Home » Archived » GMT (Generative Modeling Technologies) » [Mofscript] The context http://www.eclipse.org/uml2/2.0.0/UML is not found ...
Re: [Mofscript] The context http://www.eclipse.org/uml2/2.0.0/UML is not found ... [message #378868 is a reply to message #378847] |
Fri, 17 August 2007 06:32 |
beaperez Mising name Messages: 81 Registered: July 2009 |
Member |
Hi again,
My configuration is Eclipse 3.3 and MOFScript 1.2.4 and perhaps the problem
is that configuration. Although I think that it is strange since if I run
the trnansformations directly, using MOFScript without using any Java file,
it works perfectly.
I also load explicity the UML metamodel in my java code adding;
ParserUtil parserUtil = new ParserUtil();
ExecutionManager execMgr = ExecutionManager.getExecutionManager();
execMgr.lookupAndAddSourceMetaModel("uml","http://www.eclipse.org/uml2/2.0.0/UML");
but It seems that that code does not anything. If I change the metamodel to
the Ecore metamodel it works, I mean, the metamodel is found.
Could anybody help me? Does anybody have try to execute MOFScript
transformations by using java files? What configuration are you using?
Thank you very much in advance.
Bea
"bea" <beaperez@unizar.es> wrote in message
news:f9naul$tat$1@build.eclipse.org...
> Hello everybody,
> I would like to run Mofscript files from Java. I have no problem if I
> execute the main Mofscript transformation (it imports other m2t files)
> with the Mofscript interface but if I try to execute it from my java code
> I get the errors:
> Parsing result: 33 errors
> : Error: MTTParseError: Illegal/unknown context: uml, line: 0, column: 0
> : Error: MTTParseError: Cannot find import: guardas.m2t, line: 7, column:
> 7
> I think that it does not find neither the context
> http://www.eclipse.org/uml2/2.0.0/UML nor the imported m2t files. I am
> also using the sentence parserUtil.setCompilePath(templatesDir); in my
> java file. I am using Mofscript 1.2.4
> Any idea?
> Bea
Re: [Mofscript] The context http://www.eclipse.org/uml2/2.0.0/UML is not found ... [message #378870 is a reply to message #378868] |
Fri, 17 August 2007 10:03 |
Jacques LESCOT Messages: 247 Registered: July 2009 |
And what about the following context :
http://www.eclipse.org/uml2/2.1.0/UML ? Does it solve your problem ?
Bea a écrit :
> Hi again,
> it works perfectly.
> Bea
>> Hello everybody,
>> I get the errors:
>> 7
>> Any idea?
>> Bea
Re: [Mofscript] The context http://www.eclipse.org/uml2/2.0.0/UML is not found ... [message #606590 is a reply to message #378847] |
Member |
Hi again,
it works perfectly.
Bea
> Hello everybody,
> I get the errors:
> 7
> Any idea?
> Bea
Re: [Mofscript] The context http://www.eclipse.org/uml2/2.0.0/UML is not found ... [message #606591 is a reply to message #378868] |
Bea a écrit :
> Hi again,
> it works perfectly.
> Bea
>> Hello everybody,
>> I get the errors:
>> 7
>> Any idea?
>> Bea
Current Time: Fri Apr 26 20:40:05 GMT 2024
Powered by FUDForum. Page generated in 0.03200 seconds
