Home » Eclipse Projects » Standard Widget Toolkit (SWT) » SWT Designer
SWT Designer [message #384725] Tue, 11 November 2003 08:19 Go to next message
Originally posted by: lbraga.fpf.br
Anybody know any project as "SWT Designer", open source?
Re: SWT Designer [message #384726 is a reply to message #384725] Tue, 11 November 2003 08:39 Go to previous messageGo to next message
This was a lot of work.
I've used about 1000 hours to create it, 12 hours every day.
But nothings prevents you from starting your own project. :-)
SY, Konstantin.
Advanced Eclipse SWT Designer (http://www.swt-designer.com)
Re: SWT Designer [message #385399 is a reply to message #384725] Wed, 12 November 2003 11:59 Go to previous messageGo to next message
You might wonna check out the Luxor XUL Toolkit. Although it's not a
Form Designer per-se its half-way there. You can use a super-compact
easy-to-read easy-to-parse XML format to describe your forms.
By the way, the point of XUL is to break the vendor lock-in and let you
choose whatever Forms Designer you like. Unfortunately, for now Forms
Designer for XUL are rare creatures.
Anyway, if you're interested check out the Luxor XUL site @
http://luxor-xul.sourceforge.net
For more info about XUL check out the XUL Alliance site @
http://xul.sourceforge.net
- Gerald
Re: SWT Designer [message #385549 is a reply to message #385399] Wed, 12 November 2003 23:49 Go to previous messageGo to next message
"Gerald Bauer" <gerald@vamphq.com> wrote in message
news:botoss$ne4$1@eclipse.org...
Yeah, right. All is does is lock you into vendors that support that format.
You can just as easily "break" vendor lock in by using a GUI builder that
can read and write a variety of formats. One of our goals with SWT Designer
is to allow you to read and write in whatever style appeals you.
-Eric Clayberg
Sr. Vice President of Product Development
Instantiations, Inc.
mailto:cpsws-support@instantiations.com
http://www.instantiations.com
http://www.instantiations.com/codepro/ws
Re: SWT Designer [message #386124 is a reply to message #385549] Thu, 13 November 2003 13:26 Go to previous messageGo to next message
Eric Clayberg (SWT Designer Dev Manager) wrote:
>> By the way, the point of XUL is to break the vendor lock-in.
Eric, what XML UI formats does SWT Designer support? Have you published
your very own XML UI format? Can you post a link? Is it open and
royality-free? Do you cooperate with others to work on an XML UI spec?
- Gerald
Re: SWT Designer [message #386546 is a reply to message #386124] Thu, 13 November 2003 23:32 Go to previous message
news:bp0idc$nff$1@eclipse.org...
format.
that
Designer
None. It reads and writes pure SWT code. If your intent is to build an SWT
user interface, that's all you need.
> Have you published your very own XML UI format?
No...and we don't intend to.
> Is it open and royality-free?
Since we read and write pure SWT code, the answer is yes.
-Eric Clayberg
Previous Topic:how to get another plugin handler
Next Topic:Extra Table Column
Current Time: Wed Sep 24 19:16:19 EDT 2025
Powered by FUDForum. Page generated in 0.05398 seconds
