Home » Modeling » Modeling (top-level project) » Textual Modelling Framework?
Re: Textual Modelling Framework? [message #376415 is a reply to message #376408] |
Wed, 24 May 2006 12:47 |
Constantine Plotnikov Messages: 45 Registered: July 2009 |
Member |
I have the project in the same direction. It is ETL (see
http://etl.sourceforge.net/etl-java-0_2_0/doc/readme.html for online
documentation and
http://sourceforge.net/project/showfiles.php?group_id=153075 for demos
and documentation).
ETL also allows creating a EMF tree out of text. It is also possible to
create other kinds of trees using the framework (like using plain
JavaBeans) because ETL provides a generic pull parser. Note that ETL
does not requires Java code generation to create parser from grammar
definition. The grammar is compiled into state machine in runtime. ETL
parser framework component organization is quite similar to one of
typical XML parser.
However in my project I have focused on extensibility and reusability of
textual notation definitions rather than on generality of syntax
definition. As result, in ETL is it is possible to define smaller set of
surface syntaxes than in xText. Deep in grammar definition pipeline, the
grammar is translated to LL(1) form. Additional restrictions come from
shared phrase parser and lexer.
But on other hand it is possible to combine these languages together and
to create new languages from old ones. It is also much simpler to create
definitions of operators. See documentation for examples. And I believe
for every language definable with LL(k) grammar it is possible to define
a language with ETL with the same semantics and which still have a
reasonable notation.
As I understand the extensibility in xText is more limited as it uses
lower-level, but more general constructs to define languages. While
wider range of languages could be defined using it, I'm concerned that
these languages will become things in themselves. Lack of reuse would
not hurt on the small projects. But in larger ones it could be somewhat
counterproductive, as do-not-repeat-yourself principle will be violated.
Another problem is that lack of reuse (except using "copy/paste" reuse
methodology) will lead to languages that differ in minor details like
numeric literals, control constructs, etc. even in DSLs created by
single organization. It will impossible to select a common sub-language
and directly express it as such using grammar definition. This will be
barrier for learning and use of DSLs.
In addition to tree based parsers ETL support pull parsing to support
interpreter read-eval-print loops. I also think that pull parsing will
be more convenient for text editors.
Note that ETL is in much more early development stages than xText. I am
not able to dedicate much time to it as it is still a personal project.
There is no generic customizable text editor for the language yet. It is
believed that such text editor is possible.
I'm also interested if the xText editor supports reparsing of the source
code fragments or always parses entire source.
There might be some integration directions between ETL and xText:
- If editor framework is flexible enough, it can be used to create
general customizable ETL text editor.
- Transformation and constraint component might be reused if they mostly
depend on EMF.
- ETL might be used to define some languages used in xText framework. It
is possible that syntax for sources provided in presentation could be
expressed.
- A specialized xText ETL framework could be created that simplifies
xText editor creation for ETL-based languages.
Constantine
Sven Efftinge wrote:
> I just met Artem at the JAX conference in Germany, where we talked a bit
> about different approaches for textual notations for DSLs.
> I wanted to point you to the xText framework we are currently developing
> at openArchitectureWare.
> It offers (generates) a textual parser and a textual eclipse editor
> based on a grammar described in a simplified BNF-notation.
> The generated parser is based on AntLR and creates a (dynamic) EMF
> model. The generated text editor provides syntax highlighting, syntax
> checking, constraint checking and an outline view.
> I've written a blog entry showing some more details (and screenshots):
> http://effi-blog.blogspot.com/2006/04/textual-dsl-framework- xtext.html
> The xText framework was also a part of our session at "Eclipse Forum
> Europe", which shows the integration of EMF and GMF with oAW (and
> xText). Some of you may find that interesting, too.
> The slides can be found here:
> http://www.eclipse.org/gmt/oaw/doc/s10_gmfAndOAW_slides.pdf
> We are very interested in sharing ideas about textual DSL design and
> would be happy if we could contribute some ideas or code to a possible
> TMF (Textual Modelling Framework) if there are plans to create such a
> project.
> best regards,
> Sven
Re: Textual Modelling Framework? [message #376416 is a reply to message #376415] |
Wed, 24 May 2006 15:15 |
Sven Efftinge Messages: 1823 Registered: July 2009 |
Hi Constantine,
there are definitely a lot of interesting ideas in your work.
I think the main difference between our approaches is the way of
abstraction.
With xText grammar language one describes a textual language, which is
mapped on an Ecore model. The abstraction lays in hiding all the little
tweeking options, and stuff. So the grammars are very simple and readable.
ETL seems to provide concepts for general purpose programming languages
(with expressions, statements, etc.) and the language descriptions are
not that readable (IMO and of course the provided examples are more
complex) Additionally the language seems to be far more complex (indeed
far more powerful, too)
It's not the goal of xText to define complex languages containing
expressions and stuff, but to be able to write small structural
languages (little languages) in about 5 min (this is what my DSLs are in
about 98% of all cases).
Additionally it is important (IMO), to define the conrete syntax,
because the language should be represented the way the user (domain
expert, who ever that is) wants it to be. I don't want to automatically
have semicolons and curly brackets everywhere.
I really like the extension mechanism ETL provides (I missed such things
in common parser generators). I want to add the possibility of grammar
imports and external rule references to xText so this might relativize
the missing extensibility you mentioned. Of course it's a different
concept and not that flexible and more invasive.
The xText editor uses the generated antLR parser, which is not
incremental. IMO this is not necessary, because the parser is fast enough.
The transformation and constraint component from xText are the languages
"xtend" respective "check" from openArchitectureWare. they are not EMF
dependent but can work on EMF models. BTW.: Both languages use the same
expression sub-language which is another proof for your extensibility
requirement :-)
regards,
Sven
Constantine Plotnikov schrieb:
> documentation and
> and documentation).
> typical XML parser.
> depend on EMF.
> expressed.
> Constantine
>> Hi,
>> bit about different approaches for textual notations for DSLs.
>> developing at openArchitectureWare.
>> project.
>> best regards,
>> Sven
Re: Textual Modelling Framework? [message #376418 is a reply to message #376417] |
Wed, 24 May 2006 18:15 |
Ed Merks Messages: 33142 Registered: July 2009 |
--------------010905010501070005010905
Sven,
This is what Janet Campbell had to say:
To date I have not approved ANTLR for use in any Eclipse project.
Contributions are reviewed and approved/declined based on the
results of the investigation of the code. In the case of ANTLR
pedigree concerns were identified and use of ANTLR in Eclipse was
not approved. A revised version of ANTLR with a cleaner IP trail is
due for release this summer at which time we can revisit the issue.
Please see: http://www.antlr.org/v3/index.html.
LPG has definitely been approved; whether the next version of ANTLR will
be approved will depend on the quality of the legal audit trail for all
its contributions...
> I also had a look at some presentation slides about Gymnast and indeed
> the approaches are very similar.
> regarding the license issue:
> I thought about switching to Antlr 3 (when it is in beta).
> It will be released under BSD.
> I don't know LPG but I will have a look at it...
> Sven
> Ed Merks schrieb:
>> Rich,
>> I was asking Chris for a comparison between this work and his Gymnast
>> work; there are lots of similarities and a few differences.
>> Unfortunately, because of his use of ANTLR, Chris' donation is being
>> held up. I suspect that Sven's work will run into the same legal
>> barrier. :-( Other projects (OCL) that used ANTLR have switched to
>> LPG. I'll follow up with Janet to confirm if there is now an
>> absolute barrier against the use of ANTLR or if perhaps the
>> development work to migrate to a framework with a more sound pedigree
>> can take place within the Eclipse open source community rather than
>> being forced outside of it.
>> Richard Gronback wrote:
>>> I guess the remainder of my note didn't make it...
>>> What it said was that you might consider getting together with Artem
>>> and Chris Daly (Emfatic) to work on a project proposal. It's
>>> definitely a project we'd like to see started, as it's on our
>>> charter. We look forward to your contribution :)
>>> Best Regards,
>>> Rich
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Sven,<br>
<br>
This is what Janet Campbell had to say: <br>
<blockquote>To date I have not approved ANTLR for use in any Eclipse
project. Contributions are reviewed and approved/declined based on the
pedigree concerns were identified and use of ANTLR in Eclipse was not
approved. A revised version of ANTLR with a cleaner IP trail is due
for release this summer at which time we can revisit the issue. Please
see: <a class="moz-txt-link-freetext" href="http://www.antlr.org/v3/index.html">http://www.antlr.org/v3/index.html</a>. <br>
</blockquote>
will be approved will depend on the quality of the legal audit trail
for all its contributions...<br>
<br>
<br>
<blockquote cite="mide51tul$a1g$1@utils.eclipse.org" type="cite">I also
had a look at some presentation slides about Gymnast and indeed the
<br>
<br>
<br>
<br>
<br>
<br>
Sven
<br>
<br>
Ed Merks schrieb:
<br>
<blockquote type="cite">Rich,
<br>
<br>
LPG. I'll follow up with Janet to confirm if there is now an absolute
barrier against the use of ANTLR or if perhaps the development work to
migrate to a framework with a more sound pedigree can take place within
the Eclipse open source community rather than being forced outside of
it.
<br>
<br>
<br>
<br>
<br>
<blockquote type="cite">I guess the remainder of my note didn't
make it...
<br>
<br>
definitely a project we'd like to see started, as it's on our charter.
<br>
<br>
Best Regards,
<br>
Rich
<br>
<br>
<br>
</blockquote>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------010905010501070005010905--
Ed Merks
Re: Textual Modelling Framework? [message #377134 is a reply to message #376416] |
Thu, 25 May 2006 15:16 |
Member |
Hi Sven,
The ETL grammar definition language also specifies mapping from source
to AST (that might happen to be EMF/MOF). The simpler grammar definition
language is possible. I will evaluate it for 0.3 after more languages
are created and I will start seeing construct usage patterns better. The
current grammar language lacks any shortcuts and it should definitely
evolve. Theoretically statement definition language can be of about the
same complexity as production language in xText.
Some things in the language that increase its verbosity are done to
support extensibility, but they are possibly too straightforward. For
example name of statement/operator and name of AST object are different
to support extensibility (in xText they are the same as I understand).
This also had allowed defining different mapping to single AST node from
different contexts. I guess it could have been done in other way using
“redefine” declaration but that would have put some restrictions on
extensibility.
Also there is a bit less pressure on verbosity in ETL than in xText. If
language so big that verbosity is being felt, it is likely that some
reuse is possible (common expression language, control constructs, etc.).
The state machine is actually a good sample to demonstrate a need for
extensibility. Initial example is very small and neat. But how long will
it stay as such when you will start receiving user feedback? Feedback
will be likely chained like in the following scenario (guesswork from
experience):
1. The first thing the users will likely want would be guards on
transitions. This will lead to expression sublanguage. Possibly an
existing one like Java or OCL or directly mappable to them.
2. Then it is very likely that users will want action sublanguage that
shares some things with expression sublanguage. Specifying a method name
is a bit too limiting. User will prefer to specify code in place rather
than in some separate template. And the user will prefer to reference
external code libraries directly from action language.
3. Then it is very likely the project with completely different actions
and expression will want to reuse state machine definition but to use
own action and expression sublanguage. This will require factoring out
abstract reusable state machine language (unless copy/paste reuse is
undertaken).
4. Then in the action or expression sublanguage they will likely want to
use constructs from other domain specific language (for example
relational algebra). Note that users will love a least syntax error
checking in relational algebra sublanguage, so expressions sql(“select
id from ids”) would be less preferable than sql(select id from ids).
ETL directly support these scenarios on syntax side. Complementary "open
compiler" technology is required on implementation side. From what I
see, with xText one would quickly come to phase when answer to customer
request would be “this is too complex to implement in maintainable way”.
Please correct me if I’m wrong here.
On representation, I do not think that it ETL is too limiting. I have
done experiments with imperative language like Java (EJ in samples) and
functional like Haskell (not published because I need to learn Haskell
more to finalize it). The tailored language is usually more readable and
shorter (but sometime ETL based languages are shorter [for example
Pascal]). But result is usually better than LISP’s way and result is the
way better than XML for many cases. Considering advantages of
extensibility, reuse, and automatic error correction, I think that
overhead worth it in long time. Also this is an issue of traction: the
more DSLs are defined in ETL way the acceptable it will look.
I also do not think that simple language import will solve the problem.
Imported language should be usually customized to play well with
environment. For example in state machine example, the reused action
language would be likely extended by statement like “nextstate <state
label>”. Relational algebra DSL embedded into some host language like
Java could require inserting code fragments in host language like
"sql(select id from id where name = #(person.getName().substring(0,14))
and id < 1000)" (to replace prepared statement followed by parameter
binding).
Constantine
> Hi Constantine,
> abstraction.
> requirement :-)
> regards,
> Sven
>> Hi,
>> documentation and
>> and documentation).
>> to create other kinds of trees using the framework (like using plain
>> typical XML parser.
>> of textual notation definitions rather than on generality of syntax
>> of surface syntaxes than in xText. Deep in grammar definition
>> pipeline, the grammar is translated to LL(1) form. Additional
>> restrictions come from shared phrase parser and lexer.
>> and to create new languages from old ones. It is also much simpler to
>> create definitions of operators. See documentation for examples. And I
>> believe for every language definable with LL(k) grammar it is possible
>> to define a language with ETL with the same semantics and which still
>> have a reasonable notation.
>> somewhat counterproductive, as do-not-repeat-yourself principle will
>> be violated. Another problem is that lack of reuse (except using
>> "copy/paste" reuse methodology) will lead to languages that differ in
>> minor details like numeric literals, control constructs, etc. even in
>> DSLs created by single organization. It will impossible to select a
>> common sub-language and directly express it as such using grammar
>> definition. This will be barrier for learning and use of DSLs.
>> am not able to dedicate much time to it as it is still a personal
>> project. There is no generic customizable text editor for the language
>> yet. It is believed that such text editor is possible.
>> source code fragments or always parses entire source.
>> mostly depend on EMF.
>> It is possible that syntax for sources provided in presentation could
>> be expressed.
>> Constantine
>>> Hi,
>>> screenshots):
>>> possible TMF (Textual Modelling Framework) if there are plans to
>>> create such a project.
>>> best regards,
>>> Sven
Re: Textual Modelling Framework? [message #377138 is a reply to message #377134] |
Thu, 25 May 2006 21:13 |
Constantine,
As I said in my previous post, xText is meant to be used for little
structural languages.
If you really want to develop a complex textual language like the one
you describe (state machine with expressions for guards and actions) I
would recommend using a common parser generator (or maybe ETL when it is
more matured).
This is definitely no target language for xText!
Using xText (or GMF) I would describe the guards and actions with Java
against the generated Java code (like we do it in the example).
That makes the development of languages and generators much easier
and the drawback (describing behaviour in another artifact) is not that
big. To be honest, I think it's an advantage, because I can use all the
good tool support from JDT (not just syntax checking).
Developing such complex languages (including good tool support) is no
easy task. Additionally the user has to understand the DSL, so it should
be simple.
Don't get me wrong, I really like many of your ideas. And it is
definitely important that we do more research in this area, but I think
for a Textual Modelling Framework (helping developing DSLs) it's better
to focus on a smaller set of languages so we can describe those in a
more abstract and easy manner.
regards,
Sven
> Hi Sven,
> extensibility.
> experience):
> undertaken).
> binding).
> Constantine
>> Hi Constantine,
>> abstraction.
>> little tweeking options, and stuff. So the grammars are very simple
>> and readable.
>> languages (with expressions, statements, etc.) and the language
>> descriptions are not that readable (IMO and of course the provided
>> examples are more complex) Additionally the language seems to be far
>> more complex (indeed far more powerful, too)
>> in about 98% of all cases).
>> automatically have semicolons and curly brackets everywhere.
>> things in common parser generators). I want to add the possibility of
>> grammar imports and external rule references to xText so this might
>> relativize the missing extensibility you mentioned. Of course it's a
>> different concept and not that flexible and more invasive.
>> enough.
>> languages "xtend" respective "check" from openArchitectureWare. they
>> are not EMF dependent but can work on EMF models. BTW.: Both languages
>> use the same expression sub-language which is another proof for your
>> extensibility requirement :-)
>> regards,
>> Sven
>>> Hi,
>>> documentation and
>>> demos and documentation).
>>> ETL parser framework component organization is quite similar to one
>>> of typical XML parser.
>>> I believe for every language definable with LL(k) grammar it is
>>> possible to define a language with ETL with the same semantics and
>>> which still have a reasonable notation.
>>> that these languages will become things in themselves. Lack of reuse
>>> would not hurt on the small projects. But in larger ones it could be
>>> will be more convenient for text editors.
>>> language yet. It is believed that such text editor is possible.
>>> be expressed.
>>> Constantine
>>>> Hi,
>>>> syntax checking, constraint checking and an outline view.
>>>> screenshots):
>>>> best regards,
>>>> Sven
Re: Textual Modelling Framework? [message #377221 is a reply to message #377219] |
Sat, 24 June 2006 01:55 |
Richard Gronback Messages: 605 Registered: July 2009 |
Human usability is the primary motivation, I'd say. It's not about creating
a "new language," but providing a concrete syntax for a language that is
more "human friendly" than XML.
On 6/23/06 9:01 PM, in article op.tbmk4agaac05ss@dmw2t23.raleigh.ibm.com,
"David Williams" <david_williams@us.ibm.com> wrote:
> On Tue, 23 May 2006 11:05:18 -0400, Sven Efftinge <sven@efftinge.de> wrote:
> This sounds like it must be obvious to others on this list, but
> what exactly is the advantage of using a "new language" to
> describe a DSL instead of, let's say, using XML?
Re: Textual Modelling Framework? [message #565074 is a reply to message #376410] |
Wed, 24 May 2006 11:01 |
Rich,
the Eclipse open source community rather than being forced outside of it.
> Best Regards,
> Rich
Ed Merks
Re: Textual Modelling Framework? [message #565143 is a reply to message #376413] |
Wed, 24 May 2006 11:52 |
Srgjan,
The issue is a legal one in that ANTLR has a poorly tracked pedigree.
I.e., it's not entirely clear where everything in ANTLR came from and
whether all contributors intended their work to be licensed as it is.
Srgjan Srepfler wrote:
> Ed Merks wrote:
>> Rich,
>>> Best Regards,
>>> Rich
> Is ANTLR inferior to LPG or is it a licensing issue?
> Srgjan
Ed Merks
Re: Textual Modelling Framework? [message #565170 is a reply to message #376408] |
Member |
documentation and
and documentation).
typical XML parser.
depend on EMF.
expressed.
Constantine
> project.
> best regards,
> Sven
Re: Textual Modelling Framework? [message #565199 is a reply to message #376415] |
Hi Constantine,
abstraction.
requirement :-)
regards,
Sven
> documentation and
> and documentation).
> typical XML parser.
> depend on EMF.
> expressed.
> Constantine
>> Hi,
>> project.
>> best regards,
>> Sven
Re: Textual Modelling Framework? [message #565268 is a reply to message #376417] |
Sven,
> Sven
> Ed Merks schrieb:
>> Rich,
>>> Best Regards,
>>> Rich
<html>
<head>
</head>
Sven,<br>
<br>
</blockquote>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Sven
<br>
<br>
Ed Merks schrieb:
<br>
<br>
<br>
it.
<br>
<br>
<br>
<br>
<br>
make it...
<br>
<br>
<br>
<br>
Best Regards,
<br>
Rich
<br>
<br>
<br>
</blockquote>
</blockquote>
</blockquote>
<br>
</body>
</html>
Ed Merks
Re: Textual Modelling Framework? [message #572816 is a reply to message #376416] |
Member |
Hi Sven,
extensibility.
experience):
undertaken).
binding).
Constantine
> Hi Constantine,
> abstraction.
> requirement :-)
> regards,
> Sven
>> Hi,
>> documentation and
>> and documentation).
>> typical XML parser.
>> be expressed.
>> Constantine
>>> Hi,
>>> screenshots):
>>> best regards,
>>> Sven
Re: Textual Modelling Framework? [message #572859 is a reply to message #377134] |
Constantine,
more matured).
be simple.
regards,
Sven
> Hi Sven,
> extensibility.
> experience):
> undertaken).
> binding).
> Constantine
>> Hi Constantine,
>> abstraction.
>> and readable.
>> enough.
>> regards,
>> Sven
>>> Hi,
>>> documentation and
>>> be expressed.
>>> Constantine
>>>> Hi,
>>>> screenshots):
>>>> best regards,
>>>> Sven
Re: Textual Modelling Framework? [message #578193 is a reply to message #377219] |
Current Time: Fri Apr 26 08:41:48 GMT 2024
Powered by FUDForum. Page generated in 0.04353 seconds
