Home » Eclipse Projects » EclipseLink » ObjectTypeConverter problems
ObjectTypeConverter problems [message #385448] Sat, 07 February 2009 16:34 Go to next message
using EclipseLink 1.0.2, Oracle 10.2
Would anybody know why this converter annotation doesn't work (always
returning false for null values)? The field is a nullable VARCHAR2(1).
The possible values for the field should be "Y" or NULL, mapping to
true, or "N" for false.
@Column(name = "INACTIVE_IND")
@ObjectTypeConverter(
name="booleanConverter_N-false",
dataType=java.lang.String.class,
objectType=java.lang.Boolean.class,
conversionValues={
@ConversionValue(dataValue="N", objectValue="false")
defaultObjectValue="true")
@Convert("booleanConverter_N-false")
private boolean active;
.... while this one (on different entity with the same field definition,
though using 0 for false and 1/NULL for true) does?
name="booleanConverter_0-false",
conversionValues={
@ConversionValue(dataValue="0", objectValue="false")
@Convert("booleanConverter_0-false")
I have several converter annotations working for similar boolean
conversions on other entities, both for null and non-null values. Both
the one that's failing and the one below it operate on materialized
views, so that can't be the problem. The only difference between the
views is that currently all of the "INACTIVE_IND" values for the problem
view are NULL.
If I change the field to use a Boolean type wrapper, I get an NPE for
null values.
I then wrote a Converter impl to do the same thing as a sanity check,
and it works fine:
public class BooleanConverter_N_false
implements Converter
public Object convertDataValueToObjectValue(
Object dataValue,
Session session)
return ((dataValue != null) && dataValue.equals("N")) ?
Boolean.FALSE :
Boolean.TRUE;
public Object convertObjectValueToDataValue(
Object objectValue,
Session session)
return (objectValue == Boolean.FALSE) ?
"N" :
null;
public void initialize(DatabaseMapping mapping, Session session)
public boolean isMutable()
return false;
This Converter impl will get me by fine, but I'm still baffled. Any ideas?
Ari
Re: ObjectTypeConverter problems [message #385449 is a reply to message #385448] Mon, 09 February 2009 10:43 Go to previous messageGo to next message
This is occurring as the ObjectTypeConverter has special handling for null
values.
The defaultObjectValue does not handle null values. But perhaps it should
so feel free to log a bug for this. "defaultObjectValue" is only for if
you have legacy data that has other values than you have set, and want to
default these. The mapping has a nullValue that can be set for the value
for null, but there does not seem to be a way to set this through
annotations (please log a bug), you can set it using a
DescriptorCustomizer.
For null, the converter allows the conversion value for null to be set,
i.e. null=true, but there does not seem to be a way to set null through
annotations, maybe log a bug for this. You can set the conversion for
null in code.
In your converter you must translate each value, so you need to give the
value for "Y"="true", other if you write out true, you will not get "Y" in
the database.
James
http://www.nabble.com/EclipseLink---Users-f26658.html
Re: ObjectTypeConverter problems [message #385452 is a reply to message #385449] Tue, 10 February 2009 17:04 Go to previous messageGo to next message
Thanks a lot James -- restored my sanity. ;-) I confirmed that the one
other case I had with NULL values was one where
defaultObjectValue="false", so it just *happened* to show as correct in
my tests. When I changed it to defaultObjectValue="true" as a test, it
still returned false, confirming that the ObjectTypeConverter is not
handling it.
Regarding my converter code, my client preferred to see NULL for true
rather than "Y", which is why I had it like that (the data objects
happen to be views anyway, so they won't be written to).
I'll log a bug for this, and in the meantime switch to using custom
converters.
It would be nice if the Wiki were updated about this, since it says:
http://wiki.eclipse.org/Using_EclipseLink_JPA_Extensions_(ELUG)#How_to_Use_the_.40ObjectTypeConverter_Annotation
defaultObjectValue: Set the value of this attribute to the default
object value. Note that this argument is for dealing with legacy data if
the data value is missing.
I assumed this meant it was specifically meant for NULL ("missing")
values, but from what you said this is definitely not the case.
Ari
> null values.
> should so feel free to log a bug for this. "defaultObjectValue" is only
> for if you have legacy data that has other values than you have set, and
> want to default these. The mapping has a nullValue that can be set for
> the value for null, but there does not seem to be a way to set this
> through annotations (please log a bug), you can set it using a
> null in code.
> in the database.
> James
Re: ObjectTypeConverter problems [message #385743 is a reply to message #385452] Thu, 26 February 2009 16:48 Go to previous message
Bug logged and will be addressed for 1.1:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=265597
> handling it.
> converters.
> Ari
>> null values.
>> only for if you have legacy data that has other values than you have
>> set, and want to default these. The mapping has a nullValue that can
>> be set for the value for null, but there does not seem to be a way to
>> set this through annotations (please log a bug), you can set it using
>> a DescriptorCustomizer.
>> set, i.e. null=true, but there does not seem to be a way to set null
>> through annotations, maybe log a bug for this. You can set the
>> conversion for null in code.
>> the value for "Y"="true", other if you write out true, you will not
>> get "Y" in the database.
>> James
Previous Topic:ClassNotFoundException when configuring caching in OSGi environment
Next Topic:most optimal wy to persisted list?
Current Time: Sat Oct 25 18:41:07 EDT 2025
Powered by FUDForum. Page generated in 0.04095 seconds
