EPF Authoring - Views, Publishing [message #3330] |
Mon, 20 February 2006 21:51 |
Originally posted by: oddstray.gmail.com
I've tried and failed to create a Method Plug-In and Method Configuration
and to publish it. I followed the procedure in the tutorials. When I try
to publish, I get a notification that my selected configuration does not
contain a valid view.
I don't understand Views, so I don't know what might be wrong or how to
try to fix it. The tutorial and the Composer help aren't giving me any
enlightenment. Where else can I look?
TIA ...
B
Re: EPF Authoring - Views, Publishing [message #3397 is a reply to message #3363] |
Wed, 22 February 2006 01:00 |
I did manage to follow the tutorial and create and publish the view.
Thanks for pointing me directly to it.
But, I disagree that this it "explained" in the tutorial. There's
sufficient 'how' but not enough 'why'. And when I return to trying to
document our methodology, I'm predict that I'm going to find myself in the
same place ... with an invalid View and no clue as to what's wrong with
it.
So, where else can I look for information on Views? And, just because I
learn better from diagrams, is there somewhere I can look at the class
diagram for the EPF Composer?
Thanks ...
B
Re: EPF Authoring - Views, Publishing [message #561547 is a reply to message #3363] |
it.
Thanks ...
B
FUDForum. Page generated in 0.03571 seconds
