Home » Modeling » EMF » XSD 2.0
XSD 2.0 [message #382852] Wed, 10 March 2004 11:34 Go to next message
Originally posted by: jdmcduf.nsa.gov
I am getting an error message when reading a schema when I added the
pluging for EMF 2.0 and XSD2.0.
The error message is
Specify a valid XML Schema and try loading again
The Schema is valid checked in XMLSpy and also loaded it with EMF 1.1.1
and XSD1.1.1
Can anyone help?
Re: XSD 2.0 [message #382853 is a reply to message #382852] Wed, 10 March 2004 12:18 Go to previous messageGo to next message
Originally posted by: gerhard.wagner.iternum.com
I had the same problem after moving to 2.0 from 1.1,
make sure that you provide the needed startup property to exclipse.exe as
described on top of the EMF download page.
Additionally, I have to start eclipse.exe from the command line - using a
desktop link the property got not picked up, but that may be due
to my lacking windows skills :-))
cu
Gerhard.
"jdmcduf" <jdmcduf@nsa.gov> schrieb im Newsbeitrag
news:c2ng1t$99a$1@eclipse.org...
> and XSD1.1.1
> Can anyone help?
Re: XSD 2.0 [message #382854 is a reply to message #382853] Wed, 10 March 2004 13:54 Go to previous messageGo to next message
Gerhard,
still no luck. How much did you have to tailor the startup line?
> cu
> Gerhard.
> > and XSD1.1.1
> > Can anyone help?
Re: XSD 2.0 [message #382855 is a reply to message #382854] Wed, 10 March 2004 14:56 Go to previous messageGo to next message
JD,
When in doubt, check the workspace/.metadata/.log.
jdmcduf wrote:
> Gerhard,
> > cu
> > Gerhard.
> > > and XSD1.1.1
> > > Can anyone help?
Re: XSD 2.0 [message #382856 is a reply to message #382854] Wed, 10 March 2004 15:46 Go to previous messageGo to next message
news:c2no9q$kf0$1@eclipse.org...
> Gerhard,
My startup line is as follows ("Programme" equals "Program Files"):
C:\Programme\eclipse-3.0M6\eclipse.exe -vmargs -Djava.endorsed.dirs=c:\Progr
amme\eclipse-3.0M6\plugins\org.apache.xerces_4.0.13
(I use a desktop reference and fully qualified paths, to be able to choose
different workspaces by changing the
field "execute in".)
Gerhard.
Re: XSD 2.0 [message #382857 is a reply to message #382855] Wed, 10 March 2004 16:04 Go to previous messageGo to next message
Originally posted by: servaas.van.der.heijden.ict.nl
JD,
I got the same error message when I moved to 2.0. The message has no
relation with the provided xsd file, it's caused by a bug in the default
Crimson DOM implementation.
The next workaround is also described at the EMF download page:
The Crimson DOM implementation in (some versions of) the Sun JDK has
bug in the implementation of hasAttributeNS which manifests itself as
a null pointer exception when importing a model from XML Schema. Use
the following to control the JAXP implementation:
D:\applications\Development\eclipse3M6\eclipse.exe -vmargs
-Djava.endorsed.dirs=plugins/org.apache.xerces_4.0.13
After creating a desktop shortcut with this command everything worked OK.
Success!
Servaas
Ed Merks wrote:
> JD,
> jdmcduf wrote:
>>Gerhard,
>>>cu
>>>Gerhard.
>>>>and XSD1.1.1
>>>>Can anyone help?
Re: XSD 2.0 [message #382862 is a reply to message #382855] Thu, 11 March 2004 09:18 Go to previous messageGo to next message
Ed,
when loading a model from the XML Schema some .xsd's are processed(e.g.
Other.xsd). Some were processed with errors. Some are not even processed.
Some that were processed had errors were of this type:
Error: XSD: the element urn:<ElementName> may not overlap with another
element <ElementName2> Line 1178 Column 2
Where <ElemenName> was an element in the shema
For the ones are not processed in the log I get the following type errors
java.lang.reflect.InvocationTargetException
at sun.reflect.NativeMethodAccessorImpl.inovke0(Native Method)
(XSDConcreteCompnentImpl.java:544)
at org.eclipse.xsd.impl.XSDSchemaImpl.validate(XSDSchemaImpl.ja va:1512)
at org.eclipse.xsd.ecore.XSDEcoreBuilder.validate
(XSDEcoreBuilder.java:2023)
at org.eclipse.xsd.ecore.XSDEcoreBuilder.generate
(XSDEcoreBuilder.java:1562)
(XSDEcoreBuilder.java:1540)
... 43 more
This occurred on several xsd's. Even the xsd's in
plugins\org.eclipse.xsd.test_2.0.0\test\diagnostics\Okay.xsd
My command line was
eclipse.exe -vm C:\JBuilder8\jdk1.4\jre\bin\javaw -vmargs
The -vm was necessary to get the correct virtual machine.
Any ideas????
Ed Merks wrote:
> JD,
> jdmcduf wrote:
> > Gerhard,
> > > cu
> > > Gerhard.
> > > > and XSD1.1.1
> > > > Can anyone help?
Re: XSD 2.0 [message #382865 is a reply to message #382862] Thu, 11 March 2004 09:59 Go to previous message
JD,
Perhaps you are using the 20040225_1234SL build in which the xsd.jar is missing the
message.properties; this causes XSD to fail for any schema that uses xsd:pattern.
The I200403081633 build fixes this problem. I could not reproduce a problem for
Okay.xsd with this later build.
jdmcduf wrote:
> Ed,
> ... 43 more
> My command line was
> Any ideas????
> Ed Merks wrote:
> > JD,
> > jdmcduf wrote:
> > > Gerhard,
> > > > cu
> > > > Gerhard.
> > > > > and XSD1.1.1
> > > > > Can anyone help?
Previous Topic:EClass and EFactory as objects in an EMF resource
Next Topic:New type hierarchy
Current Time: Tue Jul 01 21:52:42 EDT 2025
Powered by FUDForum. Page generated in 0.03250 seconds
