Home » Modeling » EMF » validating xml file against its schema?
validating xml file against its schema? [message #388329] |
Wed, 06 October 2004 01:38 |
Originally posted by: jiehu.ca.ibm.com
Does EMF validate the xml file against its schema? I have created an EMF
model for a schema, and want to load an xml file for that schema into the
model. I want the xml file be validated against its schema so that user can
get meaningful error message. Does EMF has this ability? I know JAXB has.
Jie
Re: validating xml file against its schema? [message #388366 is a reply to message #388335] |
Thu, 07 October 2004 20:44 |
Thanks for your answer. But I cannot find XMLResource.OPTION_PARSER_POOL.
I am having a problem with loading the xml file. In the xsd file, I had
element name defined starting with upper case, so does the xml file.
However, when load the xml file, EMF complained that it cannot find the
feature. If I change to lower case in the xml file, then it worked. But the
xml file is not valid for the schema anymore.
For example,
xml file like this won't work.
<BusinessItem id="BI001" name="BI1">
<Description>This is description of BI1</Description>
</BusinessItem>
but change to this worked.
<businessItem id="BI001" name="BI1">
<description>This is description of BI1</description>
</businessItem>
Any idea?
thanks,
Jie
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:ck0jdb$ah4$1@eclipse.org...
> Jie,
> You should be sure to look in Resource.getErrors after loading to detect
> basic parser errors, and you can use
> org.eclipse.emf.ecore.util.Diagnostician.INSTANCE.valid(EObj ect) to
> validate a tree of objects against the constraints defined for them at
> any time, including right after loading. It's also possible to use
> XMLResource.OPTION_PARSER_POOL to create a parser that knows about your
> schema and does the normal validation while parsing an instance. This
> will ensure 100% schema validity whereas EMF validation will only
> provide an approximation.
> Jie Hu wrote:
> >Hi,
can
has.
> >Thanks,
> >Jie
Re: validating xml file against its schema? [message #388367 is a reply to message #388366] |
Thu, 07 October 2004 20:52 |
Ed Merks Messages: 33216 Registered: July 2009 |
--------------060904050307020406050508
Jie,
Typo, I meant OPTION_USE_PARSER_POOL.
It sounds like you aren't using the generated resource factory to create
your resource and hence aren't using option
XMLResource.OPTION_EXTENDED_META_DATA which is needed in order to
respect the original schema's names.
>For example,
></BusinessItem>
></businessItem>
>Any idea?
>thanks,
>Jie
>>Jie,
>>Jie Hu wrote:
>>>Hi,
>can
>has.
>>>Thanks,
>>>Jie
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
<title></title>
</head>
Jie,<br>
<br>
Typo, I meant OPTION_USE_PARSER_POOL. <br>
<br>
create your resource and hence aren't using option
respect the original schema's names.<br>
<br>
<br>
Jie Hu wrote:
<blockquote cite="midck49j6$92n$1@eclipse.org" type="cite">
<pre wrap="">Thanks for your answer. But I cannot find XMLResource.OPTION_PARSER_POOL.
For example,
</BusinessItem>
</businessItem>
Any idea?
thanks,
Jie
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com"><merks@ca.ibm.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:ck0jdb$ah4$1@eclipse.org">news:ck0jdb$ah4$1@eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Jie,
Jie Hu wrote:
</pre>
<pre wrap="">Hi,
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->can
</pre>
<pre wrap="">get meaningful error message. Does EMF has this ability? I know JAXB
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->has.
</pre>
<pre wrap="">Thanks,
Jie
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
--------------060904050307020406050508--
Ed Merks
Re: validating xml file against its schema? [message #388643 is a reply to message #388367] |
Sat, 16 October 2004 02:47 |
------=_NextPart_000_000C_01C4B308.EC5BB580
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Thanks for your answer. I still cannot found the OPTION_USE_PARSER_POOL. =
Forgot to metion, I am using emf 1.1.1.
For the other schema's name problem, you are correct, I wasn't use the =
generated resource factory. After correct that, it fixed that problem.
"Ed Merks" <merks@ca.ibm.com> wrote in message =
news:ck4a09$9s7$1@eclipse.org...
Jie,
Typo, I meant OPTION_USE_PARSER_POOL. =20
It sounds like you aren't using the generated resource factory to =
create your resource and hence aren't using option =
XMLResource.OPTION_EXTENDED_META_DATA which is needed in order to =
Jie Hu wrote:=20
Thanks for your answer. But I cannot find =
feature. If I change to lower case in the xml file, then it worked. But =
the
For example,
<BusinessItem id=3D"BI001" name=3D"BI1">
</BusinessItem>
<businessItem id=3D"BI001" name=3D"BI1">
</businessItem>
Any idea?
thanks,
Jie
Jie,
model for a schema, and want to load an xml file for that schema into =
the
can
has.
Jie
=20
=20
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD><TITLE></TITLE>
<META http-equiv=3DContent-Type =
content=3Dtext/html;charset=3DISO-8859-1>
<META content=3D"MSHTML 6.00.2800.1458" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY text=3D#000000 bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Thanks for your answer. I still cannot =
found the=20
OPTION_USE_PARSER_POOL. Forgot to metion, I am using emf=20
1.1.1.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>For the other schema's name problem, =
you are=20
correct, I wasn't use the generated resource factory. After correct =
that, it=20
fixed that problem.</FONT></DIV>
<BLOCKQUOTE=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Ed Merks" <<A =
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>>=20
wrote in message <A=20
href=3D"news:ck4a09$9s7$1@eclipse.org">news:ck4a09$9s7$1@eclipse.org</A>.=
...</DIV>Jie,<BR><BR>Typo,=20
I meant OPTION_USE_PARSER_POOL. <BR><BR>It sounds like you =
aren't using=20
the generated resource factory to create your resource and hence =
aren't using=20
option XMLResource.OPTION_EXTENDED_META_DATA which is needed in order =
to=20
respect the original schema's names.<BR><BR><BR>Jie Hu wrote:=20
<BLOCKQUOTE cite=3Dmidck49j6$92n$1@eclipse.org type=3D"cite"><PRE =
wrap=3D"">Thanks for your answer. But I cannot find =
the
For example,
</BusinessItem>
</businessItem>
Any idea?
thanks,
Jie
"Ed Merks" <A class=3Dmoz-txt-link-rfc2396E =
href=3D"mailto:merks@ca.ibm.com"><merks@ca.ibm.com></A> wrote in =
message
<A class=3Dmoz-txt-link-freetext =
href=3D"news:ck0jdb$ah4$1@eclipse.org">news:ck0jdb$ah4$1@eclipse.org</A>.=
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Jie,
Jie Hu wrote:
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Hi,
the
</PRE></BLOCKQUOTE></BLOCKQUOTE><PRE wrap=3D""><!---->can
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">get meaningful error =
</PRE></BLOCKQUOTE></BLOCKQUOTE><PRE wrap=3D""><!---->has.
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Thanks,
Jie
</PRE></BLOCKQUOTE><BR></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_000C_01C4B308.EC5BB580--
Re: validating xml file against its schema? [message #388645 is a reply to message #388643] |
Sat, 16 October 2004 11:48 |
--------------000309000905020209080205
Jie,
Since it was introduced in 2.0.0, that's not surprising.
> OPTION_USE_PARSER_POOL. Forgot to metion, I am using emf 1.1.1.
> "Ed Merks" <merks@ca.ibm.com <mailto:merks@ca.ibm.com>> wrote in
> message news:ck4a09$9s7$1@eclipse.org...
> Jie,
>>For example,
>></BusinessItem>
>></businessItem>
>>Any idea?
>>thanks,
>>Jie
>>>Jie,
>>>Jie Hu wrote:
>>>>Hi,
>>can
>>has.
>>>>Thanks,
>>>>Jie
<html>
<head>
<title></title>
</head>
Jie,<br>
<br>
Since it was introduced in 2.0.0, that's not surprising.<br>
<br>
<br>
Jie Hu wrote:
<blockquote cite="midckq1pk$pn4$1@eclipse.org" type="cite">
<title></title>
<meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-1">
<meta content="MSHTML 6.00.2800.1458" name="GENERATOR">
<style></style>
<div><font face="Arial" size="2">Thanks for your answer. I still
cannot found the OPTION_USE_PARSER_POOL. Forgot to metion, I am using
emf 1.1.1.</font></div>
<div><font face="Arial" size="2">For the other schema's name problem,
you are correct, I wasn't use the generated resource factory. After
correct that, it fixed that problem.</font></div>
<blockquote
style="border-left: 2px solid rgb(0, 0, 0); padding-right: 0px; padding-left: 5px; margin-left: 5px; margin-right: 0px;">
<div>"Ed Merks" <<a href="mailto:merks@ca.ibm.com">merks@ca.ibm.com</a>>
wrote in message <a href="news:ck4a09$9s7$1@eclipse.org">news:ck4a09$9s7$1@eclipse.org</a>...</div>
Jie,<br>
<br>
<br>
<br>
<br>
For example,
</BusinessItem>
</businessItem>
Any idea?
thanks,
Jie
</pre>
<pre wrap="">Jie,
Jie Hu wrote:
</pre>
<pre wrap="">Hi,
</pre>
</blockquote>
</blockquote>
</pre>
</pre>
</blockquote>
</blockquote>
</pre>
Jie
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------000309000905020209080205--
Ed Merks
Current Time: Wed Sep 18 23:39:48 GMT 2024
Powered by FUDForum. Page generated in 0.03774 seconds
