Home » Archived » GMT (Generative Modeling Technologies) » [Epsilon] Problem with HUTN and sqlmodel
[Epsilon] Problem with HUTN and sqlmodel [message #383957] |
Thu, 17 July 2008 03:57  |
I'm trying to use HUTN in order to define a SQL model, but when I save the
file I just get this error:
org.epsilon.hutn.exceptions.HutnGenerationException:
The URI of the metamodel I'm using is 'http:///SQLModel.ecore', from the
main package of the ecore file (it has child packages). First I thougth it
failed because of the chidren packages, but I managed to define a QVT
model and another I made for proofs (both with child packages).
My code where I specify de metamodel is just:
@Spec{
MetaModel "sqmodel"{
nsUri = "http:///SQLModel.ecore"
Do you know something about this error?
Héctor.
Re: [Epsilon] Problem with HUTN and sqlmodel [message #384228 is a reply to message #383958] |
Thu, 17 July 2008 15:32   |
Hi again,
Recently, we have performing some migration activities on Epsilon, and
the HUTN test suite is currently being migrated. I aim to finish this
tomorrow, and will have a better idea of the cause of your problem then.
In the meantime, here are some things to check:
1) Ensure that your metamodel is registered with Epsilon. (Right-click
the Ecore file and click Register EPackages).
2) Ensure that you specify a body after your HUTN header. For example:
SqModelPackage {
Table "sample" {
(The above example assumes that a Table classifier exists in your
metamodel, and that the Table classifier defines a String attribute
called name).
Finally, if you could send me your metamodel and HUTN source, I will
continue to investigate your problem over the next few days.
Many thanks,
Louis.
Louis Rose wrote:
> Hi Héctor,
> I suspect that this problem is fixed in some recent changes made to
> HUTN. I will investigate your problem this afternoon and post an update.
> Cheers,
> Louis.
> Héctor Iturria wrote:
>> Hello,
>> the file I just get this error:
>> java.lang.NullPointerException
>> the main package of the ecore file (it has child packages). First I
>> thougth it failed because of the chidren packages, but I managed to
>> define a QVT model and another I made for proofs (both with child
>> packages).
>> @Spec{
>> Thanks,
>> Héctor.
Re: [Epsilon] Problem with HUTN and sqlmodel [message #384244 is a reply to message #384239] |
Fri, 18 July 2008 15:05   |
Hi Héctor,
Many thanks for the debug information. I now suspect that you may have a
buggy version of HUTN.
Could you tell us what version of HUTN you are running?
This information can be obtained by:
1) Selecting the Help | About Eclipse option from Eclipse.
2) Clicking the Plugin Details button.
3) Locating the table row with plugin ID
"org.eclipse.epsilon.hutn.engine" or "org.epsilon.hutn.engine"
4) Noting the version number in the version column.
Many thanks,
Louis.
> Hi!
> Both things are done. I registered the main package and after its
> children. The feedback I got when I did it was that the main package was
> registered succesfully. Even for the children packages.
> I have tried the HUNT file with and without body and I get the same
> error, so I think the problem should be with the meta model. However,
> when I define the body, HUTN recognises the classifiers and the types of
> its attributes. I have already tried another HUTN model without body
> with another ecore, and it works.
> I send you the metamodel and the HUTN file.
> Thanks!
> Héctor
> Louis Rose escribió:
>> Hi again,
>> SqModelPackage {
>> Table "sample" {
>> called name).
>> Many thanks,
>> Louis.
>> Louis Rose wrote:
>>> Hi Héctor,
>>> Cheers,
>>> Louis.
>>>> Hello,
>>>> save the file I just get this error:
>>>> packages).
>>>> @Spec{
>>>> Thanks,
>>>> Héctor.
Re: [Epsilon] Problem with HUTN and sqlmodel [message #384248 is a reply to message #384244] |
Mon, 21 July 2008 02:37   |
Hi Louis,
The version number of the HUTN engine is 1.0.1
Héctor
> Hi Héctor,
> Many thanks,
> Louis.
>> Hi!
>> was registered succesfully. Even for the children packages.
>> of its attributes. I have already tried another HUTN model without
>> body with another ecore, and it works.
>> Thanks!
>> Héctor
>>> Hi again,
>>> and the HUTN test suite is currently being migrated. I aim to finish
>>> this tomorrow, and will have a better idea of the cause of your
>>> problem then.
>>> (Right-click the Ecore file and click Register EPackages).
>>> SqModelPackage {
>>> Table "sample" {
>>> called name).
>>> Many thanks,
>>> Louis.
>>> Louis Rose wrote:
>>>> Hi Héctor,
>>>> update.
>>>> Cheers,
>>>> Louis.
>>>>> Hello,
>>>>> from the main package of the ecore file (it has child packages).
>>>>> First I thougth it failed because of the chidren packages, but I
>>>>> managed to define a QVT model and another I made for proofs (both
>>>>> @Spec{
>>>>> Thanks,
>>>>> Héctor.
Re: [Epsilon] Problem with HUTN and sqlmodel [message #384376 is a reply to message #384375] |
Mon, 28 July 2008 06:00   |
Hi Héctor,
Sorry to hear you're still experiencing problems.
Could you also send the HUTN source from which you're trying to
construct a model?
Many thanks,
Louis.
> Hi Louis,
> I updated all the epsilon plugins and the UML Null point exception
> doesn't apperar any more, but continued in the sqlmodel. I changed some
> references of the metamodel to other ecores and now the error I get is
> this one:
> org.eclipse.epsilon.hutn.exceptions.HutnGenerationException: Could not
> parse transformation: [Line: 267, Column: 15, Reason: mismatched input
> 'Sequence' expecting NAME]
> I send you the changed metamodel too.
> Many thanks,
> Héctor
>> Hi Héctor,
>> Dimitrios has just released a new version of HUTN. The version number
>> is 0.7.0. Apologies if this seems a little counter-intuitive (the last
>> version was 1.3.6), but we've had to change the version numbers of all
>> Epsilon features to comply with the Eclipse incubation process.
>> Please update your installation of Epsilon and HUTN from the new
>> update manager site:
>> http://download.eclipse.org/technology/gmt/epsilon/updates/
>> You should find that the NullPointerException that you were
>> encountering no longer occurs.
>> However, we have had some problems instantiating your sqlmodel.ecore
>> metamodel using the built-in EMF editor. Could you try it too? If you
>> manage to successfully instantiate your model with the built-in
>> editor, and the same model cannot be constructed with HUTN, please let
>> us know.
>> Many thanks,
>> Louis.
Re: [Epsilon] Problem with HUTN and sqlmodel [message #384378 is a reply to message #384376] |
Mon, 28 July 2008 07:06   |
Hi Héctor,
Regardless of the potential HUTN issue, the sqlmodel.ecore still appears
to be somewhat problematic. If I select sqlmodel->schema->Database in
the built-in EMF tree editor, right click and select "Create dynamic
instance", EMF raises an exception and complains that
"java.lang.IllegalArgumentException: The class 'ENamedElement' is not a
valid classifier". I'm not sure why this happens - perhaps the EMF
newsgroup would be a good place to ask. In any case, I believe we should
first resolve this issue before looking into HUTN.
If you have control over the metamodel (i.e. you are not required to use
it as-is) I would suggest removing all references to ECore (e.g.
extending the ECore ENamedElement class in SQLObject / using
EAnnotations) and trying again.
Dimitrios
Louis Rose wrote:
> Hi Héctor,
> construct a model?
> Many thanks,
> Louis.
>> Hi Louis,
>> some references of the metamodel to other ecores and now the error I
>> get is this one:
>> Many thanks,
>> Héctor
>>> Hi Héctor,
>>> last version was 1.3.6), but we've had to change the version numbers
>>> of all Epsilon features to comply with the Eclipse incubation process.
>>> let us know.
>>> Many thanks,
>>> Louis.
Re: [Epsilon] Problem with HUTN and sqlmodel [message #384379 is a reply to message #384378] |
Mon, 28 July 2008 08:21   |
Hi Héctor,
The exception you mention was due to an unescaped character being
created in the final transformation to the target model. I have now
fixed this. The fix will appear in a new release later on in the week.
If you need the patch before then, please let me know. (I can provide
you with an overlay, like we did for Pau).
However, resolving this problem uncovered an issue with instantiating
your metamodel with EMF. The following exception was raised:
Caused by: java.lang.IllegalArgumentException: The class 'ENamedElement'
is not a valid classifier
org.eclipse.emf.ecore.impl.EcoreFactoryImpl.create(EcoreFact oryImpl.java:104)
at org.eclipse.emf.ecore.impl.EFactoryImpl.create(EFactoryImpl. java:243)
This is the same exception that Dimitrios encountered. As Dimitrios
mentions below, HUTN will not be able to generate models with the
current version of the SQLModel metamodel. Once you can instantiate the
SQLModel metamodel with EMF reflexive editor, HUTN should be capable of
generating models too.
Louis.
Dimitrios Kolovos wrote:
> Hi Héctor,
> Cheers,
> Dimitrios
> Louis Rose wrote:
>> Hi Héctor,
>> construct a model?
>> Many thanks,
>> Louis.
>>> Hi Louis,
>>> get is this one:
>>> not parse transformation: [Line: 267, Column: 15, Reason: mismatched
>>> input 'Sequence' expecting NAME]
>>> Many thanks,
>>> Héctor
>>>> Hi Héctor,
>>>> number is 0.7.0. Apologies if this seems a little counter-intuitive
>>>> (the last version was 1.3.6), but we've had to change the version
>>>> numbers of all Epsilon features to comply with the Eclipse
>>>> incubation process.
>>>> you manage to successfully instantiate your model with the built-in
>>>> let us know.
>>>> Many thanks,
>>>> Louis.
Re: [Epsilon] Problem with HUTN and sqlmodel [message #618237 is a reply to message #383957] |
Thu, 17 July 2008 06:59  |
Hi Héctor,
Louis.
> Hello,
> it failed because of the chidren packages, but I managed to define a QVT
> @Spec{
> Héctor.
Re: [Epsilon] Problem with HUTN and sqlmodel [message #618239 is a reply to message #383958] |
Hi again,
SqModelPackage {
Table "sample" {
called name).
Many thanks,
Louis.
Louis Rose wrote:
> Hi Héctor,
> Cheers,
> Louis.
>> Hello,
>> packages).
>> @Spec{
>> Thanks,
>> Héctor.
Re: [Epsilon] Problem with HUTN and sqlmodel [message #618240 is a reply to message #384228] |
Fri, 18 July 2008 02:55  |
--------------030401080703080603070203
Hi!
Thanks!
H
Re: [Epsilon] Problem with HUTN and sqlmodel [message #618242 is a reply to message #384239] |
Hi Héctor,
Many thanks,
Louis.
> Hi!
> Thanks!
> Héctor
>> Hi again,
>> SqModelPackage {
>> Table "sample" {
>> called name).
>> Many thanks,
>> Louis.
>> Louis Rose wrote:
>>> Hi Héctor,
>>> Cheers,
>>> Louis.
>>>> Hello,
>>>> packages).
>>>> @Spec{
>>>> Thanks,
>>>> Héctor.
Re: [Epsilon] Problem with HUTN and sqlmodel [message #618244 is a reply to message #384244] |
Hi Louis,
Héctor
> Hi Héctor,
> Many thanks,
> Louis.
>> Hi!
>> Thanks!
>> Héctor
>>> Hi again,
>>> problem then.
>>> SqModelPackage {
>>> Table "sample" {
>>> called name).
>>> Many thanks,
>>> Louis.
>>> Louis Rose wrote:
>>>> Hi Héctor,
>>>> update.
>>>> Cheers,
>>>> Louis.
>>>>> Hello,
>>>>> @Spec{
>>>>> Thanks,
>>>>> Héctor.
Re: [Epsilon] Problem with HUTN and sqlmodel [message #618512 is a reply to message #384250] |
Mon, 21 July 2008 12:13  |
Hi Héctor,
There are a couple of small problems in HUTN version 1.0.1 (as you have
noticed!) Dimitrios and I are currently assembling a new release of
Epsilon and HUTN that should fix your problem. We hope to have the
release ready in the next couple of days.
I'll post here once it's available.
Many thanks,
Louis.
> Hi again!
> The plugin version I'm using is 1.0.1, but it has been patched for
> working properly with UML and the search of URIs. Is the one you gave to
> Pau Giner.
> Thanks!
> Héctor
Re: [Epsilon] Problem with HUTN and sqlmodel [message #618540 is a reply to message #384259] |
Wed, 23 July 2008 10:17  |
> Ok, I wait for it.
> Héctor
Hi Héctor,
Dimitrios and I have finalised most of the details for the new release.
We've fixed the null pointer exception that you were encountering with HUTN.
We're going to investigate a further problem related to the nesting of
packages in your metamodel before we make a new release of Epsilon and
HUTN available.
I'll update this thread as soon as we have more information.
Louis.
Re: [Epsilon] Problem with HUTN and sqlmodel [message #618547 is a reply to message #384372] |
Fri, 25 July 2008 09:55  |
Hi Héctor,
Dimitrios has just released a new version of HUTN. The version number is
Please update your installation of Epsilon and HUTN from the new update
manager site: http://download.eclipse.org/technology/gmt/epsilon/updates/
You should find that the NullPointerException that you were encountering
no longer occurs.
manage to successfully instantiate your model with the built-in editor,
and the same model cannot be constructed with HUTN, please let us know.
Many thanks,
Louis.
Re: [Epsilon] Problem with HUTN and sqlmodel [message #618551 is a reply to message #384374] |
Mon, 28 July 2008 05:21  |
--------------080403070308060801050600
Hi Louis,
this one:
Many thanks,
H
Re: [Epsilon] Problem with HUTN and sqlmodel [message #618616 is a reply to message #384375] |
Hi Héctor,
construct a model?
Many thanks,
Louis.
> Hi Louis,
> this one:
> Many thanks,
> Héctor
>> Hi Héctor,
>> us know.
>> Many thanks,
>> Louis.
Re: [Epsilon] Problem with HUTN and sqlmodel [message #618618 is a reply to message #384376] |
Hi Héctor,
Dimitrios
Louis Rose wrote:
> Hi Héctor,
> construct a model?
> Many thanks,
> Louis.
>> Hi Louis,
>> get is this one:
>> Many thanks,
>> Héctor
>>> Hi Héctor,
>>> let us know.
>>> Many thanks,
>>> Louis.
Re: [Epsilon] Problem with HUTN and sqlmodel [message #618619 is a reply to message #384378] |
Hi Héctor,
Louis.
> Hi Héctor,
> Cheers,
> Dimitrios
> Louis Rose wrote:
>> Hi Héctor,
>> construct a model?
>> Many thanks,
>> Louis.
>>> Hi Louis,
>>> get is this one:
>>> Many thanks,
>>> Héctor
>>>> Hi Héctor,
>>>> incubation process.
>>>> let us know.
>>>> Many thanks,
>>>> Louis.
Current Time: Fri Jul 04 19:32:21 EDT 2025
Powered by FUDForum. Page generated in 0.10540 seconds
