@OneToOne and @PrimaryKeyJoinColumn do not fetch the object on H2/HSQL database [message #390507] |
Mon, 20 July 2009 10:14 |
I have this construct:
@Entity
class PickOrder {
@OneToOne(optional = false, fetch = FetchType.EAGER)
@PrimaryKeyJoinColumn(name = "auf_nr")
OrderProgress progress;
@Entity
@Table(name = "order_infos")
public class OrderProgress implements Comparable<OrderProgress> {
@Id
@Column(name = "auf_nr", length = 18)
String id;
float done_percent;
float shortfalls_percent;
int shortfalls;
public OrderProgress() {
public String toString() {
String value = this.done_percent + "%"; //$NON-NLS-1$
if (this.shortfalls_percent > 0.f) {
value += " [" + this.shortfalls_percent + "%]"; //$NON-NLS-1$
//$NON-NLS-2$
return value;
public int compareTo(final OrderProgress o) {
float result = this.done_percent - o.done_percent;
if (result == 0.f) {
result = this.shortfalls_percent - o.shortfalls_percent;
return (int) result;
When calling "select o from PickOrder" the progress object is never
filled with the data from the table (which is a view actually).
When I call "select o from PickOrder where o.id=1" it is sometimes
fetched sometimes not. The generated SQL is correct. Any Ideas what
might cause such a behaviour on H2 (HSQL)?
Phil
FUDForum. Page generated in 0.04746 seconds
