Re: indirect resultlist [message #389781 is a reply to message #389758] |
Thu, 02 July 2009 14:21 |
Normal queries are expected to return real lists, that can be serialized,
etc. very large queries are the exceptional case. For very large queries
you can use tge firstResult/maxResult or use a
CursoredStream/ScrollableCursor (you can set this through Query hints).
In TopLink we did have a CursoredCollection implementation at one point,
but this is not in EclipseLink, so if this is something you desire you
could log an enhancement request for it.
James
http://www.nabble.com/EclipseLink---Users-f26658.html
James : Wiki : Book : Blog : Twitter
Re: indirect resultlist [message #389783 is a reply to message #389781] |
Thu, 02 July 2009 17:06 |
Tom Eugelink Messages: 817 Registered: July 2009 |
Oh oh... Bugzilla has a problem. Send an email to the webmaster.
DBD::mysql::db do failed: Table './bugs/bugs_activity' is marked as crashed and should be repaired at /home/data/httpd/bugs.eclipse.org/html/bugzilla-2.20/Bugzill a/DB/Mysql.pm line 209
Bugzilla::DB::Mysql::bz_lock_tables('Bugzilla::DB::Mysql=HAS H(0x555558e1eb60)', 'bugs WRITE', 'bug_group_map WRITE', 'longdescs WRITE', 'cc WRITE', 'keywords WRITE', 'dependencies WRITE', 'bugs_activity WRITE', 'fielddefs READ', ...) called at /home/data/httpd/bugs.eclipse.org/html/bugzilla-2.20/Bugzill a/Bug.pm line 285
Bugzilla::Bug::create('Bugzilla::Bug', 'HASH(0x5555576622a0)') called at /home/data/httpd/bugs.eclipse.org/html/bugzilla-2.20/post_bu g.cgi line 166
ModPerl::ROOT::Bugzilla::ModPerl::ResponseHandler::home_data _httpd_bugs_2eeclipse_2eorg_html_bugzilla_2d2_2e20_post_bug_ 2ecgi::handler('Apache2::RequestRec=SCALAR(0x55555868e570)') called at /usr/lib/perl5/vendor_perl/5.8.8/x86_64-linux-thread-multi/M odPerl/RegistryCooker.pm line 204
eval {...} called at /usr/lib/perl5/vendor_perl/5.8.8/x86_64-linux-thread-multi/M odPerl/RegistryCooker.pm line 204
ModPerl::RegistryCooker::run('Bugzilla::ModPerl::ResponseHan dler=HASH(0x555558d03560)') called at /usr/lib/perl5/vendor_perl/5.8.8/x86_64-linux-thread-multi/M odPerl/RegistryCooker.pm line 170
ModPerl::RegistryCooker::default_handler('Bugzilla::ModPerl: :ResponseHandler=HASH(0x555558d03560)') called at /usr/lib/perl5/vendor_perl/5.8.8/x86_64-linux-thread-multi/M odPerl/Registry.pm line 31
ModPerl::Registry::handler('Bugzilla::ModPerl::ResponseHandl er', 'Apache2::RequestRec=SCALAR(0x55555868e570)') called at /home/data/httpd/bugs.eclipse.org/html/bugzilla-2.20/mod_per l.pl line 96
Bugzilla::ModPerl::ResponseHandler::handler('Bugzilla::ModPe rl::ResponseHandler', 'Apache2::RequestRec=SCALAR(0x55555868e570)') called at -e line 0
eval {...} called at -e line 0
FUDForum. Page generated in 0.02936 seconds
