Home » Eclipse Projects » Eclipse Platform » update manager isn't working through https
update manager isn't working through https [message #38497] Mon, 19 May 2003 14:51 Go to next message
Originally posted by: cmbrandt.us.InternationalBusinessMachines.com
I'm having a problem accessing an eclipse plugin download site through
https. I'm getting the following errors:
Unable to access "https://<site-removed>/<path-removed>/".
Unable to access Site stream: https://<site-removed>/<path-removed>/"
[Could not find trusted certificate]
https://<site-removed>/<path-removed>/site.xml"
Is there some initial setup in eclipse I need to do in order to work
through https? I can access the site through a web browser without problem.
Thanks!
-Chris
Re: update manager isn't working through https [message #40506 is a reply to message #38497] Tue, 20 May 2003 11:53 Go to previous messageGo to next message
Originally posted by: birsan.nospam.ca.ibm.com
Https support is automatically picked up by the update manager from the JDK.
Depending on the JDK version you are using, the https support may or may not
be part of your JDK.
I think 1.4 has built-in support, but for 1.3.1 you will need to install the
https extension.
-Dorian
"Chris Mildebrandt" <cmbrandt@us.InternationalBusinessMachines.com> wrote in
message news:bab92s$m02$1@rogue.oti.com...
problem.
> Thanks!
> -Chris
Re: update manager isn't working through https [message #40664 is a reply to message #40506] Tue, 20 May 2003 13:24 Go to previous messageGo to next message
I'm using JDK1.4.0_01-b03, and it seems to have support for https
through the jsse.jar. Here's the stack trace I just found a few minutes ago:
!SUBENTRY 1 org.eclipse.update.core 4 42 May 20, 2003 13:12:08.144
!MESSAGE Unable to access Site stream:
"https://<site-removed>/<path-removed>/site.xml" [Could not find trusted
certificate]
!STACK 0
javax.net.ssl.SSLHandshakeException: Could not find trusted certificate
at com.sun.net.ssl.internal.ssl.SSLSocketImpl.b(DashoA6275)
at com.sun.net.ssl.internal.ssl.SSLSocketImpl.a(DashoA6275)
at com.sun.net.ssl.internal.ssl.ClientHandshaker.a(DashoA6275)
at com.sun.net.ssl.internal.ssl.ClientHandshaker.processMessage (DashoA6275)
at com.sun.net.ssl.internal.ssl.Handshaker.process_record(Dasho A6275)
at com.sun.net.ssl.internal.ssl.AppOutputStream.write(DashoA627 5)
at java.io.OutputStream.write(OutputStream.java:58)
at com.sun.net.ssl.internal.ssl.SSLSocketImpl.startHandshake(Da shoA6275)
at sun.net.www.protocol.https.HttpsClient.afterConnect(DashoA62 75)
sun.net.www.protocol.https.AbstractDelegateHttpsURLConnectio n.connect(DashoA6275)
sun.net.www.protocol.http.HttpURLConnection.getInputStream(H ttpURLConnection.java:562)
sun.net.www.protocol.https.HttpsURLConnectionImpl.getInputSt ream(DashoA6275)
org.eclipse.update.internal.core.ConnectionThreadManager$Str eamRunnable.run(ConnectionThreadManager.java:76)
at java.lang.Thread.run(Thread.java:536)
Thanks for any help you can give!
-Chris
> https extension.
> -Dorian
>>Hi,
> problem.
>>Thanks!
>>-Chris
Re: update manager isn't working through https [message #40976 is a reply to message #40664] Tue, 20 May 2003 18:03 Go to previous messageGo to next message
Chris,
I searched the newsgroups a bit and found this posting that may help you:
------ begin newsgroup quote ------------------------------
That's normal for self-signed certificates. You don't want your code to
automatically trust a certificate and establish encryption with it if you
don't really know where it came from. If you want to test with a
self-signed certificate, you can add it to the list of "cacerts" that the
JSSE implementation trusts. Here are a relevant few paragraphs from Sun's
JSSE 1.0.2 Guide:
When running the sample programs that create a secure socket connection
between a client and a server, you will need to make the appropriate
certificates file (truststore) available. For both the client and the server
programs, you should use the certificates file samplecacerts, located in the
directory <ExtractDir>/samples. Using this certificates file will allow the
client to authenticate the server. The file contains all the common
Certification Authority certificates shipped with J2SDK (in the cacerts
file), plus a certificate for "duke" needed by the client to authenticate
"duke" when communicating with the sample server ClassFileServer.
(ClassFileServer uses a keystore containing the private key for "duke" which
corresponds to the public key in samplecacerts. )
To make the samplecacerts file available to both the client and the server,
you can either copy it to the file <java-home>/lib/security/jssecacerts,
rename it cacerts and use it to replace the <java-home>/lib/security/cacerts
file, or add the following option to the command line when running the java
command for both the client and the server:
-Djavax.net.ssl.trustStore=path_to_samplecacerts_file
The password for the samplecacerts truststore is changeit. You can
substitute your own certificates in the samples, using keytool.
----------- end newsgroup quote --------------------
message news:badod2$n82$1@rogue.oti.com...
ago:
> certificate]
> !STACK 0
> at
> at
6275)
> at
..java:562)
> at
> at
> -Chris
JDK.
not
the
> > https extension.
> > -Dorian
wrote in
> >>Hi,
> > problem.
> >>Thanks!
> >>-Chris
Re: update manager isn't working through https [message #43923 is a reply to message #40976] Thu, 22 May 2003 11:39 Go to previous message
Dorian,
Thanks for your help! that did the trick. I'm still a little surprised
eclipse wouldn't just grab the cert and ask permission to install it.
Thanks again!!
-Chris
> Chris,
> JSSE 1.0.2 Guide:
Previous Topic:vi Editor Plugin
Next Topic:Re: Preventing an Editor fom being restored!
Current Time: Fri Oct 31 11:42:46 EDT 2025
Powered by FUDForum. Page generated in 0.04312 seconds
