| Clean EMF install: Project does not exist? [message #381256] |
Sun, 14 October 2007 09:31  |
Originally posted by: mielzpost.gmail.com
Dear All,
I've 'installed' a copy of Eclipse 3.3.0, with EMF 2.3.0.v2 under Vista.
And as soon as i try to start a new project it gives me the following
error:
The project was not built due to "[PROJECTNAME HERE] does not exist". Fix
the problem, then try refreshing this project and building it since it may
be inconsistent
I've also tried to install OAW and but same results. It seems like i cant
build anything, while i've installed practically everything.
Actually im a c#/.net guru, but your EMF DSL tools kick so much ass i just
had to install it, too bad i cant get it too work. Who has any ideas?
Emile Bosch
| Re: Clean EMF install: Project does not exist? [message #381257 is a reply to message #381256] |
Sun, 14 October 2007 11:36  |
--------------050404040602000308040803
Emile,
I see you reposted in the EMFT newsgroup. The EMF newsgroup itself
would have been better, but maybe you had trouble finding it because
it's in the tools group:
news://news.eclipse.org/eclipse.tools.emf
(I don't want to move it to modeling because then the 5 year newsgroup
history will be harder for folks to find).
Emile Bosch wrote:
> Dear All,
> Vista. And as soon as i try to start a new project it gives me the
> following error:
> Fix the problem, then try refreshing this project and building it
> since it may be inconsistent
> cant build anything, while i've installed practically everything.
> just had to install it, too bad i cant get it too work. Who has any
> ideas?
> Emile Bosch
<html>
<head>
http-equiv="Content-Type">
</head>
Emile,<br>
<br>
| Re: Clean EMF install: Project does not exist? [message #600154 is a reply to message #381256] |
Emile,
Emile Bosch wrote:
> Dear All,
> following error:
> ideas?
> Emile Bosch
<html>
<head>
</head>
Emile,<br>
<br>
FUDForum. Page generated in 0.03220 seconds
