Home » Archived » GMT (Generative Modeling Technologies) » [MOFScript] undefined properties
[MOFScript] undefined properties [message #377488] Fri, 11 May 2007 06:31 Go to next message
I have an input meta model for which one of the classes
has a property that does not required a value. Thus, I
want to make the generation of the output conditional
on whether or not a value is defined in the input model.
i.e something along the lines
if (self.p.oclIsDefined()) {
self.p.name
However, it appears that oclIsDefined is not among
the ocl functions defined in MOFScript. How is this
situation handled in MOFScript?
thanks
Andy.
Dr Andy Carpenter
School of Computer Science,
University of Manchester, Manchester M13 9PL, UK
Email: Andy.Carpenter@manchester.ac.uk
Tel: +44 161 275 6168
Fax: +44 161 275 6280
Re: [MOFScript] undefined properties [message #377491 is a reply to message #377488] Fri, 11 May 2007 07:42 Go to previous messageGo to next message
Originally posted by: eric.vepa.gmail.com
Hi Andy,
I am not using MOFScript but in ATL you can use the function
oclIsUndefined().
Your code may look like (do not forget the "not") :
if (not self.p.oclIsUndefined()) {
self.p.name
> self.p.name
> thanks
> Andy.
Éric Vépa
Re: [MOFScript] undefined properties [message #377493 is a reply to message #377488] Fri, 11 May 2007 09:02 Go to previous messageGo to next message
Hello Andy,
I am not quite sure if I understand you correctly, but this might work
if (self.p != null) {
self.p.name
or try to print the property that does not have a value, and see what you
get,
or always use a defalult value in your model that you can check for.
/G
Re: [MOFScript] undefined properties [message #377495 is a reply to message #377493] Mon, 14 May 2007 03:28 Go to previous message
G
Re: [MOFScript] undefined properties [message #596155 is a reply to message #377488] Fri, 11 May 2007 07:42 Go to previous message
Hi Andy,
oclIsUndefined().
self.p.name
> self.p.name
> thanks
> Andy.
Éric Vépa
Re: [MOFScript] undefined properties [message #596162 is a reply to message #377488] Fri, 11 May 2007 09:02 Go to previous message
Hello Andy,
self.p.name
get,
/G
Re: [MOFScript] undefined properties [message #596170 is a reply to message #377493] Mon, 14 May 2007 03:28 Go to previous message
G
Previous Topic:[MOFScript] undefined properties
Next Topic:[MOFScript] objectsOfType
Current Time: Tue Nov 04 22:10:55 EST 2025
Powered by FUDForum. Page generated in 0.04508 seconds
