EMF Migration - EDataType error [message #385159] |
Fri, 10 July 2009 07:59 |
Originally posted by: aurelien.pupier.esial.net
I want to migrate to the latest EMF version.
I used the Migrate to EMF 2.5 pop-up menu and regenerate code.
All works fine except that at the runtime, this exeception is thrown when one of my element is initialized with an EDataType :
!ENTRY org.eclipse.jface 4 2 2009-07-10 09:37:47.785
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.jface".
!STACK 0
java.lang.ExceptionInInitializerError
at org.ow2.jasmine.design.model.apache_http_server.impl.Apache_ http_serverFactoryImpl.createApache_HTTPd(Apache_http_server FactoryImpl.java:132)
at org.ow2.jasmine.design.model.middleware.provider.DomainItemP rovider.collectNewChildDescriptors(DomainItemProvider.java:1 82)
at org.ow2.jasmine.design.model.jonas.provider.JOnASDomainItemP rovider.collectNewChildDescriptors(JOnASDomainItemProvider.j ava:173)
at org.eclipse.emf.edit.provider.ItemProviderAdapter.getNewChil dDescriptors(ItemProviderAdapter.java:765)
at org.eclipse.emf.edit.domain.AdapterFactoryEditingDomain.getN ewChildDescriptors(AdapterFactoryEditingDomain.java:746)
at org.ow2.jasmine.design.model.jasmine.presentation.JasmineAct ionBarContributor.selectionChanged(JasmineActionBarContribut or.java:299)
at org.ow2.jasmine.design.model.jasmine.presentation.JasmineEdi tor.setSelection(JasmineEditor.java:1745)
at org.ow2.jasmine.design.model.jasmine.presentation.JasmineEdi tor$6.selectionChanged(JasmineEditor.java:938)
at org.eclipse.jface.viewers.Viewer$2.run(Viewer.java:162)
at org.eclipse.core.runtime.Platform.run(Platform.java:888)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:17 5)
at org.eclipse.jface.viewers.Viewer.fireSelectionChanged(Viewer .java:160)
at org.eclipse.jface.viewers.StructuredViewer.updateSelection(S tructuredViewer.java:2132)
at org.eclipse.jface.viewers.StructuredViewer.handleSelect(Stru cturedViewer.java:1160)
at org.eclipse.jface.viewers.StructuredViewer$4.widgetSelected( StructuredViewer.java:1190)
at org.eclipse.jface.util.OpenStrategy.fireSelectionEvent(OpenS trategy.java:228)
at org.eclipse.jface.util.OpenStrategy.access$4(OpenStrategy.ja va:222)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:389)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3880)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3473)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
Caused by: java.lang.IllegalArgumentException: The value '80' is invalid.
at org.eclipse.emf.ecore.impl.EFactoryImpl.createFromString(EFa ctoryImpl.java:439)
at org.ow2.jasmine.design.model.jasmine.impl.JasmineFactoryImpl .createPortFromString(JasmineFactoryImpl.java:236)
at org.ow2.jasmine.design.model.jasmine.impl.JasmineFactoryImpl .createFromString(JasmineFactoryImpl.java:117)
at org.ow2.jasmine.design.model.apache_http_server.impl.Apache_ HTTPdImpl. <clinit>(Apache_HTTPdImpl.java:139)
... 45 more
thanks by advance for any help
Aurelien Pupier
Re: EMF Migration - EDataType error [message #385160 is a reply to message #385159] |
Fri, 10 July 2009 08:25 |
Ed Merks Messages: 33216 Registered: July 2009 |
--------------090104030502040906050206
Aurelien,
Please ask EMF questions on the EMF newsgroup, which I've added to the
"to" list of the reply. Mind you, I don't know where a "Migrate to EMF
2.5" pop-up menu item comes from...
My guess would be that you overwrote specialized code in when you
regenerated because you didn't change it to @generated not
So now it calls
which is not able reflectively to produce a value of the data type.
What is the Java wrapped by your Port EDataType, by the way?
Aurelien Pupier wrote:
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 45 more
> Aurelien Pupier
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Aurelien,<br>
<br>
2.5" pop-up menu item comes from...<br>
<br>
regenerated because you didn't change it to @generated not<br>
<blockquote> org.ow2.jasmine.design.model.jasmine.impl.JasmineFactoryImpl .createPortFromString(JasmineFactoryImpl.java:236)
<br>
</blockquote>
So now it calls<br>
<blockquote> org.eclipse.emf.ecore.impl.EFactoryImpl.createFromString(EFa ctoryImpl.java:439)
<br>
</blockquote>
What is the Java wrapped by your Port EDataType, by the way?<br>
<br>
<br>
<blockquote cite="mid:h36scl$clr$1@build.eclipse.org" type="cite">Hi,
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
!STACK 0
<br>
<br>
at
<br>
at
<br>
at
<br>
at
<br>
at
<br>
at
<br>
at
<br>
at
<br>
<br>
<br>
<br>
<br>
<br>
at
<br>
at
<br>
at
<br>
at
<br>
at
<br>
at
<br>
at
<br>
<br>
<br>
at
<br>
at
<br>
at
<br>
<br>
<br>
<br>
at
<br>
at
<br>
at
<br>
at
<br>
at
<br>
at
<br>
at
<br>
at
<br>
at
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
invalid.
<br>
at
<br>
at
<br>
at
<br>
at
org.ow2.jasmine.design.model.apache_http_server.impl.Apache_ HTTPdImpl.<clinit>(Apache_HTTPdImpl.java:139)
<br>
... 45 more
<br>
<br>
<br>
<br>
<br>
Aurelien Pupier
<br>
</blockquote>
</body>
</html>
--------------090104030502040906050206--
Ed Merks
Re: EMF Migration - EDataType error [message #617522 is a reply to message #385159] |
Aurelien,
So now it calls
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 45 more
> Aurelien Pupier
<html>
<head>
</head>
Aurelien,<br>
<br>
<br>
<br>
</blockquote>
So now it calls<br>
<br>
</blockquote>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
!STACK 0
<br>
<br>
at
<br>
at
<br>
at
<br>
at
<br>
at
<br>
at
<br>
at
<br>
at
<br>
<br>
<br>
<br>
<br>
<br>
at
<br>
at
<br>
at
<br>
at
<br>
at
<br>
at
<br>
at
<br>
<br>
<br>
at
<br>
at
<br>
at
<br>
<br>
<br>
<br>
at
<br>
at
<br>
at
<br>
at
<br>
at
<br>
at
<br>
at
<br>
at
<br>
at
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
invalid.
<br>
at
<br>
at
<br>
at
<br>
at
<br>
... 45 more
<br>
<br>
<br>
<br>
<br>
Aurelien Pupier
<br>
</blockquote>
</body>
</html>
Ed Merks
FUDForum. Page generated in 0.04606 seconds
