Home » Modeling » MDT (Model Development Tools) » ChangeCommand problem...
ChangeCommand problem... [message #380015] |
Fri, 10 April 2009 12:13 |
Sorin Fagateanu Messages: 46 Registered: July 2009 |
Member |
Hello all,
I have another problem.
I have a in the eclipse's Project Explorer a model file,that when I expand
it I can see in the tree packages ,clases,operations,attributes
etc...,this being done with the emf generation.
#1 comm
I have made myself a command for renaming a Package and it look something
like:
EditingDomain editingDomain = AdapterFactoryEditingDomain.
getEditingDomainFor(package);
CompoundCommand command = new CompoundCommand();
command.append(SetCommand.create(editingDomain, package
,UMLPackage.eINSTANCE.getNamedElement_Name(), newName));
editingDomain.getCommandStack().execute(command);
After calling this it automaticaly updates the name in the tree.
#2 comm
I have made another command for adding a steretype and setting a value
and it looks like:
Runnable runnable = new Runnable() {
public void run() {
package.applyStereotype(MyStereotype);
package.setValue(MyStereotype, myInt, 5);
command.append(new ChangeCommand(editingDomain, runnable));
However, when I call this comand, in the tree ,the package's label isn't
updated like I would have expected (something like : <<MyStereotipe>>
PackageName )
At the next rename it updates the label in the tree to show also the
"<<MyStereotype>>".
My problems are the following :
1. the label of package isnt't updated when applying the second command.
I have observed the in the case of renaming ,when it enter's the "set"
method it also triggers the "notify" which iterates thru all the adapters
including the PackageImplAdatpter which calls my content/label provider.
And i have observed that in the case of applying stereotype, in the
notify,it doesn't have a PackageImplAdapter,which it means that no changes
are done.
2.in case of the second command,I cant undo the command.I would have
expected in the Edit menu to appear something like Undo "#2 comm".
If someone has got any ideas I would be very grateful.
Thank you in advance!
Re: ChangeCommand problem... [message #380016 is a reply to message #380015] |
Wed, 22 April 2009 13:25 |
Kenn Hussey Messages: 1620 Registered: July 2009 |
Sorin,
This is a more appropriate question for the UML2 newsgroup (copied).
1. Yes, when stereotypes are applied/unapplied, no event is fired on the
element to which the stereotype has been applied/unapplied, so you'll need
to trigger a refresh of your editor in another way. This has been done in
UML2, for example, by introducing a specialized "RefreshingChangeCommand";
see ApplyStereotypeAction in the sample UML editor plug-in for details.
2. ChangeCommands should be undoable, so I'm not sure what's going on here.
However, UML2 has a specialized change command (and change recorder) that
takes into acccount some UML-isms that aren't accounted for in EMF... I'd
suggest trying to use it; see the UML editor again for examples.
Kenn
"Sorin Fagateanu" <cyron_16@yahoo.com> wrote in message
news:209e8410d148745fc9ab624f8d9e724b$1@www.eclipse.org...
> Hello all,
> #1 comm
> like:
> #2 comm
> and it looks like:
> public void run() {
> PackageName )
> "<<MyStereotype>>".
> are done.
Re: ChangeCommand problem... [message #597612 is a reply to message #380015] |
Sorin,
Kenn
> Hello all,
> #1 comm
> like:
> #2 comm
> and it looks like:
> public void run() {
> PackageName )
> "<<MyStereotype>>".
> are done.
Current Time: Tue May 07 03:02:05 GMT 2024
Powered by FUDForum. Page generated in 0.03888 seconds
