Use of Eclipse Comparaison Tool after JMerge [message #379966] |
Mon, 05 March 2007 14:01 |
Originally posted by: rital77.hotmail.com
I'm studing the way of using Eclipse Comparaison Tool after an incremental
generation made with EMF and JMerge.
I would like to show to the user a display that looks like a CVS or SVN
merge result. This fonctionnality should reassure the user when he uses
tags to customize generated code.
Is there a simple way of reusing Eclipse Compare Tools ? Do you know if
there is an article about compare tool programming ?
Thanks in advance,
JB Volta.
Re: Use of Eclipse Comparaison Tool after JMerge [message #379968 is a reply to message #379966] |
Mon, 05 March 2007 18:15 |
Ed Merks Messages: 33141 Registered: July 2009 |
--------------000308050507060700000705
JB,
Although not directly related to your questions, we're in the process of
starting a model comparison component in EMF/EMFT which uses Eclipse's
compare framework:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=157166
https://bugs.eclipse.org/bugs/show_bug.cgi?id=161382
But I'm not sure where to point you for general information about how
you might use JMerge to generate a result and then show a comparison. A
simple approach might be to use the GenModel's "Redirection Pattern" to
generate a side file rather than updating the actual file and then do
just a plain old resource/resource comparison on that.
JB Volta wrote:
> incremental generation made with EMF and JMerge. I would like to show
> to the user a display that looks like a CVS or SVN merge result. This
> fonctionnality should reassure the user when he uses tags to customize
> generated code.
> if there is an article about compare tool programming ?
> Thanks in advance,
> JB Volta.
<html>
<head>
http-equiv="Content-Type">
</head>
JB,<br>
<br>
of starting a model comparison component in EMF/EMFT which uses
Eclipse's compare framework:<br>
<blockquote><a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=157166">https://bugs.eclipse.org/bugs/show_bug.cgi?id=157166</a><br>
<a href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=161382">https://bugs.eclipse.org/bugs/show_bug.cgi?id=161382</a><br>
</blockquote>
Ed Merks
Re: Use of Eclipse Comparaison Tool after JMerge [message #589952 is a reply to message #379966] |
JB,
compare framework:
JB Volta wrote:
> generated code.
> Thanks in advance,
> JB Volta.
<html>
<head>
</head>
JB,<br>
<br>
<blockquote><a
</blockquote>
Ed Merks
FUDForum. Page generated in 0.03605 seconds
