addChildObjects( child,
 objectList );
| Re: Invalid EMF references on customized save [message #391159 is a reply to message #391149] | Tue, 15 February 2005 07:05   |  |
| Eclipse User  |  |  |  |  | Will,
 The algorithm below will do really nasty things because once you do the
 addAll to the resource, the cross referenced objects will be detached
 from their container and attached to the resource, so your trees will be
 often be broken into so many little separate pieces. Since there can be
 cross references (potentially) even within the original resource, even
 that tree will end up being broken up. Here's how I would imagine doing
 this. Start with a list of resources containing just the one resource
 that you want to save. Look at the nth resource in the list (starting at
 0), walk the resource.getAllContents, which recursively visits every
 contained EObject, for each EObject iterate over the eCrossReferences to
 look at each referenced object, and for each referenced object, check if
 its eResource in in the list and add it if it isn't. If you repeat this
 for each resource, you'll end up with a list of all the resources that
 are referenced. If you take the getContents of all but the first and add
 them to the first, you'll have a resource containing the roots of all
 the tree you want to save into a single resource.
 Note that one of the many problems with your algorithm below is that it
 doesn't look at the cross references of the cross references, so it
 doesn't ensure that everything that's need will actually all be in one
 resource...
 Will wrote:
 > I�ve been trying to put together a custom serialization method for our
 > EMF model.
 > to break down the model for editing purposes. However, at times we
 > need an XML representation of the complete model for XML
 > transformations and other needs.
 > put all the XML in one document represented by one resource.
 > model. For example, I might have an XMI reference like (ref=�/3 /4�)
 > resource files (the ones that this resource was created with, and
 > should no longer be necessary), for example (ref=�
 > Another_sub_file_from_emf_model.extension#/�) when that EObject is now
 > value would have changed as well. (Such that the value would be
 > something more like ref=�/3� where 3 refers to a node in the same
 > resource)
 > Or in other words, in � I have successfully looped through and copied
 > all the eObjects to an empty resource. However, when saving the
 > resource the referenced items (some times) do not point back inside
 > the file. (Although, they usually appear to do so besides the
 > occasional reference that is off a little, possibly these other
 > references are off). In fact, it appears that earlier references in
 > the file are more likely to be correct than latter references, � but
 > I�m not sure why!?!?!?
 > I�ve been racking my brain over this one, but I�m afraid I�m going to
 > have to brute force a custom XML document by looping through the EMF
 > objects � Any opinion on if that is going to be easier? This method
 > was very slick and perfect for what I need, except for the inaccurate
 > references 
 > newResource.save( os, Collections.EMPTY_MAP ); int count = 0;
 > EObject eObject,
 > // Add the object
 > System.out.println("Added object: " + eObject.getClass().getName());
 > objectList );
| Re: Invalid EMF references on customized save [message #391169 is a reply to message #391159] | Tue, 15 February 2005 13:45   |  |
| Eclipse User  |  |  |  |  | Ed,
 Thanks for your help.  Using your suggestions I was able to rid myself of
 the references pointing to old resource files.  However, I'm still getting
 invalid references to items within the document (for example I get a "/7"
 when it should be a "/9").
 Any ideas why this still might be happening?
 Here is the re-written code:
 private Resource buildConsolidatedResource( URI newResourceUri,
 Resource inputResource )
 // create a list of resources to consolidate
 List resourceList = new ArrayList<Resource>();
 resourceList.add(inputResource);
 // recursivly add referenced resources (method below)
 addReferencedResources((Resource)resourceList.get(0), resourceList);
 // copy contents to a consolidated resource (which has the
 customized lookup method)
 Resource consolidatedResource = new MyResourceImpl( newResourceUri );
 for (Iterator iter = resourceList.iterator(); iter.hasNext();)
 consolidatedResource.getContents().addAll( ((Resource)
 iter.next()).getContents() );
 return consolidatedResource;
 private static void addReferencedResources(Resource resource, List
 resourceList )
 for (Iterator allContentsIterator = resource.getAllContents();
 allContentsIterator.hasNext();)
 EObject allContentsEObject = (EObject) allContentsIterator.next();
 for (Iterator crossRefIterator =
 allContentsEObject.eCrossReferences().iterator();
 crossRefIterator.hasNext();)
 Resource crossRefResource = ((EObject)
 crossRefIterator.next()).eResource();
 if (!resourceList.contains(crossRefResource))
 resourceList.add(crossRefResource);
 addReferencedResources(crossRefResource, resourceList);
 Ed Merks wrote:
 > Will,
 > resource...
 > Will wrote:
 >> I?ve been trying to put together a custom serialization method for our
 >> EMF model.
 >> model. For example, I might have an XMI reference like (ref=?/3 /4?)
 >> should no longer be necessary), for example (ref=?
 >> Another_sub_file_from_emf_model.extension#/?) when that EObject is now
 >> something more like ref=?/3? where 3 refers to a node in the same
 >> resource)
 >> Or in other words, in ? I have successfully looped through and copied
 >> the file are more likely to be correct than latter references, ? but
 >> I?m not sure why!?!?!?
 >> I?ve been racking my brain over this one, but I?m afraid I?m going to
 >> objects ? Any opinion on if that is going to be easier? This method
 >> references 
 >> EObject eObject,
 >> // Add the object
 >> objectList );
| Re: Invalid EMF references on customized save [message #391171 is a reply to message #391169] | Tue, 15 February 2005 15:22   |  |
| Eclipse User  |  |  |  |  | This is a multi-part message in MIME format. --------------080304040109000602050709
 Will,
 I don't have a good theory for that.  The root index is computed by
 ResourceImpl like this:
 protected String getURIFragmentRootSegment(EObject eObject)
 List contents = getContents();
 return contents.size() > 1 ?
 Integer.toString(getContents().indexOf(eObject)) :
 I.e., it really does represent the position within the resource contents
 list of the root object and it being wrong seems to imply that the
 contents are changing during the save.
 Will wrote:
 > Ed,
 > of the references pointing to old resource files.  However, I'm still
 > getting invalid references to items within the document (for example I
 > get a "/7" when it should be a "/9").
 > newResourceUri );
 > iter.next()).getContents() );        }
 > resourceList )
 > Ed Merks wrote:
 >> Will,
 >> the addAll to the resource, the cross referenced objects will be
 >> detached from their container and attached to the resource, so your
 >> trees will be often be broken into so many little separate pieces.
 >> Since there can be cross references (potentially) even within the
 >> original resource, even that tree will end up being broken up. Here's
 >> how I would imagine doing this. Start with a list of resources
 >> containing just the one resource that you want to save. Look at the
 >> nth resource in the list (starting at 0), walk the
 >> resource.getAllContents, which recursively visits every contained
 >> EObject, for each EObject iterate over the eCrossReferences to look
 >> this for each resource, you'll end up with a list of all the
 >> resources that are referenced. If you take the getContents of all but
 >> the first and add them to the first, you'll have a resource
 >> containing the roots of all the tree you want to save into a single
 >> resource.
 >> it doesn't look at the cross references of the cross references, so
 >> it doesn't ensure that everything that's need will actually all be in
 >> one resource...
 >>> our EMF model.
 >>> over write the Lookup method to redefine containment such that save
 >>> will put all the XML in one document represented by one resource.
 >>> discover that some of the references are not correct in the custom
 >>> serialized model. For example, I might have an XMI reference like
 >>> (ref=?/3 /4?) point to some nodes that are not correct. (Either the
 >>> nodes are not there, or they are the wrong type, and so forth)
 >>> now contained in the same resource and the hope was that the
 >>> reference value would have changed as well. (Such that the value
 >>> would be something more like ref=?/3? where 3 refers to a node in
 >>> the same resource)
 >>> copied all the eObjects to an empty resource. However, when saving
 >>> the resource the referenced items (some times) do not point back
 >>> inside the file. (Although, they usually appear to do so besides the
 >>> to have to brute force a custom XML document by looping through the
 >>> EMF objects ? Any opinion on if that is going to be easier? This
 >>> method was very slick and perfect for what I need, except for the
 >>> EObject eObject,
 >>> // Add the object
 >>> objectList );
 <html>
 <head>
 http-equiv="Content-Type">
 </head>
 Will,<br>
 <br>
| Re: Invalid EMF references on customized save [message #391175 is a reply to message #391171] | Tue, 15 February 2005 19:01   |  |
 From what I can tell, it seems to be having problems with forward
 refereneces.  At least when it starts running into problems.
 I used the getURIFragment method to determin the URI fragment of the
 resource, for example:
 for (int i = 0; i < newResource.getContents().size(); i++)
 EObject o = newResource.getEObject("/" + i);
 System.out.println("/" + i + " " + o.getClass().getName());
 I get result like:
 /0 com.novell.porpoise.common.model.impl.ProjectImpl
 /1 com.novell.porpoise.common.model.impl.DomainImpl
 /2 com.novell.porpoise.common.model.impl.DomainImpl
 /3 com.novell.porpoise.common.model.impl.DomainImpl
 /4 com.novell.porpoise.common.model.impl.DomainImpl
 ... (and so on)
 The XML (from the xmi file) appears to be created in the same element
 order as the output from this debug.  EXCEPT, when I start hitting the
 invalid references in the XML, the ordering is different.
 Either the XML elements are written out in the wrong order, or it seems
 related to forward references (reference to elements not yet there?!?!?).
 Also, I'm wondering if the my Lookup.featureKind(...) method is related to
 that changes going on.  Because I'm changing the containment in this
 method, this could possibly change the number of elements in the complete
 document ... I'm not sure, but somehow these items seem related.
 This method, by the way, looks like:
 protected int featureKind( EStructuralFeature f )
 int kind = super.featureKind( f );
 if (    f == ModelPackage.eINSTANCE.getProject_Domain()
 || f == ModelPackage.eINSTANCE.getDomain_DomainItems()
 || f == ModelPackage.eINSTANCE.getDriver_Policies()
 switch (kind)
 case OBJECT_HREF_MANY :
 return OBJECT_CONTAIN_MANY;
 case OBJECT_HREF_SINGLE :
 return OBJECT_CONTAIN_SINGLE;
 case OBJECT_HREF_SINGLE_UNSETTABLE :
 return OBJECT_CONTAIN_SINGLE_UNSETTABLE;
 case OBJECT_HREF_MANY_UNSETTABLE :
 return OBJECT_CONTAIN_MANY_UNSETTABLE;
 return kind;
 Ed Merks wrote:
 > Will,
 > Will wrote:
 >> Ed,
 >> newResourceUri );
 >> resourceList )
 >> Ed Merks wrote:
 >>> Will,
 >>> resource.
 >>> one resource...
 >>>> our EMF model.
 >>>> the same resource)
 >>>> EObject eObject,
 >>>> // Add the object
 >>>> objectList );
| Re: Invalid EMF references on customized save [message #391179 is a reply to message #391175] | Wed, 16 February 2005 06:26   |  |
| Eclipse User  |  |  |  |  | This is a multi-part message in MIME format. --------------090009020903080002040403
 Will,
 Given that you've moved the entire closure of objects into the one
 resource, why are you doing the containment overrides?  I would think
 this would cause duplicate objects to serialize, so you must be doing
 something to prevent that.   The containment override will certainly
 mess this code in ResourceImpl which relies on properly knowing the
 inverse of containment  to determine a path up the tree that can later
 be followed to walk back down the tree.  You'll need to change this code
 to make eContainer appear "correct" based on who you are pretending is
 the container:
 public String getURIFragment(EObject eObject)
 String id = EcoreUtil.getID(eObject);
 if (id != null)
 return id;
 else
 List uriFragmentPath = new ArrayList();
 *      for (EObject container = eObject.eContainer(); container !=
 null; container = eObject.eContainer())
 uriFragmentPath.add(((InternalEObject)container).eURIFragmen tSegment(eObject.eContainingFeature(),
 eObject));
 eObject = container;
 StringBuffer result = new StringBuffer("/");
 result.append(getURIFragmentRootSegment(eObject));
 for (ListIterator i =
 uriFragmentPath.listIterator(uriFragmentPath.size()); i.hasPrevious(); )
 result.append('/');
 result.append((String)i.previous());
 return result.toString();
 Will wrote:
 > Ed,
 > I get result like:
 > .. (and so on)
 > seems related to forward references (reference to elements not yet
 > there?!?!?).
 > related to that changes going on.  Because I'm changing the
 > containment in this method, this could possibly change the number of
 > elements in the complete document ... I'm not sure, but somehow these
 > items seem related.
 >                    || f ==
 > ModelPackage.eINSTANCE.getDriver_Policies()    )
 >                  switch (kind)
 >               return kind;
 > Ed Merks wrote:
 >> Will,
 >> contents list of the root object and it being wrong seems to imply
 >> that the contents are changing during the save.
 >> Will wrote:
 >>> Ed,
 >>> myself of the references pointing to old resource files.  However,
 >>> I'm still getting invalid references to items within the document
 >>> (for example I get a "/7" when it should be a "/9").
 >>> resourceList);
 >>> newResourceUri );
 >>> resourceList )
 >>> Ed Merks wrote:
 >>>> Will,
 >>>> Here's how I would imagine doing this. Start with a list of
 >>>> resources containing just the one resource that you want to save.
 >>>> Look at the nth resource in the list (starting at 0), walk the
 >>>> but the first and add them to the first, you'll have a resource
 >>>> resource.
 >>>> that it doesn't look at the cross references of the cross
 >>>> references, so it doesn't ensure that everything that's need will
 >>>> actually all be in one resource...
 >>>>> our EMF model.
 >>>>> order to break down the model for editing purposes. However, at
 >>>>> times we need an XML representation of the complete model for XML
 >>>>> save will put all the XML in one document represented by one
 >>>>> resource.
 >>>>> the nodes are not there, or they are the wrong type, and so forth)
 >>>>> the same resource)
 >>>>> the occasional reference that is off a little, possibly these
 >>>>> other references are off). In fact, it appears that earlier
 >>>>> references in the file are more likely to be correct than latter
 >>>>> references, ? but I?m not sure why!?!?!?
 >>>>> the EMF objects ? Any opinion on if that is going to be easier?
 >>>>> This method was very slick and perfect for what I need, except for
 >>>>> EObject eObject,
 >>>>> // Add the object
 >>>>> objectList );
 <html>
 <head>
 </head>
 Will,<br>
 <br>
| Re: Invalid EMF references on customized save [message #391220 is a reply to message #391179] | Thu, 17 February 2005 18:54   |  |
 OK ... That last post may have been what I was looking for. So I'm happy
 boy right now.  I'm still hitting some issues, but I think it's some model
 design issues I'll try to get ironed out.
 Also, ... I'm getting reference that read more like:
 ref="/0/@domain/@domainItems.3/@driverSets.0" when they used to be more
 like: ref="/23"
 Both make sense ... However, the latter result is preferred because of
 "fun" transformation issues with XSLT.
 Is it possible to force the reference to be just the element order in the
 document??? (like the second reference)
 By the way, In answer to your question about "why are you doing the
 containment overrides?" ... We'll basically based on an earlier threads on
 this message board I was left to think this was the best solution.
 Because our model has classes that refer to other classes (with no
 containment) in order to imply that that these classes are to be stored in
 different files (but may actually "logically" contain the related class).
 However, when we need an XML doc to represent the whole model, this custom
 save will pull it back together in one file.  And from what I see, having
 the related eObjects all in the same resource does not necessarily change
 the XML containment ... but somehow EMF is still able to treat the items
 separately (and the end result is that saving would only write out one of
 the eObjects "unless" containment is redefined) ... I hope that mess of a
 paragraph made sense.
 - Will
 Ed Merks wrote:
 > Will,
 > the container:
 >         if (id != null)
 >           return id;
 >         else
 >     eObject));
 >             result.append('/');
 > Will wrote:
 >> Ed,
 >> I get result like:
 >> .. (and so on)
 >> there?!?!?).
 >> items seem related.
 >>                    || f ==
 >>                  switch (kind)
 >>               return kind;
 >> Ed Merks wrote:
 >>> Will,
 >>> Will wrote:
 >>>> Ed,
 >>>> resourceList);
 >>>> newResourceUri );
 >>>> resourceList )
 >>>> Ed Merks wrote:
 >>>>> Will,
 >>>>> resource.
 >>>>>> our EMF model.
 >>>>>> resource.
 >>>>>> the same resource)
 >>>>>> EObject eObject,
 >>>>>> // Add the object
 >>>>>> objectList );
| Re: Invalid EMF references on customized save [message #391234 is a reply to message #391220] | Fri, 18 February 2005 07:01   |  |
 If both make sense, then it sounds like you could first test in
 getURIFragment if the object is directly in Resource.getContents before
 walking up the pseudo containment tree, and to use the index in that
 case.  That last paragraph confused me a little.  An XMLResourceImpl
 will only let you save one root element but an XMIRsourceImpl lets you
 save many because it automatically introduces a single pseudo root to
 hold all the contents.  To do this same thing with an XMLResourceImpl,
 you'd have to define a single root object that can contain many
 children.  Is this related to your question? ;-)
 Will wrote:
 > Ed,
 > happy boy right now.  I'm still hitting some issues, but I think it's
 > some model design issues I'll try to get ironed out.
 > more like: ref="/23"
 > the document??? (like the second reference)
 > threads on this message board I was left to think this was the best
 > solution.  Because our model has classes that refer to other classes
 > (with no containment) in order to imply that that these classes are to
 > be stored in different files (but may actually "logically" contain the
 > related class).  However, when we need an XML doc to represent the
 > whole model, this custom save will pull it back together in one file.
 > And from what I see, having the related eObjects all in the same
 > resource does not necessarily change the XML containment ... but
 > somehow EMF is still able to treat the items separately (and the end
 > result is that saving would only write out one of the eObjects
 > "unless" containment is redefined) ... I hope that mess of a paragraph
 > made sense.
 > - Will
 > Ed Merks wrote:
 >> Will,
 >> later be followed to walk back down the tree.  You'll need to change
 >> this code to make eContainer appear "correct" based on who you are
 >> pretending is the container:
 >>         if (id != null)
 >>           return id;
 >>         else
 >>     eObject));
 >> i.hasPrevious(); )
 >>             result.append('/');
 >> Will wrote:
 >>> Ed,
 >>> I get result like:
 >>> .. (and so on)
 >>> element order as the output from this debug.  EXCEPT, when I start
 >>> hitting the invalid references in the XML, the ordering is different.
 >>> there?!?!?).
 >>>                    || f ==
 >>>                    || f ==
 >>>                  switch (kind)
 >>>               return kind;
 >>> Ed Merks wrote:
 >>>> Will,
 >>>> Will wrote:
 >>>>> Ed,
 >>>>> resourceList);
 >>>>> newResourceUri );
 >>>>> List resourceList )
 >>>>> resource.getAllContents(); allContentsIterator.hasNext();)
 >>>>> Ed Merks wrote:
 >>>>>> Will,
 >>>>>> do the addAll to the resource, the cross referenced objects will
 >>>>>> be detached from their container and attached to the resource, so
 >>>>>> your trees will be often be broken into so many little separate
 >>>>>> pieces. Since there can be cross references (potentially) even
 >>>>>> within the original resource, even that tree will end up being
 >>>>>> broken up. Here's how I would imagine doing this. Start with a
 >>>>>> list of resources containing just the one resource that you want
 >>>>>> to save. Look at the nth resource in the list (starting at 0),
 >>>>>> eCrossReferences to look at each referenced object, and for each
 >>>>>> referenced object, check if its eResource in in the list and add
 >>>>>> it if it isn't. If you repeat this for each resource, you'll end
 >>>>>> up with a list of all the resources that are referenced. If you
 >>>>>> take the getContents of all but the first and add them to the
 >>>>>> first, you'll have a resource containing the roots of all the
 >>>>>>> for our EMF model.
 >>>>>>> XML transformations and other needs.
 >>>>>>> resource.
 >>>>>>> custom serialized model. For example, I might have an XMI
 >>>>>>> reference like (ref=?/3 /4?) point to some nodes that are not
 >>>>>>> correct. (Either the nodes are not there, or they are the wrong
 >>>>>>> type, and so forth)
 >>>>>>> and should no longer be necessary), for example (ref=?
 >>>>>>> is now contained in the same resource and the hope was that the
 >>>>>>> saving the resource the referenced items (some times) do not
 >>>>>>> point back inside the file. (Although, they usually appear to do
 >>>>>>> so besides the occasional reference that is off a little,
 >>>>>>> possibly these other references are off). In fact, it appears
 >>>>>>> correct than latter references, ? but I?m not sure why!?!?!?
 >>>>>>> going to have to brute force a custom XML document by looping
 >>>>>>> through the EMF objects ? Any opinion on if that is going to be
 >>>>>>> easier? This method was very slick and perfect for what I need,
 >>>>>>> EObject eObject,
 >>>>>>> // Add the object
 >>>>>>> objectList );
| Re: Invalid EMF references on customized save [message #391299 is a reply to message #391220] | Wed, 23 February 2005 12:06   |  |
| Eclipse User  |  |  |  |  | I'm getting reference that read like: ref="/0/@domain/@domainItems.3/@driverSets.0" when they used to be more
 like: ref="/23"
 Is it possible to force the references to be just the element order in the
 document??? (like the second reference, and not include @ or class names)
 (See below for more detail)
 Will wrote:
 > Ed,
 > like: ref="/23"
 > - Will
 > Ed Merks wrote:
 >> Will,
 >> the container:
 >>         if (id != null)
 >>           return id;
 >>         else
 >>     eObject));
 >>             result.append('/');
 >> Will wrote:
 >>> Ed,
 >>> I get result like:
 >>> .. (and so on)
 >>> there?!?!?).
 >>> items seem related.
 >>>                    || f ==
 >>>                  switch (kind)
 >>>               return kind;
 >>> Ed Merks wrote:
 >>>> Will,
 >>>> Will wrote:
 >>>>> Ed,
 >>>>> resourceList);
 >>>>> newResourceUri );
 >>>>> resourceList )
 >>>>> Ed Merks wrote:
 >>>>>> Will,
 >>>>>> resource.
 >>>>>>> our EMF model.
 >>>>>>> resource.
 >>>>>>> the same resource)
 >>>>>>> EObject eObject,
 >>>>>>> // Add the object
 >>>>>>> objectList );
| Re: Invalid EMF references on customized save [message #391303 is a reply to message #391299] | Wed, 23 February 2005 14:46  |  |
| Eclipse User  |  |  |  |  | This is a multi-part message in MIME format. --------------040002020206030106020608
 Will,
 You can override these two methods in your ResourceImpl to have complete
 control over how the fragment looks for that resource:
 EObject getEObject(String uriFragment)
 Note that "/23" means select the 24th object in Resource.getContents(),
 i.e., it only selects root objects.
 > the document??? (like the second reference, and not include @ or class
 > names)
 > Will wrote:
 >> Ed,
 >> of "fun" transformation issues with XSLT.
 >> to be stored in different files (but may actually "logically" contain
 >> the related class).  However, when we need an XML doc to represent
 >> the whole model, this custom save will pull it back together in one
 >> file.  And from what I see, having the related eObjects all in the
 >> same resource does not necessarily change the XML containment ... but
 >> - Will
 >> Ed Merks wrote:
 >>> Will,
 >>> think this would cause duplicate objects to serialize, so you must
 >>> be doing something to prevent that.   The containment override will
 >>> certainly mess this code in ResourceImpl which relies on properly
 >>> knowing the inverse of containment  to determine a path up the tree
 >>> that can later be followed to walk back down the tree.  You'll need
 >>> to change this code to make eContainer appear "correct" based on who
 >>> you are pretending is the container:
 >>>         if (id != null)
 >>>           return id;
 >>>         else
 >>>     eObject));
 >>> i.hasPrevious(); )
 >>>             result.append('/');
 >>> Will wrote:
 >>>> Ed,
 >>>> the resource, for example:
 >>>> I get result like:
 >>>> .. (and so on)
 >>>> there?!?!?).
 >>>> of elements in the complete document ... I'm not sure, but somehow
 >>>>                    || f ==
 >>>>                    || f ==
 >>>>                  switch (kind)
 >>>>               return kind;
 >>>> Ed Merks wrote:
 >>>>> Will,
 >>>>> by ResourceImpl like this:
 >>>>> Will wrote:
 >>>>>> Ed,
 >>>>>> However, I'm still getting invalid references to items within the
 >>>>>> document (for example I get a "/7" when it should be a "/9").
 >>>>>> resourceList);
 >>>>>> newResourceUri );
 >>>>>> List resourceList )
 >>>>>> resourceList);
 >>>>>> Ed Merks wrote:
 >>>>>>> Will,
 >>>>>>> so your trees will be often be broken into so many little
 >>>>>>> separate pieces. Since there can be cross references
 >>>>>>> (potentially) even within the original resource, even that tree
 >>>>>>> resource that you want to save. Look at the nth resource in the
 >>>>>>> list (starting at 0), walk the resource.getAllContents, which
 >>>>>>> recursively visits every contained EObject, for each EObject
 >>>>>>> iterate over the eCrossReferences to look at each referenced
 >>>>>>> object, and for each referenced object, check if its eResource
 >>>>>>> in in the list and add it if it isn't. If you repeat this for
 >>>>>>> that are referenced. If you take the getContents of all but the
 >>>>>>> single resource.
 >>>>>>> will actually all be in one resource...
 >>>>>>>> for our EMF model.
 >>>>>>>> to over write the Lookup method to redefine containment such
 >>>>>>>> that save will put all the XML in one document represented by
 >>>>>>>> one resource.
 >>>>>>>> type, and so forth)
 >>>>>>>> value would be something more like ref=?/3? where 3 refers to a
 >>>>>>>> do so besides the occasional reference that is off a little,
 >>>>>>>> iter.hasNext();)
 >>>>>>>> EObject eObject,
 >>>>>>>> // Add the object
 >>>>>>>> objectList );
 <html>
 <head>
 </head>
 Will,<br>
 <br>
 complete control over how the fragment looks for that resource:<br>
 <blockquote>String getURIFragment(EObject eObject)<br>
 EObject getEObject(String uriFragment)<br>
 </blockquote>
 i.e., it only selects root objects.<br>
 <br>
 <br>
 Will wrote:
 <blockquote cite="midcvid60$1nu$1@www.eclipse.org" type="cite">I'm
 ref=<a class="moz-txt-link-rfc2396E" href="mailto:/0/@domain/@domainItems.3/@driverSets.0">"/0/@domain/@domainItems.3/@driverSets.0 "</a> when they used to be more
 like: ref="/23"
 <br>
 <br>
 names)
 <br>
 <br>
 <br>
 <br>
 Will wrote:
 <br>
 <br>
 <blockquote type="cite">Ed,
 <br>
 </blockquote>
 <br>
 <blockquote type="cite">OK ... That last post may have been what I
 was looking for. So I'm happy boy right now.
 Current Time: Fri Oct 31 04:15:59 EDT 2025
 Powered by FUDForum . Page generated in 0.21551 seconds |
