| Build fails: Unable to find feature [message #38640] |
Sun, 28 December 2008 10:05  |
I'm trying to build an RCP app with dependencies to e.g. org.eclipse.help.ui
Build fails when using RCP runtime + delta pack as target environment
(which appears obvious).
Alternatively, I've tried to use a separate Eclipse SDK as target
environment, but build gets much further still fails, but with strange
errors:
[java] customAssembly:
[java] BUILD FAILED
[java]
c:\eclipse\plugins\org.eclipse.pde.build_3.4.1.R34x_v2008080 5\scripts\productBuild\productBuild.xml:30:
The following error occurred while executing this line:
[java]
C:\eclipse\plugins\org.eclipse.pde.build_3.4.1.R34x_v2008080 5\scripts\build.xml:91:
[java]
C:\workspace\com.siemens.ct.mp3m.build\customTargets.xml:12: The
[java]
C:\eclipse\plugins\org.eclipse.pde.build_3.4.1.R34x_v2008080 5\scripts\productBuild\allElements.xml:10:
[java]
C:\eclipse\plugins\org.eclipse.pde.build_3.4.1.R34x_v2008080 5\scripts\genericTargets.xml:158:
[java]
c:\temp\mp3m-build\assemble.org.eclipse.pde.build.container. feature.all.xml:23:
[java]
c:\temp\mp3m-build\assemble.org.eclipse.pde.build.container. feature.all.xml:15:
[java]
C:\eclipse\plugins\org.eclipse.pde.build_3.4.1.R34x_v2008080 5\scripts\productBuild\allElements.xml:44:
[java]
c:\temp\mp3m-build\assemble.org.eclipse.pde.build.container. feature.win32.win32.x86.xml:188:
java.io.EOFException
Any ideas what this might be?
-- Andi
| [Solved] Re: Build fails: Unable to find feature [message #42324 is a reply to message #38640] |
Sun, 25 January 2009 12:35  |
I've solved this issue by setting up the target runtime environment
again. Runtime needs to consist of
Eclipse Platform SDK + RCP Delta Pack
The previous Eclipse SDK + RCP Delta Pack or RCP Runtime + RCP Delta
Pack were both not sufficient.
Hope this helps,
Andi
| Re: Build fails: Unable to find feature [message #587639 is a reply to message #38640] |
Mon, 29 December 2008 08:32  |
I've done some more investigation with a simple PDE build using the
examples from
http://rcpquickstart.com/2007/06/06/getting-started-with-pde -build/
Building against the RCP runtime works fine. This won't work for me
though as runtime doesn't contain all required features like e.g. Common
Navigator etc.
Building against Eclipse SDK (even if separate install) continues to
fail with java.io.EOFException
So I believe it comes down to the question of how to do a PDE build with
required features not part of RCP runtime?
All insight greatly appreciated!
Andi
| Re: Build fails: Unable to find feature [message #588317 is a reply to message #40060] |
Fri, 16 January 2009 17:17  |
Mhm- I do have the delta pack installed, even re-downloaded to make
sure. Selected target SDK containing delta pack as runtime. Still same
problem:
On 12.01.2009 15:49, Lars Vogel wrote:
> Hi Andreas,
> I believe I had the same error message. In my case the Eclipse Deltapack
> was missing. For a small tutorial which related to the Eclipse PDE Build
> you can check here:
> http://www.vogella.de/articles/EclipsePDEBuild/article.html
> Best regards, Lars
>> examples from
>> Common Navigator etc.
>> with required features not part of RCP runtime?
>> Thanks,
>> Andi
| Re: Build fails: Unable to find feature [message #588334 is a reply to message #40060] |
Fri, 16 January 2009 20:06  |
Even straight-forward plugins seem to fail:
Bundle
org.eclipse.core.filesystem.win32.x86:
Host plug-in
org.eclipse.core.filesystem_[1.1.0,2.0.0) has not been found.
Bundle
org.eclipse.core.net.win32.x86:
Host plug-in
org.eclipse.core.net_1.1.0 has not been found.
Bundle
org.eclipse.core.resources.win32.x86:
Host plug-in
org.eclipse.core.resources_[3.4.0,3.5.0) has not been found.
Bundle
org.eclipse.equinox.launcher.win32.win32.x86:
Bundle
org.eclipse.equinox.security.win32.x86:
Host plug-in
org.eclipse.equinox.security_[1.0.0,2.0.0) has not been found.
Bundle
org.eclipse.swt.win32.win32.x86:
Bundle org.eclipse.ui.win32:
Host plug-in
org.eclipse.ui.ide_[3.2.0,4.0.0) has not been found.
Bundle org.eclipse.update.core.win32:
[eclipse.generateFeature] Host plug-in
org.eclipse.update.core_[3.0.0,4.0.0) has not been found.
Any idea what might be wrong with the target runtime definition (RCP
binary + Delta pack)?
Andi
| Re: Build fails: Unable to find feature [message #588362 is a reply to message #40683] |
Sat, 17 January 2009 19:36  |
> Bundle
> Host plug-in
> Bundle
> Host plug-in
> Bundle
> Host plug-in
> Bundle
> Bundle
> Host plug-in
> Bundle
> Host plug-in
Is the delta pack and rcp binary co-located, ie., c:/dir/plugins ?
| Re: Build fails: Unable to find feature [message #588387 is a reply to message #40783] |
Mon, 19 January 2009 06:54  |
I've setup c:\eclipse for my SDK and created c:\eclipse\runtime as base
folder for the rcp binary and delta pack. Thus the combined plugin of
rcp binary and delta pack end up in c:\eclipse\runtime\eclipse\plugins.
I've also configured build properties to match the runtime folder:
base=c:/eclipse/runtime
baseLocation=${base}/eclipse
Makes sense?
>> Bundle
>> Host plug-in
>> Bundle org.eclipse.core.net.win32.x86:
>> Host plug-in
>> Bundle
>> Host plug-in
>> Bundle
>> Bundle
>> Host plug-in
>> Bundle org.eclipse.swt.win32.win32.x86:
>> Host plug-in
| [Solved] Re: Build fails: Unable to find feature [message #590454 is a reply to message #38640] |
Hope this helps,
Andi
FUDForum. Page generated in 0.06159 seconds
