[TCS]:beginning TCS with Eclipse [message #379837] |
Fri, 05 October 2007 11:55 |
Originally posted by: joseph.brooth.gmail.com
hi,
I am new with TCS
I tested the TCSToolkit project(Eclipse3.3+ATL2.0+EMF2.3) but I found the
problems of SampleDSL_InjectorCreation.xml and here the extract of the
errors.
BUILD FAILED
/home/ydkiouak/Desktop/eclipse/Test/SampleDSL/SampleDSL_Inje ctorCreation.xml:5:
The following error occurred while executing this line:
/home/ydkiouak/Desktop/eclipse/Test/TCSToolkit/TCS2JAR/build .xml:23: The
/home/ydkiouak/Desktop/eclipse/Test/TCSToolkit/TCS2JAR/build .xml:120:
Unable to determine generated class
Total time: 3 seconds
then I tried to start with TCS/Language Project but I didn't has to find
the AMMAScripts, and AMMACore projects ???
and also how to configure the fishier build.properties
regards
Joseph
Re: [TCS]:beginning TCS with Eclipse [message #379847 is a reply to message #379840] |
Fri, 05 October 2007 14:47 |
thank you for informations
but i'm the problem with checked out the AMMAScripts and AMMACore.
is necessary to add CVS Repository ?
so yes I find how I can the configuration with this CVS(the host, the
standard connection.............)
thnx
Joseph
Re: [TCS]:beginning TCS with Eclipse [message #379901 is a reply to message #379854] |
Mon, 08 October 2007 09:28 |
Originally posted by: joseph.Brooth.gmail.com
yes I added the All scripts in my workspace but I have remarks for the
following points:
******* build.properties (you can copy and paste
/SampleLanguage/build.properties and modify it).*******
for this file I recovered with one project of ZOO TCS because I did'nt
find "/SampleLanguage/build.properties"
how to configure this file?
for me I notched "Custom build"!!
Es this that it is correct?.
******** In the "Targets" tab:--Set "During a Clean" to target "clean"
I dont arrive to fair this point because I found the zone "During a Clean"
desactivate and text posted inside "Builder is not set to run for this
build kind" same thing in the fields "After A clean" and "Auto build"
I tested with the button "Set Targets" but always this zone is desactivate?
how I should make to activate?
finaly for excute my TCS Projects(Model-To project -- Text) how I must
make?
Thank you for your Helps.
Joseph
Re: [TCS]:beginning TCS with Eclipse [message #608047 is a reply to message #379840] |
thnx
Joseph
Re: [TCS]:beginning TCS with Eclipse [message #608063 is a reply to message #379854] |
following points:
make?
Joseph
FUDForum. Page generated in 0.04291 seconds
