Home » Archived » GMT (Generative Modeling Technologies) » [Epsilon][Eugenia]Multiple compartments problem
Re: [Epsilon][Eugenia]Multiple compartments problem [message #385200 is a reply to message #385196] |
Wed, 27 August 2008 11:45 |
Louis Rose Messages: 440 Registered: July 2009 Location: York, United Kingdom |
Louis Rose wrote:
> Kimon Polychroniadis wrote:
>> O/H Kimon Polychroniadis έγραψε:
>>> Hello,
>>> I seem to be having a problem with inclusion relationships. In
>>> previous versions of EuGENia, I didnt have any problem but now I get
>>> an error message. The class is the following:
>>> @gmf.diagram
>>> @gmf.node(label="name")
>>> class MyModel{
>>> attr String name;
>>> @gmf.compartment
>>> val StaticView[*] structuralElements;
>>> @gmf.compartment
>>> val DynamicView[*] dynamicElements;
>>> @gmf.compartment
>>> val OrganizationalView[*] organizationalElements;
>>> @gmf.compartment
>>> val MyModel[*] modelViews;
>>> The error message is "Node is referenced from multiple containers
>>> with different 'List Layout' values".
>>> Could you give me any hint on what is the problem?
>>> Best regards,
>>> Kimon
>> No ideas so far?? :(
>> K.
> Hi Kimon,
> Apologies for the delay; Dimitrios is on vacation, and I've been unwell
> this week. I shall take a look at this now, and determine what the
> problem is.
> Many thanks,
> Louis.
Hi Kimon,
I've been able to reproduce the problem - it seems to be originating
from the GMF validation of the generator model.
For the source your provided above, I believe it is safe to ignore this
error message, and generate the diagram editor.
When Dimitrios is back from his vacation, we will investigate further
and see if there is a better solution to this problem.
Let us know if encounter any further problems.
Many thanks,
Louis.
Re: [Epsilon][Eugenia]Multiple compartments problem [message #385202 is a reply to message #385200] |
Wed, 27 August 2008 12:40 |
Kimon Polychroniadis Messages: 30 Registered: July 2009 |
Member |
You are right, the diagram editor seems to work just fine, despite the
error messages..!!
Thank you very much for your help,
K.
O/H Louis Rose έγραψε:
>>>> Hello,
>>>> @gmf.diagram
>>>> class MyModel{
>>>> attr String name;
>>>> @gmf.compartment
>>>> @gmf.compartment
>>>> @gmf.compartment
>>>> @gmf.compartment
>>>> Best regards,
>>>> Kimon
>>> K.
>> Hi Kimon,
>> unwell this week. I shall take a look at this now, and determine what
>> the problem is.
>> Many thanks,
>> Louis.
> Hi Kimon,
> Many thanks,
> Louis.
Re: [Epsilon][Eugenia]Multiple compartments problem [message #385284 is a reply to message #385202] |
Sat, 30 August 2008 07:18 |
Dimitrios Kolovos Messages: 1776 Registered: July 2009 |
Hi Kimon,
I've seen this message before but in all cases it was - as Louis
suggested - safe to just ignore it. I'll investigate a bit more on its
meaning in the next few days.
Dimitrios
> error messages..!!
> K.
>>>>> Hello,
>>>>> get an error message. The class is the following:
>>>>> @gmf.diagram
>>>>> class MyModel{
>>>>> attr String name;
>>>>> @gmf.compartment
>>>>> @gmf.compartment
>>>>> @gmf.compartment
>>>>> @gmf.compartment
>>>>> Best regards,
>>>>> Kimon
>>>> K.
>>> Hi Kimon,
>>> the problem is.
>>> Many thanks,
>>> Louis.
>> Hi Kimon,
>> this error message, and generate the diagram editor.
>> Many thanks,
>> Louis.
Re: [Epsilon][Eugenia]Multiple compartments problem [message #385299 is a reply to message #385284] |
Sat, 30 August 2008 07:49 |
As a general remark about the latest EuGENia-related posts, I should
remind that posts about Epsilon should be prefixed with [Epsilon] only
and not with [Epsilon][xxx] (where xxx a language or tool provided by
Epsilon) as indicated in www.eclipse.org/gmt/epsilon.
This is dictated by the structure of the GMT project and the newsgroup
policy (http://wiki.eclipse.org/index.php/GMT).
Dimitrios
Dimitrios Kolovos wrote:
> Hi Kimon,
> Cheers,
> Dimitrios
>> error messages..!!
>> K.
>>>>>> Hello,
>>>>>> @gmf.diagram
>>>>>> class MyModel{
>>>>>> attr String name;
>>>>>> @gmf.compartment
>>>>>> @gmf.compartment
>>>>>> @gmf.compartment
>>>>>> @gmf.compartment
>>>>>> Best regards,
>>>>>> Kimon
>>>>> K.
>>>> Hi Kimon,
>>>> what the problem is.
>>>> Many thanks,
>>>> Louis.
>>> Hi Kimon,
>>> Many thanks,
>>> Louis.
Re: [Epsilon][Eugenia]Multiple compartments problem [message #620441 is a reply to message #385196] |
>>> Hello,
>>> @gmf.diagram
>>> class MyModel{
>>> attr String name;
>>> @gmf.compartment
>>> @gmf.compartment
>>> @gmf.compartment
>>> @gmf.compartment
>>> Best regards,
>>> Kimon
>> K.
> Hi Kimon,
> problem is.
> Many thanks,
> Louis.
Hi Kimon,
Many thanks,
Louis.
Re: [Epsilon][Eugenia]Multiple compartments problem [message #620445 is a reply to message #385200] |
Member |
error messages..!!
K.
>>>> Hello,
>>>> @gmf.diagram
>>>> class MyModel{
>>>> attr String name;
>>>> @gmf.compartment
>>>> @gmf.compartment
>>>> @gmf.compartment
>>>> @gmf.compartment
>>>> Best regards,
>>>> Kimon
>>> K.
>> Hi Kimon,
>> the problem is.
>> Many thanks,
>> Louis.
> Hi Kimon,
> Many thanks,
> Louis.
Re: [Epsilon][Eugenia]Multiple compartments problem [message #621681 is a reply to message #385202] |
Hi Kimon,
Dimitrios
> error messages..!!
> K.
>>>>> Hello,
>>>>> @gmf.diagram
>>>>> class MyModel{
>>>>> attr String name;
>>>>> @gmf.compartment
>>>>> @gmf.compartment
>>>>> @gmf.compartment
>>>>> @gmf.compartment
>>>>> Best regards,
>>>>> Kimon
>>>> K.
>>> Hi Kimon,
>>> the problem is.
>>> Many thanks,
>>> Louis.
>> Hi Kimon,
>> Many thanks,
>> Louis.
Re: [Epsilon][Eugenia]Multiple compartments problem [message #621687 is a reply to message #385284] |
Dimitrios
> Hi Kimon,
> Cheers,
> Dimitrios
>> error messages..!!
>> K.
>>>>>> Hello,
>>>>>> @gmf.diagram
>>>>>> class MyModel{
>>>>>> attr String name;
>>>>>> @gmf.compartment
>>>>>> @gmf.compartment
>>>>>> @gmf.compartment
>>>>>> @gmf.compartment
>>>>>> Best regards,
>>>>>> Kimon
>>>>> K.
>>>> Hi Kimon,
>>>> Many thanks,
>>>> Louis.
>>> Hi Kimon,
>>> Many thanks,
>>> Louis.
Current Time: Fri Apr 26 19:48:42 GMT 2024
Powered by FUDForum. Page generated in 0.04623 seconds
