Home » Eclipse Projects » EclipseLink » @ManyToOne relation problem
@ManyToOne relation problem [message #387082] Fri, 10 April 2009 10:30 Go to next message
I have a dilemma:
+ I have 2 entities with a ManyToOne relationship and no unique ids
(Embedded ids):
Entity A (date, field1, field2)
Entity B (field1, field2, startDate, endDate)
+ Primary key of Entity B is an embedded id composed by field1, field2,
and startDate.
+ Relationship between EntityA and EntityB
SELECT EntityB.*
FROM EntityA, EntityB
WHERE EntityB.field1 = EntityA.field1
AND EntityB.field2 = EntityA.field2
AND EntityB.startDate <= EntityA.date
AND EntityB.endDate > EntityA.date
It always return an unique row.
=> Is it possible to establish the relationship between EntityA and Entity B
with JPA annotations to fetch EntityA rows or I need to use a JPQL query to
make the join ?
Re: @ManyToOne relation problem [message #387088 is a reply to message #387082] Tue, 14 April 2009 04:15 Go to previous messageGo to next message
Any idea ?
Re: @ManyToOne relation problem [message #387094 is a reply to message #387082] Wed, 15 April 2009 09:32 Go to previous message
JPA only allows relationships to be define using foreign keys
(JoinColumn). However in EclipseLink you can define complex relationships
such as this using the Expression criteria API and a DescriptorCustomizer.
See,
http://wiki.eclipse.org/EclipseLink/Examples/JPA/MappingSele ctionCriteria
James
http://www.nabble.com/EclipseLink---Users-f26658.html
Previous Topic:multiple xml-mappings from fragments?
Next Topic:@Version field does partially update?
Current Time: Fri Sep 26 00:17:40 EDT 2025
Powered by FUDForum. Page generated in 0.03874 seconds
