Home » Archived » GMT (Generative Modeling Technologies) » [AM3] Compile atl file using Ant
Re: [AM3] Compile atl file using Ant [message #378469 is a reply to message #378462] |
Thu, 12 July 2007 09:34 |
Marcos Didonet Del Fabro Messages: 84 Registered: July 2009 |
Member |
Hi Bas,
First, you need to generate the ATL model that conforms to the ATL metamodel using your
higher-order transformation.
Then, you can extract the ATL model into the ATL file.
Once you have extracted the file in an ATL project, the transformation compiles automatically.
I copied below an example of how to extract the ATL model.
<project name="ATL Extractor" default="extract">
<target name="extract">
<property name="context" value="/YourFolder/"/>
<property name="source" value="${context}yourATLModel.ecore"/>
<property name="target" value="${context}yourATLModel.atl"/>
<am3.loadModel modelHandler="EMF" name="ATL" metamodel="MOF"
nsuri="http://www.eclipse.org/gmt/2005/ATL" />
<am3.loadModel modelHandler="EMF" name="IN" metamodel="ATL" path="${source}" />
<am3.loadModel modelHandler="EMF" name="TCS" metamodel="MOF" path="${context}TCS.ecore" />
<am3.loadModel modelHandler="EMF" name="ATL.tcs" metamodel="TCS"
path="${context}ATL-0.2-TCS.ecore">
</am3.loadModel>
<am3.saveModel model="IN" path="${target}">
<extractor name="ebnf">
<param name="format" value="ATL.tcs"/>
</extractor>
</am3.saveModel>
</target>
</project>
The TCS.ecore and ATL-0.2-TCS.ecore files are available in the AM3 component:
( http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.gmt/AM3 /org.eclipse.am3.core/resources/?root=Technology_Project)
After that, you can call the compiled transformation using the am3.atl task as any other
ATL transformation.
However, the compilation process takes some time, so it is possible that you call the
am3.atl task before the transformation is compiled.
Marcos.
Bas Graaf wrote:
> Hi All,
> Is it possible to compile an atl transformation from within an Ant
> script? I want to use this to generate an atl transformation using a
> higher-order transformation and apply it to some source models from a
> single Ant script.
> Kind regards,
> Bas.
Re: [AM3] Compile atl file using Ant [message #378471 is a reply to message #378469] |
Thu, 12 July 2007 13:05 |
Bas Graaf Messages: 9 Registered: July 2009 |
Hi Marcos,
Thanks for your reply. My problem was in fact that the extracted ATL
file was not compiled fast enough. Now I solved the problem using a
waitfor task:
<waitfor maxwait="30" maxwaitunit="second">
<available file="${target}.asm"/>
</waitfor>
Kind regards,
Bas.
Marcos Didonet Del Fabro wrote:
> Hi Bas,
> metamodel using your higher-order transformation.
> path="${source}" />
> </am3.loadModel>
> </extractor>
> </am3.saveModel>
> </target>
> </project>
> component:
> task as any other ATL transformation.
> you call the am3.atl task before the transformation is compiled.
> Regards,
> Marcos.
> Bas Graaf wrote:
>> Hi All,
>> single Ant script.
>> Kind regards,
>> Bas.
Re: [AM3] Compile atl file using Ant [message #602290 is a reply to message #378462] |
Member |
Hi Bas,
</am3.loadModel>
</extractor>
</am3.saveModel>
</target>
</project>
ATL transformation.
Marcos.
Bas Graaf wrote:
> Hi All,
> single Ant script.
> Kind regards,
> Bas.
Re: [AM3] Compile atl file using Ant [message #602295 is a reply to message #378469] |
Hi Marcos,
waitfor task:
</waitfor>
Kind regards,
Bas.
> Hi Bas,
> path="${source}" />
> </am3.loadModel>
> </extractor>
> </am3.saveModel>
> </target>
> </project>
> component:
> Regards,
> Marcos.
> Bas Graaf wrote:
>> Hi All,
>> single Ant script.
>> Kind regards,
>> Bas.
Current Time: Fri Apr 26 10:14:11 GMT 2024
Powered by FUDForum. Page generated in 0.03733 seconds
