Home » Archived » Buckminster » searchPath gets ignored
searchPath gets ignored [message #387334] Tue, 30 June 2009 14:58 Go to next message
Originally posted by: news.eclipse.org.08.lemmster.de
with the Galileo Buckminster release it looks like that the searchPath
set in ECF's RMAP [1] gets ignored. Apparently Buckminster designates
the version range for o.e.ecf.filetransfer to what is set in
o.e.platform feature, but obviously we want to build ecf.* from HEAD.
How can I configure bm to ignore the platform feature (or at least the
ECF portion)?
Markus
[1]
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.ecf/rel eng/org.eclipse.ecf.releng.bm/ecf.rmap?revision=1.19&roo t=RT_Project&view=markup
----- cut -----
[java] ERROR [0043] : No suitable provider for component
org.eclipse.ecf.provider.filetransfer:osgi.bundle/[3.0.0.v20 090604-1131,3.0.0.v20090604-1131]#OSGi
was found in resourceMap file:/opt/hudson/jobs/N-HEAD-ECF/workspace/ecf.rmap
was found in searchPath org.eclipse.ecf
[java] ERROR [0043] : Version 3.0.0.qualifier rejected: Not
designated by [3.0.0.v20090604-1131,3.0.0.v20090604-1131]
org.eclipse.ecf.provider.filetransfer.httpclient:osgi.bundle /[3.0.0.v20090604-1131,3.0.0.v20090604-1131]#OSGi
org.eclipse.ecf.identity:osgi.bundle/[3.0.0.v20090604-1131,3 .0.0.v20090604-1131]#OSGi
Re: searchPath gets ignored [message #387335 is a reply to message #387334] Tue, 30 June 2009 17:21 Go to previous messageGo to next message
Hi Markus,
if I got you right, you need to add an advisor node to your cquery that
matches the components you don't want to resolve from the target
platform and reduce the resolution scope for that advisor node.
Hope that helps.
Johannes
Markus Kuppe schrieb:
> ECF portion)?
> Thanks
> Markus
> [1]
> ----- cut -----
Re: searchPath gets ignored [message #387337 is a reply to message #387335] Wed, 01 July 2009 03:46 Go to previous messageGo to next message
Johannes Utzig wrote:
> Hi Markus,
Hi Johannes,
this is how the advisory node looks like.
Markus
<cq:componentQuery
xmlns:cq="http://www.eclipse.org/buckminster/CQuery-1.0"
resourceMap="ecf.rmap">
<!-- this is us -->
<cq:advisorNode namePattern="ch.ethz.iks.*" useTargetPlatform="false"
useWorkspace="false"/>
<cq:advisorNode namePattern="org.eclipse.ecf.*"
useTargetPlatform="false" useWorkspace="false"/>
<cq:advisorNode namePattern="org.eclipse.team.ecf.*"
<cq:advisorNode namePattern="org.jivesoftware.smack"
<!-- the rest we want binary only -->
<cq:advisorNode namePattern=".*" useTargetPlatform="true"
skipComponent="false" mutableLevel="REJECT" sourceLevel="REJECT"/>
</cq:componentQuery>
Re: searchPath gets ignored [message #387338 is a reply to message #387337] Wed, 01 July 2009 04:31 Go to previous messageGo to next message
Hi Markus,
Please note that the namePattern is a regular expression. Instead of writing "org.eclipse.ecf.*" you
should write "org\.eclipse\.ecf\..*"
The '.' is "any character" and '*' is "repeat previous expression 0-n times"
Thomas Hallgren
>> Hi Markus,
> Hi Johannes,
> Markus
> <cq:componentQuery
> <!-- this is us -->
Re: searchPath gets ignored [message #387340 is a reply to message #387338] Wed, 01 July 2009 07:45 Go to previous messageGo to next message
Originally posted by: eclipse-news.lemmster.de
Thomas Hallgren wrote:
> Hi Markus,
> writing "org.eclipse.ecf.*" you should write "org\.eclipse\.ecf\..*"
> times"
Hi Thomas,
I'm pretty sure I got the regex right now, still it uses platform's
feature to designate the versions. Btw. org.eclipse.ecf.core feature
neither includes nor depends on org.eclipse.platform.
Markus
----- cut -----
org.eclipse.ecf:osgi.bundle/[3.0.0.v20090604-1131,3.0.0.v200 90604-1131]#OSGi
org.eclipse.ecf.provider.filetransfer.ssl:osgi.bundle/[1.0.0 .v20090604-1131,1.0.0.v20090604-1131]#OSGi
[java] ERROR [0043] : Version 1.0.0.qualifier rejected: Not
designated by [1.0.0.v20090604-1131,1.0.0.v20090604-1131]
org.eclipse.ecf.ssl:osgi.bundle/[1.0.0.v20090604-1131,1.0.0. v20090604-1131]#OSGi
org.eclipse.ecf.provider.filetransfer.httpclient.ssl:osgi.bu ndle/[1.0.0.v20090604-1131,1.0.0.v20090604-1131]#OSGi
org.eclipse.ecf.filetransfer:osgi.bundle/[3.0.0.v20090604-11 31,3.0.0.v20090604-1131]#OSGi
[java] INFO: TAG-ID 0043 = Query for
org.eclipse.ecf.sdk:eclipse.feature, path:
org.eclipse.ecf.sdk:eclipse.feature$1.2.0.qualifier#OSGi ->
org.eclipse.ecf.core:eclipse.feature$3.0.0.qualifier#OSGi ->
org.eclipse.platform:eclipse.feature$3.5.0.v20090611a-9gEeG1 HFtQcmRThO4O3aR_fqSMvJR2sJ#OSGi
org.eclipse.equinox.p2.user.ui:eclipse.feature$1.1.0.v200906 05-1440-7u6Fb3FbPbJP5MjJjZgifk#OSGi
[java]
Re: searchPath gets ignored [message #387393 is a reply to message #387340] Sat, 04 July 2009 02:18 Go to previous messageGo to next message
Hi Markus,
I'm looking at this but there's no way I can reproduce your problems. It all looks very odd but. Especially the last
printout indicating that the feature should depend on the platform. When trying, I can resolve the org.eclipse.ecf.core
feature without problems so I need some more input from you.
Would it be possible for you to attach the CQUERY and RMAP that you are using to a bugzilla? It might be helpful if you
describe your target platform as well.
Thomas Hallgren
>> Hi Markus,
>> times"
> Hi Thomas,
> Thanks
> Markus
> ----- cut -----
> [java]
Re: searchPath gets ignored [message #387659 is a reply to message #387393] Wed, 08 July 2009 03:50 Go to previous messageGo to next message
> Hi Markus,
> all looks very odd but. Especially the last printout indicating that the
> org.eclipse.ecf.core feature without problems so I need some more input
> from you.
> using to a bugzilla? It might be helpful if you describe your target
> platform as well.
Hi Thomas,
you can view all files via ViewCVS [1].
org.eclipse.buckminster.pde.targetPlatformPath gets set to an empty
directory. Thus bm is supposed to not resolve against its own installation.
Markus
[1]
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.ecf/rel eng/org.eclipse.ecf.releng.bm/?root=RT_Project
Re: searchPath gets ignored [message #387660 is a reply to message #387659] Wed, 08 July 2009 04:00 Go to previous messageGo to next message
Not sure I understand. Resolution is not controlled by the targetPlatformPath. If it's empty, it defaults to it's own
runtime. If I understood correctly before, you are using CQUERY advisor nodes to prevent target platform resolution, right?
- thomas
Re: searchPath gets ignored [message #387661 is a reply to message #387659] Wed, 08 July 2009 04:44 Go to previous messageGo to next message
Hi Markus,
I'm able to reproduce the problem locally now. I'll get back to you on this.
Thomas Hallgren
>> Hi Markus,
>> from you.
>> platform as well.
> Hi Thomas,
> Thanks
> Markus
> [1]
Re: searchPath gets ignored [message #387704 is a reply to message #387340] Wed, 08 July 2009 05:00 Go to previous messageGo to next message
Markus Kuppe wrote:
> Hi Thomas,
This is actually not true. The org.eclipse.ecf.core feature contains a buckminster.cspex with this in it:
<dependencies>
<dependency name="org.eclipse.platform" componentType="eclipse.feature"/>
</dependencies>
and that is probably the source of all evil since the platform feature in turn has explicit dependency to many ecf
components.
Thomas Hallgren
Re: searchPath gets ignored [message #387712 is a reply to message #387704] Wed, 08 July 2009 08:09 Go to previous messageGo to next message
> Markus Kuppe wrote:
>> Hi Thomas,
> <dependencies>
> </dependencies>
> in turn has explicit dependency to many ecf components.
Frag, I completely forgot about the .cpsex file. Without it
materialization works fine now, unfortunately the subsequent PDE build
fails due to missing platform dependencies. IIRC that was exactly the
reason for adding the platform dep via the cspex in the first place.
Markus
[java] init:
[java] generateScript:
[java] [eclipse.buildScript] Some inter-plug-in dependencies have
not been satisfied.
[java] [eclipse.buildScript] Bundle org.eclipse.help.base:
[java] [eclipse.buildScript] Missing required plug-in
org.eclipse.help_[3.3.0,4.0.0).
[java] [eclipse.buildScript] Unsatisfied import package
com.ibm.icu.text_0.0.0.
org.eclipse.equinox.http.jetty_0.0.0.
org.eclipse.ui.workbench.texteditor:
org.eclipse.compare.core_[3.5.0,4.0.0).
org.eclipse.jface.text_[3.5.0,4.0.0).
org.eclipse.ui_[3.5.0,4.0.0).
[java] [eclipse.buildScript] Bundle org.eclipse.equinox.p2.engine:
org.eclipse.equinox.p2.metadata.repository_1.0.100.
org.eclipse.equinox.internal.p2.metadata.repository_0.0.0.
org.eclipse.equinox.internal.p2.metadata.repository.io_0.0.0 .
org.eclipse.equinox.internal.p2.persistence_0.0.0.
org.eclipse.equinox.internal.provisional.p2.artifact.reposit ory_0.0.0.
org.eclipse.equinox.internal.provisional.p2.metadata.reposit ory_0.0.0.
org.eclipse.equinox.internal.provisional.p2.repository_0.0.0 .
org.eclipse.equinox.internal.provisional.spi.p2.metadata.rep ository_0.0.0.
org.eclipse.equinox.internal.provisional.spi.p2.repository_0 .0.0.
[java] [eclipse.buildScript] Bundle org.eclipse.help:
com.ibm.icu.text_3.8.0.
[java] [eclipse.buildScript] Bundle org.eclipse.ui.intro:
org.eclipse.help_[3.4.0,4.0.0).
[java] [eclipse.buildScript] Optional plug-in
org.eclipse.help.base_[3.4.0,4.0.0) is not available.
org.eclipse.ui.forms_[3.4.0,4.0.0).
[java] [eclipse.buildScript] Bundle org.eclipse.ui.navigator:
[java] [eclipse.buildScript] Bundle org.eclipse.ui.navigator.resources:
org.eclipse.ui.ide_[3.2.0,4.0.0).
org.eclipse.ui.navigator_[3.2.1,4.0.0).
org.eclipse.ui.views.properties.tabbed_[3.2.0,4.0.0).
org.eclipse.ui.workbench.texteditor_[3.2.0,4.0.0).
[java] [eclipse.buildScript] Bundle org.eclipse.compare:
org.eclipse.jface.text_[3.3.0,4.0.0).
org.eclipse.ui.ide_[3.3.0,4.0.0).
org.eclipse.ui.views_[3.2.0,4.0.0).
org.eclipse.ui.workbench.texteditor_[3.5.0,4.0.0).
org.eclipse.ui.editors_[3.5.0,4.0.0).
org.eclipse.ui.forms_[3.2.0,4.0.0).
com.ibm.icu.util_0.0.0.
[java] [eclipse.buildScript] Bundle org.eclipse.update.ui:
org.eclipse.ui_[3.2.0,4.0.0).
[java] [eclipse.buildScript] Bundle org.eclipse.ui.ide:
org.eclipse.help_[3.2.0,4.0.0).
org.eclipse.ui.views_[3.2.0,4.0.0) is not available.
org.eclipse.jface.text_[3.2.0,4.0.0).
org.eclipse.ui.forms_[3.3.0,4.0.0) is not available.
org.eclipse.equinox.p2.engine_[1.0.100,2.0.0).
[java] [eclipse.buildScript] Bundle org.eclipse.emf.common.ui:
org.eclipse.ui.ide_[3.5.0,4.0.0) is not available.
[java] [eclipse.buildScript] Bundle org.eclipse.ui.intro.universal:
org.eclipse.ui.intro_[3.3.0,4.0.0).
org.eclipse.ui.views.properties.tabbed:
org.eclipse.ui.forms_[3.3.0,4.0.0).
org.eclipse.ui_[3.3.0,4.0.0).
[java] [eclipse.buildScript] Bundle org.eclipse.core.databinding:
com.ibm.icu.math_0.0.0.
[java] [eclipse.buildScript] Bundle org.eclipse.text:
[java] [eclipse.buildScript] Bundle org.eclipse.ui.editors:
org.eclipse.ui.ide_[3.5.0,4.0.0).
org.eclipse.core.filebuffers_[3.5.0,4.0.0).
[java] [eclipse.buildScript] Bundle org.eclipse.ui.forms:
org.eclipse.ui_[3.5.0,4.0.0) is not available.
[java] [eclipse.buildScript] Bundle org.eclipse.emf.edit.ui:
org.eclipse.ui.views_[3.4.0,4.0.0).
org.eclipse.ui.workbench_[3.5.0,4.0.0).
org.eclipse.emf.common.ui_[2.5.0,3.0.0).
[java] [eclipse.buildScript] Bundle org.eclipse.core.filebuffers:
org.eclipse.text_[3.5.0,4.0.0).
[java] [eclipse.buildScript] Bundle org.eclipse.jface.databinding:
org.eclipse.core.databinding_[1.2.0,2.0.0).
[java] [eclipse.buildScript] Bundle org.eclipse.compare.core:
com.ibm.icu.text_3.6.1.
com.ibm.icu.util_3.6.1.
[java] [eclipse.buildScript] Bundle org.eclipse.ui.workbench:
org.eclipse.jface.databinding_[1.1.0,2.0.0).
[java] [eclipse.buildScript] Bundle org.eclipse.ui:
[java] [eclipse.buildScript] Bundle org.eclipse.ui.console:
[java] [eclipse.buildScript] Bundle org.eclipse.team.ui:
org.eclipse.ui.ide_[3.3.0,4.0.0) is not available.
org.eclipse.compare_[3.3.0,4.0.0).
org.eclipse.ui.navigator_[3.3.0,4.0.0).
org.eclipse.ui.navigator.resources_[3.2.0,4.0.0).
org.eclipse.ui.editors_[3.3.0,4.0.0).
[java] [eclipse.buildScript] Bundle org.eclipse.jface.text:
org.eclipse.equinox.p2.metadata.repository:
org.eclipse.equinox.internal.p2.repository_0.0.0.
org.eclipse.equinox.internal.p2.repository.helpers_0.0.0.
[java] [eclipse.buildScript] Bundle org.eclipse.ui.views:
org.eclipse.ecf.discovery.ui.properties:
[java] [eclipse.buildScript] Host plug-in
org.eclipse.ecf.discovery.ui_[3.0.0,4.0.0) has not been found.
[java] [eclipse.buildScript] Bundle org.eclipse.ecf.filetransfer.ui:
org.eclipse.ui_0.0.0.
org.eclipse.ecf.ui_0.0.0.
org.eclipse.jface.text_0.0.0.
org.eclipse.ecf.example.collab.editor:
org.eclipse.ui.ide_0.0.0.
org.eclipse.ui.editors_0.0.0.
[java] [eclipse.buildScript] Bundle org.eclipse.team.ecf.core:
org.eclipse.compare.core_0.0.0.
[java] [eclipse.buildScript] Bundle org.eclipse.ecf.provider.irc.ui:
org.eclipse.ecf.presence.ui_0.0.0.
org.eclipse.ui.workbench.texteditor_0.0.0.
[java] [eclipse.buildScript] Bundle org.eclipse.ecf.provider.xmpp.ui:
org.eclipse.ecf.discovery.ui.browser:
org.eclipse.ecf.discovery.ui_3.0.0.
org.eclipse.ui_3.3.0.
[java] [eclipse.buildScript] Bundle org.eclipse.ecf.telephony.call.ui:
[java] [eclipse.buildScript] Bundle org.eclipse.ecf.provider.ui:
[java] [eclipse.buildScript] Bundle org.eclipse.ecf.provider.msn.ui:
[java] [eclipse.buildScript] Bundle org.eclipse.ecf.ui.capabilities:
[java] [eclipse.buildScript] Bundle org.eclipse.ecf.sync:
[java] [eclipse.buildScript] Bundle org.eclipse.ecf.presence.collab.ui:
org.eclipse.ui.console_0.0.0.
org.eclipse.ecf.examples.remoteservices.client:
org.eclipse.ecf.remoteservice.ui_[3.0.0,4.0.0) has not been found.
[java] [eclipse.buildScript] Bundle org.eclipse.ecf.example.collab:
[java] [eclipse.buildScript] Bundle org.eclipse.ecf.remoteservice.ui:
org.eclipse.ecf.examples.updatesite.client:
org.eclipse.ecf.discovery.ui_0.0.0.
org.eclipse.update.ui_0.0.0.
[java] [eclipse.buildScript] Bundle org.eclipse.ecf.example.clients:
[java] [eclipse.buildScript] Bundle org.eclipse.ecf.docshare:
org.eclipse.ecf.sync_1.0.0.
[java] [eclipse.buildScript] Bundle org.eclipse.ecf.discovery.ui:
org.eclipse.emf.edit.ui_[2.2.0,3.0.0).
[java] [eclipse.buildScript] Bundle org.eclipse.ecf.doc:
org.eclipse.help_0.0.0.
org.eclipse.ui.intro_0.0.0.
org.eclipse.ui.intro.universal_0.0.0.
[java] [eclipse.buildScript] Bundle org.eclipse.team.ecf.ui:
org.eclipse.team.ui_0.0.0.
org.eclipse.compare_0.0.0.
org.eclipse.team.ecf.core_0.0.0.
[java] [eclipse.buildScript] Bundle org.eclipse.ecf.presence.ui:
org.eclipse.ui.forms_0.0.0.
org.eclipse.jface.text.source_0.0.0.
org.eclipse.ui.editors.text_0.0.0.
org.eclipse.ecf.discovery.ui.properties.tabbed:
org.eclipse.ui.views.properties.tabbed_[3.4.0,4.0.0).
[java] [eclipse.buildScript] Bundle org.eclipse.ecf.ui:
org.eclipse.ecf.provider.bittorrent.ui:
org.eclipse.ecf.filetransfer.ui_0.0.0.
[java] BUILD FAILED
[java]
/opt/toolbox/eclipse.org/buckminster/r10382/plugins/org.ecli pse.pde.build_3.5.0.v20090527-1800/scripts/build.xml:35:
The following error occurred while executing this line:
[java]
/opt/toolbox/eclipse.org/buckminster/r10382/plugins/org.ecli pse.pde.build_3.5.0.v20090527-1800/scripts/build.xml:91:
[java]
/opt/toolbox/eclipse.org/buckminster/r10382/plugins/org.ecli pse.pde.build_3.5.0.v20090527-1800/templates/headless-build/ customTargets.xml:12:
[java]
/opt/toolbox/eclipse.org/buckminster/r10382/plugins/org.ecli pse.pde.build_3.5.0.v20090527-1800/templates/headless-build/ allElements.xml:16:
[java]
/opt/toolbox/eclipse.org/buckminster/r10382/plugins/org.ecli pse.pde.build_3.5.0.v20090527-1800/scripts/genericTargets.xm l:106:
Bundle org.eclipse.ecf.doc_0.0.0 failed to resolve.:
Re: searchPath gets ignored [message #387717 is a reply to message #387660] Wed, 08 July 2009 10:51 Go to previous messageGo to next message
>> installation.
> targetPlatformPath. If it's empty, it defaults to it's own runtime. If I
directory and the CQUERY sets useTargetPlatform to true.
But even changing useTargertPlatform to false does not solve any problems.
Markus
Re: searchPath gets ignored [message #387718 is a reply to message #387717] Wed, 08 July 2009 11:10 Go to previous messageGo to next message
>>> installation.
Nope, and the reason for that was that the org.eclipse.platform feature was found using your emf.rmap.
- thomas
Re: searchPath gets ignored [message #387725 is a reply to message #387712] Wed, 08 July 2009 11:20 Go to previous messageGo to next message
Buckminster cannot resolve transitively based on package imports alone. You will need to add the missing bundles to a
top level feature that you resolve. Either that or set up a target platform that contains the missing things. Judging
from the errors here, you don't even have the basic P2 included in the TP.
Thomas Hallgren
> Thanks
> Markus
> [java] init:
> not been satisfied.
> [java] BUILD FAILED
> [java]
> [java]
> [java]
> [java]
> [java]
Re: searchPath gets ignored [message #387728 is a reply to message #387725] Thu, 09 July 2009 05:03 Go to previous messageGo to next message
> You will need to add the missing bundles to a top level feature that you
> missing things. Judging from the errors here, you don't even have the
That's the reason why we decided to depend upon the platform feature
which contains all required bundles + keeps them consistent over time.
If I have to list all bundles separately, this list will probably soon
get out of date.
Thus I will probably file an enhancement request so that BM is capable
of relaxing the version ranges set in a feature (e.g. use platforms
feature but only honor major.minor.micro and not qualifier).
Does this make sense?
Markus
Re: searchPath gets ignored [message #387730 is a reply to message #387728] Thu, 09 July 2009 06:26 Go to previous message
> get out of date.
It makes sense and Buckminster is already capable of doing this. You can override version ranges by using advisor nodes.
But that is just moving the problem since using that would mean that you must keep your CQUERY in sync with the platform
feature.
Another option for you would be to use the source for the org.eclipse.platform feature (appoint the platform CVS and
pick it from there, either by tag or in head). I don't think it's checked in with the version requirements. They are
added when the feature is built.
A third option (that would be my preference) is to populate the target platform with the org.eclipse.platform feature
and then run the resolution as a second step after that. That way, you don't need to reference the platform feature
directly but you would still be sure that the target platform contains everything that you need. It doesn't matter that
it also contains outdated ECF components since your CQUERY ensures that they are resolved using your RMAP.
Thomas Hallgren
Previous Topic:SVN materialization issues in 3.5
Next Topic:How to deal with feature patches
Current Time: Wed Sep 24 06:54:49 EDT 2025
Powered by FUDForum. Page generated in 0.08571 seconds
