Realize/Extend external interfaces [message #382607] |
Fri, 27 February 2004 12:59  |
I have an external set of interfaces that I would like to implement in
my EMF Model. But I cannot find the right way to design this with Rose.
For example, I have an interface MyInterface declared (not in EMF model)
outside my EMF model. I tried to declare a class MyClass in my EMF
model, as realization of MyInterface (declared as datatype). This seems
not work correctly, the generated model ignore completly my interface
MyInterface.
Secondly, I tried to extends MyInterface (instead of using realization
link), but the following error is generated in the wizard:
Problems were encountered converting the Rose model to Generator and
Core models
Cannot add super link between 'MyClass' and 'MyInterface' because the
later is not a class
So, I tried to create an abstract class MyAbstract that implements my
interface MyInterface, and extends this abstract class declared as
datatype in my EMF Model, but the similar error is generated:
Core models
Cannot add super link between 'MyClass' and 'MyAbstract' because the
An abstract class is not considered as a class by EMF?
I also tried to run a reverse engineering on my external model, and
reference these classes directly in my Rose diagram (without datatype
stereotype), but it doesn't work...
An EMF model cannot specialize an external declaration of class/interface?
Where is my mistake(s)?
David Baran
Re: Realize/Extend external interfaces [message #382609 is a reply to message #382607] |
Fri, 27 February 2004 14:08  |
--------------2746778B15876FBC92261565
Content-Type: text/plain; charset=us-ascii
David,
You should define your interface like this:
[Image]
I.e., use a class with an <<Interface>> stereotype and use a <<javaclass>>
attribute to point it at the right "external" implementation interface. EMF
will generate no Java code from this, but now you can define a class that
extends this interface and that will produce your desired result of a model
class that extends some external interface in Java. (Note that EMF ignores
realizations.)
David Baran wrote:
> Hello,
> MyInterface.
> Core models
> Core models
> Regards
> David Baran
Content-Type: multipart/related;
boundary="------------6721C68AEF61CDF10E6199A6"
--------------6721C68AEF61CDF10E6199A6
Content-Type: text/html; charset=us-ascii
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
David,
<p>You should define your interface like this:
<blockquote><img SRC="cid:part1.403F95BA.27EAA3D9@ca.ibm.com" height=130 width=455></blockquote>
EMF will generate no Java code from this, but now you can define a class
that extends this interface and that will produce your desired result of
a model class that extends some external interface in Java. (Note
that EMF ignores realizations.)
<br>
<p>David Baran wrote:
<blockquote TYPE=CITE>Hello,
<p>I have an external set of interfaces that I would like to implement
in
<br>my EMF Model. But I cannot find the right way to design this with Rose.
<p>For example, I have an interface MyInterface declared (not in EMF model)
<br>outside my EMF model. I tried to declare a class MyClass in my EMF
<br>model, as realization of MyInterface (declared as datatype). This seems
<br>not work correctly, the generated model ignore completly my interface
<br>MyInterface.
<p>Secondly, I tried to extends MyInterface (instead of using realization
<br>link), but the following error is generated in the wizard:
<p>--------
<br>Problems were encountered converting the Rose model to Generator and
<br>Core models
<br> Cannot add super link between 'MyClass' and 'MyInterface'
because the
<br>later is not a class
<br>--------
<p>So, I tried to create an abstract class MyAbstract that implements my
<br>interface MyInterface, and extends this abstract class declared as
<br>datatype in my EMF Model, but the similar error is generated:
<p>--------
<br>Core models
<br> Cannot add super link between 'MyClass' and 'MyAbstract'
because the
<br>--------
<p>An abstract class is not considered as a class by EMF?
<p>I also tried to run a reverse engineering on my external model, and
<br>reference these classes directly in my Rose diagram (without datatype
<br>stereotype), but it doesn't work...
<p>An EMF model cannot specialize an external declaration of class/interface?
<p>Where is my mistake(s)?
<p>Regards
<br>David Baran</blockquote>
</html>
Content-Type: image/jpeg
Content-ID: <part1.403F95BA.27EAA3D9@ca.ibm.com>
Content-Disposition: inline; filename="C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\nsmailJM.jpeg"
/9j/4AAQSkZJRgABAQAAAQABAAD/2wBDACAWGBwYFCAcGhwkIiAmMFA0MCws MGJGSjpQdGZ6
eHJmcG6AkLicgIiuim5woNqirr7EztDOfJri8uDI8LjKzsb/2wBDASIkJDAq MF40NF7GhHCE
xsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbG xsbGxsb/wAAR
CACBAccDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS 0fAkM2JyggkK
FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1 dnd4eXqDhIWG
h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW 19jZ2uHi4+Tl
5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcI CQoL/8QAtREA
AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMz UvAVYnLRChYk
NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0 dXZ3eHl6goOE
hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU 1dbX2Nna4uPk
5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwDUtoFktYnZ5izICT5rdcfW pPs0f96b/v8A
P/jRZ/8AHlB/1zX+VTVldltu5D9mj/vTf9/n/wAaPs0f96b/AL/P/jU1FF2K 7Ifs0f8Aem/7
/P8A40fZo/703/f5/wDGpqKLsLsh+zR/3pv+/wA/+NH2aP8AvTf9/n/xqaii 7C7Ifs0f96b/
AL/P/jR9mj/vTf8Af5/8amoouwuyH7NH/em/7/P/AI0fZo/703/f5/8AGpqK LsLsh+zR/wB6
b/v8/wDjR9mj/vTf9/n/AMamoouwuyH7NH/em/7/AD/40fZo/wC9N/3+f/Gp qKLsLsh+zR/3
pv8Av8/+NH2aP+9N/wB/n/xqaii7C7Ifs0f96b/v8/8AjR9mj/vTf9/n/wAa moouwuyH7NH/
AHpv+/z/AONH2aP+9N/3+f8Axqaii7C7Ifs0f96b/v8AP/jR9mj/AL03/f5/ 8amqC6maFV2q
ME4Ltnanucf/AFhx1FF2F2L9mj/vTf8Af5/8aPs0f96b/v8AP/jTJJ3igjYM sm/kykfIo9eO
36YHJ9YZ5WiKzB1lZbaVw2ODyp7dqNQuyz9mj/vTf9/n/wAaPs0f96b/AL/P /jVa4lucGPei
OHibKgkYZ8Y689OvcdhT3u5BdtGikqjqhURsc5AOdw4GM9Pb3o1C7Jvs0f8A em/7/P8A40fZ
o/703/f5/wDGqkjTXLwiTyvJNw6FCpO4Lu68+3T1wfanC/dfMLBXAiaUbUZR 8uOAx+9nPUf1
o1C7LP2aP+9N/wB/n/xo+zR/3pv+/wA/+NMllnt4GeQo5yoUoh7nH3cnOM54 PPTimrPI1u7v
IsPlvjzJIyqsMDqrHI6469R+FGoXZL9mj/vTf9/n/wAaPs0f96b/AL/P/jTP Pd7XzWZbYqes
g+U9uc4P8ufbrJbytNFveMoc9Dnn8wD+YFF2F2J9mj/vTf8Af5/8aPs0f96b /v8AP/jU1FF2
F2Q/Zo/703/f5/8AGj7NH/em/wC/z/41NRRdhdkP2aP+9N/3+f8Axo+zR/3p v+/z/wCNTUUX
YXZD9mj/AL03/f5/8aPs0f8Aem/7/P8A41NRRdhdkP2aP+9N/wB/n/xo+zR/ 3pv+/wA/+NTU
UXYXZD9mj/vTf9/n/wAaPs0f96b/AL/P/jU1FF2F2Q/Zo/703/f5/wDGj7NH /em/7/P/AI1N
RRdhdkP2aP8AvTf9/n/xo+zR/wB6b/v8/wDjU1FF2F2Q/Zo/703/AH+f/Gj7 NH/em/7/AD/4
1NRRdhdkP2aP+9N/3+f/ABo+zR/3pv8Av8/+NTUUXYXZD9mj/vTf9/n/AMaP s0f96b/v8/8A
jU1FF2F2Q/Zo/wC9N/3+f/GipqKLsLshs/8Ajyg/65r/ACqaobP/AI8oP+ua /wAqmpMHuFFF
FAgooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooARVCj CgAZJ4Hc1G9v
C4IZBgqynHHDdfzqO/UNbBWAKmWMEEcEb1ppCWtwFhVI0MTuy/dXIK4J9Op5 /wAKYE0tvFLu
3qcsFBIYg/Kcjp7mhreJpfMKndkHG44JHQkdCenPsPSqUlzPIjIrhXV4jvMT JkM+MYJz269+
lTz3TxXAUFSu9UKhGPUgct0HXp/jQBOIIxtwv3XLjnoTnJ/U0xbO3RiwjGSp Tkkjaf4cHtx0
6VAsaSxtNJbmeXzXUEY3KAxAwSRjGO3fmnR3UjkFCnlCBZS0hwTnd1xwOnXt 6egBMtrEEZcM
d2MlnLHjpyTnjt6U6OCOMAKucHdljuOcYzk89OPpVQXsu2RQFd1MeC0bRg7m xjBye3X/AAok
kmeSJPkMsdxs3YIU/uyc4/HpnnHagC8VBIJAJU5GR0NLUVtIZYtzAbgzKcdC QSM/pUtIAooo
oAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiig CpaXCLaQgrLk
RqOImPb6VL9qj/uy/wDfl/8ACiz/AOPKD/rmv8qfNKsKbmyewA6k+gp2uxya Tdxn2qP+7L/3
5f8Awo+1R/3Zf+/L/wCFKbmERLKZBtY4HqT6Adc+3Wg3EaxCSTMYY4UMME+m B1yfTrRYLoT7
VH/dl/78v/hR9qj/ALsv/fl/8KPPXKlj5YKM2HGDgEc+3Xoeee2DQl1E7BQW DMcBWQqehPQj
2PPtQGgfao/7sv8A35f/AAo+1R/3Zf8Avy/+FIbuBernqQSFJC4JBJ44GQeT 6GnNcRLL5ZY7
sgZ2nAJ6AnoD049x60BoJ9qj/uy/9+X/AMKPtUf92X/vy/8AhTEu18vdJncX dQqKWOFYjOBk
+n5097qFNuXyCN2VBIA9SR0HuaA0D7VH/dl/78v/AIUfao/7sv8A35f/AApW uIll8ssd2QM7
TgE9AT0B6ce49aFuIzL5TZSTJwrDG76ev4dO9AaCfao/7sv/AH5f/Cj7VH/d l/78v/hSrcRm
XymykmThWGN309fw6d6dLKkS7nJ5OAACST7AcmkGgz7VH/dl/wC/L/4Ufao/ 7sv/AH5f/Chr
qIIrZY7s4CoWPHXgDPHf0pGvLdGCmQZKh+ASNp/iyO3HXpTDQX7VH/dl/wC/ L/4Ufao/7sv/
AH5f/Ck+2W/ltIZAEUjJIIHJwD9D69KFu4GYKHIYnBBUgqe2eOM9s9e1AaC/ ao/7sv8A35f/
AAo+1R/3Zf8Avy/+FKtxE0vlhjuyRnacEjqAehPXj2PpUYvYJIXeOUYCFwxU 4x6++O+PpQGg
/wC1R/3Zf+/L/wCFH2qP+7L/AN+X/wAKkkdY0LucAVH9qi8vflsZ27dh3Z9N uM9OenTmkGgf
ao/7sv8A35f/AAo+1R/3Zf8Avy/+FMivUaESMd253C+WpbIDEZwM+3PvT7ib y7OWeMq22Mup
6g8ZFMNBkssM0ZSRJipIPEbg5ByOQKahtkVl8uZg4w2+ORiR6ZI6dePenh5o pY1mZHEh2qUU
rg4J5yT2B/z0SW+iSCWRdz7ELAbSNw9jjkdORxzQGhFstNrjy5/n27m2Sbjg 5HPXinP9lkkE
jxSlgQ3+qfGR0OMdeOvpxUz3USbdxYZG77h+UercfL+OOh9KaXmllkWFkQRn axdS2TgHjBHY
j/PUDQjk+zSOWZJ+fvAJIA31AGD+NPMsDM7NHKS6hWzC5BAzxjHuaf8AaFUx pN8ksmcJ1zg4
OMfXP09OaQXcBV23kKiliSpAKjqRxyPp7UBoVZYrYxsqRykuyby8cjbgrZ5y DnjNTIbZNuI5
sq24ExyE5xjJJHPBxzTpb2NYTJG64V0BLcDaWAz9MZwenFTRSpKu5CeDgggg g+4PIoDQiSaG
NSqJKASW/wBU/UnJ7epp32qP+7L/AN+X/wAKmopBoQ/ao/7sv/fl/wDCj7VH /dl/78v/AIVN
RQGhD9qj/uy/9+X/AMKPtUf92X/vy/8AhU1FAaEP2qP+7L/35f8Awo+1R/3Z f+/L/wCFTUUB
oQ/ao/7sv/fl/wDCj7VH/dl/78v/AIVNRQGhD9qj/uy/9+X/AMKPtUf92X/v y/8AhU1FAaEP
2qP+7L/35f8Awo+1R/3Zf+/L/wCFTUUBoQ/ao/7sv/fl/wDCj7VH/dl/78v/ AIVNRQGhD9qj
/uy/9+X/AMKPtUf92X/vy/8AhU1FAaEP2qP+7L/35f8Awo+1R/3Zf+/L/wCF TUUBoQ/ao/7s
v/fl/wDCj7VH/dl/78v/AIVNRQGhD9qj/uy/9+X/AMKPtUf92X/vy/8AhU1F AaEP2qP+7L/3
5f8AwoqaigNCGz/48oP+ua/yqpeR3X2rdGglDjahPAj9c+3fP4elTWlwi2kI Ky5EajiJj2+l
S/ao/wC7L/35f/CrjJxd0KpT57pojisUjiCl3MuSxlBwcn+nA46cCpGg3ovm OxkXOJF+U/56
ZHQ46Ufao/7sv/fl/wDCj7VH/dl/78v/AIVLbbuwUbaJELB2uljWYGRIXUuA CVJK7cj14/HB
piWUo85iVDMEKAyM+GUkjJPOM49O/wBTZ+1R/wB2X/vy/wDhR9qj/uy/9+X/ AMKNR2ZWubGV
7cQQyfIIvLXc7DGB1IH3s8demO/Sp1jmjnkKbCkjhyxJyOAMY79Oue/ty77V H/dl/wC/L/4U
fao/7sv/AH5f/CjULMha1m8sIrjG92IDsv3mJByOTgHpxnPXim/ZJlhgRCgd IlQuHZSpHfA4
Yexx39asfao/7sv/AH5f/Cj7VH/dl/78v/hRqFmMeCU3QkTaoJBLB2H1BXoc jjP+FP8AI3Sb
5XZ8HKr0VfTjv26556Yo+1R/3Zf+/L/4Ufao/wC7L/35f/CjULMPI3Sb5XZ8 HKr0VfTjv265
56YouI3fynj2lo33BWOAeCOvOOtH2qP+7L/35f8Awo+1R/3Zf+/L/wCFAWYx 4598cwEbSKrK
VLFRgkHrg9MenPt0qP7E628sSsp3WywqTxyAwyfzFT/ao/7sv/fl/wDCj7VH /dl/78v/AIUa
hZjJrZ5JmcFcHyuv+y5Y/oaHtnbzcFfnmSQfQbM/+gmn/ao/7sv/AH5f/Cj7 VH/dl/78v/hR
qFmRpbyLKgOzy45WlDAnJLbuMY4+91z296r3MBhsUV2Tctq0AGeWchcAev3T Vz7VH/dl/wC/
L/4Ufao/7sv/AH5f/CjULMWZGkiddqHkbck89D26H3HTg+1Qi3nEcbZUvHJv VGckAbSMbiMn
qT09ql+1R/3Zf+/L/wCFH2qP+7L/AN+X/wAKAsyGO3ni2SBY2kBkypcgYZt3 XHbHpT2tn/s9
rRSp/c+WrHjJxjkdu1P+1R/3Zf8Avy/+FH2qP+7L/wB+X/wo1CzGhJpZY2mV EEZ3KEYtk4I5
yB2J/wA9azWNw/mF5FJaF48l2OScfNg8L06Dp79rf2qP+7L/AN+X/wAKPtUf 92X/AL8v/hRq
FmQXtrcXUZUMq7o9uN7AKe/T72eBz0x0OcVJLA+6TbFFMkpDMspxggAehz0H +ej/ALVH/dl/
78v/AIUfao/7sv8A35f/AAo1CzGQWnkSRbSu1EcEAY5ZgeB2HB/Sqk9rNHDc SyuGxbyKTvYl
icHODwM46Dp79r32qP8Auy/9+X/wo+1R/wB2X/vy/wDhRqFmRNbTSMzuUDEx j5c4IRt2fbOT
xz9amhjKSTsSMSOGGPTao/pSfao/7sv/AH5f/Cj7VH/dl/78v/hRqFmTUVD9 qj/uy/8Afl/8
KPtUf92X/vy/+FKwWZNRUP2qP+7L/wB+X/wo+1R/3Zf+/L/4UWCzJqKh+1R/ 3Zf+/L/4Ufao
/wC7L/35f/CiwWZNRUP2qP8Auy/9+X/wo+1R/wB2X/vy/wDhRYLMmoqH7VH/ AHZf+/L/AOFH
2qP+7L/35f8AwosFmTUVD9qj/uy/9+X/AMKPtUf92X/vy/8AhRYLMmoqH7VH /dl/78v/AIUf
ao/7sv8A35f/AAosFmTUVD9qj/uy/wDfl/8ACj7VH/dl/wC/L/4UWCzJqKh+ 1R/3Zf8Avy/+
FH2qP+7L/wB+X/wosFmTUVD9qj/uy/8Afl/8KPtUf92X/vy/+FFgsyaioftU f92X/vy/+FH2
qP8Auy/9+X/wosFmTUVD9qj/ALsv/fl/8KPtUf8Adl/78v8A4UWCzJqKh+1R /wB2X/vy/wDh
RRYLMLP/AI8oP+ua/wAqmqGz/wCPKD/rmv8AKs7VJLiO6RmJWMH90yngNjnP v1/D8auMeeVi
lHmlY16Kp22oJLbrJIrBiSMIhbdjqQBk45qY3UAcL5q5Kb/bbzzn046/T1FS 007EPQmoqFbq
IozZYbcZDIVPPTgjPPb1pjXsYeFVDnzH2fcIKnGeRjjt17HPSkBZoqJbiJpf LDHdkjO04JHU
A9CevHsfSq8U9z9mguJGiZZNmUVCCNxA65PTPpQBdoqJbiJpfLDHdkjO04JH UA9CevHsfSo5
b6JIJZF3PsQsBtI3D2OOR05HHNAFmiq7SySSeXAVQhA5aRCeDnAxkeh/z0Y1 4YyiybQRL5bk
A8/IWGB78cfhz1osBboqH7RGSp8xQpRmORjoRnJ7YzyD/ShbqIozZYbcZDIV PPTgjPPb1oAm
oqs17GHhVQ58x9n3CCpxnkY47dexz0o+1opZpCFj3+WnBJZhnP6gjHt3yKLA WaKha6iCK2WO
7OAqFjx14Azx39KRry3RgpkGSofgEjaf4sjtx16UAT0VCt1CyM4fhcdjznpj 1z2x17UfaovL
35bGdu3Yd2fTbjPTnp05oAmoqBruBQmXOXBKgKSTjqMYzken19KV7qFNuXyC N2VBIA9SR0Hu
aAJqKia4iWXyyx3ZAztOAT0BPQHpx7j1oW4iaXywx3ZIztOCR1APQnrx7H0o AloqsLlzYwT4
XdJ5eR2+YgH+dRme5EE1xui2Rl/k2HJCkjrn29KLAXaKihkLyTqQMRuFGPTa p/rUisGGRnqR
yMUALRVMXEzvII3h3oW/cEfOQDjrnjPHOO4608XsWZ/MzGsLhCzAgc49vU/1 70WAs0VXN3Eo
JeTALhQNhBztDYx6/wD6utOa6hVFcvw2ex4x1z6Y756d6AJqKbG6yxrIhyrA MD6g1C12iTzR
uGURRiRm2nGOc9vb+fpQBYoqKW4hi3eY4XaFLE9ACcD9RSfaovL35bGdu3Yd 2fTbjPTnp05o
AmoqrLeBJIioDRMrFz0K4KjP4Z5z0wfTFOFyFabzOAkgRQqkk/KD0HXqfwFF gLFFQNdwKEy5
y4JUBSScdRjGcj0+vpSpdQPu2yqQo3bv4SO5B6HHfHSgCaio4pkmzs3AjqGU qfyNPDAkgZ4O
ORQAtFVXnka5aFJoYmBwqupLOMZyORx1H4GlW8AeRZkaMxxCR+CQM5yM45xj 8efSiwFmiq/2
uEbnaVRGApyQRjJIBz6HH9ehp32qLy9+Wxnbt2Hdn024z056dOaAJqKrpcq8 kZRleGXKqw/v
DPHvkA/l7ip9w3BeckZ6cfnQAtFV53m+0RxQsi7kZiXUt0Kj1HrQtyFVxN99 H2HYpO44B4HX
oenbn0zQBYoquLtGuIolDHzEZt208YIGDx9fpj3oN7CI5HBYhEL/AHSNwHdc 9fqPUUAWKKrG
SeHa8xjZGYKVRSCpJwOc88n0Hr7UW92krFGIDh3XABxwxGM9M4GcfjQBZoqu LuIRxs0m7cgb
cqHAB7n+6Pr/AEp7XESy+WWO7IGdpwCegJ6A9OPcetAEtFQ2twLmIuFZcOy4 YEdDjv8A57UU
AFn/AMeUH/XNf5VJLEk0bRyqGRhgg1HZ/wDHlB/1zX+VZ2qSXEd0jMSsYP7p lPAbHOffr+H4
1cI80rJlqPNKxoSROskUkCodiFAhO0YOPQH+70xTZLZ5fPDuv72ER5A6H5sn H/AvWmW2oJLb
rJIrBiSMIhbdjqQBk45qY3UAcL5q5Kb/AG28859OOv09RUtNOxDViFLWVY5S MJI4Uf613JAO
cbjyM5I4HHWmw2k0bKxKE+f5hBdjhdm3GTkkj9farC3URRmyw24yGQqeenBG ee3rTGvYw8Kq
HPmPs+4QVOM8jHHbr2OelGoDIbNo7necFQ7OGMjHk5429B168/rwkGnpAts6 RxCaIAOwX73G
Dzj8c/h3NWFuIml8sMd2SM7TgkdQD0J68ex9KrxT3P2aC4kaJlk2ZRUII3ED rk9M+lGoD0t5
FlQHZ5ccrShgTklt3GMcfe657e9RfYpmt/KJQbLdoEIJO7IAyeOPu+/WrS3E TS+WGO7JGdpw
SOoB6E9ePY+lRy30SQSyLufYhYDaRuHsccjpyOOaNQFZJlk86NULsgV0ZiAM ZPBx7nt+XdjW
8wKSqEaXzfMZSxC/cK4Bwfb/AOtT2lkkk8uAqhCBy0iE8HOBjI9D/noxrwxl Fk2giXy3IB5+
QsMD344/DnrQBD5HmSG33ruMUwk287C7Agfz9M4qRbN9jkhVclCAZWfO1twB J6flx71P9ojJ
U+YoUozHIx0Izk9sZ5B/pQt1EUZssNuMhkKnnpwRnnt60AMaOeQwOwjDJLuK hjgLtI645POe
g/rTIoyZFTIDQzvI2e6sGwR/31j8D6U9r2MPCqhz5j7PuEFTjPIxx269jnpS G8xOqlCUklMS
kAnkA5J/EYx7E9KAGtazeWEVxje7EB2X7zEg5HJwD04znrxTVspBayRbk3Na rCOTjcA36cir
QnjO3DfecoOOpGcj9DTIry3lXckg27d24ggY7nJ9O/p3o1AZc2rTPKQQAyx4 5IOVYt1HTqOa
aLRxAQETeX34Mr56Y+/1z+HTj3qxFMk2dm4EdQylT+Rp4YEkDPBxyKAKRWeO 4twCjyCKTIYn
GNy8buvHHOOce9NuLCZ7VbeOQFVhEYJZlAIGM4HXPHXpjv0qaRroXSxLLCFd WYZiJIAI4+97
1MJ4ztw33nKDjqRnI/Q0ARrHNHPIU2FJHDliTkcAYx36dc9/bmOGzaO53nBU OzhjIx5OeNvQ
devP68SxXlvKu5JBt27txBAx3OT6d/TvTXu18ppEziMgyK6lSF7nB59T74Io ARLeQRx27bPJ
iK4YE7iFIIGMYHQZOfwGeGf2egXeI4vtAlMivt6/MSATj0OPbr2q4zBRk56g cDNRXUjxQ7o9
u4uqgsMgZYD+tACwxlJJ2JGJHDDHptUf0qRc4+YAHJ6HPFQLK8Unl3DocoXD qNoAGM5yT6jn
P8uUlvo0i3hXJ3qpUowIycZxjPr9cYpANnhuJkaJliYEkpKWwyZzggY6jPr2 7UrW8jNN9za8
0cinJzgbcg8f7P61K1xEsvlljuyBnacAnoCegPTj3HrUYknm3PCY1RWKhXUk sQcHnPHI9D6+
1MA+zP8AaPMyuPO8z8PL2/zqF1NqyO0sSHMoBkJCgM27OfUenGeeeKkS/jMg 3HajRJIuRyAc
5Jx0AwOegqU3CJ5m587X24VSTnAOMd/Xjt9KAGWRdLe1iaNh+5BYn+EgKMH8 z+VO2mO6kmYo
IjEoJJwQQSfy5/Sla6iCK2WO7OAqFjx14Azx39KSO6SW5eFASFRXDgHBBz36 f59qAKaRbNN/
dn70yBSwyMB1VT75Cg++amktJZFLttEhl8zYsjKPu7cbgM+/T296u0UXAqxW m1o9wQoEkVly
WyWYHv16Hk0xbSdIpFEu/MgblypZQoGCw5B4zkdce9XaKVwKlraSQNEXZW2C QEgnncwI6/T1
/Om/Yna3iiZlG22aFiOeSFGR+Rq7RRcCtaQNEzu6hWYAf61pDgZ7t9emKsDO TkADPGD1FLRQ
BWmSZi6GKGeJiDtkbGOnGNpzyM596ja0mMcse9X32wi3sTksN3J+u71q7RRc CtNbPJMzgrg+
V1/2XLH9DUc6GF2nZ0H77eu8kL/q9vJxx3/Qd6u0UXAz7XL/AGdchmWWSZmA wCpLAH8d2R7A
1f53DgbccnPOf85paKAK86TfaI5YVRtqMpDsV6lT6H0pr28pjYhhvkfe6hyo PGMBhyOg5747
Zq1RQBTtrWWB4SSjBRIGOTn5mBBGc+nc/nTFsZXkYzyZVonjYh2JOcfMAeF6 HgdPftfop3Ar
GOebakwjVFYMWRiSxByOMccj1Pp71GI3hKtO0UcMUryB9/XcWwDkDH3vXtV2 ilcDMSxeS3hy
v3rdI3VpGTbgHqB97r0OOnvVtY5o55CmwpI4csScjgDGO/Trnv7c2KKdwIba N4kdX2/6x2GD
nILE/wBaKmopAQ2f/HlB/wBc1/lUksSTRtHKoZGGCDUdn/x5Qf8AXNf5Vnap JcR3SMxKxg/u
mU8Bsc59+v4fjVwjzSsmWo80rGhJE6yRSQKh2IUCE7Rg49Af7vTFNktnl88O 6/vYRHkDofmy
cf8AAvWmW2oRy26yS/ISSMgHBx1Yf7Pv0HrUpu4AqNvJV1DAhSQFPQnjgfX3 qWmnYhqxElrK
scpGEkcKP9a7kgHONx5GckcDjrTYbSaNlYlCfP8AMILscLs24yckkfr7VKs7 zvNHCRG0T7SX
jJBGM+3r/nNFpPI8MMk7pmcAoqIRgkE46nsPagBkNm0dzvOCodnDGRjyc8be g69ef14SDT0g
W2dI4hNEAHYL97jB5x+Ofw7mpmu4FwC5JYsAApJJU4OAB2pXuoU25fII3ZUE gD1JHQe5o1Aj
S3kWVAdnlxytKGBOSW3cYxx97rnt71F9ima38olBst2gQgk7sgDJ44+779an e5VJJC7KkMWF
Zj/eOOPbAI/P2NO+1ReXvy2M7duw7s+m3GenPTpzRqA1kmWTzo1QuyBXRmIA xk8HHue35d2N
bzApKoRpfN8xlLEL9wrgHB9v/rVI13AoTLnLglQFJJx1GMZyPT6+lKl1A+7b KpCjdu/hI7kH
ocd8dKAKnkeZIbfeu4xTCTbzsLsCB/P0zipFs32OSFVyUIBlZ87W3AEnp+XH vU63URRmyw24
yGQqeenBGee3rSG7gVA7OQC20AqQd2M4xjOcfnx60agNaOeQwOwjDJLuKhjg LtI645POeg/r
Uccb71Rdu6G4aRgTjKtuwR/31+YNTtdRBFbLHdnAVCx468AZ47+lD3UKbcvk EbsqCQB6kjoP
c0ARQIjajNIjbgo5IOQGOAw/AIvHvUFtbSXFjEJGRVNqY1K5JIYDkj2x68+1 XWuIll8ssd2Q
M7TgE9AT0B6ce49ajNy4sZ58Luj8zA7fKSB/KgAtIGiZ3dQrMAP9a0hwM92+ vTFWBnJyABnj
B6iq4e5lmmWOSJFjcKA0ZYn5Qf7w9aLW5Nww+UKphjkA7gtnj9BQBI0ZN1HL kbVRlPrklf8A
A1DAiNqM0iNuCjkg5AY4DD8Ai8e9WgwJIGeDjkVWeeRrloUmhiYHCq6ks4xn I5HHUfgaAK9t
bSXFjEJGRVNqY1K5JIYDkj2x68+1OkgZLadWUCSdREo81pCSc927DJPA4AJ5 qdbwB5FmRozH
EJH4JAznIzjnGPx59KX7XCNztKojAU5IIxkkA59Dj+vQ0agTtnHygE5HU44q K6jeWHbHt3B1
YBjgHDA/0o+1ReXvy2M7duw7s+m3GenPTpzT4pY5oxJEwZCSAR0ODikBD5U0 jGRykUgRkTYd
wGccnIGeg4/x4gFlOPNYbNzGMqrSs2NrZI3Hn9P8Taa4C3cdvtbLoW3YOBjH +P8AL1FBuoRG
shf5WjMoOD90Yyf1FMCG4tZppwwcbA6MMuwwAQSNo4PQnJ+nvTxHPDuSERsj MWDOxBUk5PGO
eT6j096et1CyM4fhcdjznpj1z2x17VHNebUjeFDJlyrKQQ2Apbp1zxwD1/HN AEb2ciq8MWwx
PAsO5mO5QNwzjHPX2pvlfajLJEwZROHUhyoceWF4Yfj09MVY+0qJZMsvlLGj hhzncWHHr0GP
rSm7gVA7OQC20AqQd2M4xjOcfnx60ARpbyw+U8SoWUOCrO2PmIOdxyT0/HPb pUkcci3TSMUK
tEqkjIO4E9vTn1pY7qGRwiPkn2PX0+vt1pYriKVtqMScZGVIDD1BPUe49RQB LRSbhuK85Az0
4/Oq887rcCJZYocgFTIM7ySRgcjpgevUUgLNFVkuWE8cEsZEjKxyAccHAP49 evHA70LewMok
WUGPYz52nkDGSD7Z/wA4NFgLNFQrdQsjOH4XHY856Y9c9sde1M+1oxVoyGj3 +W/BBVjjH6kD
Hv2waALNFIWAIBzyccCoL15ord5YWQeWjMQ6k5wM+oxQBYoqKNmVhHNIjSMC w2oVGBj3PrTP
ttv8v7z7yBx8p+6e59B79u9AFiiomuIll8ssd2QM7TgE9AT0B6ce49aloAKK KKACiiigAooo
oAKKKKACiiigAooooAhs/wDjyg/65r/KpJYkmjaOVQyMMEGq9tOsdrEjJMGV ACPKbrj6VJ9p
j/uzf9+X/wAKdmU07kV0Vt5IXV4ogqNGPM+VQDj+WOnGfwquli8lvDlfvW6R urSMm3APUD73
XocdPerv2mP+7N/35f8Awo+0x/3Zv+/L/wCFGorMIY3Sa4Ztu2RwykHn7oBz +VQTJ9n0qON2
XzI0XYM/edcEAeuSOlT/AGmP+7N/35f/AAo+0x/3Zv8Avy/+FFmFmQNG8Fxa xwbW8uF1Ac4y
AUHUdPypj6c21EBDr5KwtmRkGBnnA+916Ej681a+0x/3Zv8Avy/+FH2mP+7N /wB+X/wo1CzI
WjLTTRZAZ5Y5lz0Kjbn8fl/UetOkt5T5xRh88ofaHK7htAxuHI5GePT3qT7T H/dm/wC/L/4U
faY/7s3/AH5f/CjULMitbSSBoi7K2wSAkE87mBHX6ev5037E7W8UTMo22zQs RzyQoyPyNT/a
Y/7s3/fl/wDCj7TH/dm/78v/AIUahZkKWjiOUsiB3CgAyu/Q5+8eR14wOOvN MeOeP7MMqX84
lVZiwA2NxuPJ789s98VZ+0x/3Zv+/L/4UfaY/wC7N/35f/CjULMha1m8pFVw Ms7MA7KAWOc5
GCcZIxxn2oht57dY/L8tm8lImLE4Urnkcc9enHSpvtMf92b/AL8v/hR9pj/u zf8Afl/8KNQs
yF7Nmu2k4KM6uSZGGCAONo4P3ep9fanPbyGOS3XZ5MpbLEncAxJIxjB6nBz+ BxzJ9pj/ALs3
/fl/8KPtMf8Adm/78v8A4UahZkMunxzG4aRIy8jAo5UErhQB+o6VNHG4uHlf aN0aLgHOCCxP
86PtMf8Adm/78v8A4UfaY/7s3/fl/wDCjULMlGcnIAGeMHqKrzJMxdDFDPEx B2yNjHTjG055
Gc+9P+0x/wB2b/vy/wDhR9pj/uzf9+X/AMKLMLMga0mMcse9X32wi3sTksN3 J+u71qSa2eSZ
nBXB8rr/ALLlj+hp/wBpj/uzf9+X/wAKPtMf92b/AL8v/hRqFmQToYXadnQf vt67yQv+r28n
HHf9B3p1m7rBGCu/zJXyyjAwSxDfQ8fmKl+0x/3Zv+/L/wCFH2mP+7N/35f/ AAo1CzB43N3F
Ku3aqMrZPPOCMflVIon2PUZY23IyMFYHIYYLZB/3nYfhV37TH/dm/wC/L/4U faY/7s3/AH5f
/CjULMhktZZhKZCgdggG0kA7WLZz1Gc++PelitXUxsQqkSmRhvZ/4CvU9e3p /jL9pj/uzf8A
fl/8KPtMf92b/vy/+FGoWZCLOSNpvLkAVlUIOQQAzErnsOcAjoPpSQWcsbqz MvE3mfeZuPL2
4yeTz/kdKn+0x/3Zv+/L/wCFH2mP+7N/35f/AAo1CzGJbOvlZK/JM8h+h34/ 9CFMsrNrdl3Y
PlpsDeYzEjjnB4Xp0Gf05m+0x/3Zv+/L/wCFH2mP+7N/35f/AAo1CzJedx4G 3HBzzn/OKhmW
YsdixyxsuCkjbQOuexznP6e9L9pj/uzf9+X/AMKPtMf92b/vy/8AhRZhZkcN vJHJA3yFVVww
yflDEEAccgYx2/pUbWUhtY4tybltWhPJxuIX9ODVj7TH/dm/78v/AIUfaY/7 s3/fl/8ACjUL
MiuojulmLKFxHjOeqsW59ByOe3JqCNjNvGUZpbhXUocrtUISc9wMYz6+lXPt Mf8Adm/78v8A
4UfaY/7s3/fl/wDCjULMlOcjABGecnoKjuozNazRKQGdGUZ6ZIpPtMf92b/v y/8AhR9pj/uz
f9+X/wAKLMLMi1FEljjiLfOz4VQeSD8rED2ViaZcRyTXVxFGU2yQKjbs5AJf kfT07+oqx9pj
/uzf9+X/AMKPtMf92b/vy/8AhRqFmQvZs120nBRnVyTIwwQBxtHB+71Pr7Vc qH7TH/dm/wC/
L/4UfaY/7s3/AH5f/CizCzJqKh+0x/3Zv+/L/wCFH2mP+7N/35f/AAoswsya ioftMf8Adm/7
8v8A4UfaY/7s3/fl/wDCizCzJqKh+0x/3Zv+/L/4UfaY/wC7N/35f/CizCzJ qKh+0x/3Zv8A
vy/+FH2mP+7N/wB+X/woswsyaioftMf92b/vy/8AhR9pj/uzf9+X/wAKLMLM moqH7TH/AHZv
+/L/AOFFFmFmWKKKK1JCiiigAooooAr3P+vtP+up/wDQGqxRRQAUUUUAFFFF ABRRRQAUUUUA
FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU UUUAFFFFABRR
RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAf//Z
--------------6721C68AEF61CDF10E6199A6--
--------------2746778B15876FBC92261565--
FUDForum. Page generated in 0.04094 seconds
