[xtext] Couldn't load xmi file (org/openarchitectureware/xtext/xtext.xmi) [message #381952] |
Mon, 21 April 2008 10:47 |
Originally posted by: philipp.kutter.org
Hi.
I posted the same message on the 14th April on
www.openarchtectureware.org, and I assume no answer will come.
Thus I repost here:
I installed the newest oaw4.3b on eclipse 3.4m6 and EMF 2.4m6
Then I try an example xtxt file, and get the following.
Any ideas, what I am doing wrong?
Best, Philipp
0 INFO WorkflowRunner -
16 INFO WorkflowRunner - openArchitectureWare 4.2.1, Build 200803080335NGT
16 INFO WorkflowRunner - (c) 2005-2007 openarchitectureware.org and
contributors
16 INFO WorkflowRunner - running workflow: generate.oaw
1359 INFO StandaloneSetup - Registering platform uri 'C:\workspaces\xtext'
1406 INFO StandaloneSetup - Adding generated EPackage
'org.openarchitectureware.xtext.XtextPackage'
1438 INFO WorkflowComponent - grammar :
...//cmpwk.dsl/src-gen//org/example/dsl/cmpwk/parser/cmpwkds l.g
1438 INFO WorkflowComponent - -o
1438 INFO WorkflowComponent - .
1641 INFO CompositeComponent - Workflow: executing workflow
org/openarchitectureware/xtext/Generator.oaw in generate.oaw:3
org/openarchitectureware/xtext/parser/Parser.oaw in
org/openarchitectureware/xtext/Generator.oaw:8
1641 INFO CompositeComponent - ParserComponent
Replacing org.openarchitectureware.xtext.impl.AlternativesImpl@1ebd75b
(cardinality: NULL)Alternatives: with Group:
Replacing org.openarchitectureware.xtext.impl.AlternativesImpl@ec4a87
(cardinality: ANY)Alternatives: ANY with
Assignment:CapabilityModel.capabilityTree ANY
Replacing org.openarchitectureware.xtext.impl.AlternativesImpl@110fe28
Assignment:CapabilityModel.connectors ANY
Replacing org.openarchitectureware.xtext.impl.AlternativesImpl@9e29fb
Assignment:CapabilityModel.valueChains ANY
Replacing org.openarchitectureware.xtext.impl.AlternativesImpl@1d64c37
1875 ERROR WorkflowRunner - java.lang.IllegalStateException
java.lang.RuntimeException: java.lang.IllegalStateException
at
org.openarchitectureware.xtext.parser.impl.AbstractParserCom ponent.invokeInternal(AbstractParserComponent.java:55)
at
org.openarchitectureware.workflow.lib.AbstractWorkflowCompon ent2.invoke(AbstractWorkflowComponent2.java:38)
at
org.openarchitectureware.workflow.container.CompositeCompone nt.internalInvoke(CompositeComponent.java:95)
at
org.openarchitectureware.workflow.container.CompositeCompone nt.invoke(CompositeComponent.java:84)
at
at
at
at
at
org.openarchitectureware.workflow.WorkflowRunner.executeWork flow(WorkflowRunner.java:335)
at
org.openarchitectureware.workflow.WorkflowRunner.run(Workflo wRunner.java:252)
at
org.openarchitectureware.workflow.WorkflowRunner.main(Workfl owRunner.java:204)
Caused by: java.lang.IllegalStateException
at
org.openarchitectureware.xtext.parser.model.XtextGrammarUtil .normalize(XtextGrammarUtil.java:165)
at
org.openarchitectureware.xtext.parser.model.XtextGrammarUtil .normalize(XtextGrammarUtil.java:150)
at
org.openarchitectureware.xtext.parser.XtextParser.replace(Xt extParser.java:56)
at
org.openarchitectureware.xtext.parser.XtextParser.normalize( XtextParser.java:29)
at
org.openarchitectureware.xtext.parser.XtextParser.normalize( XtextParser.java:49)
at
at
at
at
org.openarchitectureware.xtext.parser.XtextParser.internalPr eLink(XtextParser.java:21)
at
org.openarchitectureware.xtext.parser.impl.AbstractXtextPars er.preLinking(AbstractXtextParser.java:58)
at
org.openarchitectureware.xtext.resource.AbstractXtextResourc e.doLoad(AbstractXtextResource.java:27)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1414)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1210)
at
org.openarchitectureware.xtext.parser.impl.AbstractParserCom ponent.invokeInternal(AbstractParserComponent.java:42)
.... 10 more
FUDForum. Page generated in 0.04054 seconds
