Home » Modeling » EMF » [NEWBIE] library.xsd --> cant see the diagramm
[NEWBIE] library.xsd --> cant see the diagramm [message #376694] Fri, 24 January 2003 05:36 Go to next message
Originally posted by: frank.frank-bur.de
hello NG,
i'm new to eclipse, EMF and omondo. i tried the example, downloaded the
library.xsd-file, created an EMF-project, imported the xsd-file and
generated the ecore model. now i wanted to see the diagramm. i thought it
would work, while telling the ecore model 'open with --> EMF class diagramm
editor. but i cant see anything. whats wrong?
tia,
frank
W2K, M3
visit the future: http://www.frank-bur.de
Re: [NEWBIE] library.xsd --> cant see the diagramm [message #376696 is a reply to message #376694] Fri, 24 January 2003 11:55 Go to previous messageGo to next message
Frank,
I just tried it and it doesn't work for me either. If I create the model from
the Rose .mdl file, it works fine. If I create it from XML Schema, then I get
no diagram in Omondo. It looks like an Omondo problem to me.
Frank.
Frank Bur wrote:
> hello NG,
> tia,
> frank
> W2K, M3
Re: [NEWBIE] library.xsd --> cant see the diagramm [message #376700 is a reply to message #376696] Sat, 25 January 2003 09:08 Go to previous messageGo to next message
frank,
yes, ure right, i tested it also with an mdl-file and it works. but that is
a very static solution, i think supporting an xml-file-import would be the
more flexible way...
is that the right place to talk about omondo and concerned UML-problems?
nice weekend,
frank
"Frank Budinsky" <frankb@ca.ibm.com> schrieb im Newsbeitrag
news:3E31701F.FAD2375D@ca.ibm.com...
> Frank,
from
get
> Frank.
> Frank Bur wrote:
> > hello NG,
it
diagramm
> > tia,
> > frank
> > W2K, M3
Re: [NEWBIE] library.xsd --> cant see the diagramm [message #376706 is a reply to message #376700] Mon, 27 January 2003 17:59 Go to previous messageGo to next message
Could you send me a generated ecore file for me ? I can check it out.
julien
omondo
Frank Bur wrote:
> frank,
> nice weekend,
> frank
> > Frank,
> from
> get
> > Frank.
> > Frank Bur wrote:
> > > hello NG,
> it
> diagramm
> > > tia,
> > > frank
> > > W2K, M3
Re: [NEWBIE] library.xsd --> cant see the diagramm [message #376707 is a reply to message #376706] Tue, 28 January 2003 04:16 Go to previous messageGo to next message
julien,
for sure, i attached the generated *.ecore-file. this file is generated from
the original 'library.xsd'-file. right-klicking to this ecore file, trying
to execute 'open with --> EMF class diagramm editor' doesnt bring up the
model, the omondo-plugin starts, but its blank. doing the same procedure
with the 'rose'-file does work, the UML-diagramm is visible.
i'm working with omondo 1.1.7 and M3/M4
frank
....der weg ist das ziel...
"julien" <julien@omondo.com> schrieb im Newsbeitrag
news:b14dk4$qsh$1@rogue.oti.com...
> julien
> omondo
> Frank Bur wrote:
> > frank,
is
the
> > nice weekend,
> > frank
> > > Frank,
model
> > from
then I
> > get
> > > Frank.
> > > Frank Bur wrote:
> > > > hello NG,
the
thought
> > it
> > diagramm
> > > > tia,
> > > > frank
> > > > W2K, M3
Re: [NEWBIE] library.xsd --> cant see the diagramm [message #376720 is a reply to message #376707] Tue, 28 January 2003 16:48 Go to previous messageGo to next message
Hi Frank,
Thanks for posting this ecore file and using EclipseUML. I tested to load
this file with last build. It doesn't work since this file contains some
EAnnotation objects. This problem will be fixed in the next build, which
will be available probably tomorrow. One limitation is the Eannotation
will not be displayed in the diagram.
julien
omondo
Frank Bur wrote:
> julien,
> frank
> > julien
> > omondo
> > Frank Bur wrote:
> > > frank,
> is
> the
> > > nice weekend,
> > > frank
> > > > Frank,
> model
> > > from
> then I
> > > get
> > > > Frank.
> > > > Frank Bur wrote:
> > > > > hello NG,
> the
> thought
> > > it
> > > diagramm
> > > > > tia,
> > > > > frank
> > > > > W2K, M3
> begin 666 library.ecore
> M/#]X;6P@=F5R<VEO;CTB,2XP(B!E;F-O9&EN9STB05-#24DB/SX*/&5C;W)E
> M.D5086-K86=E('AM:3IV97)S:6]N/2(R+C B('AM;&YS.GAM:3TB:'1T<#HO
> M+W=W=RYO;6<N;W)G+UA-22(@>&UL;G,Z>'-I/2)H='1P.B\O=W=W+G <S+F]R
> M9R\R,# Q+UA-3%-C:&5M82UI;G-T86YC92(*(" @('AM;&YS.F5C;W)E/2)H
> M='1P.B\O=W=W+F5C;&EP<V4N;W)G+V5M9B\R,# R+T5C;W)E(B!N86UE/2)L
> M:6)R87)Y(@H@(" @;G-54DD](FAT=' Z+R]W=W<N97AA;7!L92YC;VTO3&EB
> M<F%R>2(@;G-0<F5F:7@](F-O;2YE>&%M<&QE+FQI8G)A<GDB/@H@(#QE06YN
> M;W1A=&EO;G,@<V]U<F-E/2)H='1P.B\O+V]R9R]E8VQI<'-E+V5M9B]M87!P
> M:6YG+WAS9#)E8V]R92]84T0R16-O<F4B/@H@(" @/&1E=&%I;',@:V5Y/2)R
> M97!R97-E;G1A=&EO;B(@=F%L=64](G-C:&5M82(O/@H@(" @/&1E=&%I;',@
> M:V5Y/2)T87)G971.86UE<W!A8V4B('9A;'5E/2)H='1P.B\O=W=W+F5X86UP
> M;&4N8V]M+TQI8G)A<GDB+SX*(" \+V5!;FYO=&%T:6]N<SX*(" \94-L87-S
> M:69I97)S('AS:3IT>7!E/2)E8V]R93I%16YU;2(@;F%M93TB0F]O:T-A=&5G
> M;W)Y(CX*(" @(#QE06YN;W1A=&EO;G,@<V]U<F-E/2)H='1P.B\O+V]R9R]E
> M8VQI<'-E+V5M9B]M87!P:6YG+WAS9#)E8V]R92]84T0R16-O<F4B/@H@( " @
> M(" \9&5T86EL<R!K97D](G)E<')E<V5N=&%T:6]N(B!V86QU93TB='EP92(O
> M/@H@(" @(" \9&5T86EL<R!K97D](FYA;64B('9A;'5E/2)";V]K0V%T96=O
> M<GDB+SX*(" @(" @/&1E=&%I;',@:V5Y/2)T87)G971.86UE<W!A8V4B('9A
> M;'5E/2)H='1P.B\O=W=W+F5X86UP;&4N8V]M+TQI8G)A<GDB+SX*(" @(#PO
> M94%N;F]T871I;VYS/@H@(" @/&5,:71E<F%L<R!N86UE/2)->7-T97)Y(B\^
> M"B @(" \94QI=&5R86QS(&YA;64](E-C:65N8V5&:6-T:6]N(B!V86Q U93TB
> M,2(O/@H@(" @/&5,:71E<F%L<R!N86UE/2)":6]G<F%P:'DB('9A;'5E/2(R
> M(B\^"B @/"]E0VQA<W-I9FEE<G,^"B @/&5#;&%S<VEF:65R<R!X<VDZ='EP
> M93TB96-O<F4Z14-L87-S(B!N86UE/2)";V]K(CX*(" @(#QE06YN;W1A=&EO
> M;G,@<V]U<F-E/2)H='1P.B\O+V]R9R]E8VQI<'-E+V5M9B]M87!P:6YG+WAS
> M9#)E8V]R92]84T0R16-O<F4B/@H@(" @(" \9&5T86EL<R!K97D](G)E<')E
> M<V5N=&%T:6]N(B!V86QU93TB='EP92(O/@H@(" @(" \9&5T86EL<R!K97D]
> M(FYA;64B('9A;'5E/2)";V]K(B\^"B @(" @(#QD971A:6QS(&ME>3TB=&%R
> M9V5T3F%M97-P86-E(B!V86QU93TB:'1T<#HO+W=W=RYE>&%M<&QE+F-O;2],
> M:6)R87)Y(B\^"B @(" \+V5!;FYO=&%T:6]N<SX*(" @(#QE4F5F97)E;F-E
> M<R!N86UE/2)A=71H;W(B(&54>7!E/2)E8V]R93I%0VQA<W,@:'1T <#HO+W=W
> M=RYE8VQI<'-E+F]R9R]E;68O,C P,B]%8V]R92,O+T5/8FIE8W0B"B @(" @
> M(" @;&]W97)";W5N9#TB,2(@8V]N=&%I;FUE;G0](G1R=64B/@H@(" @(" \
> M94%N;F]T871I;VYS('-O=7)C93TB:'1T<#HO+R]O<F<O96-L:7!S92]E;68O
> M;6%P<&EN9R]X<V0R96-O<F4O6%-$,D5C;W)E(CX*(" @(" @(" \9&5T86EL
> M<R!K97D](G)E<')E<V5N=&%T:6]N(B!V86QU93TB96QE;65N="(O/@H@( " @
> M(" @(#QD971A:6QS(&ME>3TB;F%M92(@=F%L=64](F%U=&AO<B(O/@H@( " @
> M(" @(#QD971A:6QS(&ME>3TB=&%R9V5T3F%M97-P86-E(B\^"B @(" @(#PO
> M94%N;F]T871I;VYS/@H@(" @/"]E4F5F97)E;F-E<SX*(" @(#QE071T<FEB
> M=71E<R!N86UE/2)T:71L92(@951Y<&4](F5C;W)E.D5$871A5'EP92!H='1P
> M.B\O=W=W+F5C;&EP<V4N;W)G+V5M9B\R,# R+T5C;W)E(R\O15-T<FEN9R(*
> M(" @(" @("!L;W=E<D)O=6YD/2(Q(CX*(" @(" @/&5!;FYO=&%T:6]N<R!S
> M;W5R8V4](FAT=' Z+R\O;W)G+V5C;&EP<V4O96UF+VUA<'!I;F<O>'-D,F5C
> M;W)E+UA31#)%8V]R92(^"B @(" @(" @/&1E=&%I;',@:V5Y/2)R97!R97-E
> M;G1A=&EO;B(@=F%L=64](F5L96UE;G0B+SX*(" @(" @(" \9&5T86EL<R!K
> M97D](FYA;64B('9A;'5E/2)T:71L92(O/@H@(" @(" @(#QD971A:6QS(&ME
> M>3TB=&%R9V5T3F%M97-P86-E(B\^"B @(" @(#PO94%N;F]T871I;VYS/@H@
> M(" @/"]E071T<FEB=71E<SX*(" @(#QE071T<FEB=71E<R!N86UE/2)P86=E
> M<R(@951Y<&4](F5C;W)E.D5$871A5'EP92!H='1P.B\O=W=W+F5C;&EP <V4N
> M;W)G+V5M9B\R,# R+T5C;W)E(R\O14EN="(*(" @(" @("!L;W=E<D)O=6YD
> M/2(Q(CX*(" @(" @/&5!;FYO=&%T:6]N<R!S;W5R8V4](FAT=' Z+R\O;W)G
> M+V5C;&EP<V4O96UF+VUA<'!I;F<O>'-D,F5C;W)E+UA31#)%8V]R92(^ "B @
> M(" @(" @/&1E=&%I;',@:V5Y/2)R97!R97-E;G1A=&EO;B(@=F%L=64 ](F5L
> M96UE;G0B+SX*(" @(" @(" \9&5T86EL<R!K97D](FYA;64B('9A;'5E/2)P
> M86=E<R(O/@H@(" @(" @(#QD971A:6QS(&ME>3TB=&%R9V5T3F%M97-P86-E
> M(B\^"B @(" @(#PO94%N;F]T871I;VYS/@H@(" @/"]E071T<FEB=71E<SX*
> M(" @(#QE071T<FEB=71E<R!N86UE/2)C871E9V]R>2(@951Y<&4](B,O+T)O
> M;VM#871E9V]R>2(@;&]W97)";W5N9#TB,2(^"B @(" @(#QE06YN;W1A=&EO
> M9#)E8V]R92]84T0R16-O<F4B/@H@(" @(" @(#QD971A:6QS(&ME>3TB<F5P
> M<F5S96YT871I;VXB('9A;'5E/2)E;&5M96YT(B\^"B @(" @(" @/&1E=&%I
> M;',@:V5Y/2)N86UE(B!V86QU93TB8V%T96=O<GDB+SX*(" @(" @(" \9&5T
> M86EL<R!K97D](G1A<F=E=$YA;65S<&%C92(O/@H@(" @(" \+V5!;FYO=&%T
> M:6]N<SX*(" @(#PO94%T=')I8G5T97,^"B @/"]E0VQA<W-I9FEE<G,^"B @
> M/&5#;&%S<VEF:65R<R!X<VDZ='EP93TB96-O<F4Z14-L87-S(B!N86UE/2)7
> M<FET97(B/@H@(" @/&5!;FYO=&%T:6]N<R!S;W5R8V4](FAT=' Z+R\O;W)G
> M(" @(#QD971A:6QS(&ME>3TB<F5P<F5S96YT871I;VXB('9A;'5E/2)T >7!E
> M(B\^"B @(" @(#QD971A:6QS(&ME>3TB;F%M92(@=F%L=64](E=R:71E<B(O
> M/@H@(" @(" \9&5T86EL<R!K97D](G1A<F=E=$YA;65S<&%C92(@=F%L=64]
> M(FAT=' Z+R]W=W<N97AA;7!L92YC;VTO3&EB<F%R>2(O/@H@(" @/"]E06YN
> M;W1A=&EO;G,^"B @(" \95)E9F5R96YC97,@;F%M93TB8F]O:W,B(&54>7!E
> M/2)E8V]R93I%0VQA<W,@:'1T<#HO+W=W=RYE8VQI<'-E+F]R9R]E;68O,C P
> M,B]%8V]R92,O+T5/8FIE8W0B"B @(" @(" @=7!P97)";W5N9#TB+3$B(&-O
> M;G1A:6YM96YT/2)T<G5E(CX*(" @(" @/&5!;FYO=&%T:6]N<R!S;W5R8V4]
> M(FAT=' Z+R\O;W)G+V5C;&EP<V4O96UF+VUA<'!I;F<O>'-D,F5C;W)E+UA3
> M1#)%8V]R92(^"B @(" @(" @/&1E=&%I;',@:V5Y/2)R97!R97-E;G1A=&EO
> M;B(@=F%L=64](F5L96UE;G0B+SX*(" @(" @(" \9&5T86EL<R!K97D](FYA
> M;64B('9A;'5E/2)B;V]K<R(O/@H@(" @(" @(#QD971A:6QS(&ME>3TB=&%R
> M9V5T3F%M97-P86-E(B\^"B @(" @(#PO94%N;F]T871I;VYS/@H@(" @/"]E
> M4F5F97)E;F-E<SX*(" @(#QE071T<FEB=71E<R!N86UE/2)N86UE(B!E5'EP
> M93TB96-O<F4Z141A=&%4>7!E(&AT=' Z+R]W=W<N96-L:7!S92YO<F<O96UF
> M+S(P,#(O16-O<F4C+R]%4W1R:6YG(@H@(" @(" @(&QO=V5R0F]U;F0](C$B
> M/@H@(" @(" \94%N;F]T871I;VYS('-O=7)C93TB:'1T<#HO+R]O<F<O96-L
> M:7!S92]E;68O;6%P<&EN9R]X<V0R96-O<F4O6%-$,D5C;W)E(CX*( " @(" @
> M(" \9&5T86EL<R!K97D](G)E<')E<V5N=&%T:6]N(B!V86QU93TB96QE;65N
> M="(O/@H@(" @(" @(#QD971A:6QS(&ME>3TB;F%M92(@=F%L=64](FYA;64B
> M+SX*(" @(" @(" \9&5T86EL<R!K97D](G1A<F=E=$YA;65S<&%C92(O/@H@
> M(" @(" \+V5!;FYO=&%T:6]N<SX*(" @(#PO94%T=')I8G5T97,^"B @/"]E
> M0VQA<W-I9FEE<G,^"B @/&5#;&%S<VEF:65R<R!X<VDZ='EP93TB96-O<F4Z
> M14-L87-S(B!N86UE/2),:6)R87)Y(CX*(" @(#QE06YN;W1A=&EO;G,@<V]U
> M<F-E/2)H='1P.B\O+V]R9R]E8VQI<'-E+V5M9B]M87!P:6YG+WAS9#)E8V]R
> M92]84T0R16-O<F4B/@H@(" @(" \9&5T86EL<R!K97D](G)E<')E<V5N=&%T
> M:6]N(B!V86QU93TB='EP92(O/@H@(" @(" \9&5T86EL<R!K97D](FYA;64B
> M('9A;'5E/2),:6)R87)Y(B\^"B @(" @(#QD971A:6QS(&ME>3TB=&%R9V5T
> M3F%M97-P86-E(B!V86QU93TB:'1T<#HO+W=W=RYE>&%M<&QE+F-O;2],:6)R
> M87)Y(B\^"B @(" \+V5!;FYO=&%T:6]N<SX*(" @(#QE4F5F97)E;F-E<R!N
> M86UE/2)B;V]K<R(@951Y<&4](B,O+T)O;VLB('5P<&5R0F]U;F0](BTQ(B!C
> M;VYT86EN;65N=#TB=')U92(^"B @(" @(#QE06YN;W1A=&EO;G,@<V]U<F-E
> M/2)H='1P.B\O+V]R9R]E8VQI<'-E+V5M9B]M87!P:6YG+WAS9#)E8V]R92]8
> M4T0R16-O<F4B/@H@(" @(" @(#QD971A:6QS(&ME>3TB<F5P<F5S96YT871I
> M;VXB('9A;'5E/2)E;&5M96YT(B\^"B @(" @(" @/&1E=&%I;',@:V5Y/2)N
> M86UE(B!V86QU93TB8F]O:W,B+SX*(" @(" @(" \9&5T86EL<R!K97D](G1A
> M<F=E=$YA;65S<&%C92(O/@H@(" @(" \+V5!;FYO=&%T:6]N<SX*(" @(#PO
> M95)E9F5R96YC97,^"B @(" \95)E9F5R96YC97,@;F%M93TB=W)I=&5R<R(@
> M951Y<&4](B,O+U=R:71E<B(@=7!P97)";W5N9#TB+3$B(&-O;G1A:6YM96YT
> M/2)T<G5E(CX*(" @(" @/&5!;FYO=&%T:6]N<R!S;W5R8V4](FAT=' Z+R\O
> M;W)G+V5C;&EP<V4O96UF+VUA<'!I;F<O>'-D,F5C;W)E+UA31#)%8V]R92(^
> M"B @(" @(" @/&1E=&%I;',@:V5Y/2)R97!R97-E;G1A=&EO;B(@=F%L=64 ]
> M(F5L96UE;G0B+SX*(" @(" @(" \9&5T86EL<R!K97D](FYA;64B('9A;'5E
> M/2)W<FET97)S(B\^"B @(" @(" @/&1E=&%I;',@:V5Y/2)T87)G971.86UE
> M<W!A8V4B+SX*(" @(" @/"]E06YN;W1A=&EO;G,^"B @(" \+V52969E<F5N
> M8V5S/@H@(" @/&5!='1R:6)U=&5S(&YA;64](FYA;64B(&54>7!E/2)E8V]R
> M93I%1&%T851Y<&4@:'1T<#HO+W=W=RYE8VQI<'-E+F]R9R]E;68O,C P,B]%
> M8V]R92,O+T53=')I;F<B"B @(" @(" @;&]W97)";W5N9#TB,2(^"B @(" @
> M(#QE06YN;W1A=&EO;G,@<V]U<F-E/2)H='1P.B\O+V]R9R]E8VQI<'-E+V5M
> M9B]M87!P:6YG+WAS9#)E8V]R92]84T0R16-O<F4B/@H@(" @(" @(#QD971A
> M:6QS(&ME>3TB<F5P<F5S96YT871I;VXB('9A;'5E/2)E;&5M96YT(B\^ "B @
> M(" @(" @/&1E=&%I;',@:V5Y/2)N86UE(B!V86QU93TB;F%M92(O/@H@(" @
> M94%N;F]T871I;VYS/@H@(" @/"]E071T<FEB=71E<SX*(" \+V5#;&%S<VEF
> 8:65R<SX*/"]E8V]R93I%4&%C:V%G93X*
> end
Re: [NEWBIE] library.xsd --> cant see the diagramm [message #376745 is a reply to message #376720] Thu, 30 January 2003 12:28 Go to previous message
hi julien,
i tetsed the new build and its works fine, while importing from a schema.
now i will test it.
thx,
frank
news:b16tr6$k5v$1@rogue.oti.com...
> Hi Frank,
> julien
> omondo
> Frank Bur wrote:
> > julien,
from
trying
> > frank
> > > julien
> > > omondo
> > > Frank Bur wrote:
> > > > frank,
that
> > is
be
> > the
UML-problems?
> > > > nice weekend,
> > > > frank
> > > > > Frank,
> > model
> > > > from
> > then I
> > > > get
> > > > > Frank.
> > > > > Frank Bur wrote:
> > > > > > hello NG,
downloaded
> > the
and
> > thought
> > > > it
class
> > > > diagramm
> > > > > > tia,
> > > > > > frank
> > > > > > W2K, M3
> > end
Previous Topic:Does Template support function definenation?
Next Topic:EMF info
Current Time: Wed Nov 05 11:33:15 EST 2025
Powered by FUDForum. Page generated in 0.04781 seconds
