Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Tablecolumn + icon and TableItem Alignment problems
Tablecolumn + icon and TableItem Alignment problems [message #385544] Wed, 12 November 2003 20:09 Go to next message
First, apologies for the long snippet.
I am having problem with understanding the behaviour of the setAlignment
method on the TableColumn. I can align text in the whole column of a table
quite nicely but am running into problems with I have an image on the
TableColumn as well. Basically it looks as though you can have one or the
other.
I have an example which by default sets the table alightment to SWT.RIGHT
for each column, and also has an image on the tableColumn (appears when you
click on the TableColumn) you will see depending on the order in which
setAlignment and setImage are called, you EITHER get an Image OR correctly
aligned text.
Is this a bug?
public class Main {
static public TableListener listener = new TableListener();
static public Image image = null;
static public Image image2 = null;
static public class TableListener implements SelectionListener
public void widgetDefaultSelected(SelectionEvent arg0) {
// TODO Auto-generated method stub
public void widgetSelected(SelectionEvent arg0)
if(arg0.getSource() instanceof TableColumn)
TableColumn column = (TableColumn)arg0.getSource();
if(column.getImage() == image)
// you can see an image this time
// but text is incorrectly aligned
column.setImage(image2);
else
// text is correctly aligned
// but you cannot see the image!
column.setImage(image);
column.setAlignment(SWT.RIGHT);
public static void main (String [] args) {
Display display = new Display ();
Shell shell = new Shell (display);
image = new Image (display, 20, 20);
Color color = display.getSystemColor (SWT.COLOR_BLUE);
GC gc = new GC (image);
gc.setBackground (color);
gc.fillRectangle (image.getBounds ());
gc.dispose ();
image2 = new Image (display, 20, 20);
Color color2 = display.getSystemColor (SWT.COLOR_RED);
GC gc2 = new GC (image2);
gc2.setBackground (color2);
gc2.fillRectangle (image.getBounds ());
gc2.dispose ();
Table table = new Table (shell, SWT.MULTI | SWT.BORDER |
SWT.FULL_SELECTION);
table.setLinesVisible (true);
table.setHeaderVisible (true);
String[] titles = {" ", "C", "!", "Description", "Resource", "In Folder",
"Location"};
for (int i=0; i<titles.length; i++) {
TableColumn column = new TableColumn (table, SWT.NULL);
column.addSelectionListener(listener);
column.setText (titles [i]);
int count = 128;
for (int i=0; i<count; i++) {
TableItem item = new TableItem (table, SWT.NULL);
item.setText (0, i+"");
item.setText (1, "y");
item.setText (2, "!");
item.setText (3, "this stuff behaves the way I expect");
item.setText (4, "almost everywhere");
item.setText (5, "some.folder");
item.setText (6, "line " + i + " in nowhere");
table.getColumn (i).pack ();
table.setSize (table.computeSize (SWT.DEFAULT, 200));
shell.pack ();
shell.open ();
while (!shell.isDisposed ()) {
if (!display.readAndDispatch ()) display.sleep ();
display.dispose ();
Re: Tablecolumn + icon and TableItem Alignment problems [message #385546 is a reply to message #385544] Wed, 12 November 2003 20:11 Go to previous messageGo to next message
P.S. This is under windows XP with Eclipse 3.0 Build id: 200307181617
"Vadalus" <vadalus@pobox.com> wrote in message
news:boulgh$nn8$1@eclipse.org...
> other.
you
> aligned text.
> Is this a bug?
> Thanks
> public class Main {
> else
> gc.dispose ();
> gc2.dispose ();
> "Location"};
> int count = 128;
> shell.pack ();
> shell.open ();
> display.dispose ();
Re: Tablecolumn + icon and TableItem Alignment problems [message #386040 is a reply to message #385544] Thu, 13 November 2003 08:32 Go to previous messageGo to next message
Tried your example and it seems like a bug. Can you please enter a bug
report against Platform SWT for this? Thank you.
> other.
you
> aligned text.
> Is this a bug?
> Thanks
> public class Main {
> else
> gc.dispose ();
> gc2.dispose ();
> "Location"};
> int count = 128;
> shell.pack ();
> shell.open ();
> display.dispose ();
Re: Tablecolumn + icon and TableItem Alignment problems [message #386121 is a reply to message #385544] Thu, 13 November 2003 12:05 Go to previous messageGo to next message
Fixed > 20031113
> other.
you
> aligned text.
> Is this a bug?
> Thanks
> public class Main {
> else
> gc.dispose ();
> gc2.dispose ();
> "Location"};
> int count = 128;
> shell.pack ();
> shell.open ();
> display.dispose ();
Re: Tablecolumn + icon and TableItem Alignment problems [message #386135 is a reply to message #386121] Thu, 13 November 2003 16:50 Go to previous message
great. thanks.
Liam
"Steve Northover" <steve_northover@ca.ibm.com> wrote in message
news:bp0dhd$h8v$1@eclipse.org...
> Fixed > 20031113
table
the
> > other.
SWT.RIGHT
> you
correctly
> > aligned text.
> > Is this a bug?
> > Thanks
> > public class Main {
> > else
> > gc.dispose ();
> > gc2.dispose ();
Folder",
> > "Location"};
> > int count = 128;
> > shell.pack ();
> > shell.open ();
> > display.dispose ();
Previous Topic:[Ann] Employment Opportunity
Next Topic:grabExcessHorizontalSpace does not work inside ScrolledComposite
Current Time: Tue Oct 28 16:28:47 EDT 2025
Powered by FUDForum. Page generated in 0.06944 seconds
