Home » Modeling » Modeling (top-level project) » Starting a CDO Server
Re: Starting a CDO Server [message #383558 is a reply to message #383555] |
Tue, 18 November 2008 19:18 |
Originally posted by: cdamus.zeligsoft.com
Hi, JF,
I don't have an answer for you, but Eike or Simon will in the EMF
newsgroup, which I have copied in this reply.
Christian
JF wrote:
> I'm trying to run through the CDO examples on the eclipsipedia. Do I
> still need to checkout the CDO Server sources from CVS
> (http://wiki.eclipse.org/Setting_up_a_CDO_Server) to get a server
> running or is their another way?
> Thanks
Re: Starting a CDO Server [message #383560 is a reply to message #383558] |
Tue, 18 November 2008 20:09 |
Simon Mc Duff Messages: 596 Registered: July 2009 |
Thank you Christian, I do not check modeling newsgroup!
Hi JF,
To setup a CDOServer from scratch you need :
1- Get the source code (see see
http://wiki.eclipse.org/CDO_Source_Installation)
or
Download the 1.0.2 version or 2.0.0 M3 version!
http://www.eclipse.org/modeling/emf/downloads/index.php?proj ect=cdo&showAll=0&showMax=5
2-Configure your CDOServer
If you are using 1.0.x, I think
http://wiki.eclipse.org/Setting_up_a_CDO_Server will work fine!
For 2.X, you need to slightly adjust the cdo-server.xml. Here an example:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.emf/org .eclipse.emf.cdo/features/org.eclipse.emf.cdo.server.product /rootfiles/configuration/cdo-server.xml?root=Modeling_Projec t&content-type=text%2Fplain&view=co
(Noticed the <jdbcDelegate type="statement" />)
Let us know if you have any others questions.
Simon
Christian W. Damus wrote:
> Hi, JF,
> Cheers,
> Christian
> JF wrote:
>> Hi,
>> Thanks
Re: Starting a CDO Server [message #613613 is a reply to message #383555] |
Hi, JF,
Christian
JF wrote:
> Thanks
Re: Starting a CDO Server [message #613615 is a reply to message #383558] |
Hi JF,
or
Simon
> Hi, JF,
> Cheers,
> Christian
> JF wrote:
>> Hi,
>> Thanks
Current Time: Fri Apr 26 03:31:48 GMT 2024
Powered by FUDForum. Page generated in 0.03329 seconds
