Re: EMF Tutorial [message #385790 is a reply to message #385789] |
Tue, 01 June 2004 11:01  |
Tom,
You need Eclipse M9 (or a fairly recent M8 integration driver) with the latest EMF.
Tom Stave wrote:
> I have been having some problems with the initial demo for EMF. I'm using
> Eclipse Version 3.0M8 and EMF Version 2.0 Build I200405131028.
> When trying to go through the initial tutorial "Generating an EMF Model" in
> the section "Define the Model Using Annotated Java" I can perform the
> tutorial up until the time I try to create the GenModel.
> After performing the Wizard for creating a Ecore model and GenModel, I see
> the library.ecore and library.genmodel entries listed as they are supposed
> to in Package Explorer but I can't edit them. I receive an error. I've
> included the .log file but the general error is:
> java.lang.NoSuchMethodError:
> org.eclipse.emf.codegen.ecore.genmodel.presentation.GenModel Editor.setPartNa
> me
> I'm assuming I haven't installed something correctly but can't find what it
> is. I've also include my installation as seen by Help->About Eclipse
> Platform->Configuration Details.
> Could someone please point me in the right direction?
> Thanks.
> *** Date: 6/1/04 12:59 AM
> *** System properties:
> awt.toolkit=sun.awt.windows.WToolkit
> catalina.base=/c:/eclipseIDE/V3.0M8/eclipse/plugins/org.ecli pse.tomcat_4.1.30/
> catalina.home=/c:/eclipseIDE/V3.0M8/eclipse/plugins/org.ecli pse.tomcat_4.1.30/
> catalina.useNaming=true
> eclipse.application=org.eclipse.ui.ide.workbench
> eclipse.commands=-os
> win32
> -ws
> win32
> -arch
> x86
> -showsplash
> C:\eclipseIDE\V3.0M8\eclipse\eclipse.exe -showsplash 600
> -exitdata
> C:\eclipseIDE\V3.0M8\eclipse\eclipse.exe -exitdata f0_44
> -vm
> C:\WINDOWS\system32\javaw.exe
> -vmargs
> -cp
> C:\eclipseIDE\V3.0M8\eclipse\startup.jar
> org.eclipse.core.launcher.Main
> eclipse.debug.startupTime=1086061122593
> eclipse.noLazyRegistryCacheLoading=true
> eclipse.product=org.eclipse.platform
> eclipse.vm=C:\WINDOWS\system32\javaw.exe
> eclipse.vmargs=-cp
> eof=eof
> file.encoding=Cp1252
> file.encoding.pkg=sun.io
> file.separator=\
> java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
> java.awt.printerjob=sun.awt.windows.WPrinterJob
> java.class.path=C:\eclipseIDE\V3.0M8\eclipse\startup.jar
> java.class.version=48.0
> java.endorsed.dirs=C:\Program Files\Java\j2re1.4.2_04\lib\endorsed
> java.ext.dirs=C:\Program Files\Java\j2re1.4.2_04\lib\ext
> java.home=C:\Program Files\Java\j2re1.4.2_04
> java.io.tmpdir=C:\DOCUME~1\Tom\LOCALS~1\Temp\
> java.library.path=C:\WINDOWS\system32;.;C:\WINDOWS\System32; C:\WINDOWS;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System3 2\Wbem;C:\Program Files\Common Files\Adaptec Shared\System;C:\PROGRA~1\COMMON~1\AUTODE~1;C:\GNU\mingw-run time-3.3\bin;C:\GNU\msys1.0\bin
> java.naming.factory.initial=org.apache.naming.java.javaURLCo ntextFactory
> java.naming.factory.url.pkgs=org.apache.naming
> java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
> java.runtime.version=1.4.2_04-b05
> java.specification.name=Java Platform API Specification
> java.specification.vendor=Sun Microsystems Inc.
> java.specification.version=1.4
> java.util.prefs.PreferencesFactory=java.util.prefs.WindowsPr eferencesFactory
> java.vendor=Sun Microsystems Inc.
> java.vendor.url=http://java.sun.com/
> java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
> java.version=1.4.2_04
> java.vm.info=mixed mode
> java.vm.name=Java HotSpot(TM) Client VM
> java.vm.specification.name=Java Virtual Machine Specification
> java.vm.specification.vendor=Sun Microsystems Inc.
> java.vm.specification.version=1.0
> java.vm.vendor=Sun Microsystems Inc.
> java.vm.version=1.4.2_04-b05
> line.separator=
> org.osgi.framework.executionenvironment=
> org.osgi.framework.language=en
> org.osgi.framework.os.name=Windows XP
> org.osgi.framework.os.version=5.1
> org.osgi.framework.processor=x86
> org.osgi.framework.vendor=Eclipse
> org.osgi.framework.version=1.2.0
> org.xml.sax.driver=org.apache.crimson.parser.XMLReaderImpl
> os.arch=x86
> os.name=Windows XP
> os.version=5.1
> osgi.arch=x86
> osgi.bundles=org.eclipse.osgi.services, org.eclipse.osgi.util, org.eclipse.core.runtime@2, org.eclipse.update.configurator@3
> osgi.bundlestore=c:\eclipseIDE\V3.0M8\eclipse\configuration\ org.eclipse.osgi\bundles
> osgi.configuration.area=file:c:/eclipseIDE/V3.0M8/eclipse/co nfiguration/
> osgi.framework=file:c:/eclipseIDE/V3.0M8/eclipse/plugins/org .eclipse.osgi_3.0.0/
> osgi.framework.beginningstartlevel=1
> osgi.framework.version=3.0.0
> osgi.frameworkClassPath=core.jar, console.jar, osgi.jar, resolver.jar, defaultAdaptor.jar, eclipseAdaptor.jar
> osgi.install.area=file:c:/eclipseIDE/V3.0M8/eclipse/
> osgi.instance.area=file:C:/eclipseIDE/V3.0M8/eclipse/workspa ce
> osgi.logfile=C:\eclipseIDE\V3.0M8\eclipse\workspace\.metadat a\.log
> osgi.manifest.cache=c:\eclipseIDE\V3.0M8\eclipse\configurati on\org.eclipse.osgi\manifests
> osgi.nl=en_US
> osgi.os=win32
> osgi.splashLocation=c:\eclipseIDE\V3.0M8\eclipse\plugins\org .eclipse.platform_3.0.0\splash.bmp
> osgi.splashPath=platform:/base/plugins/org.eclipse.platform
> osgi.ws=win32
> path.separator=;
> sun.arch.data.model=32
> sun.boot.class.path=C:\Program Files\Java\j2re1.4.2_04\lib\rt.jar;C:\Program Files\Java\j2re1.4.2_04\lib\i18n.jar;C:\Program Files\Java\j2re1.4.2_04\lib\sunrsasign.jar;C:\Program Files\Java\j2re1.4.2_04\lib\jsse.jar;C:\Program Files\Java\j2re1.4.2_04\lib\jce.jar;C:\Program Files\Java\j2re1.4.2_04\lib\charsets.jar;C:\Program Files\Java\j2re1.4.2_04\classes
> sun.boot.library.path=C:\Program Files\Java\j2re1.4.2_04\bin
> sun.cpu.endian=little
> sun.cpu.isalist=pentium i486 i386
> sun.io.unicode.encoding=UnicodeLittle
> sun.java2d.fontpath=
> sun.os.patch.level=Service Pack 1
> user.country=US
> user.dir=C:\eclipseIDE\V3.0M8\eclipse
> user.home=C:\Documents and Settings\Tom
> user.language=en
> user.name=Tom
> user.timezone=America/New_York
> user.variant=
> vendor=Apache Software Foundation
> vendor-url=http://xml.apache.org/xalan-j
> version=2.4.1
> *** Features:
> org.eclipse.cdt (2.0.0) "Not Specified"
> org.eclipse.cdt.make (2.0.0) "org.eclipse.cdt.make"
> org.eclipse.cdt.managedbuilder (2.0.0) "org.eclipse.cdt.managedbuilder"
> org.eclipse.emf (2.0.0) "Eclipse Modeling Framework (EMF)"
> org.eclipse.emf.doc (2.0.0) "EMF Programmers Guide"
> org.eclipse.emf.ecore.sdo (2.0.0) "EMF Service Data Objects (SDO)"
> org.eclipse.emf.ecore.sdo.doc (2.0.0) "EMF Service Data Objects (SDO) Programmers Guide"
> org.eclipse.emf.ecore.sdo.source (2.0.0) "EMF Service Data Objects (SDO) Source"
> org.eclipse.emf.examples (2.0.0) "Examples for Eclipse Modeling Framework (EMF)"
> org.eclipse.emf.sdk (2.0.0) "org.eclipse.emf.sdk"
> org.eclipse.emf.source (2.0.0) "Eclipse Modeling Framework (EMF) Source"
> org.eclipse.jdt (3.0.0) "Eclipse Java Development Tools"
> org.eclipse.jdt.source (3.0.0) "Eclipse Java Development Tools SDK"
> org.eclipse.pde (3.0.0) "Eclipse Plug-in Development Environment"
> org.eclipse.platform (3.0.0) "Eclipse Platform"
> org.eclipse.platform.source (3.0.0) "Eclipse Platform Plug-in Developer Resources"
> org.eclipse.sdk (3.0.0) "Eclipse Project SDK"
> org.eclipse.sdk.examples (3.0.0) "Eclipse SDK Examples"
> org.eclipse.team.extras (3.0.0) "Eclipse FTP and WebDAV Support"
> org.eclipse.xsd (2.0.0) "XML Schema Infoset Model"
> org.eclipse.xsd.doc (2.0.0) "XSD Documentation"
> org.eclipse.xsd.source (2.0.0) "XML Schema Infoset Model Source"
> *** Plug-in Registry:
> org.apache.ant (1.6.1) "Apache Ant"
> org.apache.lucene (1.3.0) "Apache Lucene"
> org.apache.xerces (4.0.13) "Xerces Based XML Parser"
> org.eclipse.ant.core (3.0.0) "Ant Build Tool Core"
> org.eclipse.ant.ui (3.0.0) "Ant UI"
> org.eclipse.cdt (2.0.0) ""
> org.eclipse.cdt.core (2.0.0) ""
> org.eclipse.cdt.debug.core (2.0.0) ""
> org.eclipse.cdt.debug.mi.core (2.0.0) ""
> org.eclipse.cdt.debug.mi.ui (2.0.0) ""
> org.eclipse.cdt.debug.ui (2.0.0) ""
> org.eclipse.cdt.doc.user (2.0.0) ""
> org.eclipse.cdt.launch (2.0.0) ""
> org.eclipse.cdt.make.core (2.0.0) ""
> org.eclipse.cdt.make.ui (2.0.0) ""
> org.eclipse.cdt.managedbuilder.core (2.0.0) ""
> org.eclipse.cdt.managedbuilder.ui (2.0.0) ""
> org.eclipse.cdt.ui (2.0.0) ""
> org.eclipse.compare (3.0.0) "Compare Support"
> org.eclipse.compare.examples (3.0.0) "Compare Example"
> org.eclipse.compare.examples.xml (3.0.0) "XML Compare Support"
> org.eclipse.core.boot (3.0.0) "Core Boot"
> org.eclipse.core.expressions (3.0.0) "Expression Language"
> org.eclipse.core.filebuffers (3.0.0) "File Buffers"
> org.eclipse.core.resources (3.0.0) "Core Resource Management"
> org.eclipse.core.runtime (3.0.0) "Core Runtime"
> org.eclipse.core.runtime.compatibility (3.0.0) "Core Runtime Plug-in Compatibility"
> org.eclipse.core.variables (3.0.0) "Core Variables"
> org.eclipse.debug.core (3.0.0) "Debug Core"
> org.eclipse.debug.ui (3.0.0) "Debug UI"
> org.eclipse.emf.codegen (2.0.0) "EMF Template Code Generator"
> org.eclipse.emf.codegen.ecore (2.0.0) "EMF Ecore Code Generation"
> org.eclipse.emf.codegen.ecore.ui (2.0.0) "EMF Ecore Code Generation UI"
> org.eclipse.emf.codegen.ui (2.0.0) "EMF Template Code Generator UI"
> org.eclipse.emf.common (2.0.0) "EMF Common"
> org.eclipse.emf.common.ui (2.0.0) "EMF Common UI"
> org.eclipse.emf.commonj.sdo (2.0.0) "CommonJ SDO"
> org.eclipse.emf.ecore (2.0.0) "EMF Ecore"
> org.eclipse.emf.ecore.change (2.0.0) "EMF Ecore Change Model"
> org.eclipse.emf.ecore.change.edit (2.0.0) "EMF Ecore Change Edit Support"
> org.eclipse.emf.ecore.edit (2.0.0) "EMF Ecore Edit Support"
> org.eclipse.emf.ecore.editor (2.0.0) "Sample Ecore Editor"
> org.eclipse.emf.ecore.sdo.edit (2.0.0) "EMF Service Data Objects (SDO) Edit Support"
> org.eclipse.emf.ecore.sdo.editor (2.0.0) "EMF Service Data Objects (SDO) Editor"
> org.eclipse.emf.ecore.xmi (2.0.0) "EMF XMI"
> org.eclipse.emf.edit (2.0.0) "EMF Edit"
> org.eclipse.emf.edit.ui (2.0.0) "EMF Edit UI"
> org.eclipse.emf.java (2.0.0) "EMF Java"
> org.eclipse.emf.java.edit (2.0.0) "EMF Java Edit"
> org.eclipse.emf.java.editor (2.0.0) "EMF Java Editor"
> org.eclipse.emf.mapping (2.0.0) "EMF Mapping"
> org.eclipse.emf.mapping.ecore2ecore (2.0.0) "Ecore to Ecore Mapping"
> org.eclipse.emf.mapping.ecore2ecore.editor (2.0.0) "Ecore to Ecore Mapping Editor"
> org.eclipse.emf.mapping.ui (2.0.0) "EMF Mapping UI"
> org.eclipse.emf.mapping.xsd2ecore (2.0.0) "XSD to Ecore Mapping"
> org.eclipse.emf.mapping.xsd2ecore.editor (2.0.0) "XSD to Ecore Mapping Editor"
> org.eclipse.help (3.0.0) "Help System Core"
> org.eclipse.help.appserver (3.0.0) "Help Application Server"
> org.eclipse.help.base (3.0.0) "Help System Base"
> org.eclipse.help.examples.ex1 (3.0.0) "Online Help Sample"
> org.eclipse.help.ide (3.0.0) "Help System IDE"
> org.eclipse.help.ui (3.0.0) "Help System UI"
> org.eclipse.help.webapp (3.0.0) "Help System Webapp"
> org.eclipse.jdt.core (3.0.0) "Java Development Tools Core"
> org.eclipse.jdt.debug (3.0.0) "JDI Debug Model"
> org.eclipse.jdt.debug.ui (3.0.0) "JDI Debug UI"
> org.eclipse.jdt.doc.isv (3.0.0) "Eclipse JDT Plug-in Developer Guide"
> org.eclipse.jdt.doc.user (3.0.0) "Eclipse Java Development User Guide"
> org.eclipse.jdt.junit (3.0.0) "Java Development Tools JUnit support"
> org.eclipse.jdt.junit.runtime (3.0.0) "Java Development Tools JUnit runtime support"
> org.eclipse.jdt.launching (3.0.0) "Java Development Tools Launching Support"
> org.eclipse.jdt.ui (3.0.0) "Java Development Tools UI"
> org.eclipse.jdt.ui.examples.javafamily (3.0.0) "Java Development Tools JavaFamily Example"
> org.eclipse.jdt.ui.examples.projects (3.0.0) "Java Development Tools Example Projects"
> org.eclipse.jface (3.0.0) "JFace"
> org.eclipse.jface.text (3.0.0) "JFace Text"
> org.eclipse.osgi (3.0.0) "OSGi System Bundle"
> org.eclipse.osgi.services (3.0.0) "Eclipse OSGi Services"
> org.eclipse.osgi.util (3.0.0) "Eclipse OSGi Utilities"
> org.eclipse.pde.build (3.0.0) "Plug-in Development Environment Build Support"
> org.eclipse.pde.core (3.0.0) "Plug-in Development Core"
> org.eclipse.pde.doc.user (3.0.0) "Eclipse Plug-in Development User Guide"
> org.eclipse.pde.junit.runtime (3.0.0) "PDE JUnit Plug-in Test"
> org.eclipse.pde.runtime (3.0.0) "Plug-in Development Environment Runtime"
> org.eclipse.pde.source (3.0.0) "Eclipse Plug-in Development Environment Source Code"
> org.eclipse.pde.ui (3.0.0) "Plug-in Development UI"
> org.eclipse.platform.doc.isv (3.0.0) "Eclipse Platform Plug-in Developer Guide"
> org.eclipse.platform.doc.user (3.0.0) "Eclipse Workbench User Guide"
> org.eclipse.sdk.examples.source (3.0.0) "Eclipse Platform Plug-in Developer Resources"
> org.eclipse.search (3.0.0) "Search Support"
> org.eclipse.swt (3.0.0) "Standard Widget Toolkit"
> org.eclipse.swt.examples (3.0.0) "SWT Standalone Examples Plugin"
> org.eclipse.swt.examples.browser (3.0.0) "SWT Browser Example Plugin"
> org.eclipse.swt.examples.controls (3.0.0) "SWT Controls Example Plugin"
> org.eclipse.swt.examples.launcher (3.0.0) "SWT Launcher Example Plugin"
> org.eclipse.swt.examples.layouts (3.0.0) "SWT Layout Example Plugin"
> org.eclipse.swt.examples.ole.win32 (3.0.0) "SWT OLE Example Plugin (Win32)"
> org.eclipse.swt.examples.paint (3.0.0) "SWT Paint Example Plugin"
> org.eclipse.team.core (3.0.0) "Team Support Core"
> org.eclipse.team.cvs.core (3.0.0) "CVS Team Provider Core"
> org.eclipse.team.cvs.ssh (3.0.0) "CVS SSH Core"
> org.eclipse.team.cvs.ssh2 (3.0.0) "CVS SSH2"
> org.eclipse.team.cvs.ui (3.0.0) "CVS Team Provider UI"
> org.eclipse.team.examples.filesystem (3.0.0) "Eclipse Team File System Example"
> org.eclipse.team.extras.source (3.0.0) "Eclipse Team Extras Plug-in Developer Resources"
> org.eclipse.team.ftp (3.0.0) "FTP Deployment Provider"
> org.eclipse.team.ui (3.0.0) "Team Support UI"
> org.eclipse.team.webdav (3.0.0) "WebDAV Team Provider"
> org.eclipse.text (3.0.0) "Text"
> org.eclipse.tomcat (4.1.30) "Tomcat Wrapper"
> org.eclipse.ui (3.0.0) "Eclipse UI"
> org.eclipse.ui.cheatsheets (3.0.0) "Cheat Sheets"
> org.eclipse.ui.console (3.0.0) "Console"
> org.eclipse.ui.editors (3.0.0) "Default Text Editor"
> org.eclipse.ui.examples.javaeditor (3.0.0) "JFace Text Example"
> org.eclipse.ui.examples.multipageeditor (2.1.0) "Multi-Page Editor Example"
> org.eclipse.ui.examples.propertysheet (2.1.0) "User File Editor"
> org.eclipse.ui.examples.readmetool (2.1.0) "Readme File Editing Tool"
> org.eclipse.ui.externaltools (3.0.0) "External Tools"
> org.eclipse.ui.forms (3.0.0) "Eclipse Forms"
> org.eclipse.ui.ide (3.0.0) "Eclipse IDE UI"
> org.eclipse.ui.intro (3.0.0) "Intro Plugin"
> org.eclipse.ui.versioncheck (3.0.0) "Eclipse Version Check"
> org.eclipse.ui.views (3.0.0) "Views"
> org.eclipse.ui.workbench (3.0.0) "Workbench"
> org.eclipse.ui.workbench.texteditor (3.0.0) "Text Editor Framework"
> org.eclipse.update.configurator (3.0.0) "Install/Update Configurator"
> org.eclipse.update.core (3.0.0) "Install/Update Core"
> org.eclipse.update.scheduler (3.0.0) "Automatic Updates Scheduler"
> org.eclipse.update.ui (3.0.0) "Install/Update UI"
> org.eclipse.update.ui.forms (3.0.0) "Install/Update Forms"
> org.eclipse.webdav (3.0.0) "WebDAV Client"
> org.eclipse.xsd.edit (2.0.0) "XML Schema Edit Framework"
> org.eclipse.xsd.editor (2.0.0) "XML Schema Editor"
> org.eclipse.xsd.test (2.0.0) "XML Schema Infoset Model Test"
> org.junit (3.8.1) "JUnit Testing Framework"
> *** User Preferences:
> #Tue Jun 01 00:59:27 EDT 2004
> /instance/org.eclipse.ui.workbench/resourcetypes=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<editors>\r\n<info name\="*" extension\="xsd2ecore">\r\n<editor id\=" org.eclipse.emf.mapping.xsd2ecore.presentation.XSD2EcoreEdit orID "/>\r\n</info>\r\n<info name\="*" extension\="jpage">\r\n<editor id\="org.eclipse.jdt.debug.ui.SnippetEditor"/>\r\n</info >\r\n<info name\="*" extension\="mk">\r\n<editor id\="org.eclipse.ui.DefaultTextEditor"/>\r\n</info>\r\n <info name\="delta" extension\="properties">\r\n<editor id\="org.eclipse.pde.ui.buildEditor"/>\r\n</info>\r\n<info name\="build" extension\="properties">\r\n<editor id\="org.eclipse.pde.ui.buildEditor"/>\r\n</info>\r\n<info name\="*" extension\="datagraph">\r\n<editor id\="org.eclipse.emf.ecore.sdo.presentation.SDOEditorID"/>\r\n </info>\r\n<info name\="*" extension\="xmi">\r\n<editor id\="org.eclipse.emf.ecore.presentation.ReflectiveEditorID"/ >\r\n</info>\r\n<info name\="*" extension\="ent">\r\n<editor id\="org.eclipse.ant.ui.internal.editor.AntEditor"/>\r\n</info >\r\n<info name\="*" extension\="readme">\r\n<editor id\="org.eclipse.ui.examples.readmetool.ReadmeEditor"/>\r\n </info>\r\n<info name\="*" extension\="jardesc">\r\n<editor id\="org.eclipse.jdt.ui.JARDescEditor"/>\r\n</info>\r\n <info name\="*" extension\="hpp">\r\n<editor id\="org.eclipse.cdt.ui.editor.CEditor"/>\r\n</info>\r\n <info name\="*" extension\="cxx">\r\n<editor id\="org.eclipse.cdt.ui.editor.CEditor"/>\r\n</info>\r\n <info name\="*" extension\="java">\r\n<editor id\="org.eclipse.jdt.ui.CompilationUnitEditor"/>\r\n</info >\r\n<info name\="feature" extension\="xml">\r\n<editor id\="org.eclipse.pde.ui.featureEditor"/>\r\n</info>\r\n <info name\="*" extension\="jav">\r\n<editor id\="org.eclipse.ui.JavaEditor"/>\r\n</info>\r\n<info name\="*" extension\="cc">\r\n<editor id\="org.eclipse.cdt.ui.editor.CEditor"/>\r\n</info>\r\n <info name\="Makefile" extension\="">\r\n<editor id\="org.eclipse.cdt.make.editor"/>\r\n<editor id\="org.eclipse.cdt.make.editor"/>\r\n</info>\r\n<info name\="*" extension\="cpp">\r\n<editor id\="org.eclipse.cdt.ui.editor.CEditor"/>\r\n</info>\r\n <info name\="*" extension\="class">\r\n<editor id\="org.eclipse.jdt.ui.ClassFileEditor"/>\r\n</info>\r\n <info name\="*" extension\="mxsd">\r\n<editor id\="org.eclipse.pde.ui.schemaEditor"/>\r\n</info>\r\n<info name\="*" extension\="genmodel">\r\n<editor id\=" org.eclipse.emf.codegen.ecore.genmodel.presentation.GenModel EditorID "/>\r\n</info>\r\n<info name\="*" extension\="exsd">\r\n<editor id\="org.eclipse.pde.ui.schemaEditor"/>\r\n</info>\r\n<info name\="*" extension\="ecore">\r\n<editor id\="org.eclipse.emf.ecore.presentation.EcoreEditorID"/>\r\n </info>\r\n<info name\="*" extension\="macrodef">\r\n<editor id\="org.eclipse.ant.ui.internal.editor.AntEditor"/>\r\n</info >\r\n<info name\="sample" extension\="properties">\r\n<editor id\="org.eclipse.pde.ui.sampleEditor"/>\r\n</info>\r\n<info name\="*" extension\="s">\r\n<editor id\="org.eclipse.cdt.ui.editor.asm.AsmEditor"/>\r\n</info >\r\n<info name\="plugin" extension\="xml">\r\n<editor id\="org.eclipse.pde.ui.manifestEditor"/>\r\n</info>\r\n <info name\="*" extension\="jsp">\r\n<editor id\="org.eclipse.jdt.ui.examples.JSPEditor"/>\r\n</info>\r\n <info name\="build" extension\="xml">\r\n<editor id\="org.eclipse.ant.ui.internal.editor.AntEditor"/>\r\n</info >\r\n<info name\="*" extension\="properties">\r\n<editor id\="org.eclipse.jdt.ui.DefaultTextEditor"/>\r\n</info>\r\n <info name\="site" extension\="xml">\r\n<editor id\="org.eclipse.pde.ui.siteEditor"/>\r\n</info>\r\n<info name\="*" extension\="txt">\r\n<editor id\="org.eclipse.ui.DefaultTextEditor"/>\r\n</info>\r\n <info name\="fragment" extension\="xml">\r\n<editor id\="org.eclipse.pde.ui.fragmentEditor"/>\r\n</info>\r\n <info name\="*" extension\="mpe">\r\n<editor id\=" org.eclipse.ui.examples.multipageeditor.MultiPageEditorExamp le "/>\r\n</info>\r\n<info name\="*" extension\="ecore2ecore">\r\n<editor id\=" org.eclipse.emf.mapping.ecore2ecore.presentation.Ecore2Ecore EditorID "/>\r\n</info>\r\n<info name\="*" extension\="c">\r\n<editor id\="org.eclipse.cdt.ui.editor.CEditor"/>\r\n</info>\r\n <info name\="*" extension\="xml">\r\n<editor id\=" org.eclipse.ui.examples.templateeditor.editors.TemplateEdito r "/>\r\n</info>\r\n<info name\="*" extension\="h">\r\n<editor id\="org.eclipse.cdt.ui.editor.CEditor"/>\r\n</info>\r\n <info name\="*" extension\="hh">\r\n<editor id\="org.eclipse.cdt.ui.editor.CEditor"/>\r\n</info>\r\n <info name\="*" extension\="usr">\r\n<editor id\="org.eclipse.ui.examples.propertysheet.UserEditor"/>\r\n </info>\r\n<info name\="*" extension\="xsd">\r\n<editor id\="org.eclipse.xsd.presentation.XSDEditorID"/>\r\n</info >\r\n<info name\="*" extension\="dasm">\r\n<editor id\="org.eclipse.cdt.debug.ui.DisassemblyEditor"/>\r\n</info >\r\n<info name\="*" extension\="emof">\r\n<editor id\="org.eclipse.emf.ecore.presentation.EcoreEditorID"/>\r\n </info>\r\n</editors>\r\n
> /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hContainer.library|org.eclipse.jdt.launching.JRE_CONTAINER= <?xml version\="1.0" encoding\="UTF-8"?>\r\n<classpath>\r\n<classpathentry kind\="lib" path\="C\:/Program Files/Java/j2re1.4.2_04/lib/rt.jar"/>\r\n<classpathentry kind\="lib" path\="C\:/Program Files/Java/j2re1.4.2_04/lib/sunrsasign.jar"/>\r\n<classpathentry kind\="lib" path\="C\:/Program Files/Java/j2re1.4.2_04/lib/jsse.jar"/>\r\n<classpathentry kind\="lib" path\="C\:/Program Files/Java/j2re1.4.2_04/lib/jce.jar"/>\r\n<classpathentry kind\="lib" path\="C\:/Program Files/Java/j2re1.4.2_04/lib/charsets.jar"/>\r\n<classpathentry kind\="lib" path\="C\:/Program Files/Java/j2re1.4.2_04/lib/ext/dnsns.jar"/>\r\n<classpathentry kind\="lib" path\="C\:/Program Files/Java/j2re1.4.2_04/lib/ext/ldapsec.jar"/>\r\n<classpathentry kind\="lib" path\="C\:/Program Files/Java/j2re1.4.2_04/lib/ext/localedata.jar"/>\r\n<classpathentry kind\="lib" path\="C\:/Program Files/Java/j2re1.4.2_04/lib/ext/sunjce_provider.jar"/>\r\n </classpath>\r\n
> /instance/org.eclipse.team.cvs.core/repositories/%pserver%anonymous@dev.eclipse.org%%home%eclipse/location=\:pserver\:anonymous@dev.eclipse.org\:/home/eclipse
> /instance/org.eclipse.jdt.ui/org.eclipse.jface.textfont=1|Co urier New|10|0|WINDOWS|1|0|0|0|0|0|0|0|0|1|0|0|0|0|Courier New;
> /instance/org.eclipse.ui.workbench/editors=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<editors>\r\n<descriptor label\="XSD to Ecore Model Editor" image\="icons/full/obj16/XSD2EcoreModelFile.gif" class\=" org.eclipse.emf.mapping.xsd2ecore.presentation.XSD2EcoreEdit or " id\=" org.eclipse.emf.mapping.xsd2ecore.presentation.XSD2EcoreEdit orID " plugin\="org.eclipse.emf.mapping.xsd2ecore.editor" openMode\="1" internal\="true" open_in_place\="false"/>\r\n<descriptor label\="Scrapbook" image\="icons/full/obj16/jsbook_obj.gif" class\=" org.eclipse.jdt.internal.debug.ui.snippeteditor.JavaSnippetE ditor " id\="org.eclipse.jdt.debug.ui.SnippetEditor" plugin\="org.eclipse.jdt.debug.ui" openMode\="1" internal\="true" open_in_place\="false"/>\r\n<descriptor label\="Default Text Editor" image\="icons/full/obj16/file_obj.gif" class\="org.eclipse.ui.editors.text.TextEditor" id\="org.eclipse.ui.DefaultTextEditor" plugin\="org.eclipse.cdt.ui" openMode\="1" internal\="true" open_in_place\="false"/>\r\n<descriptor label\="Build Properties Editor" image\="icons/obj16/build_exec.gif" class\=" org.eclipse.pde.internal.ui.editor.build.BuildPropertiesEdit or " id\="org.eclipse.pde.ui.buildEditor" plugin\="org.eclipse.pde.ui" openMode\="1" internal\="true" open_in_place\="false"/>\r\n<descriptor label\="Data Graph Editor" image\="icons/full/obj16/SDOModelFile.gif" class\="org.eclipse.emf.ecore.sdo.presentation.SDOEditor" id\="org.eclipse.emf.ecore.sdo.presentation.SDOEditorID" plugin\="org.eclipse.emf.ecore.sdo.editor" openMode\="1" internal\="true" open_in_place\="false"/>\r\n<descriptor label\="Sample Reflective Ecore Model Editor" image\=" platform\:/plugin/org.eclipse.emf.edit/icons/full/obj16/Mode lFile.gif " class\="org.eclipse.emf.ecore.presentation.EcoreEditor" id\="org.eclipse.emf.ecore.presentation.ReflectiveEditorID" plugin\="org.eclipse.emf.ecore.editor" openMode\="1" internal\="true" open_in_place\="false"/>\r\n<descriptor label\="Ant Editor" image\="icons/full/obj16/ant_buildfile.gif" class\="org.eclipse.ant.internal.ui.editor.AntEditor" id\="org.eclipse.ant.ui.internal.editor.AntEditor" plugin\="org.eclipse.ant.ui" openMode\="1" internal\="true" open_in_place\="false"/>\r\n<descriptor label\="&Readme File Editor" image\="icons/obj16/editor.gif" class\="org.eclipse.ui.examples.readmetool.ReadmeEditor" id\="org.eclipse.ui.examples.readmetool.ReadmeEditor" plugin\="org.eclipse.ui.examples.readmetool" openMode\="1" internal\="true" open_in_place\="false"/>\r\n<descriptor label\="JAR Description Editor" image\="icons/full/obj16/jar_desc_obj.gif" class\="org.eclipse.ui.editors.text.TextEditor" id\="org.eclipse.jdt.ui.JARDescEditor" plugin\="org.eclipse.jdt.ui" openMode\="1" internal\="true" open_in_place\="false"/>\r\n<descriptor label\="C Editor" image\="icons/full/obj16/h_file_obj.gif" class\="org.eclipse.cdt.internal.ui.editor.CEditor" id\="org.eclipse.cdt.ui.editor.CEditor" plugin\="org.eclipse.cdt.ui" openMode\="1" internal\="true" open_in_place\="false"/>\r\n<descriptor label\="C Editor" image\="icons/full/obj16/c_file_obj.gif" class\="org.eclipse.cdt.internal.ui.editor.CEditor" id\="org.eclipse.cdt.ui.editor.CEditor" plugin\="org.eclipse.cdt.ui" openMode\="1" internal\="true" open_in_place\="false"/>\r\n<descriptor label\="Java Editor" image\="icons/full/obj16/jcu_obj.gif" class\=" org.eclipse.jdt.internal.ui.javaeditor.CompilationUnitEditor " id\="org.eclipse.jdt.ui.CompilationUnitEditor" plugin\="org.eclipse.jdt.ui" openMode\="1" internal\="true" open_in_place\="false"/>\r\n<descriptor label\="Feature Manifest Editor" image\="icons/obj16/ftr_xml_obj.gif" class\="org.eclipse.pde.internal.ui.editor.feature.FeatureEditor " id\="org.eclipse.pde.ui.featureEditor" plugin\="org.eclipse.pde.ui" openMode\="1" internal\="true" open_in_place\="false"/>\r\n<descriptor label\="Example Java Editor" image\="icons/obj16/java.gif" class\="org.eclipse.ui.examples.javaeditor.JavaEditor" id\="org.eclipse.ui.JavaEditor" plugin\="org.eclipse.ui.examples.javaeditor" openMode\="1" internal\="true" open_in_place\="false"/>\r\n<descriptor label\="Makefile Editor" image\="icons/ctool16/makefile.gif" class\="org.eclipse.cdt.make.internal.ui.editor.MakefileEditor " id\="org.eclipse.cdt.make.editor" plugin\="org.eclipse.cdt.make.ui" openMode\="1" internal\="true" open_in_place\="false"/>\r\n<descriptor label\="Class File Viewer" image\="icons/full/obj16/classf_obj.gif" class\="org.eclipse.jdt.internal.ui.javaeditor.ClassFileEditor " id\="org.eclipse.jdt.ui.ClassFileEditor" plugin\="org.eclipse.jdt.ui" openMode\="1" internal\="true" open_in_place\="false"/>\r\n<descriptor label\="Extension Point Schema Editor" image\="icons/obj16/schema_obj.gif" class\="org.eclipse.pde.internal.ui.editor.schema.SchemaEditor " id\="org.eclipse.pde.ui.schemaEditor" plugin\="org.eclipse.pde.ui" openMode\="1" internal\="true" open_in_place\="false"/>\r\n<descriptor label\="EMF Generator" image\="icons/full/obj16/GenModelModelFile.gif" class\=" org.eclipse.emf.codegen.ecore.genmodel.presentation.GenModel Editor " id\=" org.eclipse.emf.codegen.ecore.genmodel.presentation.GenModel EditorID " plugin\="org.eclipse.emf.codegen.ecore.ui" openMode\="1" internal\="true" open_in_place\="false"/>\r\n<descriptor label\="Sample Ecore Model Editor" image\="icons/full/obj16/EcoreModelFile.gif" class\="org.eclipse.emf.ecore.presentation.EcoreEditor" id\="org.eclipse.emf.ecore.presentation.EcoreEditorID" plugin\="org.eclipse.emf.ecore.editor" openMode\="1" internal\="true" open_in_place\="false"/>\r\n<descriptor label\="Code Sample Editor" image\="icons/obj16/build_exec.gif" class\="org.eclipse.pde.ui.internal.samples.SampleEditor" id\="org.eclipse.pde.ui.sampleEditor" plugin\="org.eclipse.pde.ui" openMode\="1" internal\="true" open_in_place\="false"/>\r\n<descriptor label\="Assembly Editor" image\="icons/full/obj16/c_file_obj.gif" class\="org.eclipse.cdt.internal.ui.editor.asm.AsmTextEditor " id\="org.eclipse.cdt.ui.editor.asm.AsmEditor" plugin\="org.eclipse.cdt.ui" openMode\="1" internal\="true" open_in_place\="false"/>\r\n<descriptor label\="Plug-in Manifest Editor" image\="icons/obj16/plugin_mf_obj.gif" class\="org.eclipse.pde.internal.ui.editor.manifest.ManifestEditor " id\="org.eclipse.pde.ui.manifestEditor" plugin\="org.eclipse.pde.ui" openMode\="1" internal\="true" open_in_place\="false"/>\r\n<descriptor label\="JSP Editor" image\="icons/full/obj16/jsp_obj.gif" class\="org.eclipse.jdt.internal.ui.examples.jspeditor.JspEditor " id\="org.eclipse.jdt.ui.examples.JSPEditor" plugin\="org.eclipse.jdt.ui.examples.javafamily" openMode\="1" internal\="true" open_in_place\="false"/>\r\n<descriptor label\="Properties File Editor" image\="icons/full/obj16/file_obj.gif" class\="org.eclipse.ui.editors.text.TextEditor" id\="org.eclipse.jdt.ui.DefaultTextEditor" plugin\="org.eclipse.jdt.ui" openMode\="1" internal\="true" open_in_place\="false"/>\r\n<descriptor label\="Site Manifest Editor" image\="icons/obj16/site_xml_obj.gif" class\="org.eclipse.pde.internal.ui.editor.site.SiteEditor" id\="org.eclipse.pde.ui.siteEditor" plugin\="org.eclipse.pde.ui" openMode\="1" internal\="true" open_in_place\="false"/>\r\n<descriptor label\="Text Editor" image\="icons/full/obj16/file_obj.gif" class\="org.eclipse.ui.editors.text.TextEditor" id\="org.eclipse.ui.DefaultTextEditor" plugin\="org.eclipse.ui.editors" openMode\="1" internal\="true" open_in_place\="false"/>\r\n<descriptor label\="Fragment Manifest Editor" image\="icons/obj16/frgmt_mf_obj.gif" class\=" org.eclipse.pde.internal.ui.editor.manifest.FragmentManifest Editor " id\="org.eclipse.pde.ui.fragmentEditor" plugin\="org.eclipse.pde.ui" openMode\="1" internal\="true" open_in_place\="false"/>\r\n<descriptor label\="Multi-Page Editor Example" image\="icons/copy.gif" class\=" org.eclipse.ui.examples.multipageeditor.MultiPageEditorExamp le " id\=" org.eclipse.ui.examples.multipageeditor.MultiPageEditorExamp le " plugin\="org.eclipse.ui.examples.multipageeditor" openMode\="1" internal\="true" open_in_place\="false"/>\r\n<descriptor label\="Ecore to Ecore Mapping Editor" image\="icons/full/obj16/Ecore2EcoreModelFile.gif" class\=" org.eclipse.emf.mapping.ecore2ecore.presentation.Ecore2Ecore Editor " id\=" org.eclipse.emf.mapping.ecore2ecore.presentation.Ecore2Ecore EditorID " plugin\="org.eclipse.emf.mapping.ecore2ecore.editor" openMode\="1" internal\="true" open_in_place\="false"/>\r\n<descriptor label\="Template Editor" image\="icons/sample.gif" class\=" org.eclipse.ui.examples.templateeditor.editors.TemplateEdito r " id\=" org.eclipse.ui.examples.templateeditor.editors.TemplateEdito r " plugin\="org.eclipse.ui.examples.javaeditor" openMode\="1" internal\="true" open_in_place\="false"/>\r\n<descriptor label\="User File Editor" image\="icons/obj16/usereditor.gif" class\="org.eclipse.ui.examples.propertysheet.UserEditor" id\="org.eclipse.ui.examples.propertysheet.UserEditor" plugin\="org.eclipse.ui.examples.propertysheet" openMode\="1" internal\="true" open_in_place\="false"/>\r\n<descriptor label\="Sample XML Schema Editor" image\="icons/full/obj16/XSDModelFile.gif" class\="org.eclipse.xsd.presentation.XSDEditor" id\="org.eclipse.xsd.presentation.XSDEditorID" plugin\="org.eclipse.xsd.editor" openMode\="1" internal\="true" open_in_place\="false"/>\r\n<descriptor label\="Disassembly Editor" image\="icons/full/obj16/disassembly_obj.gif" class\="org.eclipse.cdt.debug.internal.ui.editors.DisassemblyEditor " id\="org.eclipse.cdt.debug.ui.DisassemblyEditor" plugin\="org.eclipse.cdt.debug.ui" openMode\="1" internal\="true" open_in_place\="false"/>\r\n</editors>\r\n
> /instance/org.eclipse.ui.workbench/ENABLED_DECORATORS=org.ec lipse.pde.ui.binaryProjectDecorator\:false,org.eclipse.team. cvs.ui.decorator\:true,org.eclipse.ui.LinkedResourceDecorato r\:true,
> /instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.typefilter.d isabled=java.awt*;COM*;
> /instance/org.eclipse.ui.ide/INTRO=false
> /instance/org.eclipse.team.cvs.ui/pref_first_startup=false
> /instance/org.eclipse.jdt.launching/org.eclipse.jdt.launchin g.PREF_VM_XML= <?xml version\="1.0" encoding\="UTF-8"?>\r\n<vmSettings defaultVM\=" 57,org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType 1,0 " defaultVMConnector\="">\r\n<vmType id\="org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType ">\r\n<vm id\="0" name\="j2re1.4.2_04" path\="C\:\\Program Files\\Java\\j2re1.4.2_04" javadocURL\="http\://java.sun.com/j2se/1.4.2/docs/api"/>\r\n</vmType>\r\n</vmSettings>\r\n
> /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JRE_SRC=
> /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.builder. resourceCopyExclusionFilter=*.launch
> /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JRE_LIB=C\:/Program Files/Java/j2re1.4.2_04/lib/rt.jar
> /instance/org.eclipse.compare/StructureViewerAliases=CLASSPA TH.XML
> /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JRE_SRCROOT=
> /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JUNIT_HOME=/c\:/eclipseIDE/V3.0M8/eclipse/plugins/ org.junit_3.8.1/
> /instance/org.eclipse.ui.ide/WELCOME_DIALOG=false
> /instance/org.eclipse.debug.ui/org.eclipse.debug.ui.DebugVie w+org.eclipse.debug.ui.debugview.toolbar.toggleAutoManageVie ws=true
> /instance/org.eclipse.ui.workbench/org.eclipse.ui.commands=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<org.eclipse.ui.commands>\r\n<activeKeyConfiguration keyConfigurationId\="org.eclipse.ui.defaultAcceleratorConfiguration "/>\r\n</org.eclipse.ui.commands>\r\n
> /instance/org.eclipse.ui.workbench/UIActivities.org.eclipse. plugInDevelopment=true
> /instance/org.eclipse.jdt.ui/tabWidthPropagated=true
> /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.codeComp lete.visibilityCheck=enabled
> /instance/org.eclipse.debug.ui/org.eclipse.debug.ui.PREF_LAU NCH_PERSPECTIVES= <?xml version\="1.0" encoding\="UTF-8"?>\r\n<launchPerspectives>\r\n<launchPerspective configurationType\="org.eclipse.cdt.launch.localCLaunch" mode\="run" perspective\="org.eclipse.cdt.ui.CPerspective"/>\r\n</launchPerspectives >\r\n
> /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.ECLIPSE_HOME=c\:/eclipseIDE/V3.0M8/eclipse
> /instance/org.eclipse.jdt.ui/fontPropagated=true
> \!/instance=
> file_export_version=3.0
> *** Update Manager Log:
> Configuration=Fri May 28 02:15:18 EDT 2004
> Is current configuration=false
> Configuration=Fri May 28 02:33:14 EDT 2004
> Configuration=Sun May 30 16:08:14 EDT 2004
> Configuration=Sun May 30 20:20:27 EDT 2004
> Configuration=Mon May 31 10:46:12 EDT 2004
> Configuration=Mon May 31 23:38:48 EDT 2004
> Is current configuration=true
> *** Error Log:
> !SESSION May 28, 2004 02:51:31.729 ---------------------------------------------
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> !ENTRY org.eclipse.ui 4 4 May 28, 2004 02:51:31.749
> !MESSAGE Unhandled event loop exception
> !ENTRY org.eclipse.ui 4 0 May 28, 2004 02:51:31.769
> !MESSAGE org.eclipse.emf.codegen.ecore.genmodel.presentation.GenModel Editor.setPartName(Ljava/lang/String;)V
> !STACK 0
> java.lang.NoSuchMethodError: org.eclipse.emf.codegen.ecore.genmodel.presentation.GenModel Editor.setPartName(Ljava/lang/String;)V
> at org.eclipse.emf.codegen.ecore.genmodel.presentation.GenModel Editor.init(GenModelEditor.java:938)
> at org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:569)
> at org.eclipse.ui.internal.EditorManager.openInternalEditor(Edi torManager.java:633)
> at org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:438)
> at org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:426)
> at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2129)
> at org.eclipse.ui.internal.WorkbenchPage.access$6(WorkbenchPage .java:2072)
> at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2059)
> at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:84)
> at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2054)
> at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2037)
> at org.eclipse.emf.codegen.ecore.genmodel.presentation.EMFProje ctWizard.performFinish(EMFProjectWizard.java:703)
> at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:606)
> at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:319)
> at org.eclipse.jface.dialogs.Dialog$1.widgetSelected(Dialog.jav a:413)
> at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:769)
> at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2578)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2256)
> at org.eclipse.jface.window.Window.runEventLoop(Window.java:670 )
> at org.eclipse.jface.window.Window.open(Window.java:650)
> at org.eclipse.ui.actions.NewWizardAction.run(NewWizardAction.j ava:163)
> at org.eclipse.jface.action.Action.runWithEvent(Action.java:881 )
> at org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:550)
> at org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:502)
> at org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:435)
> at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1562)
> at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1536)
> at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:257)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:139)
> at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:90)
> at org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:277)
> at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:239)
> at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:117)
> at org.eclipse.core.launcher.Main.basicRun(Main.java:267)
> at org.eclipse.core.launcher.Main.run(Main.java:692)
> at org.eclipse.core.launcher.Main.main(Main.java:676)
> .log Type: Text Document (application/x-unknown-content-type-txtfile)
> Encoding: x-uuencode
FUDForum. Page generated in 0.03308 seconds
