| I don't find the solution [message #384285] | Tue, 14 April 2009 10:07  |  |
| Eclipse User  |  |  |  |  | In the method actionPerformed  of a button  ,how can I invoke my plugin (4 files jar) which is a graphical editor developped with GMF ?
| Re: I don't find the solution [message #384286 is a reply to message #384285] | Tue, 14 April 2009 10:18   |  |
| Eclipse User  |  |  |  |  | This is a multi-part message in MIME format. --------------080406060502040708050201
 Please use the GMF newsgroup for questions about GMF.  I've added it to
 the "to" list of the reply, so no need to repost.   Here's how EMF's
 generated wizard opens the editor upon completion.
 public boolean performFinish() {
 try {
 // Remember the file.
 final IFile modelFile = getModelFile();
 // Do the work within an operation.
 WorkspaceModifyOperation operation =
 new WorkspaceModifyOperation() {
 protected void execute(IProgressMonitor
 progressMonitor) {
 try {
 // Create a resource set
 ResourceSet resourceSet = new
 ResourceSetImpl();
 // Get the URI of the model file.
 URI fileURI =
 URI.createPlatformResourceURI(modelFile.getFullPath().toStri ng(), true);
 // Create a resource for this file.
 Resource resource =
 resourceSet.createResource(fileURI);
 // Add the initial model object to the
 contents.
 EObject rootObject = createInitialModel();
 if (rootObject != null) {
 resource.getContents().add(rootObject);
 // Save the contents of the resource to
 the file system.
 Map<Object, Object> options = new
 HashMap<Object, Object>();
 options.put(XMLResource.OPTION_ENCODING,
 initialObjectCreationPage.getEncoding());
 resource.save(options);
 catch (Exception exception) {
 CustOrderEditorPlugin.INSTANCE.log(exception);
 finally {
 progressMonitor.done();
 getContainer().run(false, false, operation);
 // Select the new file resource in the current view.
 IWorkbenchWindow workbenchWindow =
 workbench.getActiveWorkbenchWindow();
 IWorkbenchPage page = workbenchWindow.getActivePage();
 final IWorkbenchPart activePart = page.getActivePart();
 if (activePart instanceof ISetSelectionTarget) {
 final ISelection targetSelection = new
 StructuredSelection(modelFile);
 getShell().getDisplay().asyncExec
 (new Runnable() {
 public void run() {
 ((ISetSelectionTarget)activePart).selectReveal(targetSelecti on);
 // Open an editor on the new file.
 try {
 page.openEditor
 (new FileEditorInput(modelFile),
 workbench.getEditorRegistry().getDefaultEditor(modelFile.get FullPath().toString()).getId());
 catch (PartInitException exception) {
 MessageDialog.openError(workbenchWindow.getShell(),
 CustOrderEditorPlugin.INSTANCE.getString("_UI_OpenEditorError_label "),
 exception.getMessage());
 return false;
 return true;
 return false;
 > Thanks
 <html>
 <head>
 http-equiv="Content-Type">
 </head>
| Re: I don't find the solution [message #384397 is a reply to message #384287] | Tue, 14 April 2009 10:50  |  |
| Eclipse User  |  |  |  |  | I don't think so.  I'm not sure how to make an Eclipse do something from another process.  That's not even a GMF question...
 basem-ca wrote:
 > thanks
 > Can I  applicate this code in a one external java file in another IDE
 > like JCreator ?
| Re: I don't find the solution [message #615329 is a reply to message #384285] | Tue, 14 April 2009 10:18  |  |
 try {
 progressMonitor) {
 try {
 ResourceSetImpl();
 URI fileURI =
 Resource resource =
 contents.
 the file system.
 finally {
 (new Runnable() {
 public void run() {
 try {
 page.openEditor
 return false;
 return true;
 return false;
 > Thanks
 <html>
 <head>
 </head>
| Re: I don't find the solution [message #615704 is a reply to message #384287] | Tue, 14 April 2009 10:50  |  |
 basem-ca wrote:
 > thanks
 > like JCreator ?
FUDForum. Page generated in 0.04324 seconds
