Home » Eclipse Projects » EclipseLink » First steps
First steps [message #376084] Sun, 06 July 2008 14:15 Go to next message
I would like to start developing with Eclipselik, but I am a little confused
about tools.
I've just discovered that "Workbench" is an independent application, but I
mean to use Eclipse IDE to delevop an RCP application, so what should I do?
Using Dali inside the IDE can substituite the use of the external
"Workbench"?
Giovanni
Re: First steps [message #376088 is a reply to message #376084] Mon, 07 July 2008 07:34 Go to previous messageGo to next message
Giovani,
Yes, I would recommend using the Dali functionality within WTP to build a
RCP application using EclipseLink JPA. The Ganymede version of Dali
offered support for simplified configuration of many of EclipseLink JPA's
advanced features.
The Workbench is only provided for compatibility with those customers
using Oracle TopLink's classic API and metadata. Developers using JPA and
the Eclipse IDE should not need to use this utility.
Doug
Re: First steps [message #376324 is a reply to message #376088] Tue, 08 July 2008 15:20 Go to previous messageGo to next message
OK thanks
In the wiki this concept is not clear.
Giovanni
"Doug Clarke" <douglas.clarke@oracle.com> ha scritto nel messaggio
news:129ea7e62c943798d0104298f7bb84fd$1@www.eclipse.org...
> Giovani,
> advanced features.
> Doug
Re: First steps [message #379614 is a reply to message #376324] Tue, 19 August 2008 14:42 Go to previous message
Giovanni wrote:
> OK thanks
I second that! I am a "newbe" as far as modern persistence (used JDBC
than Ibatis in the past). After studying the wiki I ended up working the
Eclipselink workbench.
I haven't made the jump from Europa to Gyanmede yet. The Eclipselink
workbench has let me use Eclipselink with my 3.3 projects ... so far.
It a great job guys! Thanks!!!
Previous Topic:rcp, osgi, and dynamic weaving
Next Topic:Connecting to Derby using EmbeddedDriver
Current Time: Sat Oct 25 05:17:14 EDT 2025
Powered by FUDForum. Page generated in 0.05071 seconds
