[TCS]TCS-Importer.jar that works with ATL CVSHEAD? [message #378268] |
Thu, 21 June 2007 19:04 |
Originally posted by: matt.mcgill.gmail.com
Is there an updated TCS-Importer.jar anywhere to be found, on the web or
in CVS, which will work correctly with the current ATL sources as found
in the m2m CVS repository and the current AM3 sources as found in the
gmt CVS repository?
I can only make the TCS stuff in the TCS toolkit work with the 20070217
ATL bundle, but I can't find sources for that release. And I can't get
the CVSHEAD sources for ATL/AM3 to work with the stuff in the TCS
toolkit. This is a major roadblock right now -- any solutions?
-Matt McGill
Re: [TCS]TCS-Importer.jar that works with ATL CVSHEAD? [message #378269 is a reply to message #378268] |
Sat, 23 June 2007 07:36 |
Frédéric Jouault Messages: 572 Registered: July 2009 |
> gmt CVS repository?
We are working on the ATL CVS HEAD right now. The new version uses ANTLR
3 ;-).
We have not had the time yet to work on AM3, but this is the next step.
However, new versions of KM3 and TCS parsers have already been committed
to AM3 yesterday. TGE now works again.
Of course, if you want an older version of ATL to work with AM3, you can
simply check out an older version from CVS.
Frédéric Jouault
Re: [TCS]TCS-Importer.jar that works with ATL CVSHEAD? [message #602095 is a reply to message #378268] |
> gmt CVS repository?
3 ;-).
Frédéric Jouault
FUDForum. Page generated in 0.03878 seconds
