Home » Eclipse Projects » EclipseLink » Entity must be managed to call remove
Re: Entity must be managed to call remove [message #384215 is a reply to message #384213] |
Wed, 03 December 2008 15:51 |
Tom Eugelink Messages: 817 Registered: July 2009 |
> Try doing a persist before the commit.
No difference. For your comparison, this is the SQL that happens on the application event:
2008-12-03 10:32:47,390 DEBUG nl.reinders.bm.Batchcount.changeContibutionTo(Batchcount.jav a:329) changeContibutionTo done
2008-12-03 10:32:47,515 DEBUG org.tbee.util.jdbc.PreparedStatement.invoke(PreparedStatemen t.java:139) #13778707: [1] setTimestamp=2008-12-03 10:32:47.156 / java.sql.Timestamp / UPDATE batch SET dwhmodified = >>>HERE<<< , lazylock = ? WHERE ((batchnr = ?) AND (lazylock = ?))
2008-12-03 10:32:47,531 DEBUG org.tbee.util.jdbc.PreparedStatement.invoke(PreparedStatemen t.java:139) #13778707: [2] setLong=40 / java.lang.Long / UPDATE batch SET dwhmodified = ?, lazylock = >>>HERE<<< WHERE ((batchnr = ?) AND (lazylock = ?))
2008-12-03 10:32:47,562 DEBUG org.tbee.util.jdbc.PreparedStatement.invoke(PreparedStatemen t.java:139) #13778707: [3] setBigDecimal=11428 / java.math.BigDecimal / UPDATE batch SET dwhmodified = ?, lazylock = ? WHERE ((batchnr = >>>HERE<<< ) AND (lazylock = ?))
2008-12-03 10:32:47,578 DEBUG org.tbee.util.jdbc.PreparedStatement.invoke(PreparedStatemen t.java:139) #13778707: [4] setInt=39 / java.lang.Integer / UPDATE batch SET dwhmodified = ?, lazylock = ? WHERE ((batchnr = ?) AND (lazylock = >>>HERE<<< ))
2008-12-03 10:32:47,703 DEBUG org.tbee.util.jdbc.PreparedStatement.invoke(PreparedStatemen t.java:139) #13778707: executeUpdate: UPDATE batch SET dwhmodified = ?, lazylock = ? WHERE ((batchnr = ?) AND (lazylock = ?))
2008-12-03 10:32:47,734 DEBUG org.tbee.util.jdbc.PreparedStatement.invoke(PreparedStatemen t.java:139) #17255007: [1] setBigDecimal=110 / java.math.BigDecimal / UPDATE batchtransferline SET from_amount = >>>HERE<<< , dwhmodified = ?, lazylock = ? WHERE ((batchtransferlinenr = ?) AND (lazylock = ?))
2008-12-03 10:32:47,734 DEBUG org.tbee.util.jdbc.PreparedStatement.invoke(PreparedStatemen t.java:139) #17255007: [2] setTimestamp=2008-12-03 10:32:47.0 / java.sql.Timestamp / UPDATE batchtransferline SET from_amount = ?, dwhmodified = >>>HERE<<< , lazylock = ? WHERE ((batchtransferlinenr = ?) AND (lazylock = ?))
2008-12-03 10:32:47,734 DEBUG org.tbee.util.jdbc.PreparedStatement.invoke(PreparedStatemen t.java:139) #17255007: [3] setLong=54 / java.lang.Long / UPDATE batchtransferline SET from_amount = ?, dwhmodified = ?, lazylock = >>>HERE<<< WHERE ((batchtransferlinenr = ?) AND (lazylock = ?))
2008-12-03 10:32:47,734 DEBUG org.tbee.util.jdbc.PreparedStatement.invoke(PreparedStatemen t.java:139) #17255007: [4] setBigDecimal=18 / java.math.BigDecimal / UPDATE batchtransferline SET from_amount = ?, dwhmodified = ?, lazylock = ? WHERE ((batchtransferlinenr = >>>HERE<<< ) AND (lazylock = ?))
2008-12-03 10:32:47,734 DEBUG org.tbee.util.jdbc.PreparedStatement.invoke(PreparedStatemen t.java:139) #17255007: [5] setInt=53 / java.lang.Integer / UPDATE batchtransferline SET from_amount = ?, dwhmodified = ?, lazylock = ? WHERE ((batchtransferlinenr = ?) AND (lazylock = >>>HERE<<< ))
2008-12-03 10:32:47,734 DEBUG org.tbee.util.jdbc.PreparedStatement.invoke(PreparedStatemen t.java:139) #17255007: executeUpdate: UPDATE batchtransferline SET from_amount = ?, dwhmodified = ?, lazylock = ? WHERE ((batchtransferlinenr = ?) AND (lazylock = ?))
2008-12-03 10:32:47,781 DEBUG org.tbee.util.jdbc.PreparedStatement.invoke(PreparedStatemen t.java:139) #31617140: [1] setBigDecimal=1330191 / java.math.BigDecimal / INSERT IGNORE INTO batchcount (batchcountnr, batchdate, amount, description, rollentodolinenr, rollendonelinenr, lazylock, dwhmodified, dwhby, batchnr, to_amount_batchtransferlinenr, from_amount_batchtransferlinenr) VALUES ( >>>HERE<<< , ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)
2008-12-03 10:32:47,781 DEBUG org.tbee.util.jdbc.PreparedStatement.invoke(PreparedStatemen t.java:139) #31617140: [2] setNull=91 / java.lang.Integer / INSERT IGNORE INTO batchcount (batchcountnr, batchdate, amount, description, rollentodolinenr, rollendonelinenr, lazylock, dwhmodified, dwhby, batchnr, to_amount_batchtransferlinenr, from_amount_batchtransferlinenr) VALUES (?, >>>HERE<<< , ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)
2008-12-03 10:32:47,781 DEBUG org.tbee.util.jdbc.PreparedStatement.invoke(PreparedStatemen t.java:139) #31617140: [3] setBigDecimal=-60 / java.math.BigDecimal / INSERT IGNORE INTO batchcount (batchcountnr, batchdate, amount, description, rollentodolinenr, rollendonelinenr, lazylock, dwhmodified, dwhby, batchnr, to_amount_batchtransferlinenr, from_amount_batchtransferlinenr) VALUES (?, ?, >>>HERE<<< , ?, ?, ?, ?, ?, ?, ?, ?, ?)
2008-12-03 10:32:47,781 DEBUG org.tbee.util.jdbc.PreparedStatement.invoke(PreparedStatemen t.java:139) #31617140: [4] setNull=12 / java.lang.Integer / INSERT IGNORE INTO batchcount (batchcountnr, batchdate, amount, description, rollentodolinenr, rollendonelinenr, lazylock, dwhmodified, dwhby, batchnr, to_amount_batchtransferlinenr, from_amount_batchtransferlinenr) VALUES (?, ?, ?, >>>HERE<<< , ?, ?, ?, ?, ?, ?, ?, ?)
2008-12-03 10:32:47,781 DEBUG org.tbee.util.jdbc.PreparedStatement.invoke(PreparedStatemen t.java:139) #31617140: [5] setNull=4 / java.lang.Integer / INSERT IGNORE INTO batchcount (batchcountnr, batchdate, amount, description, rollentodolinenr, rollendonelinenr, lazylock, dwhmodified, dwhby, batchnr, to_amount_batchtransferlinenr, from_amount_batchtransferlinenr) VALUES (?, ?, ?, ?, >>>HERE<<< , ?, ?, ?, ?, ?, ?, ?)
2008-12-03 10:32:47,781 DEBUG org.tbee.util.jdbc.PreparedStatement.invoke(PreparedStatemen t.java:139) #31617140: [6] setNull=4 / java.lang.Integer / INSERT IGNORE INTO batchcount (batchcountnr, batchdate, amount, description, rollentodolinenr, rollendonelinenr, lazylock, dwhmodified, dwhby, batchnr, to_amount_batchtransferlinenr, from_amount_batchtransferlinenr) VALUES (?, ?, ?, ?, ?, >>>HERE<<< , ?, ?, ?, ?, ?, ?)
2008-12-03 10:32:47,781 DEBUG org.tbee.util.jdbc.PreparedStatement.invoke(PreparedStatemen t.java:139) #31617140: [7] setLong=1 / java.lang.Long / INSERT IGNORE INTO batchcount (batchcountnr, batchdate, amount, description, rollentodolinenr, rollendonelinenr, lazylock, dwhmodified, dwhby, batchnr, to_amount_batchtransferlinenr, from_amount_batchtransferlinenr) VALUES (?, ?, ?, ?, ?, ?, >>>HERE<<< , ?, ?, ?, ?, ?)
2008-12-03 10:32:47,781 DEBUG org.tbee.util.jdbc.PreparedStatement.invoke(PreparedStatemen t.java:139) #31617140: [8] setTimestamp=2008-12-03 10:32:47.156 / java.sql.Timestamp / INSERT IGNORE INTO batchcount (batchcountnr, batchdate, amount, description, rollentodolinenr, rollendonelinenr, lazylock, dwhmodified, dwhby, batchnr, to_amount_batchtransferlinenr, from_amount_batchtransferlinenr) VALUES (?, ?, ?, ?, ?, ?, ?, >>>HERE<<< , ?, ?, ?, ?)
2008-12-03 10:32:47,781 DEBUG org.tbee.util.jdbc.PreparedStatement.invoke(PreparedStatemen t.java:139) #31617140: [9] setBigDecimal=24 / java.math.BigDecimal / INSERT IGNORE INTO batchcount (batchcountnr, batchdate, amount, description, rollentodolinenr, rollendonelinenr, lazylock, dwhmodified, dwhby, batchnr, to_amount_batchtransferlinenr, from_amount_batchtransferlinenr) VALUES (?, ?, ?, ?, ?, ?, ?, ?, >>>HERE<<< , ?, ?, ?)
2008-12-03 10:32:47,796 DEBUG org.tbee.util.jdbc.PreparedStatement.invoke(PreparedStatemen t.java:139) #31617140: [10] setBigDecimal=11428 / java.math.BigDecimal / INSERT IGNORE INTO batchcount (batchcountnr, batchdate, amount, description, rollentodolinenr, rollendonelinenr, lazylock, dwhmodified, dwhby, batchnr, to_amount_batchtransferlinenr, from_amount_batchtransferlinenr) VALUES (?, ?, ?, ?, ?, ?, ?, ?, ?, >>>HERE<<< , ?, ?)
2008-12-03 10:32:47,796 DEBUG org.tbee.util.jdbc.PreparedStatement.invoke(PreparedStatemen t.java:139) #31617140: [11] setNull=4 / java.lang.Integer / INSERT IGNORE INTO batchcount (batchcountnr, batchdate, amount, description, rollentodolinenr, rollendonelinenr, lazylock, dwhmodified, dwhby, batchnr, to_amount_batchtransferlinenr, from_amount_batchtransferlinenr) VALUES (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, >>>HERE<<< , ?)
2008-12-03 10:32:47,796 DEBUG org.tbee.util.jdbc.PreparedStatement.invoke(PreparedStatemen t.java:139) #31617140: [12] setBigDecimal=18 / java.math.BigDecimal / INSERT IGNORE INTO batchcount (batchcountnr, batchdate, amount, description, rollentodolinenr, rollendonelinenr, lazylock, dwhmodified, dwhby, batchnr, to_amount_batchtransferlinenr, from_amount_batchtransferlinenr) VALUES (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, >>>HERE<<< )
2008-12-03 10:32:48,171 DEBUG org.tbee.util.jdbc.PreparedStatement.invoke(PreparedStatemen t.java:139) #31617140: executeUpdate: INSERT IGNORE INTO batchcount (batchcountnr, batchdate, amount, description, rollentodolinenr, rollendonelinenr, lazylock, dwhmodified, dwhby, batchnr, to_amount_batchtransferlinenr, from_amount_batchtransferlinenr) VALUES (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)
There are 3 SQLs
1. update the BATCH
2. update the BATCHTRANSFERLINE (from 50 to 110, so a delta of 60)
3. insert a BATCHCOUNT (allocate that 60)
The change causing SQL 2 is made by the user, and SQL 1 and 3 and the result of the event code.
And this is done when using @PrePersist:
2008-12-03 10:30:26,562 DEBUG nl.reinders.bm.Batchcount.changeContibutionTo(Batchcount.jav a:329) changeContibutionTo done
2008-12-03 10:30:26,593 DEBUG org.tbee.util.jdbc.PreparedStatement.invoke(PreparedStatemen t.java:139) #17256714: [1] setBigDecimal=110 / java.math.BigDecimal / UPDATE batchtransferline SET from_amount = >>>HERE<<< , dwhmodified = ?, lazylock = ? WHERE ((batchtransferlinenr = ?) AND (lazylock = ?))
2008-12-03 10:30:26,593 DEBUG org.tbee.util.jdbc.PreparedStatement.invoke(PreparedStatemen t.java:139) #17256714: [2] setTimestamp=2008-12-03 10:30:11.031 / java.sql.Timestamp / UPDATE batchtransferline SET from_amount = ?, dwhmodified = >>>HERE<<< , lazylock = ? WHERE ((batchtransferlinenr = ?) AND (lazylock = ?))
2008-12-03 10:30:26,609 DEBUG org.tbee.util.jdbc.PreparedStatement.invoke(PreparedStatemen t.java:139) #17256714: [3] setLong=52 / java.lang.Long / UPDATE batchtransferline SET from_amount = ?, dwhmodified = ?, lazylock = >>>HERE<<< WHERE ((batchtransferlinenr = ?) AND (lazylock = ?))
2008-12-03 10:30:26,640 DEBUG org.tbee.util.jdbc.PreparedStatement.invoke(PreparedStatemen t.java:139) #17256714: [4] setBigDecimal=18 / java.math.BigDecimal / UPDATE batchtransferline SET from_amount = ?, dwhmodified = ?, lazylock = ? WHERE ((batchtransferlinenr = >>>HERE<<< ) AND (lazylock = ?))
2008-12-03 10:30:26,640 DEBUG org.tbee.util.jdbc.PreparedStatement.invoke(PreparedStatemen t.java:139) #17256714: [5] setInt=51 / java.lang.Integer / UPDATE batchtransferline SET from_amount = ?, dwhmodified = ?, lazylock = ? WHERE ((batchtransferlinenr = ?) AND (lazylock = >>>HERE<<< ))
2008-12-03 10:30:26,687 DEBUG org.tbee.util.jdbc.PreparedStatement.invoke(PreparedStatemen t.java:139) #17256714: executeUpdate: UPDATE batchtransferline SET from_amount = ?, dwhmodified = ?, lazylock = ? WHERE ((batchtransferlinenr = ?) AND (lazylock = ?))
Only SQL number 2 is present.
For completeness the testcode:
// increment (causing an insert)
Batchtransferline lBatchtransferline = Batchtransferline.findByPK(18);
lBatchtransferline.setFromAmount(BigInteger.valueOf(100));
// commit
EntityManagerExtender.executeNextClearWithoutClearingRemoved Entities(lEntityManager); // if we're using EntityManagerExtender (which we should)...
lEntityManager.clear(); // prevent errors from a previous store session (not rollbacked optimistic lock increments) to screw things up
lEntityManager.getTransaction().begin();
lBatchtransferline = lEntityManager.merge(lBatchtransferline);
lEntityManager.persist(lBatchtransferline);
//lBatchtransferline.updateBatchcount(); // emulate application event
lEntityManager.getTransaction().commit();
System.out.println(" ------------------------------------------------------------ ---------------------- ");
// decrement (causing a remove)
lBatchtransferline.setFromAmount(BigInteger.valueOf(50));
// commit
Re: Entity must be managed to call remove [message #384220 is a reply to message #384215] |
Thu, 04 December 2008 14:14 |
I suppose making changes and adding new objects from within change events
is not really a good idea. The issue seems to be if you do not
persist/trigger the events before the commit, then they are not trigger
until the commit in the middle of the process that is auto-persisting new
objects, but this process has already process some of the objects that you
are changing, so it is really too late to be changing objects in this way.
So, if you ensure the events fire before commit, by calling persist on the
object with the persist event before commit (or ensure the persist will
cascade to this object). If you fire the events before commit, you should
be ok.
You could also try to call EntityManager.persist from within your
prePersist method, but updates will still be an issue depending on your
change policy.
James
http://www.nabble.com/EclipseLink---Users-f26658.html
James : Wiki : Book : Blog : Twitter
Re: Entity must be managed to call remove [message #384230 is a reply to message #384220] |
Thu, 04 December 2008 15:20 |
> events is not really a good idea. The issue seems to be if you do not
> new objects, but this process has already process some of the objects
> that you are changing, so it is really too late to be changing objects
> in this way.
I understand. However, then the capability of the @PrePersist event is severely reduced. For what is the event intended? Only update simple and internal properties?
> the object with the persist event before commit (or ensure the persist
> will cascade to this object). If you fire the events before commit, you
> should be ok.
For all means and purposes, my application level event is the same as @PrePersist, it only is triggered before the commit (as you suggest here).
Wouldn't it be a better idea to first fire the @PrePersist events on all objects first and then start really persist them? So really PRE persist and not somewhere inside the persist logic?
Again, I do not like the BM to be dependent on an trigger that is controller one layer up.
Would it be possible to register a listener on the EntityManager and fire an event upon executing the commit method?
Hmmm. AspectJ could do catch that... And I already confirmed that it can be combined with Eclipselink. Hm. Hm. Have to think about that one.
> change policy.
I already do a persist on the newly created Batchcount entity. So that won't work. Is there a way to force that entity into the persist logic?
Tom
Current Time: Wed May 08 06:07:07 GMT 2024
Powered by FUDForum. Page generated in 0.05755 seconds
