Home » Archived » Buckminster » Random failure resolving maven components
| Random failure resolving maven components [message #379823] |
Thu, 21 August 2008 14:29  |
I'm getting a random failure resolving maven dependencies in a project
that I'm working on. It is random in the fact which artifact fails, but
the error/failure messages are the same for all failed artifacts. (I can
provide the entire buckminster debug output if needed, but for now I will
post the relavent snippet from the log at the end of this post) It appears
that buckminster is internally corrupting some of the pom files that it is
downloading. I think this because, I started with a clean .m2/repository,
ran my build and got the failure below. After running the build I checked
my ${HOME}/.m2/repository for the pom file
(org/apache/geronimo/genesis/config/project-config/1.2/proje ct-config-1.2.pom)
and that directory was empty. I looked at the copy on our internal
maven-repo (mirror of the ibiblio central maven repo) and it was a
perfectly valid pom/xml file. To me, it appears that the pom file is
getting corrupted between downloading from the maven repo server and
placing it into my local cache.
One interesting point, I have encountered this problem with a couple of
different maven artifacts and the pom files failing with this problem all
have a parent relationship to an artifact/pom that I am depending on. (ie.
the failing pom files are the parent poms of artifacts I am pulling in)
I am using Eclipse 3.3 and the latest 1.0.0 releases of buckminster on the
download site (ArchivedSite: 1.0.0.r09499 and Headless
Product:1.0.0.r09472)
Buckminster debug output:
[java] Downloading
http://maven-repo.boston.amer.iona.com/maven-proxy-release/r epository/org/apache/geronimo/genesis/config/project-config/ 1.2/project-config-1.2.pom.md5
[java] Getting POM information for parent: org.apache.geronimo.specs
- specs at path org/apache/geronimo/specs/specs/1.4/specs-1.4.pom
[java] Downloading
http://maven-repo.boston.amer.iona.com/maven-proxy-release/r epository/org/apache/geronimo/specs/specs/1.4/specs-1.4.pom. md5
org.apache.geronimo.genesis.config - project-config at path
org/apache/geronimo/genesis/config/project-config/1.2/projec t-config-1.2.pom
[java] Downloading
[java] Getting POM information for parent: org.apache.cxf - cxf at
path org/apache/cxf/cxf/2.0.6.1-fuse/cxf-2.0.6.1-fuse.pom
[java] Downloading
http://repo.open.iona.com/maven2/org/apache/cxf/cxf/2.0.6.1- fuse/cxf-2.0.6.1-fuse.pom.md5
[java] Downloading
[java]
com.iona.repository/it-repos-testutil/[2.0-M8,2.1.0.a)#Tripl et: Using
resource map file:/x1/devel/uitools/trunk/build/buckminster/uitools.rmap
[java]
search path iona_maven_repo
[java]
com.iona.repository/it-repos-testutil/[2.0-M8,2.1.0.a)#Tripl et: Trying
provider
maven2( http://maven-repo.boston.amer.iona.com/iona-snapshot/reposit ory)
[java] [Fatal Error] project-config-1.2.pom:1:1: Content is not
allowed in prolog.
[java] org.apache.geronimo.specs/geronimo-j2ee-management_1.1_spec:
Resolution attempt ended with exception: org.xml.sax.SAXParseException:
Content is not allowed in prolog.:
at line: 1 column: 1
No provider was found that could resolve the request
[java] ERROR [0032] : No suitable provider for component
org.apache.geronimo.specs/geronimo-j2ee-management_1.1_spec was found in
searchPath iona_maven_repo_proxy_release
[java] ERROR [0032] : Resolution attempt ended with exception:
org.xml.sax.SAXParseException: Content is not allowed in prolog.:
[java]
com.iona.repository/it-repos-testutil/[2.0-M8,2.1.0.a)#Tripl et: Rejecting
provider
maven2( http://maven-repo.boston.amer.iona.com/iona-snapshot/reposit ory):
No component match was found
[java]
provider
maven2( http://maven-repo.boston.amer.iona.com/iona-release/reposito ry)
allowed in prolog.
[java] Doing full workspace refresh
[java] ERROR: Error while refreshing workspace: null
[java] org.apache.geronimo.specs/geronimo-jms_1.1_spec: Resolution
attempt ended with exception: org.xml.sax.SAXParseException: Content is
[java] Waiting for jobs to end
[java] Downloading
http://maven-repo.boston.amer.iona.com/maven-proxy-release/r epository/org/apache/geronimo/genesis/config/project-config/ 1.2/project-config-1.2.pom.sha1
[java] [Fatal Error] :-1:-1: Premature end of file.
[java]
provider
maven2( http://maven-repo.boston.amer.iona.com/iona-release/reposito ry): No
[java]
com.iona.repository/it-repos-testutil/[2.0-M8,2.1.0.a)#Tripl et: No
[java] ERROR [0033] : No suitable provider for component
com.iona.repository/it-repos-testutil/[2.0-M8,2.1.0.a)#Tripl et was found
in searchPath iona_maven_repo
[java] ERROR [0033] : Rejecting provider
[java] JOB:
org.apache.geronimo.specs/geronimo-activation_1.1_spec(317) is still
running
[java] Command canceled
Any help would be greatly appreciated.
Chris
| Re: Random failure resolving maven components [message #379827 is a reply to message #379823] |
Fri, 22 August 2008 04:26  |
Hi Chris,
This sounds like a bug that has been fixed. Can you try cleaning the
$HOME/.m2/repository completely? If that doesn't help, can you try using
Eclipse 3.4 with the latest Buckminster? (the reason for that is that
all changes there hasn't been merged to our 3.3 version yet and I'm a
bit uncertain if this particular bug fix is there).
A clarification, are you saying that all files that are corrupted ARE
parent poms or that they HAVE a parent pom?
Thomas Hallgren
Chris Butt wrote:
> will post the relavent snippet from the log at the end of this post) It
> appears that buckminster is internally corrupting some of the pom files
> that it is downloading. I think this because, I started with a clean
> .m2/repository, ran my build and got the failure below. After running
> the build I checked my ${HOME}/.m2/repository for the pom file
> all have a parent relationship to an artifact/pom that I am depending
> on. (ie. the failing pom files are the parent poms of artifacts I am
> pulling in)
> the download site (ArchivedSite: 1.0.0.r09499 and Headless
> [java] Downloading
> [java] Downloading
> [java] Downloading
> [java] Downloading
> [java] Downloading
> [java]
> [java]
> [java]
> provider
> allowed in prolog.
> [java]
> Rejecting provider
> [java]
> provider
> allowed in prolog.
> [java] Downloading
> [java]
> Rejecting provider
> [java]
> [java] JOB:
> running
> Chris
Current Time: Fri Oct 24 00:41:57 EDT 2025
Powered by FUDForum. Page generated in 0.03944 seconds
