Home » Archived » Buckminster » .log file
.log file [message #375593] |
Wed, 13 February 2008 14:49  |
Originally posted by: johnmc.cs.clemson.edu
--------------030400080509050707020509
An unnamed file is created at the time of this error. A copy is attached.
John
name="eclipseError.txt"
Content-Disposition: inline;
filename="eclipseError.txt"
!SESSION 2008-02-13 14:41:59.734 -----------------------------------------------
eclipse.buildId=I20071101-2000
java.version=1.6.0_02
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.ui.workbench 2 0 2008-02-13 14:42:31.437
!MESSAGE A handler conflict occurred. This may disable some commands.
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2008-02-13 14:42:31.437
!MESSAGE Conflict for 'AUTOGEN:::org.eclipse.buckminster.ui.projectaction/org.ecli pse.buckminster.pde.ui.viewCSpec':
HandlerActivation(commandId=AUTOGEN:::org.eclipse.buckminste r.ui.projectaction/org.eclipse.buckminster.pde.ui.viewCSpec,
handler=ActionDelegateHandlerProxy(null,org.eclipse.buckmins ter.pde.ui.actions.ViewBundleCSpecAction),
expression=WorkbenchWindowExpression(org.eclipse.ui.internal.WorkbenchWindow@152bdc7),sourcePriority=16384)
!MESSAGE Conflict for 'AUTOGEN:::org.eclipse.buckminster.ui.projectaction/org.ecli pse.buckminster.pde.ui.invokeAction':
HandlerActivation(commandId=AUTOGEN:::org.eclipse.buckminste r.ui.projectaction/org.eclipse.buckminster.pde.ui.invokeActi on,
handler=ActionDelegateHandlerProxy(null,org.eclipse.buckmins ter.pde.ui.actions.InvokeBundleAction),
!ENTRY org.eclipse.jface 2 0 2008-02-13 14:42:31.515
!MESSAGE Keybinding conflicts occurred. They may interfere with normal accelerator operation.
!SUBENTRY 1 org.eclipse.jface 2 0 2008-02-13 14:42:31.515
!MESSAGE A conflict occurred for CTRL+3:
Binding(CTRL+3,
ParameterizedCommand(Command(net.sourceforge.texlipse.comman ds.wordCount,Word Count,
Category(net.sourceforge.texlipse.latexEditingCategory,Texli pse,Latex Editing,true),
,,true),null),
org.eclipse.ui.defaultAcceleratorConfiguration,
org.eclipse.ui.contexts.window,,,system)
Binding(CTRL+3,
ParameterizedCommand(Command(org.eclipse.ui.window.quickAcce ss,Quick Access,
Quickly access UI elements,
Category(org.eclipse.ui.category.window,Window,null,true),
org.eclipse.ui.internal.quickaccess.QuickAccessHandler@13598c3,
,,true),null),
!MESSAGE A conflict occurred for SHIFT+DEL:
Binding(SHIFT+DEL,
ParameterizedCommand(Command(org.eclipse.datatools.sqltools. result.removeAllInstances,Remove All Visible Results,
Category(org.eclipse.datatools.sqltools.result.category,SQL Results View,null,true),
,,true),null),
Binding(SHIFT+DEL,
ParameterizedCommand(Command(org.eclipse.ui.edit.cut,Cut,
Cut the selection to the clipboard,
Category(org.eclipse.ui.category.edit,Edit,null,true),
org.eclipse.ui.internal.handlers.WidgetMethodHandler@1c06a6d,
,,true),null),
org.eclipse.ui.contexts.dialogAndWindow,,,system)
Binding(SHIFT+DEL,
ParameterizedCommand(Command(org.topcased.modeler.deleteMode lObject,Delete From Model,
Allows the user to delete the selected graph element and its associated model element in a Topcased editor.,
,,true),null),
!ENTRY org.eclipse.ui.console 4 2 2008-02-13 14:42:32.968
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.ui.console".
!STACK 0
org.eclipse.swt.SWTException: Invalid thread access
at org.eclipse.swt.SWT.error(SWT.java:3706)
at org.eclipse.swt.SWT.error(SWT.java:3624)
at org.eclipse.swt.SWT.error(SWT.java:3595)
at org.eclipse.swt.widgets.Widget.error(Widget.java:441)
at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:335)
at org.eclipse.swt.widgets.Control.getFont(Control.java:1210)
at org.eclipse.ui.console.TextConsoleViewer.setFont(TextConsole Viewer.java:198)
at org.eclipse.ui.console.TextConsolePage.propertyChange(TextCo nsolePage.java:236)
at org.eclipse.ui.console.AbstractConsole$PropertyNotifier.run( AbstractConsole.java:104)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.ui.console.AbstractConsole$PropertyNotifier.noti fy(AbstractConsole.java:120)
at org.eclipse.ui.console.AbstractConsole.firePropertyChange(Ab stractConsole.java:246)
at org.eclipse.ui.console.TextConsole.setFont(TextConsole.java: 241)
at org.eclipse.m2m.atl.adt.ui.AtlUIPlugin.initConsole(AtlUIPlug in.java:232)
at org.eclipse.m2m.atl.adt.ui.AtlUIPlugin.<init>(AtlUIPlugin.java:142)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknow n Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Un known Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:137)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:970)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:261)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:419)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:189)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:344)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:412)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:373)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:361)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:289)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1269)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:160)
at org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:819)
at org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:244)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:49)
at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:240)
at org.eclipse.ui.internal.decorators.LightweightDecoratorDefin ition$1.run(LightweightDecoratorDefinition.java:117)
at org.eclipse.core.runtime.Platform.run(Platform.java:857)
at org.eclipse.ui.internal.decorators.LightweightDecoratorDefin ition.internalGetDecorator(LightweightDecoratorDefinition.ja va:113)
at org.eclipse.ui.internal.decorators.LightweightDecoratorDefin ition.decorate(LightweightDecoratorDefinition.java:241)
at org.eclipse.ui.internal.decorators.LightweightDecoratorManag er$LightweightRunnable.run(LightweightDecoratorManager.java: 71)
at org.eclipse.ui.internal.decorators.LightweightDecoratorManag er.decorate(LightweightDecoratorManager.java:336)
at org.eclipse.ui.internal.decorators.LightweightDecoratorManag er.getDecorations(LightweightDecoratorManager.java:322)
at org.eclipse.ui.internal.decorators.DecorationScheduler$1.ens ureResultCached(DecorationScheduler.java:369)
at org.eclipse.ui.internal.decorators.DecorationScheduler$1.run (DecorationScheduler.java:329)
!ENTRY org.eclipse.ui.console 4 120 2008-02-13 14:42:32.968
!MESSAGE Exception occurred during console property change notification.
!STACK 0
!ENTRY org.topcased.externalbus.core 1 1 2008-02-13 14:43:09.812
!MESSAGE Topcased Web Server launched. Listening on port :8080
!ENTRY org.eclipse.buckminster.core 2 293 2008-02-13 14:45:26.312
!MESSAGE java.lang.StackOverflowError
!STACK 0
at org.eclipse.ui.internal.progress.ProgressManager.access$2(Pr ogressManager.java:787)
at org.eclipse.ui.internal.progress.ProgressManager$1.updateFor (ProgressManager.java:491)
at org.eclipse.ui.internal.progress.ProgressManager$1.scheduled (ProgressManager.java:460)
at org.eclipse.core.internal.jobs.JobListeners$5.notify(JobList eners.java:49)
at org.eclipse.core.internal.jobs.JobListeners.doNotify(JobList eners.java:96)
at org.eclipse.core.internal.jobs.JobListeners.scheduled(JobLis teners.java:162)
at org.eclipse.core.internal.jobs.JobManager.schedule(JobManage r.java:958)
at org.eclipse.core.internal.jobs.InternalJob.schedule(Internal Job.java:368)
at org.eclipse.core.runtime.jobs.Job.schedule(Job.java:461)
at org.eclipse.ui.internal.progress.ProgressViewUpdater.schedul eUpdate(ProgressViewUpdater.java:226)
at org.eclipse.ui.internal.progress.ProgressViewUpdater.refresh JobInfo(ProgressViewUpdater.java:338)
at org.eclipse.ui.internal.progress.ProgressManager.refreshJobI nfo(ProgressManager.java:664)
at org.eclipse.ui.internal.progress.ProgressManager$JobMonitor. internalWorked(ProgressManager.java:239)
at org.eclipse.core.runtime.ProgressMonitorWrapper.internalWork ed(ProgressMonitorWrapper.java:94)
at org.eclipse.core.runtime.SubProgressMonitor.internalWorked(S ubProgressMonitor.java:155)
Re: .log file [message #375599 is a reply to message #375595] |
Wed, 13 February 2008 15:43   |
--------------080004000302030600020203
I am using Eclipse 3.4.0 Build Id I20071101-2000
The workspace has a large number of projects but they are all closed.
I copied the uri from the web page, put it into the Open file dialog.
With a workspace with only two small projects (but they are closed). It
took longer but eventually the stack overflowed.
I have attached another log file.
John
Thomas Hallgren wrote:
> Hi John,
> Thanks for the attached log. Unfortunately, it doesn't say much. It
> tells me that some recursion involving a progress monitor occurred but
> the bottom of the stack is excluded. Perhaps the printout got truncated
> due to some max limit. Is the log complete?
> Can you tell me what exact steps you take before this happens? Are you
> using an old workspace? If so, what other components do you have there?
> What Eclipse version are you currently using?
> (sorry, lot's of questions, but since I cannot reproduce the error,
> you're my only source of information).
> Thomas Hallgren
>> John
name="logFile.txt"
filename="logFile.txt"
!ENTRY org.eclipse.ui.workbench 2 0 2008-02-13 15:29:54.375
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2008-02-13 15:29:54.375
expression=WorkbenchWindowExpression(org.eclipse.ui.internal.WorkbenchWindow@c59ad5),sourcePriority=16384)
!ENTRY org.eclipse.jface 2 0 2008-02-13 15:29:54.390
!SUBENTRY 1 org.eclipse.jface 2 0 2008-02-13 15:29:54.390
Binding(CTRL+3,
,,true),null),
Binding(CTRL+3,
org.eclipse.ui.internal.quickaccess.QuickAccessHandler@1dfe453,
,,true),null),
Binding(SHIFT+DEL,
,,true),null),
Binding(SHIFT+DEL,
org.eclipse.ui.internal.handlers.WidgetMethodHandler@73b72,
,,true),null),
Binding(SHIFT+DEL,
,,true),null),
!ENTRY org.topcased.externalbus.core 2 2 2008-02-13 15:29:57.843
!MESSAGE Topcased Web Server not launched. Please define the preference value port in the Preferences Page.
!ENTRY com.pnp.xfeature 1 0 2008-02-13 15:30:04.671
!MESSAGE createControl() called, object reference: com.pnp.xfeature.editor.MetaModelEditorOutlinePage@5d529e
!ENTRY org.eclipse.osgi 2 0 2008-02-13 15:31:17.234
!MESSAGE While loading class "org.eclipse.buckminster.core.metadata.StorageManager", thread "Thread[Worker-4,5,main]" timed out waiting (5000ms) for thread "Thread[main,6,main]" to finish starting bundle "update@plugins/org.eclipse.buckminster.core_1.0.0.r08922.jar [916]". To avoid deadlock, thread "Thread[Worker-4,5,main]" is proceeding but "org.eclipse.buckminster.core.metadata.StorageManager" may not be fully initialized.
!STACK 0
org.osgi.framework.BundleException: State change in progress for bundle "update@plugins/org.eclipse.buckminster.core_1.0.0.r08922.jar" by thread "main".
at org.eclipse.osgi.framework.internal.core.AbstractBundle.begi nStateChange(AbstractBundle.java:1139)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:259)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at org.eclipse.buckminster.core.materializer.WorkspaceBindingIn stallJob.runInWorkspace(WorkspaceBindingInstallJob.java:45)
at org.eclipse.core.internal.resources.InternalWorkspaceJob.run (InternalWorkspaceJob.java:38)
Caused by: org.eclipse.osgi.framework.internal.core.AbstractBundle$Bund leStatusException
... 16 more
Root exception:
!ENTRY org.eclipse.osgi 2 0 2008-02-13 15:31:22.234
!MESSAGE While loading class "org.eclipse.buckminster.core.metadata.ISaxableStorage", thread "Thread[Worker-4,5,main]" timed out waiting (5000ms) for thread "Thread[main,6,main]" to finish starting bundle "update@plugins/org.eclipse.buckminster.core_1.0.0.r08922.jar [916]". To avoid deadlock, thread "Thread[Worker-4,5,main]" is proceeding but "org.eclipse.buckminster.core.metadata.ISaxableStorage" may not be fully initialized.
!STACK 0
... 16 more
Root exception:
!ENTRY org.eclipse.buckminster.core 2 293 2008-02-13 15:37:13.140
!STACK 0
Re: .log file [message #375603 is a reply to message #375602] |
Wed, 13 February 2008 17:16   |
--------------000406080206010104060701
Thomas,
I have cleared the metadata. I have tried two workspaces. I have
attached a small workspace. It takes longer to overflow but it does.
John
> Hi again John,
> The only thing I can think of is if you have some project that has a
> circular dependency somehow or that the Buckminster meta-data is corrupt
> in some way that causes a circular dependency. It should of course not
> cause a StackOverflowException in any case.
> If your workspace contains non-sensive data only, it would be very
> helpful if you could zip it and email it to me directly so that I can
> analyze the problem, or if you feel that it would be less sensitive to
> just zip the Buckminster meta-data from the
> <workspace>/.metadata/.plugins/org.eclipse.buckminster.core folder, then
> that might help too.
> Thomas Hallgren
>> Forgot about that, but yes it does the same thing.
>> John
>>> OK, does the same thing happen if you paste the URL into the "Open a
>>> Component Query" dialog (also under "File"?
>>> - thomas
Content-Type: application/octet-stream;
name="workspace.zip"
Content-Disposition: attachment;
filename="workspace.zip"
UEsDBAoAAAAAALeLaDcAAAAAAAAAAAAAAAAKAAAAd29ya3NwYWNlL1BLAwQK AAAAAABYfU04
AAAAAAAAAAAAAAAAFAAAAHdvcmtzcGFjZS8ubWV0YWRhdGEvUEsDBAoAAAAA AACXMjcAAAAA
AAAAAAAAAAAZAAAAd29ya3NwYWNlLy5tZXRhZGF0YS8ubG9ja1BLAwQUAAAA CACNiU04RiKl
xv1HAADVmwwAGAAAAHdvcmtzcGFjZS8ubWV0YWRhdGEvLmxvZ+xd+3PbOJL+ eVOV/wHjc9Uq
tTZCUm/VZWs8srPjHb/Gss9ztbeVokhY4oQiNXz4sX/9NR6USAkUJdlOnExP 1TgSSHxoNIDu
xocm9cPgaDA4Pj8jlmG0943uvtkhZrfXbPYaXdpp1Mn+Zv+9fcMc35vGjA5T z3eP3Q/HHNlo
Wc19s2kYb9/8bt/Z9I5FsRcGH0zaosYnw5oVB24YfRikATn1nCiMH+OETWJy HDj07ZufwjA5
CW2XRcQJgzixgyTukfPBh3svqFt75OCy//OHh05rj9zMys5OPrDg0/Xg7Zt+ OJnYgbvvewEj
djRKJ0zUJ/thTMTdZP9+9smOnDEBrLdv3r754ejs6vJ/SRiNaNa5329thxGL GIt6a/WsBq13
oZ8/nIJmD/5xRH5hj0MvcL1gxMW+9T0niUnoOGkUMZcScjVmj2RiPxIvSFh0 yyIGQiRjEoTR
xPaJ7TjMZ5GdhBEJp/wDKA608cPg+icpmLm1aAcziWYCkVtoZ/Dz8cervx0e nfRA61L22qxs
7+2bv1zYkT1hIK73H+Yqzdayf/PSuHYCkod+TOM/fPkhYnHqJ/DPJLxjB75/ LIbSYfHepSgi
UEb+x4u9oc/Ipbg55m3+Rfzp2wkbhdHjmq046va9wa8nGRiAs/u9IPX9vSRK 2bs5+J4q4NdE
cb6R1KMuu7UB4WA+JH3QnzdK5ahoaoB+E/aQxBTmlRve7+3tyTn97qmKBWzm etDBNNnrw/9C
N2lCkjEjMUjncIFIEooCXmcY2pFbrkIuqyoXwHtH/M+Ckg4E6s8gC3S/dskS WEcskaU1kOTd
u5dWo+vZfjg6CNybZ9JnEk4dO4aFOAldLg3lfxN2yr+dD38HPe4dihLyMQon RJRLXfh+CPaC
qzeNwSSBqmXV3BDAchpF9nRM4Bs3NwRaJR7MQDuOQ8ez+Q2i3dkNXkBscqVk Inwgwog+cdS+
/NQu2MyZhuFmFgW2P0xjqBxxI2UtG6mGSTvNbs5IzbRxw4ZkwCLwHWAbE+Lb aeCMuQm98Bnc
AOq/5badq38aMW5IwaqQO9tPoSCMhHL5xYvZxZhc2CNGS4x8OgW7wqSojaI9 tYye1e4Zbdpu
NXOiHnojFidgVFPfFTIOoWU7AuF7R2qAk8cpIzte4Pipy+IdMkljcdttyOcT 9HL4SBiYf+ik
nSSRN0xhRsVT5ni3niOGIt4jO3/fAUnJzvu/72wtvAnOwOp8C8I3CrPEsnpG p2fUqdls5aQ/
Y8l9GH3mDi1Qxm8aheBCIHyAoQ5T7lxBQjeNuCeOGffwK9zoKv3pJbgObO6x wA5wlx3HZGec
JNPe+/f39/cUPHfAW/QSEC6N2L0dMQrtvZftxFC+I6S5Ouj/Qsy3b/KycCFo BD3wJoz24cvR
g8OmvI89chRFoEw+TqJbHld4EjF7Qsm/bsbi69TmMx0aJBH7I/W4FoagLcZA RekQvP+xKwyT
XL7HLv03LHY7KVMHvU4830s8FtOA3RfEqc0v8XiuZ1n1d8+G1WxUYAlLSgee st4fbSfhdlHM
YV5aW7okgLsrZBQhGZgs2QCvf315ktV2QM3JHDl3ReB2jHVxj9U3IZ8dgEmK 8uC6y6KFen2F
Sp6pCav10k1Y3c5TmgBDwybTpL9OS5b1lJYg1FmNb7ZW4M9m0CLcEsyqiaPs 1rX4NhBfLmFR
g+FWl84DqQTdHQK90Vwh5Ap42HrA1mAiC8vhrW63HB6iBlnxn+GQGzT5Ja7N CyWG0V4fY7Gy
2dJNJ6H92RD/Hg5jegPuAlTOIdRHUb/ZfLeu9f2X8e+eaOVh4tPYfqCDg98u uLXJ2edtbbDs
ghNOaJwG3FNQGzDGjD6wCKDmfUnBTFLhBVRcfgMR53S+9hZFql0Hn4PwPiCD MAWkd09v6BZ2
X764sDW2N5n69LfTE4FyyXi0xodGfHge5IFjQ2CQYX58PpEz4Bj+PVIR7vHh k2EPQ0cwFAr+
mBfzJqCcR2GHMDtfoo3diyiEDdZh5EGYDT75IXmRnjwL8NngxaAz4I+RPSoZ BXF964ZEUBLF
vC3TLOy05KVXDSwMSvRMeAdDiFchbsoM1VNxf7cfpjNDLOf0P+HbWvDcATwI a55Jt1a11QHp
odxZc69cgFoul/5rlX9+SpzbMTHOxTgX41yMc+dx7pz9sJ7IfrwQD6EIEUOG 5BhnY5yNcTbG
2a8rHMY4G+NsjLMxzsY4G+Psl4iz2ybG2RhnY5yNcTbG2RhnY5yNcTbG2Rhn Y5ytjbOXH2eA
QNrs9hoWNbr4OENFvmXmXmGLsaTBpkk77Xy2a3+WKepx8X2fDFMeSJOpn46g 6H3AYHYLxwIz
cMSoPx3x/7lusnwaefmTSU1q0DupW9M02/UOjGpECPlJQu6sjbVD1GiQHQ3q DhnbsG/xweq4
j7Blgf2KEp4/+hCFkx6RyvjxWTrxfpPnR0DNltFrGLTeqL+y50dKRMPnR/D5 EXx+BJ8feR3P
jygj1aH1L/78yHLc0SWm0WvWe/Uuf5zlzx53kH1uYkm/93/8IQ3BHq7vGTNV NpoLT6x8fc9Y
Khp6RvSM6BnRM74GzzgzUm3aKRipr+IZLW4+e4bBd+StTvvP7hnXdoNKb2bP sBZS7766GywX
Dd0gukF0g+gGX4EbVEbK6pkt2im8BeXLu0HT2DfaxGz0mvxVO9Qwm093g6k8 yfvW/N/WO0Ol
wyYPJQzzVbnElaKVucT+1eXJ3+o5fygLNrXZcq3QP1LP+czXWhzv/co/E/WF L1VR4D9m7ym4
Ps6sQ7yeIVDrUVnIBWOwUGl2diMkki3SX+fSKVv/Y7dh1O3613OSa2p78TQA YLODKnEDNBFG
UCsNkr0b+ETkx+XoohTIhzseuJUFqbK7967U1b0TfpWoy1/VBC9btC43sCbs MxrU6ph/9sB+
fcOWevPcv4IeO7Rh6N8wIs/nlfsmx4ekbNV5LlMhTUxvmA+zlB2JSj2ikh5K q2qrHQfTNMlq
RixJowDsF59w4vRMCZa9L4bbNSWj537YWEYSwEL8oIrKXo4CSLBik+PAS3Jp it9c55ZOzXMY
ssJlFlTwDATYaUARc4XItcUbZApIS/tik9W4OUWUoFra3JUVqFJrfIx+Zj44 Uz1us6tN51kL
V4/Y0KfA5BB5+sAQKow5SEENArXkshJXm42xJO4BCCm7TWOWqE2nvFRbukMm Uaw5bFnqSQls
McGlYTQ3Ad1t8vSKG4iI5mm2GthuXZszkkMdwAYuSadXY37eDh5rVxVcpoGw ZSKLY/EmNdF0
8yG+T8AVuTBCMc0wTkLns8ApFEgMXa/zGINHGN4oDMDVi4ySgxgKTiEsgU7G tcJVqUjtC43y
iIdePPXtx2Ww7IJam02d6rRAoBTYjvKvduKMF3Csbskkt6dTX71zaz7PD9w7 L4b9Hn8blYze
4trSRQHc7mpTeXSLZ9fSzJbZVaW3eqNqveBU+VpTZXlIRY7X8eIgWnWjar3P a8hIf7exBGKZ
a4PsNmZZXjmERkvXD5EoxiMute+j4TCGrbyYOZfM9ifZHFVpqjVZKGXqrN8v 6XVAyzCFZqXL
IpY4swuI7nk23vVxCVDuBmW5q0TjAUZ+sR8fHh3kvsZ8xdQWCiW0odMjf5oj CB/m+IBNj+RF
gJDbNTEsS4Uq3Vc37QvvUJpDu/aU009zpBNJucgFNhe4prljRR82bk0qqayR dmUbC9DCSqkU
xYWiFZHZUxDNmYw8mzxit5wcpGegvDt2ypJx6MrddihT/r3gLvzMjJq8gcg7 NgfQZ4/nATiz
ObL5XnVDELGp821YxxmUBFhZSTeP/WwoT20vULU/8g0+35XVRKEM6AxdXKtH Gdqx58CyzVVv
NHRDqq8eFWqaZqv7rpxaWntz+M3teEr2wpxAkcawSKhlHW/Czr/wRNwBGUsO aZlYE0yfFwum
z/VisXuOoXEyY2tWKX5jSfpZ+1xRfz24vjr/x9FZr9cLfPrZt2MADUHTU8FO B/L1qGDc6u+X
rw/G4b04CZBHH3/tvX2jiDJecCeNourEsfvhGZviJJDS5wdZotYwUwJcROHD Y02QfstgPPAU
lZZwBR/FHqYRrH/O38xcnoxDj2ZXFlnHZR8sa/xoOq066zjv9iSNdhF5YeQl jx/MVr3D1zIq
bEOFrcu65+Z/u954Vax7qWgrWffTRdb9dEvWfWI/eBO4nRMGe6fqCxEzkIlD Yf7iY2kMBWF7
FY5GPuP2Sd76PpK0DoGAJGEkvCW2rHun6rJ53aex9MWD1rIZdJrrj6zxo8nY rcmGL34OW8HU
V4/QqiUul9yAJWssb/6dXJ+e5E5mi0X81E9+EMf+pWMj4ruZ41HDxF9vbKdJ OGIBVxBz966D
7BJ0ak/1hh8DQ2xxz5dM9oJtqLU/q8Ynx9iGmRKEZJaSsDjcz2iYvvRZw8tZ AExFwVQUTEXB
VJQvlYpSMFIN2u62vm4qirlvdIjZ7lmdntmmhmE808GtaRrmPnz4sxzc5vRo 1WnLam5+cMtC
d0LDe5+qtcAjfJBYxsHnNydqz37YI2dhBuGy2Ik8zhUJb+a5WyFudrj6/K2/ xHmi9un013ue
uN6xKp4nfl+HRHXdOwO2OCRqW1XdW++QqN4sWTZPPE/sGFXH+5ueJ1atF5wq X2uqrH+eaFZZ
kXXOE621QcrOE0tfPLH1eeL6mlnzPLHEhv8JzhO1P8+E54nF80RdcsXTzhOz RYXniVueJ2pt
2/rnic31qy+eJ4oVs9Z54qo9y/MH+ZvtoRrUaGyR/Ip7KNxDlYLzShd2wHKb nNqsTJpSQ/sS
rxxGfgBieqG+ARIHKgAvXJKrU/+SsFJ88ZLSBaSPoe+KjRq3Y4vNqIsyDmlv 0dgJu02uwktv
NE6u7OF5lGtKd0k01KoKwTTtAMKQueB1nM8X+Tkt2xKDXXaLnErtqoxCjiEq c5sP9cd5kEHG
G9fmt6m8vWbVHJ3XkAe/h3weRsw9uuP80jJgZcr0if0YpqLPnJtkUfZ+tVy5 7HPl7BRt2/G4
H0I/Pf4e13IRC7epPUZl2ufziZpbyiOmF7N4ixKxkiQo1ipIqQW0NgNUOxGz WYK2Ub8BZsVm
d44LWyXc8L7WDS9yIzhVkBtBbgS5EeRGkBv5DrmRRS7ii3EjuRTkMslMI/+y wxvhpniy8zTk
eQRJCKLakf/4Q/43PuYjfinXQP4HPlYgbL5x3zWV5zxUeCt38Ga7yv1ePU6Z e+LFCZvvbcRm
oVa8kqXWV8CJqlfCccHAyG1HLVcod7dVKFJlOQRVIA81G7ot1frVK1Wyurr2 reGa6hETiSWF
ym2tQ8xX7ocTGFUvYVn9/tjzXRjR2vyKhNJuqteVo7IT36EcfTu4s+NlHFm8 5nI5ZODpFOuy
iJS/JmWqhBuMme8vAclSteI6VU89Pkm/6m5lnAqVG9rnCsuUkSEsKaHRqBoY 2d0MINf5lnaL
LnJUswRxuRGkji+lF1+yHUNV3VyMVoBZLldM5tpUq6o2tiO3LyVbuCLHtrU+ paPqDdP4cQVi
S/+bAysA1U7HKMFrr73dkdV2reKmJw/W7pbtKZ00TsIJ/Qk6dwz7H4cnENJ4 HN7fwIpgtWK5
EmzDfjrlSmuvv4HabZmVbEG93ka24LWyBUgs4VRBYgmJJSSWkFhCYun1E0vr sDiWnsVp5N9I
ehGFYPIm84dnyf1Y/FIRdFw+Xesy+YA+/5WifS/okZ2yJnfo4q+7aufqQQyW li/TjzYEsW6O
EBJvA8ienuhVTHkJQ734LEzOoGJNFch4RBc+rF+98sBf0mn8Z9Tof3uBl/y9 litRNv25E1oq
s+sxoQUTWjChBRNaMKEFE1q+lc0k8g44VZB3QN4BeQfkHZB3+EZ5h8WX4+QJ hzbtvKLfGF4p
2nP/Xgb+gsOWP32xSDB9oz80Yrp20201v4EXxeRWRaPDfyToC78oZoPn9boQ a9Buq1N4Xk/u
gF3C+N6X+GE4JSyL8fXZaJzyuwjFSB7N7+SGERYnnQZT+nALgU8a8aSI/9gR LNYzdn8Rhfzd
RR89n92IUrlNFm9P6oMQI+bWSm9THjDzqZu3M0tJqGhi9krojZvYNfkLm7zb R7AhSUUzlek3
myXQVaa+YQId5aNC7yfKTIqsqJook9uDRuV74DlnFYWwTzj91D8/PT04O6xl RTLi6xq6LYYO
QlodmB/OAkRbmxqj2wfmIApbwEajXjaMM9Mr3qREzwe0b/v+zQzoRhsrbopS gxK1C6zr+ICl
MXGK1edjYmqD8o302dFG4cvTQte8ZWjzgTYbjNJZtazGbEuvKIJtR2MBZj4c eoZwG45B1ydd
/hwEwWKlnoBPKaTRdbT8gA6Cs1jFqpWklXrLLzcY3OiqgGIXDDJ4ceaksxdr 1go3KC21qmhU
PXwGrcWsPHuZYeZf+TmDLBQqa6VDLL65VBm6DIXTIv0xcz7HWaSYHWfohqII pYs3Nbja21Qj
m2qAx0oezAbVShbcLlxV3q+KbJqBD3z7jq1uQXeL0nnVEUX2IlYFJd9BOaNN hcsqXpLiN3W4
ci1IRCpv7+deeH0MsarqlvSC82OlkpvlBrijM4frtKXCJ2slfEObKLoG/G6z EOKsbMOssmKv
ItbJ8b4LZ0sLxK+WM9/GKK9P2xbN8iL/290ISMcga38IBxlkZJCRQUYGGRnk F8hcK+F6mtRq
Gsj1INeDXA9yPcj1INeDXA9yPcj1INeDXA9yPcj1INeDXA9yPcj1fCdcT6vT Rq4HuR7kepDr
Qa4HuR7kepDrQa4HuR7kepDrQa4HuR7kepDrQa7nu+B6WtTo1pHrQa4HuR7k epDrQa4HuR7k
epDrQa4HuR7kepDrQa4HuR7kepDr+U64HnyGC7ke5HqQ60GuB7ke5HqQ60Gu B7ke5HqQ60Gu
B7ke5HqQ60Gu5/vheuoWvpsZuR7kepDrQa4HuR7kepDrQa4HuR7kepDrQa4H uR7kepDrQa7n
2+d66m1YZNRotJ7I9Rz7fGz8g2iU8l9rm/E9PZIVEccO+O+NDRnhP56m92aD mysKXjCMavyT
mt/dMleuvVv7S+Nldze1bkzj4GXFvHNvNKqYCBFHiJAkZolge+YlarS0gdZm GNbst7uXqKip
ZJZoxjCBKxAMVEfBy2iQubWFG5RytOZwa/bJsqqCIYzIMCLDiAwjMozIMCL7 s0Zk3Z7R5RFZ
t9PAiAwjMozIMCLDiAwjMozIMCLDiOzrRWRWnTaNpz77hhEZRmQYkWFEhhEZ RmQYkWFEhhFZ
SUS26KSJuRSTmc1evUGtVjMXk52ENjd7JKs1CV3mk51+7z3vKHgWh733rrwR i97/9lHec8pv
gXYmO9s0XwwJyUyACUts2XqP6Fr/ePjJCYNbb5RGYm1/uvV8FkMxl2RCKKXk /Be6lURmUyuR
K/3pKqEWVOK+iBwjPxzaPuAEcRLB+CfxBiKNHCHSrQ3acp9BrLMwYT1yNWbE hyiMhLckgIZi
Yvs8HHmEcB6KY1ID0068mHz69Ons/Ar+EsdnNsQ877aQoUnNtpmTQbpAlY1c e0d4ljNz90g4
5MEmiXh4BV4R5FyKXJnrcfMIRsEWCjoS38/TxPcCxkPUH816u205zQ2l7PQM k7bref55YN/l
F5br2SOwHyQJX2h1lYtwdXqxvRg0mUy3EqXTzs+b3z6ekti+g72fWiFvno6p updfGOt1axrG
m3apC5aeNuv5aXjgurC/mbIoeRywRKWf/leWWfxOdFRECF+mKdiXbNaQZfSM 9oJKX6hPqqmu
8QX6VG/TZiE1J9fQc3ZoqR1uFDm6DRblEcKZIQQxnKCIOUPB6QkvgK0FbIsJ uHS2VXvtzib9
KmqvkrKxLG5qixNvG8qm79tx3LfjPFmjNcRTUHtM1coEcx7INGtuky/gUo7Y cQCNr+1qmDNY
4BlACXuhfICqcCgNonQEFIIKnzsW9pCcsiCtaW+S0b1V+jTbqgZmz8qVI7dm zzRsgswfkQOJ
D4ZhmlyFg3F4v6oJ7aMYhWxy3v1TOwCXyLUSsTxw/prcmVi6vU4pnpxTKxH1 LFgpolKrqQGq
Vz4DkKuzawktcpkCDZZ2f749c1X5ENerYK6+7rOFuUcDj8+Or06Pzq4vzi+u L4pPozWM7tMf
aDOqHn/4//buv6ltY234+N+HGd7DlslMnalRJRsb43lyTymlLS0JKSbNdPp0 MrIsg4KQfCQZ
wrnnee/PtSvJ2EYCQxL643zbmQCydO1+9pdW8srec6NLN12IkG8pbrnde+fO l4t1N3+SZf65
trnN+bVdp/KO2XyowZkfLljyDfnhvcqnoj7b03Unieudv44n04kZM1d5tq7M hz7Aepf62a9B
GkiLNn2u7B0rP1M3jUzqt26lVj4a9YhbqffeTONWKrdSuZXKrVRupf4TbqXe e6XU7vS3Wp/g
wz64UuJKiSslrpS4UuJKiSslrpS4UuJKiSslrpT+NldKK7xzJddKndbSopPF 6Xb+nmziX8SX
c9c2jed9dfOXvqSRq5t8p1Ff/e8PSTyVaeLctczm/wziMJCGdj238f+pxjiJ L9Tt3XXEigPu
1G3J/0u6rnTrpTUt+8fHR8d9Vb7lvLmvl/h+I2fu8t26X91wWiyiuNS/qo38 XeqNues42V3n
8P+8Pj56vX988tu7V7sv9//nzsUT1bnbWVrA8ZfKXXu5ZTwid9lZlp19ZOaW mm3LljarM9fr
7PxJKzpusrDwpvmfsaJjlpUde/7t7o9a0VEX84e9Tx7zI1eJfDGQOAdHr25S 2lFOp9/aksHQ
2u7YavNh/62vlQPucBqEo4PRi2l+eihuDF36SSoD3gvH6lr2O7s12yyXH8mL wTRSLwMvidNr
uT6+SNVB5EnL/jaOM71czE9ypyvKvjoavDBXHk21e7z344sPvW5TvZ1te3X4 wo/evRmsrxWr
Bzb1GijlFo9VyPFqM06V2VttXs1+cxPvTEmsmhtm5n6Bas1XTVlgbXupQ/3s XxczYJ3tscyg
pHJiz5vq1fGW0r38Wl2418rMi/SqLslEdqYimXS6odLT9tBP9HoLpUeHfL6o q+zNt3nGnEdn
bXeWo1mGlMx11d7J8eFX7b4UeZ7xRr6hKefTqs/oKz+VrrE0Iy4+iVFOud55 Ps9o/qJ/V8Uf
Eu5fZkN4rfKrE/XmQJULSszLezIjP42T6+XQXrG9SKOZf8JjUz8b08ySqf/c HF03Qzc5ylO0
frnJXfGpfd84Y29n7PsmRLMIpyOboEsxR/nFy+5NLe3NL+CsOMLL7yeWl/zN ZjNv5s8fXNyR
vo9ipltSaae+JWHLiWvxwYvS+eUomcE25YJmpPJfDWuhcGsDybWP/0HfKZRc lXs3T4pXm4f6
VVW8PFfsT19wt8YvR06+Tr8lU4O21d5qf/z4daAjO47tbMov9t9tGFOb+kJc 7fX/7+x0sPLI
VhTlTr+1bXU73b/SyFaftU89stHVHjlG/UNOCW5v298ePn1pL/TRLJ54bipd S3Y2uR5OU3OT
QjpFa6lTtJ1+Z9va6rTn124Wx6u3/lDpz6aVIUhfThQXw9JlX4e+7KCEoIeX TK4/JrOF5sWl
yCROMunQ5sXXsxdTZR59XHUiW+Sx3e/0rO2d+Y77JI9q3CS/o88Of4FHNeZz tLUws3/aRzVW
ycef8KhGfbae7lGNIg9beon+4sciftZHNdode2t7vOpNhyKTnf7WztJF9aNv iRxE48SVmp56
+rhPeA+iyOt2f6tjtZ3Wn3EP4t4sPN09iPmsLC65f/w9iPqYn+qpkvkz2Zkf TiqmZ1uOnoTb
C3cPzdvVurOaU59OXfqmblWTJLhwEzn3S3c1p6YgOhe45M2VP8/khHVytKe+ nk82m2QTa1K8
S2NJl4kyL++K+gP0R7FnBenl14nrvZOf7zL5+8NFqBrpeTCZSBnUrYn5y2qm qVSK5txJubdd
tPtbtn4Gx95pP+70m/+YfxProT2vzMJWt7fKKVimRlEoL6VfF4X1dRl51kbf ycj7rpiALZ6e
0/L8/PJ19Xn75etHn7jvc6xw4q4ozMedvO/Ly8NO3hXZevwJvDprT3sCL/PQ tXee6gTujHzP
63kPyaX59OVO17IXHlN60rNimYXWTsVp42nPinlWdpYeDPu4s2J1zCd51rJI vqcfFrSdikc9
Vy3Zjx+AZ9nofuTUpzIrj6loyc6O1Vp4vvejK7oi5gMq+jbtjimQvsNRrhzR s/LlrOz0nS1r
254/48r0W2YPFzc3ztTVmR8p8754nseRr8zbu5NweroZRH21UZfkhlW9BLf+ +/b80dT6cOmF
NzGEN5lOZt9F88q98E15yCyq+D31i088aty8WLxxXq4dfEBYuYjQX9dy6esl ussRW/ctAzoy
I/RrKZkgyr/15Zlj3s6//UKxwrB2qVK50GPgjv3jaRQVizvm/iyWkd0XoFwx ZA6f/WEO7lV+
V8/dIHktyIplG36tq3rdzXzkhWPyM94sakW8exeFLRyTll8fVH4R4+2Ircov irrHrhdz74Vx
KhHr5Peux9INq1xpq3+2nrXzqlne/vdoIbezrddj52tpa0iVX7h2f8zXN4Vf V1b3Njo5rvwW
rIqQi9/DZd+XzdmqPD2xKrO0HLd6p2JN74rlMN/uFkO07v3Esdn++ToeM6wt xqj+XsJaqKWv
HyQrJtLiK8Xy4N7KCzjNURp3nC8yqo63fV85/Rr4V9/LWK5vtye+uWmsNzXm t69aXH6STnxz
Biihjfltxdix8jrX+RKr1HXv7WGzo4rvDfR0Q9iVU6gESRvLr+bddvU1tMVh Z24yMi2sOmDN
mu+7Ig6n6fUdEbuVX652V8DZwynV8e4dz5cOe9ZaXDw8H2y79mMqvWmaySTv W8EdRCM9B5PL
rfQsvnp7JlegjcXtRcYeU781+apciFzxRZPlgyFFrIVtxei2cvE/czpVy6x3 Kr+57qPPTNWr
qisaU5ELe/Ug5WM4neUgvcrvmK0ujFarqjAcu/ahhs/ZYpbbSpmZe0fMuZX8 fr64eXkZvt27
74tJzcLyYgJ9NPHNInUzWS6/KbKIXPVa8bzAfdD7kpgNCfVptFZaH1+fxrPZ 3y+P39x8B2Z9
ijtVz9lUfGnk4jdpLk4h63s5X6H5d/0Kzc/7oNqKmY/iLBhfl1PndCHIduUK 91XqamflunJa
935K8l+isvjkYB7i4iEuHuLiIS4e4vqED3HNLwzubdqtTadtFsPvFB+4ysLg uxYG1727sliS
eqnRwmMFT7GIYDELHdvadv6WiwhuO7qP/qDmj11EsHJenn4RwT1Ze5JFBEt5 aOkHo55w5eqt
5BfX9/0JK1dv5WinU72W9jOvXF05H0+7cvV2tp5+4ctSHtpLn3z7WRe+eHar u+2u8k55qzKz
W1Z78WObVX7Rm9x+tsM8bCKFpB82kcZm1uOl8YWvZo9n1D9W8oic7JXp60dK vtx9c3L0w/6r
fr8/H3Y49c4vAmloMj+RJIpvE8ov67+u23EyMvm5DPyrvcHE977sr68VjyCY N8nzaXuBksnH
Z0xaP6dQlPeL/AZD+W5xkaHXSfzhumEer7gnZnmzT7879O1UH2xSyKOaRyj8 D5NEZrB6yrR0
G35/9sry8x51t/O/8To77qjzvJk/ZvM6CeIkyK5fON12T987oDw/bXn+jfpV fp2Sl9PTd635
1D9Dazgw4fP28F/Rtf755Xn/E5q3O9TCpPDPfELznqzxhCZPaH7Sh/ZHY3+r 0/4znj3/fJ1h
8OPB9ydffbd/ONcfZtseVLP6Nk8Wx2Fqpf8O819ksJJCKJYp7YbhgbnnJGXa zBcHKdmmig/i
U8dm57Siv6yWSln3zcEvh2UwpScwy9X/5/WXxxWsxNaXQpY3zZp703xAkZ/m +djZqki9ulhv
0McMYzcZrdZPdOCmHlJW7SPFKbB8Ny6/uVv2kO32cLv1uYt3FLhhfLobjd5+ onKePfRsrtT1
M1Dyb5ZflOdLQpvfmS3qe71I2mw3SGm98VVqil0/MqWrID90rmqkm50m7uSs HL/Mk1qBtEw3
TWMvcPUO+X2ccocgUu7Ng9TFRfBH1uZf/bHypcFr2+pt/eUeK5/LY9vu21tW 9+m+Ta0z6rR2
6j5QI05Pg4qzQNvpO9tLTyWY9UkqLG5WefpzsxfX+s/PVs37WvpWnx5zrYFk SbJSrDjbaEo5
6rtIauPE/PxdTzz9ZHOr2WleuEH0x4bS74eNVCwj1ZVr5iyq0bFt+yJ9bs48 S8frg5rd2bGx
kpoM0rP8W6X0wUMzT1Yb04nkx/9mYpZpp7VTeJ37d45ly/+J3dtp6fXEifp9 x+n+sWFJi1Lu
ZRyMpMW4ozD2zlfwBKk0qtjz/VGeneyRRWemw8UDzmPpi3puLOXjhnqAWni+ QofXtWuNyze+
rPxqYe6DzgdyPpRh3yyK181bsniqLxJMGX+KMttQw+tZ4eii0M+ALL9htpTL 2enCFMTuUN8M
9bI879bQl0yYbOdL+RtLrxfvrrWr3kB/SDr5m8NVwVuV6yGWYk+zILQGvsyV yrVgecCFTcVn
Qd+7bLLuzexD9z/X5RvCkzjNvpeB9DCWscN8pn2jYq+idKrWFhnAUMbBMpHQ vNeXfz7+xM3O
bj5efSGVW68Xa7BqC2mmmU+sWJ9hguVvMi6nU7FH8fHRD67qvDark1l4LX/f vnJJz8MSMLEP
in0q0thyqtYGPCKNqvxvV63N+ESxu7VNadVq1s3s7hrutW8tD6gOcM+agsqD ZpVy79qC20O0
q+eFZuRNrNnSz2Iaaa5WwvCneKi78cHN0tDGHXsWiwrqxoNZkcoQbXKp7wLl m2ZBiwQblS/U
P2WyGP99PEyt/Bw2W4tV1oZZ8rDnTvWManjdf+wA+yz/oUfyaTr/1J9+E8vp yrRWfz3jcSxn
utkXePTzk9qnTI0zEWcizkSciTgT/U3PRA+8qJWrkk92UXswcD/ot/KLKzSu ah9wVbtcdlzW
MplgMsFkgskEkwkua7ms5UzEmYgzEWei/9YzUeVl7XIB6be/d9rLF7nb+hNg na359Ts3VSTj
lHd+dOkn4zC+Mp+xXP2RbFX73fU8anmFZb0ufim/odaxUv0m+zTUH1W0+Fr5 1Gzt8LxYXFK+
s+fUn3WKJ9cb81vv+MCte+JZo/hVXbzKD5G6L94N+nZAp/5B0FsRy6Iq4zXm thVP+q/Y2sr2
qpvpLNr8xmK8uffjxcqsLeSprMv7PiPkVjvRa6zemCvxG2T+d6Nql+Jp8vs+ nuXOZBJ/LJvO
JNcH0TiuT6Z97+dx1bX6uiQWaq7brTrtrdSpdCOII7PuI5gbhuq6WKtysrb4 kW/lcXnYt4k7
mfj10Rf3qv+Yk8VP/5kOlwIsx6/YI+8xlc/ZAgAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAABQC1hf+2L/1cnxbwsJDafe+UUQpRLKJKq2 VGunrVq23du0
W5tOWzmdfnu777StVntLQrzcHwx2f9hX+8fHR8dKqd9t23b+UH2lE7JCNzq1 BpnrnR9d+sk4
jK/2kyROVki8wEr6dnXqPWcu9RVT/WJwsrv3s7LX1+7eb7n4p8GsdK1JUa43 1eBG7qmfPHOs
1DvzR9NwvvDz1/JS3+radVU7i/4+HqbWT/HwMJBSiPwkfdaxojgLxteN+a1F wJ2Hx7NG8au6
eDvdR8S7Qd8O6HRbK0csi6qM15jblueu01st2EHxlwS4iTa/0YRrd2vDlR2t zNpCnsq6dCqO
vrOd/Br4V28mIzebQ+Z/N6p2Mcm0WlVVsnIyiT+WTWeS64NoHNcn025XlcUq rb4uiYWa63ar
BsyVOpVuBNUDaGVKrXZtl2D4BwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAPCPBKyvfbH/6uT4t4WEhlPv/CKIUglVpqe2lK1att3btFub Tls5nX57u++0
rfaOLTFe7g8Guz/sq99t23b+UH2lU7BCNzq1BpnrnR9d+sk4jK/2kyROZP/B ye7ez0qOvHu/
5RKYBjOgNSloNyXhRu6pnzxzrNQ780fTcN6fv5bDt7p2XenOor+Ph6n1Uzw8 DKQUIj9Jn3Ws
KM6C8XVjfmsRcOfh8axR/Kou3k73EfFu0LcDOt3WyhHLoirjNea25bnr9FYL dlD8JQFuos1v
NOHa3dpwZVsvs7aQp7IunYqj72wnvwb+1ZvJyM3mkPnfjapdTDKtVlWVrJxM 4o9l05nk+iAa
x/XJtNtVZbFKq69LYqHmut2qMWulTqUbQfUYVplSq13bJRiBAQAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAPwjAetrX+y/Ojn+bSGhaaC2 lK1att3btFub
Tls5nX57u++0rS27K4e83B8Mdn/YV/tJEicq9rxpkvgjNZomQXSq0szNpqk6 c6NRKH/L/oOT
3b2flb2+phO2Qjc6tV5Nw/B1bLK7/8HzJ1kQR7fJ02AmsvKwJqqfpNbA/Pkq zoJx4Ln68Jdu
5J6Kzh2NTMYa9bvkBbBdUciS4lJCuiiHfuSdmaA/5put/OVG9YsmfMeuDj8D BSPfOvhu/874
ta/nAueeJCqPlUbx4fpOQL6HSaLdXamQ8qIui7eIvbgxb9m9Txuv1a4p5bvi PVv46zA+PQzS
zI8kZhifnkqTrUypV9vhZ8Vdds7j/KdE1hEbc3/m1Vbbu2eR3sfDvOVJ8hK1 UfxqDt9uP9d9
SvrgwdGrpV7acfqtjtVpO2rzYf+tr5UZGU6DcHQwenEgkbcdx3Y25Zey715K YUo/euFYXct+
Z7dmm6NRnLwYTCP1MvCSOL2WAr1I1UHkWetr38Zxdhi7Iz9RXhxJzURZ2ldH gxdXQdRuNdXu
8d6PLz70uk31drbt1eELP3r3ZrC+thdfXEg1bspY4is3OZ1e+OZ4tRmnyuyt Nq9mv7mJd6Yk
Vu3QZl2VLV61bg1ynbYuvp2FQW5XFa1IZ34cBl42G/EspU7OglRduNdqFKTu MPRVGl/4sqfJ
c2rpinrzbZ4P52NzslemP5ZR98vdNydHP+y/6vf782GHU+/8IpBCltYiSUyS +L3vZa6nR7+v
63acjEx+LgP/am8w8b0v++trxVCwK0demrGzUaCkaXzGpJvSM4ryfrFrDv3O D/1TN/Pnx6ZG
JKeP5j0x85RT61eJ/e1UH2xSyKM+1wn5Hyb67Kgb9GwcfBtIU77an73SuHds zY/4ptNpua3h
82YaTxPPf50EcRJk1y+cbtuMHJTnpy3Pv1G/CqLL+NzPy+npu9Z86p+hNRyY 8Hl7+K/oWv/8
8qw8c74fu55f36E67bkO9bN/PZSU9MVAec5MF0+a/rU5aZocjv3El9N3dqai OLlwQ+V6npRi
4mb64mKifxHcHafSh2Rt9/ZZ3HT7vZPjw6/a0jm/zTPeyDfoon/tJu6FLxkN /uOPitlIo/wZ
+ZmVF6NEOfWtzP9QzueKKYCMRnKUTAGbUg0jlf8qYf9l/tmTtnIaJ9f1gULZ 48P+KMgkV+Xe
zZPi1eahflUVLzezZOo/vwneLDbo9mc2LzWQkT92p2G2e1PeeigMTqd5kVcc IYUn6WWiMi2p
2WzmU73nDy645THbxLP+PQ28c52fNG3+on9XxR+aYzaE16Z9pKl6c6Ak22Y2 uFiUy3kutpd5
zjuBKZS5AqvrOyZHeYrWLze5K/r3N46z5W9vbz99cX/OzjD48eD7k6++2z+c 6w+zbQ+q2ZEr
V1JxHKZW+u8w/0UGKykE+XERX/q7YXhgrgikTJvHZpOSberXIA30bPrY7JxW 9JfVUinrvjn4
5bAMpvQEZrn6/7z+8riCldi+dHrLm2bNvWk+oMhPlZ3JJYjkzpw5VBabDfqY Yewmo9X6iQ7c
1EPKqn3k5l5JMDr1s5d+dhaPZj2k2+v4bftzF/AocOVaezcavf1EJZ3FE89N 5Xx1EY90biz9
b+a/1H8dDfV8ofmd2aK+T+ILZbYbpLTfWC5IdcFPU7lslErID52rHOlop4k7 OStHMCWpqkDa
ppumsRe4egeT7myHIFKuOinypHQVxYn1kfX59I1+YWoxK2HZ2TSk4TQ190Fk +GrdHr62tq32
jj03fM1K460/VAM/uZTCjuJMhe5U5jp6pvE69GUHKf6xvnmgi1/mSnq+IeON unTDqWyIE1O4
+sXXsxdT9dqVk3DNXChOT4OqIXarb7esznZvLo9vzwIZxsLYzWdDodSv2qib Cpp7QNIoXT2g
WQMpaslEcRdqoylZTHx3pDZOzM/f83tCm+1mp3nhBtEfG0rfZRqpWIaBK9dM CFSjY9v2Rfrc
DOtLx+uDmt3ZsbGSQgrSM33/NjEHD80kVG1MJ5If/5tJOD2VjNbOj3Xu3zmW Lf8ndm+n1bLe
u4n6fcfp/rFhSWUp9zIORlIZ7iiMvfMVPEEq9RV7vj/Ks5M9sujMXFO3jKGv xtLM9cRTyscN
dd+35m9Q6/C6dq2xHh30haSVT8VnN6n7St8clDFVBr1TX7ecSXGT3ZTxpyiz DTW8nhWOLooN
6/b9wqVczsZiUxC7wzRL5Ioiz7s19CUTJtt7JteNpdfzW7NOe6fivuRD0jEt pzJ4q7NC7GkW
hNbAl4lIceVTBFzYZMJt2VW3fRfeIJllVFrERI+V+/leh+5/rgc6rL70itPs exmjDmPPDfd0
32xU7FWUTtW9dgMYyhBTJhKa25yWiTVxs7PyFvJ4MZVbr+cqp7aQZpr5xL7L R2YTLL+/upxO
xR7FbfgHV3Vem9XJLLyWv22wVXW3/GEJmNgHxT4VaWw5rU+TRlX+zU32zxS7 W9uUVq1m3czu
ruFemf+bt9yqA7yJzqP4KlIDc+252kGzSqk8+O4h2tVTLjPyJua+hHQDzy9m aOZSIAx/ioe6
Gx9Es9cbd+yZt4X731KRIdrkUt9iuXmT1AQtEmxUvpDXWe+j3rIx7+fuuVM9 WRle9x87wD7L
f+TvTs2/bWpZlnK6MmNM/PW141jOdP7sfJWf1D5lapyJOBNxJuJMxJnob3om qryoXS4gfQm+
016+xO3oS9xWz5m7xL2pIhmnvPMjuQwfh/GVWVBSvfinar8VSGWh6LI49TNz GmnMb8wH+FbV
up6FEdlEW4hyU7x2VXeryIwcUQ6Zqb7ZMA1NlMUVRpVjzz2yWbRbsna3tu5v yebzVDTMys4+
fxuvvJCdLS7TN0rfmAvZG2T+d6Nql6L4a1b4rJZM4o9l05nk+iAax/XJtCv7 wZ3JlFVTk8RC
zXW7VTW3SvhnuhFUL/erTKlVOddhsSIAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAH9ZwPraF/uvTo5/W0hoOPXOL4IolVAmUbWlWjtt 1bLt3qbd2nTa
yun0O52+3bLarZ6EeLk/GOz+sK/2j4+PjpVSv9u27fyh+konZIVudGoNMtc7 P7r0k3EYX+0n
SZyskHiBlfTtytQ7W9251FdM9YvBye7ez8peX7t7v8riL8vXeh8PU+ug+Oun eGid+plEyfzG
/EZT0K3W9n21aaItRJkd3bbbdUcvZkaOeOlG7qmUW+qd+aNpaKKU24o6r221 9bJZtFuydre3
smw+T/nRW12n4uhpcJOVSdF8Z63918C/ejMZudkcMv+7UbVLUfzdj0km8cey 6UxyfRCN4/pk
2u2qsrgzmbJqapJYqLlut6rmVgn/TDeC6vGnMqVWe4fREwAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACAvxPgi8H+YHBw9Eq1bLu3abc2 nbZytvv2Tr/T
sradntp82H/ra2Vuh9MgHB2MXhxI5G3HsZ1N+cVeX9NpW5d+kgZx9MKxupb9 zm7NNkejOHkx
mEbqZeAlcXqdZv5Fqg4iz1pf+zaOs8PYHfmJ8uIozdwoS/vqaPDiKojaraba Pd778cWHXrep
3s62vTp84Ufv3gzW1/biiws3Gm2GQeQrNzmdXvjmeLUZp8rsrTavZr+5iXem JNb6mpTR/quT
498WqmIaWFdSwkM/kt1ayl4qPseWKrQ6TkcOfikFvPvDvtpVZ5J8mGd+HAae VK7nTZPEH1lK
nZwFqbpwr9UoSN1h6Ks0vvBlT5Pn1NIV9ebbPB/Ox+Zkr0x/HCfqy903J0c/ 7L/q9/vzYYdT
7/wikEKW1iJJTJL4ve9lrpdJrX1dt+NkZPJzGfhXe4OJ733ZX1/7MUfvypGX rj66UaCkaXzG
pJvSfYryfrFrDv3OD/1TN/OLDEnP+HDdiKZh2LwnZp5yav0qsb+d6oNNCnnU 5zoh/8NEdzLd
oN+WdfE2kKZ8tT97pbFUaWVHtZaO+Mbr+C1v/LyZxtPE818nQZwE2fULp9vu 6Q5LeX7a8vwb
9asguozP/bycnr5rzaf+GVrDgQmft4f/iq71zy/PyjPn+7Hr+fUdqu3Mdaif /euhpBREp7Nz
Zrp40vSvzUnT5HDsJ76cvrMzFcXJhRsq1/OkFBNXJj4qnuhfBHfHqfQhWdu9 fRY33X7v5Pjw
q7Z0zm/zjDfyDbroX7uJe+FLRoP/+KNiNtIof0Z+ZuXFKFFOfSvzP5STvmIK IKORHCWzv6ZU
w0jlv0rYf5l/9qStnMbJdX2gUPb4sD8KMslVuXfzpHi1eahfVcXLzSyZ+s9v gjeLDbr9mc1L
DWTkj91pmO3elLceCoPTaV7kFUdI4Ul6mahMS2o2m/lU7/mDC255zDbxrH9P A+9c5ydNm7/o
31Xxh+aYDeG1aR9pqt4cKMm2mQ0uFuVynovtZZ7zTmAKZa7A6vqOyVGeovXL Te6K/v2N4wz9
zvb46Yv7c3aGwY8H35989d3+4Vx/mG17UM2O3EyccZha6b/D/BcZrKQQ5MdF fOnvhuGBuSKQ
Mm0em01KtqlfgzTQs+ljs3Na0V9WS6Ws++bgl8MymNITmOXq//P6y+MKVmL7 0uktb5o196b5
gCI/VXYmlyCSO3PmUFlsNuhjhrGbjFbrJzpwUw8pq/aR4hSYWm+D0amfvfSz s3hU9pDtnu2O
O5+7fEeBG8anu9Ho7Scq6CyeeG4qp6uLeKRzY+l/M/+l/utoqKcLze/MFvV9 El8os90gpfnG
cj2qy32aylWj1EF+6FzdSD87lUv6s3IAU5KqCqRpumkae4GrdzDpznYIIuWq kyJPStdQnFgf
WZ1P3+YXZhazEpadTTsaTlNzr0RGr9bt0avVs3a6vbnRa1Yab/2hGvjJpRR2 FGcqdKcy1dET
jdehLztI8Y/1vQNd/DJV0tMNGW7UpRtOZUOcmMLVL76evZiq166cg2umQnF6 GlSPsFvbVnur
PZfHt2eBjGJh7OaToVDqV23UzQTNfSJplK4ez6yBFLVk4qUbyb/JRlOymPju SG2cmJ+/mztF
yWan2WleuEH0x4bS95dGKpZR4Mo18wHV6Ni2fZE+N6P60vH6oGZ3dmyspJCC 9EzJaJyYg4dm
Dqo2phPJj//NJJyeSkZrp8c69+8cy5b/E7u302pZ791E/b7jdP/YsKSylHsZ ByOpDHcUxt75
Cp4glfqKPd8f5dnJHll0ZqqpW8bQV2Np5nreKeXjhrrvm3nlye7ez8peX9Ph de1aYz066OtI
K5+J73/w/Ilu7301kHONDKky5p36uuVMilt1pow/RZltqOH1rHB0UWxYt+8p LuVyNhSbgtgd
plkiFxR53q2hL5kw2d4zuW4svZ7funTaOxX3Lh+Sjmk5lcFbnRViT7MgtAa+ zEOKC58i4MIm
E27Ltu+7zTrLqLSIiR4r9/O9Dt3/XA90WH3lFafZ9zJGHcaeG+7pvtmo2Kso HacOMJQhpkwk
NHc5LRNr4mZnRQu0xoup3Ho9Vzm1hTTTzCf2XT4ym2D57dXldCr2yDW9B1d1 XpvVySy8ZhJo
b1XdZH9YAib2QbFPRRpbTuvTpFGV/+3254vdrW1Kq1azbmZ313CvzL+5PR9K r7eqA7yJzqP4
KlIDc+m52kGzSqk8+O4h2tVTLjPyJua2hHQDzy9maOZKIAx/ioe6Gx9Es9cb d+yZt4Xat11m
RSpDtMmlvsNy81aLCVok2Kh8Ia+z3r3x38fD1MrPYSZY8as53LwrtOdO9WRl eN1/7AD7LP+h
R/JpOjsjScYsy1JOV2aMib++dhzLmc6fna/yk9qnTI0zEWcizkSciTgT/U3P RJUXtcsFpC/B
d9rLl7itfqtrOb3tuUvcmyqScco7P5LL8HEYX+0nSZzMX1vdvd8yaf72UnmF dbN2Ih+snjlW
qi/0p+H8iomFgaxbOzwvFpeU72Eg9shP0mcdSy4Wg/F1Y35rEbBquLonnjWK X9XF2+k+It4N
+nZAp1s1FlVHLIuqjNeY25bnrrNiayvbq26ms2jzG4vxpjZcebIss7aQp7Iu q0arO9uJvtH7
xlyJ3yDzvxtVu+QThFZVlaycTOKPZdOZ5PogGsf1ybQrO/Iqrb4uiYWa63ar TnsrdSrdCKpX
PVWm1KqcrLFmCwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AMA/F7C+9sX+q5Pj3xYSGk6984sgSiWUSVRtqdZOW7Vsu7dptzadtnK2+06r 3+pa7e2OhHi5
Pxjs/rCv9o+Pj46VUr/btu38ofpKJ2SFbnRqDTLXOz+69JNxGF/tJ0mcrJB4 gZX07crUO21n
LvUVU/1icLK797Oy19fu3m+5+KfBrHStSVGuN9XgRu6pnzxzrNQ780fTcL7w 89fyUt/q2nVV
O4v+Ph6m1k/x8DCQUoj8JH3WsaI4C8bXjfmtRcCdh8ezRvGrung73UfEu0Hf Duh0WytHLIuq
jNeY25bnrtNbLdhB8ZcEuIk2v9GEa3drw5UdrczaQp7KunQqjr6znfwa+Fdv JiM3m0Pmfzeq
djHJtFpVVbJyMok/lk1nkuuDaBzXJ9NuV5XFKq2+LomFmut2qwbMlTqVbgTV A2hlSq12bZdg
+AcAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AADwjwT8f1BL
AwQKAAAAAACdfE04AAAAAAAAAAAAAAAAHQAAAHdvcmtzcGFjZS8ubWV0YWRh dGEvLnBsdWdp
bnMvUEsDBAoAAAAAALOmaDcAAAAAAAAAAAAAAAAuAAAAd29ya3NwYWNlLy5t ZXRhZGF0YS8u
cGx1Z2lucy9jb20ucG5wLnhmZWF0dXJlL1BLAwQUAAAACACzpmg3OONNmKIA AAArAQAAQQAA
AHdvcmtzcGFjZS8ubWV0YWRhdGEvLnBsdWdpbnMvY29tLnBucC54ZmVhdHVy ZS9kaWFsb2df
c2V0dGluZ3MueG1sbc/BC4IwFMfxs0H/w3j30tKDwpaXDIKOi86mDzfUDXSZ /fdNWRDl7Qff
DzweTce2IQN2vdSKwW4bAEFV6FKqisGVnzYxpIf1ivZYGEuIyltkcNNdfbdO gG3eT+Q4mqyU
RndHmTe6mo1HpcGWDHnzsGQf2Ts1vhgIlJUw4P+bMPiYpyyNWCRh4shrKUdJ 7PK4lLnkl8wB
fp72jKjv3pne/tpvUEsDBAoAAAAAAA+XMjcAAAAAAAAAAAAAAAAyAAAAd29y a3NwYWNlLy5t
ZXRhZGF0YS8ucGx1Z2lucy9vcmcuZWNsaXBzZS5hbTMuY29yZS9QSwMECgAA AAAA63tNOAAA
AAAAAAAAAAAAADoAAAB3b3Jrc3BhY2UvLm1ldGFkYXRhLy5wbHVnaW5zL29y Zy5lY2xpcHNl
LmJ1Y2ttaW5zdGVyLmNvcmUvUEsDBAoAAAAAAOt7TTgAAAAAAAAAAAAAAABA AAAAd29ya3Nw
YWNlLy5tZXRhZGF0YS8ucGx1Z2lucy9vcmcuZWNsaXBzZS5idWNrbWluc3Rl ci5jb3JlL2Nz
cGVjL1BLAwQKAAAAAADre004S0gmrgQAAAAEAAAARwAAAHdvcmtzcGFjZS8u bWV0YWRhdGEv
LnBsdWdpbnMvb3JnLmVjbGlwc2UuYnVja21pbnN0ZXIuY29yZS9jc3BlYy8u c3FmaWxlBAAA
AFBLAwQKAAAAAADre004AAAAAAAAAAAAAAAASgAAAHdvcmtzcGFjZS8ubWV0 YWRhdGEvLnBs
dWdpbnMvb3JnLmVjbGlwc2UuYnVja21pbnN0ZXIuY29yZS9tYXRlcmlhbGl6 YXRpb24vUEsD
BAoAAAAAAOt7TTjycPEzBAAAAAQAAABRAAAAd29ya3NwYWNlLy5tZXRhZGF0 YS8ucGx1Z2lu
cy9vcmcuZWNsaXBzZS5idWNrbWluc3Rlci5jb3JlL21hdGVyaWFsaXphdGlv bi8uc3FmaWxl
AwAAAFBLAwQKAAAAAADre004AAAAAAAAAAAAAAAAQwAAAHdvcmtzcGFjZS8u bWV0YWRhdGEv
LnBsdWdpbnMvb3JnLmVjbGlwc2UuYnVja21pbnN0ZXIuY29yZS9wcm92aWRl ci9QSwMECgAA
AAAA63tNOJcXTYsEAAAABAAAAEoAAAB3b3Jrc3BhY2UvLm1ldGFkYXRhLy5w bHVnaW5zL29y
Zy5lY2xpcHNlLmJ1Y2ttaW5zdGVyLmNvcmUvcHJvdmlkZXIvLnNxZmlsZQIA AABQSwMECgAA
AAAA63tNOAAAAAAAAAAAAAAAAEUAAAB3b3Jrc3BhY2UvLm1ldGFkYXRhLy5w bHVnaW5zL29y
Zy5lY2xpcHNlLmJ1Y2ttaW5zdGVyLmNvcmUvcmVzb2x1dGlvbi9QSwMECgAA AAAA63tNOJcX
TYsEAAAABAAAAEwAAAB3b3Jrc3BhY2UvLm1ldGFkYXRhLy5wbHVnaW5zL29y Zy5lY2xpcHNl
LmJ1Y2ttaW5zdGVyLmNvcmUvcmVzb2x1dGlvbi8uc3FmaWxlAgAAAFBLAwQK AAAAAADre004
AAAAAAAAAAAAAAAASwAAAHdvcmtzcGFjZS8ubWV0YWRhdGEvLnBsdWdpbnMv b3JnLmVjbGlw
c2UuYnVja21pbnN0ZXIuY29yZS93b3Jrc3BhY2VCaW5kaW5nL1BLAwQKAAAA AADre004ebj4
mQQAAAAEAAAAUgAAAHdvcmtzcGFjZS8ubWV0YWRhdGEvLnBsdWdpbnMvb3Jn LmVjbGlwc2Uu
YnVja21pbnN0ZXIuY29yZS93b3Jrc3BhY2VCaW5kaW5nLy5zcWZpbGUBAAAA UEsDBAoAAAAA
AOmMcjcAAAAAAAAAAAAAAAA4AAAAd29ya3NwYWNlLy5tZXRhZGF0YS8ucGx1 Z2lucy9vcmcu
ZWNsaXBzZS5jb3JlLnJlc291cmNlcy9QSwMECgAAAAAAQJpoNwAAAAAAAAAA AAAAAEEAAAB3
b3Jrc3BhY2UvLm1ldGFkYXRhLy5wbHVnaW5zL29yZy5lY2xpcHNlLmNvcmUu cmVzb3VyY2Vz
Ly5oaXN0b3J5L1BLAwQKAAAAAADqjHI3AAAAAAAAAAAAAAAARAAAAHdvcmtz cGFjZS8ubWV0
YWRhdGEvLnBsdWdpbnMvb3JnLmVjbGlwc2UuY29yZS5yZXNvdXJjZXMvLmhp c3RvcnkvOTQv
UEsDBAoAAAAAALeLaDcAAAAAAAAAAAAAAABCAAAAd29ya3NwYWNlLy5tZXRh ZGF0YS8ucGx1
Z2lucy9vcmcuZWNsaXBzZS5jb3JlLnJlc291cmNlcy8ucHJvamVjdHMvUEsD BAoAAAAAAOqM
cjcAAAAAAAAAAAAAAABJAAAAd29ya3NwYWNlLy5tZXRhZGF0YS8ucGx1Z2lu cy9vcmcuZWNs
aXBzZS5jb3JlLnJlc291cmNlcy8ucHJvamVjdHMvaVRpZ2VyL1BLAwQUAAAA CADZjHI3VD1a
xoMFAABtGAAATwAAAHdvcmtzcGFjZS8ubWV0YWRhdGEvLnBsdWdpbnMvb3Jn LmVjbGlwc2Uu
Y29yZS5yZXNvdXJjZXMvLnByb2plY3RzL2lUaWdlci8yLnRyZWWVmNtTG1Uc x08CQiiXAAEK
hSLBS7VKbFG0ijcIBKsNIKEVLy1sds+Ghb11dwOh+tCZ/hF95U/wzSdfnOmD OqMv/gm+ONqq
Dzz0xfFssrs5v+Wc3ZAZpoF+P7/f7/xuJ9n2tmQSIZRAHcqmUsEWmjKsSg6L qmLaOLcnOTnR
sMgb4UAoVxVVIgpXnkwQhPzb5Miv7Rnyl5FseVpGjdc58pP03icH0bmcqAq2 bQrOritPJD15
1ZP01QPx5AilcqZl7GHRAWLfdjdluw2hkcLStmjoslKpWoKjGPq2rKjYdlH3 gIn08N931j35
AGq+El2oo7CUq0kakfbXvbQ/6H78rfff27QUoU5XKmts7Q7U9hSkLUlbwXqu ZqtMQIBALwGI
7SiiDInxgFiQpJu6creKVwUN21xehHxmrWwXLEIcGtb+ck3QTBXTGbt139NK NJdC3S53SHJh
Gnbgp/Pefw99zS70E+h5aVZ4ellj2t+D+r6GXlowTW5I+3yEF5UagXAC0yCS hgjl5vjp6hVP
p0Omqz5nuZrGLqEB1RdKilu1vKE7lqGWjmwHa4xKBr2PaTyFzjNwkELi+uS+ pzehayYbymXA
3m2FldmsFX/kcOVp3G4N50XutIhzgq9CfJyPs7vjAPLs7gi8HcarH/72746n kKG6zdFMZtNU
QsUrFNdbXraDNJtCPculXcOM6tA1FkA8cuv7GYyuCfAqusUFODX8HALpBqCZ UV33RQTDC+zL
KIYT21eQ6Q8x7Ka6DSFGm9BL7Q5UdzJyG6yndahNeWlliz+F4l4SNuPKbPt6 5SdftQGJPpeI
uTNLEJloIhGXJu1zMzZZ9EzdhGruTN2CutHr+dJGy0OVoeEulHJhblddDsXf EIdqEqhfCccl
2lbLt8urNNyJhk/BuYooMd2+Dt0ySN7x3ognOaMzF3fUqFl9syWY4/ktCI/x YPb0XgsVNPpK
eBuq+1xfjClLDt5e9GUzEEnXEfaYBW5ykLlIMRFzlti+PLvjUa9BC5OUhaIg Wsa6ZYjYthW9
AoM4PvnTx65AE6zMfPfA8j/HXIVq7qjOQt10/QpXZAVLZxraIdpMCmUKVVXN GwfYEio4aqjG
aK4LTVLuSYZoK+HpCnZgNpTaCBOh+ywwMd26Cd7d8NwZTFCDk8mu/XzsYc9D E1m+CcbdHATy
wpms8I7z4tmsyGwrl/jNxbbC3gkvQTMxXyJehupB2NHcE1+AWCaM8e6UcciN wjOyl1FmygMm
IDwWgmNu/4uQvsSkW1xQk/E5prbLs1DN3S5TUDewVcCCU7Vw0ZCwClp4ZPOP +R89ZQ3VH3vU
X+2nKLqAI9kfTvKecjjSV6NFUeDrnqfsJz/PeO87iNuyoru6Rf+RjH+b9cbn 5/ifb/xsjkB1
bwXrpM3ViAV6niaG0dCSYpuqcFTEjqDVDyDR/Tc/vnzsid+BrkZ90IXyhmYS jxa3g+YhnPbg
zSOTrClbYnbKu5CZWFGNskBc6bZjCYruMJ3SBt6DBibDBmz30F7VODG8D01k 6kSTIp3fTFYC
P/ndP+8HobpsFW+UxF2sCTnJYXv6kEvwYluARN9WaWmWII6lhzLyy6++bBEi MQsuD9W9kuAI
DqmYzT3EEiSG7PoJyCcyfaYs2IrIDWwZgml7H6vYMfSrM3NcpgCZlINth/v1 awWK+13xNm58
YOBCH0FolNR7A2vkJmll0V0PZa8me09iQUFpdx9DYiAgZgXdAX5o6hNIjQGq eUQOfQPSwwFN
kexoi5DsJEnktupqyEvjcTe5i1VFrH/iC69owf+O+iSWBGt6s3/Sj+txPAlX teB/IfwLgafi
bbYlBquUXtU90EN3TT49TyPZR9eeeppRqKc7QjabkWQfzX3vqdIgEleRQP8D UEsDBAoAAAAA
AKOmaDcAAAAAAAAAAAAAAABiAAAAd29ya3NwYWNlLy5tZXRhZGF0YS8ucGx1 Z2lucy9vcmcu
ZWNsaXBzZS5jb3JlLnJlc291cmNlcy8ucHJvamVjdHMvaVRpZ2VyL29yZy5l Y2xpcHNlLmpk
dC5hcHQuY29yZS9QSwMECgAAAAAA2YxyNwAAAAAAAAAAAAAAAF4AAAB3b3Jr c3BhY2UvLm1l
dGFkYXRhLy5wbHVnaW5zL29yZy5lY2xpcHNlLmNvcmUucmVzb3VyY2VzLy5w cm9qZWN0cy9p
VGlnZXIvb3JnLmVjbGlwc2UuamR0LmNvcmUvUEsDBBQAAAAIANmMcjchIQh/ 4gAAAPMBAABn
AAAAd29ya3NwYWNlLy5tZXRhZGF0YS8ucGx1Z2lucy9vcmcuZWNsaXBzZS5j b3JlLnJlc291
cmNlcy8ucHJvamVjdHMvaVRpZ2VyL29yZy5lY2xpcHNlLmpkdC5jb3JlL3N0 YXRlLmRhdGMQ
yS9K10tNzsksKE7Vy0op0UvOL0plYA0OcQxxZRRjYMsMyUxPLWJgYOBkYGAU U0wy1AayGRmY
i4uSGZiTMvMYoIARpAREMDAzSDtb6UONNDbSzypK1c/JTNIvKtHLSgSaxMji aGoqAVEpi1Vl
VjHILTC1LjsgamWwq02GK3W4uXgDRKkiVqXJGYlFxaklxXCjzQ1eQNQrYVWf WlGin5JXnIfQ
wOCnANGgjlNDTn5yYk5qSmJJIsIajwiILh2cuopL84AeiS8oyi/LTEktwvSR Gj6tBdnJxYaG
CE2bAxjwAABQSwMECgAAAAAAnKZoNwAAAAAAAAAAAAAAAEcAAAB3b3Jrc3Bh Y2UvLm1ldGFk
YXRhLy5wbHVnaW5zL29yZy5lY2xpcHNlLmNvcmUucmVzb3VyY2VzLy5wcm9q ZWN0cy9vd2wx
L1BLAwQUAAAACACcpmg3PVpBy48AAAD0AAAATQAAAHdvcmtzcGFjZS8ubWV0 YWRhdGEvLnBs
dWdpbnMvb3JnLmVjbGlwc2UuY29yZS5yZXNvdXJjZXMvLnByb2plY3RzL293 bDEvMS50cmVl
Y2FmYmJgYGBkYMkvzzFkUMgvStdLTc7JLChO1ctKKdFLzi8CMhLLEpNKM3NS UosYQIqZGIEa
gDRMF5DDIgzki8lGJVUwQADIVBYom4WZgUsvOSexuLggsSQDpJyRCaI8OQmm BOwIuFYOvYKi
/KzU5BJkxXCzmaHmQ9lsvpV6QHcgKY12mg6VZkUxlxHsaABQSwMECgAAAAAA nKZoNwAAAAAA
AAAAAAAAAGAAAAB3b3Jrc3BhY2UvLm1ldGFkYXRhLy5wbHVnaW5zL29yZy5l Y2xpcHNlLmNv
cmUucmVzb3VyY2VzLy5wcm9qZWN0cy9vd2wxL29yZy5lY2xpcHNlLmpkdC5h cHQuY29yZS9Q
SwMECgAAAAAAnKZoNwAAAAAAAAAAAAAAAFwAAAB3b3Jrc3BhY2UvLm1ldGFk YXRhLy5wbHVn
aW5zL29yZy5lY2xpcHNlLmNvcmUucmVzb3VyY2VzLy5wcm9qZWN0cy9vd2wx L29yZy5lY2xp
cHNlLmpkdC5jb3JlL1BLAwQUAAAACACcpmg3muIho9EAAADrAQAAZQAAAHdv cmtzcGFjZS8u
bWV0YWRhdGEvLnBsdWdpbnMvb3JnLmVjbGlwc2UuY29yZS5yZXNvdXJjZXMv LnByb2plY3Rz
L293bDEvb3JnLmVjbGlwc2UuamR0LmNvcmUvc3RhdGUuZGF0YxDJL0rXS03O ySwoTtXLSinR
S84vSmVgDQ5xDHFlFGNgyS/PMWQAA0YxxYQ/m0AMBjTACRZhZpB2ttKHGmVs pJ9VlKqfk5mk
X1Sil5VYBNTG4mhqKgFRKYtVZVYxyA0wtS47IGplsKtNhit1uLl4A0SpIlal yRmJRcWpJcVw
o80NXkDUK2FVn1pRop+SV5yH0MDgpwDRoI5TQ05+cmJOakpiSSLCGo8IiC4d nLqKS/OAHokv
KMovy0xJLcL0kRo+rQXZycWGhghNmwPQYwYZAABQSwMECgAAAAAAkYlNOAAA AAAAAAAAAAAA
AD4AAAB3b3Jrc3BhY2UvLm1ldGFkYXRhLy5wbHVnaW5zL29yZy5lY2xpcHNl LmNvcmUucmVz
b3VyY2VzLy5yb290L1BLAwQKAAAAAABpqjI3AAAAAAAAAAAAAAAARwAAAHdv cmtzcGFjZS8u
bWV0YWRhdGEvLnBsdWdpbnMvb3JnLmVjbGlwc2UuY29yZS5yZXNvdXJjZXMv LnJvb3QvLmlu
ZGV4ZXMvUEsDBAoAAAAAAJOJTTihjgw8AQAAAAEAAABWAAAAd29ya3NwYWNl Ly5tZXRhZGF0
YS8ucGx1Z2lucy9vcmcuZWNsaXBzZS5jb3JlLnJlc291cmNlcy8ucm9vdC8u aW5kZXhlcy9o
aXN0b3J5LnZlcnNpb24CUEsDBBQAAAAIALJ7TThpb33OdwAAAJcAAABXAAAA d29ya3NwYWNl
Ly5tZXRhZGF0YS8ucGx1Z2lucy9vcmcuZWNsaXBzZS5jb3JlLnJlc291cmNl cy8ucm9vdC8u
aW5kZXhlcy9wcm9wZXJ0aWVzLmluZGV4TY0xD8IgFAY/cHbQ6OKPwIJtTGd3 F4074ovFCDS8
1/9v6tRbL7lTABTUESuNQ6lvQ+EbRyYTSiVTictUAzE2oWShLBcfBrqJF4I6 Kczsl+oeE7H4
NGJtbd92XXO2Td86jd2y/nnJ/4Atz60HVY4lX6f0pArt3A9QSwMECgAAAAAA k4lNOBvfBaUB
AAAAAQAAAFkAAAB3b3Jrc3BhY2UvLm1ldGFkYXRhLy5wbHVnaW5zL29yZy5l Y2xpcHNlLmNv
cmUucmVzb3VyY2VzLy5yb290Ly5pbmRleGVzL3Byb3BlcnRpZXMudmVyc2lv bgFQSwMEFAAA
AAgAkYlNOLkNsw6IAAAA2AAAAEUAAAB3b3Jrc3BhY2UvLm1ldGFkYXRhLy5w bHVnaW5zL29y
Zy5lY2xpcHNlLmNvcmUucmVzb3VyY2VzLy5yb290LzE0LnRyZWVjYWZiYoCA rwyYgJFBJb8o
Xa8kM70os1ivuDSpLLWoODM/D8RMzsksKE7VS84vSmXgLy7L001K1i2uzEvW zU6tBGsVAWlN
hSrLSimBKAVJMTECpUE0A1tmSGZ6ahGIyyIEFBFTTFJKg1rOBcRM/6EAKJ9f nmOIUCgblVQB
VQjyAQtcIVAFMwMAUEsDBAoAAAAAAJGJTTgAAAAAAAAAAAAAAABDAAAAd29y a3NwYWNlLy5t
ZXRhZGF0YS8ucGx1Z2lucy9vcmcuZWNsaXBzZS5jb3JlLnJlc291cmNlcy8u c2FmZXRhYmxl
L1BLAwQUAAAACACRiU046ZwiUdcAAACgAgAAXQAAAHdvcmtzcGFjZS8ubWV0 YWRhdGEvLnBs
dWdpbnMvb3JnLmVjbGlwc2UuY29yZS5yZXNvdXJjZXMvLnNhZmV0YWJsZS9v cmcuZWNsaXBz
ZS5jb3JlLnJlc291cmNlc3PY2N2ovIdBREp12vPFk/fJKecmFpekFimUJCbl pPJyKYenpii4
pSYpGBorGJpbGRpZGZsouAaHKBgZGFjwcqWk5pQkulYUZBYllmTm58XnF6Xr pSbnZBYUp+pl
pZToJecXpdoaGhkYWZoYmJuamJoZ8XIl56QmFrmANKIoT0lNKk3XK820TUvM KU4loAxsLn6F
IOtzEkvzkjMy89JhavUzQzLTU4v09UqKUlNtcTsG7naYvvzyHEOoLkMgF8oy 4eU6EPH7Mzj8
Aj/3VO8uP+YwGp5UDU8AUEsDBAoAAAAAAAaXMjcAAAAAAAAAAAAAAAA2AAAA d29ya3NwYWNl
Ly5tZXRhZGF0YS8ucGx1Z2lucy9vcmcuZWNsaXBzZS5jb3JlLnJ1bnRpbWUv UEsDBAoAAAAA
ADyETTgAAAAAAAAAAAAAAABAAAAAd29ya3NwYWNlLy5tZXRhZGF0YS8ucGx1 Z2lucy9vcmcu
ZWNsaXBzZS5jb3JlLnJ1bnRpbWUvLnNldHRpbmdzL1BLAwQUAAAACAA8hE04 +zyKaoMAAACN
AAAAYAAAAHdvcmtzcGFjZS8ubWV0YWRhdGEvLnBsdWdpbnMvb3JnLmVjbGlw c2UuY29yZS5y
dW50aW1lLy5zZXR0aW5ncy9vcmcuZWNsaXBzZS5idWNrbWluc3Rlci51aS5w cmVmczXLvQrC
MBhG4b3Qewi4J43BIoVOopOLf7i4tOmrBtsk5ksNvXvr4HQ4w7O4omM7tEwq JstKqWpVsu3p
zJZFsc6zvqG4OYwI0+W4r58x+lslREqJQ/fGE7gLD9GO+jUYSxFBUDP4HiTe MzJzOwyO699N
efZHPuCOAKtB/INAxtla5tkXUEsDBBQAAAAIALmLaDeV857vQgAAAEkAAABg AAAAd29ya3Nw
YWNlLy5tZXRhZGF0YS8ucGx1Z2lucy9vcmcuZWNsaXBzZS5jb3JlLnJ1bnRp bWUvLnNldHRp
bmdzL29yZy5lY2xpcHNlLmNvcmUucmVzb3VyY2VzLnByZWZzUw7JKFXwyy9T MLBQMDS3MrK0
MjVUcA0OUTAyMDDn5SpLLSrOzM+zNeTlSk3OySwoTtUrKEpNSy1KzUtOLdZD kgYAUEsDBBQA
AAAIAGmqMjcBbPkMqAAAAMQAAABaAAAAd29ya3NwYWNlLy5tZXRhZGF0YS8u cGx1Z2lucy9v
cmcuZWNsaXBzZS5jb3JlLnJ1bnRpbWUvLnNldHRpbmdzL29yZy5lY2xpcHNl LmRlYnVnLnVp
LnByZWZzNYxNC4IwHMbvgt9h2LnlvGSiSdikIEJ86SSIzX82sE02lT5+I+r2 vP2eVTkDKmBE
xEeeF5BdYAQ9lshz3a1tARv4qAGPCh6gQDDQeAGluRQRsS2pevyfdHCfezxz nOU0bS6H6pqc
mozmRUaT8nyjRRTG79eAfngdOQS7DjKfsuOiN74q07XvID21omsHKcBkQjrx vla1CId2FuyZ
GXoENvEF9OZb2NYHUEsDBBQAAAAIAGQ7aDdXybRq9QQAAPUeAABiAAAAd29y a3NwYWNlLy5t
ZXRhZGF0YS8ucGx1Z2lucy9vcmcuZWNsaXBzZS5jb3JlLnJ1bnRpbWUvLnNl dHRpbmdzL29y
Zy5lY2xpcHNlLmh5YWRlcy5leGVjdXRpb24ucHJlZnPdWVtvqlgUfm/S/9Bk 4qMM23t74gOl
1NIKOIBzOgkJQbpVergdQOv8+1kbsEeNXCvnYdJIsGy+tfda37r6h7re3Ije 9oYe3dDDu87w
Dm44Rb3p0PTw+oqdMooyY9QnXZInOsdO+ZnC6c+PDMuNWe1O07BpW36Iux1N 8+3NynJDTfOC
FZX+n3pfGibWu1QH/gTAHKAO6rUR3FHvRvAtS8LTP8wDp+hTaTLhxYk+Y2SF k5VyItf/Gm84
pGxvBc9WlG8EIQ5CvQc7QNSW7IEedXpo2O9q2jp+Gm/l4tiRv7Itx/eCqBn8 heUe6Y+VBJ2/
hw87z1aU6TmUtYCPuQGr9Kg+lRqlm9ojtYAsSeoJCsiaK6okZBlrxsmPgiTq zIQTVWX8rSUz
gPM3J+tPksC1AGkXYTe0vIxD+zhYOp5LGSvsRuEXX88iljpTZ/psyqiPkiyA yqZTjlV52PWj
zAjcd0l+KUeyyI98yreNaOkFDmV6to3NCPZGLQPDwR9e8AOMhigEPE/MNkBd 1Ee3QDkzXlKe
E/VFnTLkUBGSMuHHZhn5XriyUg+Wu52dToQMaYRGuR7MSjK5CAIjPpR0XNML yMVxDPctjCXS
FJ+ciO63Ue8zZhSFC+aBmamcXCtcGG+GH+HgnMudHvV5LvKnTnIi5H3jWhEc ZUQhTYu/FNv9
6J3EhL+MNv6wXOKKz/eSosSeMXY3tl2sE2KPWgohVom10Um1cUsj+hZ1CkK3 CklEVyVpqlQX
HeEwoiLPs8Nf0ve2GHYRyKchvJLn7ZgzVcNrKXxCRHCyYOO6OGhGBBB9Y9iN ing3tkajAtYR
RKfGBazxLsBmwxIiyBzNSEgAGlVTEigyc7Ms3XMvRdHqNKMG3gL/gFh0RmC2 qNjx67n8V0LN
ZSUCKUi5sa5nq1zU+jzOhiWPvxAKs4FTVk3nkEPSdFMFHe+wuSG1ynl0yzDb 4BOR5eDD8q5k
U3DxjAbmsWspsRTwAoPjNAAdNQe9tlGvEVhY03tvRs1x1g4bwM4IsMcNhSA9 cNOS5e5xXe94
b9gOT0QPEEKZXfjvKXpBqSvbqK3PXOS8/kT5XjJZhR9R2p1su53uYFF+q/Am FZfT6XU3Ghwi
nW1vmBnDPiWNjSR+Kj9/p4ZvmOukswFq6qlqdATtTW+vEuinBv2hptnW4s90 YTtd2E4WFh6r
iphzmk+P9sy8MLLK/E+O+CyJzFGfdJ5tnPAI96RlfRX4crzDzhLuSbrYOZZO WNOlkta4j3qI
7u/b4/16P8BLHGDXBO/Y4oBkujEq7tsaGn1dXx2NVxrK6nC8tPDUkxrigvVn tiET5pa3YkKn
2ITorAkLOFORLzlcyRmlyHNR5csaKqZlaoN0kJKOhuj9nG8yZRLLt0omllZB Hrp4iwFvpk8r
Z5982Ly0kzXLrDL6bJHhQYDjSJfcxjNJcopMLv0150XptRp1f24s19vt6Xve zFk75l45dk4G
n5fz/IOznSFV8eC1dTwbvQAEmC3PyJ86aJVeWFgA/v6JckEn3twI7vpqyt+D blROVAiRqDeS
X/d7YGT2aQwVVYGjNcDDuMu2K8eMYszqbXsBJjF529hEnmOQRW14OY0TTUqB kmBbYwpVrJ9a
vfMn7EER3jsMZfsfM6hmYEkyuKAa8nJL861iauxkQd1fmPLgl0YY7XwjqjAY qwHeDjdun25C
RGKe/wBQSwMEFAAAAAgANKFmN6Z/SGdTAAAAWgAAAFsAAAB3b3Jrc3BhY2Uv Lm1ldGFkYXRh
Ly5wbHVnaW5zL29yZy5lY2xpcHNlLmNvcmUucnVudGltZS8uc2V0dGluZ3Mv b3JnLmVjbGlw
c2UuaHlhZGVzLnVpLnByZWZzUw4pTVXwyy9TMDBTMDKwMrC0MjFQcA0OAXIM zHm5UpNzMguK
U/UKilLTUotS85JTi/XKUouKM/PzbA15udIyc0qAPD0IHZyak5pcApKKyePl AgBQSwMEFAAA
AAgAVLVnN+SN1xO+AAAAjQEAAFoAAAB3b3Jrc3BhY2UvLm1ldGFkYXRhLy5w bHVnaW5zL29y
Zy5lY2xpcHNlLmNvcmUucnVudGltZS8uc2V0dGluZ3Mvb3JnLmVjbGlwc2Uu amR0LmNvcmUu
cHJlZnOVkLFqAzEMhvdA3sGQLYO4HC2Bwk0lhS4l0EJnx/7v6iJbRrZD8va9 EDKWtCA06ful
T6tPePMmR9NtTd8/PczVmd37h+m7brtciE4ExyEX0Lev5EQxt5gDQymrHBiR kFp89Ug1jAE6
QFX0HuvEY0KianVC3bOto2gcNvS4XNyorBihSA6FjtASJA2bX4IPLbCfcxVF mjo8Sz7vTo7b
hXoJXOfD1sS2Jff1Vy9bCrT+1+y6/2py7wcxc7DpNv0DUEsDBBQAAAAIALOm aDcfpZyPNAEA
AAwCAABfAAAAd29ya3NwYWNlLy5tZXRhZGF0YS8ucGx1Z2lucy9vcmcuZWNs aXBzZS5jb3Jl
LnJ1bnRpbWUvLnNldHRpbmdzL29yZy5lY2xpcHNlLmpkdC5sYXVuY2hpbmcu cHJlZnOdkM1u
wjAQhO9IvIPlXqmdECJIBOWA4ESqCgLqwRJy44UEJXZkO1H79jX/EkeO+3l2 Zrxvad6gT9Ui
b4T6XhwGcRCh+Tp1gzfsdiAri9oAqTXsQYPMwJAWtCmUnPjdjtIHcpMchSUl b2SWF/JAvlbz
xW6b7L6T5WQ8/a1KdF1jE+wTDyPnpYRTunmTLt5HGBnLpeClkuCYVHj6wTST 47Zag7VOaZCA
PW9Ku02cIBz2ntMLaUFLXhIBP82BNMW1D2iyPntrsU3Svxr8oOf70WAQBUEY RaMBfjjPlJSQ
WaVdBL4VOO2gQjj0cuTd6+LzFH/kLRcq26yW7i23tmYxpSdITCNJpip67Bug PgmJR53QUF4X
FCPJq9Oxro2CPkY1t7kjMxYz9sD0kk4vX7kPt8OeQbfzD1BLAwQUAAAACAA0 oWY3tzVskAMB
AADMAQAAWAAAAHdvcmtzcGFjZS8ubWV0YWRhdGEvLnBsdWdpbnMvb3JnLmVj bGlwc2UuY29y
ZS5ydW50aW1lLy5zZXR0aW5ncy9vcmcuZWNsaXBzZS5qZHQudWkucHJlZnNt kE1rwzAMhu+B
/IfA7sYZY2MdOYx1hx2WZrSQY/EcOVPn2kFW0jHy4+ewr36hk/RKL++ji1UP WemHTF5nl3Im
b2dXMntcrmIjb9KkD/DSo36fozEVgalUCwVTD2nC6rXGht8q8p1qFUPzI3Rx 4IOyC2qAnrGl
Pc1TK0Bb7AKITcOiR7FRg2q8tl4rRu+C2B6exAj3znn+Vo9CHPgZpUEwfLDx jot8fPA9IVBW
wm7M5SjH+qmcL+rlmI/yqP4ne0d3Z/NCg+xJRHyxm/iLs1vG01YxA8VvGLQQ xAAUIkGR52kS
OrAWXbueqC2s0SGjsvj5R/1r10VeIHB63yFNJsKTx38BUEsDBBQAAAAIAMJ9 TTjROdYHXwAA
AGIAAABaAAAAd29ya3NwYWNlLy5tZXRhZGF0YS8ucGx1Z2lucy9vcmcuZWNs aXBzZS5jb3Jl
LnJ1bnRpbWUvLnNldHRpbmdzL29yZy5lY2xpcHNlLnBkZS5jb3JlLnByZWZz Uw5PTVFwS01S
MDRWMDS1MjGzMjBVcA0OUTAyMLDg5UpNzsksKE7VKyhKTUstSs1LTi3WK0st Ks7Mz7M15OUq
yEksScsvyo0vSCzJsHWOsYqJgeoIyS9ITixOTeHlAgBQSwMEFAAAAAgAs6Zo N7PXniReAAAA
ZAAAAFkAAAB3b3Jrc3BhY2UvLm1ldGFkYXRhLy5wbHVnaW5zL29yZy5lY2xp cHNlLmNvcmUu
cnVudGltZS8uc2V0dGluZ3Mvb3JnLmVjbGlwc2UudGVhbS51aS5wcmVmc1MO yShV8MsvUzCw
UDAysDI1tjK2UHANDgFyDMx5uVKTczILilP1CopS01KLUvOSU4v1ylKLijPz 82wNebnyi9L1
YEpKUhNz9Uoz9dIyi4pL4ksyc1Nt0xJzilN5uQBQSwMEFAAAAAgAs6ZoN/Wp lspcAAAAZAAA
AFwAAAB3b3Jrc3BhY2UvLm1ldGFkYXRhLy5wbHVnaW5zL29yZy5lY2xpcHNl LmNvcmUucnVu
dGltZS8uc2V0dGluZ3Mvb3JnLmVjbGlwc2UudWkuZWRpdG9ycy5wcmVmc1MO yShV8MsvUzCw
UDAysDI1tjK2UHANDgFyDMx5uVKTczILilP1CopS01KLUvOSU4v1ylKLijPz 82wNebnygeyy
zNTyoNKc1KL43Mz0osQSkBSElZoSb6wHVAUAUEsDBBQAAAAIAMN9TTgz8b/A gQAAAIUAAABY
AAAAd29ya3NwYWNlLy5tZXRhZGF0YS8ucGx1Z2lucy9vcmcuZWNsaXBzZS5j b3JlLnJ1bnRp
bWUvLnNldHRpbmdzL29yZy5lY2xpcHNlLnVpLmlkZS5wcmVmcw3LwQqCMBgA 4Ptg7zDoLpu5
uYQdpFYEhgcFj7H0FySb49/q+fP6wXcYYGJXeDFxZEJWhap4yWzXs5xzTQmM 6xIiZAFhBgQ/
Qsx+gHHZvBGUDLY5tw/7vNzrpr2Z2a0RKEl7qf3U4zK+o0n43S2sLs0bfrrk EhghTloWUqky
15KSP1BLAwQKAAAAAAC0pmg3PT1gc08AAABPAAAAVAAAAHdvcmtzcGFjZS8u bWV0YWRhdGEv
LnBsdWdpbnMvb3JnLmVjbGlwc2UuY29yZS5ydW50aW1lLy5zZXR0aW5ncy9v cmcuZWNsaXBz
ZS51aS5wcmVmcyNUaHUgTm92IDA4IDIwOjUzOjQwIEVTVCAyMDA3DQplY2xp cHNlLnByZWZl
cmVuY2VzLnZlcnNpb249MQ0Kc2hvd0ludHJvPWZhbHNlDQpQSwMECgAAAAAA CZcyNwAAAAAA
AAAAAAAAADQAAAB3b3Jrc3BhY2UvLm1ldGFkYXRhLy5wbHVnaW5zL29yZy5l Y2xpcHNlLmRl
YnVnLmNvcmUvUEsDBAoAAAAAAGiqMjcAAAAAAAAAAAAAAAAyAAAAd29ya3Nw YWNlLy5tZXRh
ZGF0YS8ucGx1Z2lucy9vcmcuZWNsaXBzZS5kZWJ1Zy51aS9QSwMEFAAAAAgA V11yN7WhBfC9
AAAAfgIAAFAAAAB3b3Jrc3BhY2UvLm1ldGFkYXRhLy5wbHVnaW5zL29yZy5l Y2xpcHNlLmRl
YnVnLnVpL2xhdW5jaENvbmZpZ3VyYXRpb25IaXN0b3J5LnhtbL2SQQ6CQAxF 9ybegczeQXcu
QHfqAfQAIxRsMrSkM0Pg9gLRSNgYE8Pyt799Tdvk2FY2akAcMqVqp7cqAso4 RypTdbueNnsV
OW8oN5YJUkWsjof1KrEmUPa4oPMs3SdwFg51hHmqWEoNmcXagQ6oofUgZKxn tk5PzGooriS8
WsWDLEzDgh7cqOKJ+xsph3soB97EpGvhAi0sQBqDC3Ak0H8pvvb9nqzxBUul TX+ozqHTGQvM
2e/k7wPE86d5AlBLAwQKAAAAAAAitmc3AAAAAAAAAAAAAAAAMwAAAHdvcmtz cGFjZS8ubWV0
YWRhdGEvLnBsdWdpbnMvb3JnLmVjbGlwc2UuaGVscC5iYXNlL1BLAwQKAAAA AAALoWY3AAAA
AAAAAAAAAAAAOgAAAHdvcmtzcGFjZS8ubWV0YWRhdGEvLnBsdWdpbnMvb3Jn LmVjbGlwc2Uu
aHlhZGVzLmV4ZWN1dGlvbi9QSwMECgAAAAAA6YxyNwAAAAAAAAAAAAAAADIA AAB3b3Jrc3Bh
Y2UvLm1ldGFkYXRhLy5wbHVnaW5zL29yZy5lY2xpcHNlLmpkdC5jb3JlL1BL AwQUAAAACADp
jHI3YHZjW6QAAABkAQAASAAAAHdvcmtzcGFjZS8ubWV0YWRhdGEvLnBsdWdp bnMvb3JnLmVj
bGlwc2UuamR0LmNvcmUvZXh0ZXJuYWxMaWJzVGltZVN0YW1wc2NgYOBgUHe2 0k9NzsksKE41
NtLPKkrVz8lM0k+tKNHPyU9OzElNSSxJ1MtKLGJgYGRxdC4WZlDCqSElrziv GK6WIU+AQRGr
2uSMxKLi1BKE0p18Wxh0cBpbXJqXlZwaX1CUX5aZkloE0+Vw+5czgzRWXUUl MEXO5ud7GWSw
KgKaCTfq1mNzBjV8DijITi42NISrv5PQxiCL3dTiYrixjjan/wIAUEsDBAoA AAAAAOmMcjeL
TcO7SQAAAEkAAABFAAAAd29ya3NwYWNlLy5tZXRhZGF0YS8ucGx1Z2lucy9v cmcuZWNsaXBz
ZS5qZHQuY29yZS9zYXZlZEluZGV4TmFtZXMudHh0SU5ERVggVkVSU0lPTiAx LjEyNCtDOlx3
b3Jrc3BhY2VcLm1ldGFkYXRhXC5wbHVnaW5zXG9yZy5lY2xpcHNlLmpkdC5j b3JlClBLAwQU
AAAACACRiU04jbYuvVoAAACbAAAATAAAAHdvcmtzcGFjZS8ubWV0YWRhdGEv LnBsdWdpbnMv
b3JnLmVjbGlwc2UuamR0LmNvcmUvdmFyaWFibGVzQW5kQ29udGFpbmVycy5k YXRjYGBgYoAA
DjDJ4+rs4xkQ7Brv4e/ryggUYGRg9wpyjQ8OcgbxmBi4vEL9PEPg0swM3FDp IH//EJAIC0SD
j6cTiMfKwAfRAFQB18TGwO3ihGIMOwM/VASuDgBQSwMECgAAAAAAU7VnNwAA AAAAAAAAAAAA
ADcAAAB3b3Jrc3BhY2UvLm1ldGFkYXRhLy5wbHVnaW5zL29yZy5lY2xpcHNl LmpkdC5sYXVu
Y2hpbmcvUEsDBBQAAAAIAFS1ZzfdeOcV2AAAANsEAABHAAAAd29ya3NwYWNl Ly5tZXRhZGF0
YS8ucGx1Z2lucy9vcmcuZWNsaXBzZS5qZHQubGF1bmNoaW5nL2xpYnJhcnlJ bmZvcy54bWzt
lE8LgkAQxe9B30H2nto/kMg6FEH3ugmxrlOu2G7MbFHfPiUDs6D17m0G3u/N MDxmvryfc+cG
SFKrkA1dnzmghE6kOoVsv9sMArZc9HvzXMbI8bFVR02N3kn1GUK2mkUgcnkh GI+iDIHVbaeu
f/AnrCRjrc2Fm7SsQRl8OGX3zUfFiAiNm3FknpVYDgPVQk5XhcRJntpAGRG0 kYs2apFyJDBk
iYicF9vQS+l93PVuQJW3X0skq9EFUfn8YBNdrJXYe1XA27DBe7Xs/I9SF6Mu RlYx8hov6glQ
SwMECgAAAAAAaaoyNwAAAAAAAAAAAAAAADAAAAB3b3Jrc3BhY2UvLm1ldGFk YXRhLy5wbHVn
aW5zL29yZy5lY2xpcHNlLmpkdC51aS9QSwMEFAAAAAgAkolNOFi82UFJAwAA mBwAAEMAAAB3
b3Jrc3BhY2UvLm1ldGFkYXRhLy5wbHVnaW5zL29yZy5lY2xpcHNlLmpkdC51 aS9kaWFsb2df
c2V0dGluZ3MueG1s5VhfT9swEH/epH2HKJv6gLQU2Muk0iFWWsEEqFLZeKzc 5JqYOnawndJ8
+9mJU2hIC2NNUraXyLHP98/nu/v56HgREmsOXGBGu/aBs29bQF3mYep37Z/X g89f7eNvH94f
CXClIrEoCqFr3zA+myi6wFZr746whNCaIxKrpUPbmkHSta+TCM4wcMTdIPmF 4X6IuHSCfGau
Zuz2k91TRARs5HAXI4KnGDytiShh8WXjdsYxUIm0La8STzCdgYcl47nsVc8w 7jvgEhwJcG49
6WAqgVNEnBg7EXJnyAdtujPMxv1FRBgHrnmnvlzVR/I4V8fnLI7GBE+UQjg3 fL32Ws8bLIN+
qmsZdX5QBCUslmUUB4aCMyYvmQdlNC0iOysx1LqLmeyoQMoGD9GU/achlQ2P W77stD4u9k/T
70lH84pW/WIVzM7ZG+ZY3GDqsXsdj0rGCKQh0I4zNJl9Zv4wn1xxj1nMVc7t LQi7Xwq50ked
zZpviSVuLCQLB5ioABBWLICfwhRT8IZI6pgQfYomBDzDKD289dyUi812w7FU ZICJZ01TgvOc
cTEiVSAWgs+5SN2bZJyXrl2rX3urspmLiL5rohHxI50L3IplRx5o2f1FlguG JPYxvchjOpN9
sEb4QyRv1e4eYUKFIme3Kn014/orRkcB4s1r8QPNUZ9AqApDIyr0mKpI+mo3 eQ978Qn1egQJ
fQzQ5FHUEw5+OHVUZQIfqNYlwB6M1VjVewlelYY/7giKHuiHkUzOKdUNQbqy 0QcVpQbzf6rI
EE87pcq1eNYnL3FHVWF5HkaMyzrdUaLEAAPxasiQm07iTN2RNDiXaWKzQhW5 QqWJYTwh2G0i
GsZR1r0NzMaxs1eR9aZp+I6pKgkmJ25uFSrrkRIqA1Bt0iWEE9V6/s2ht1/U yLZXmudSigJQ
0DQGroRpJWcGnrUNPivBao/q/gg0zDtJV4X93MYSny3vTUGvElBXEWSCHDK9 GhSVmGV4ixT3
Sgb/F1xqrEdosAA0mfJ2EiI+MX/v057j6gr4z5a9nW7H6gFJIJ1bVR6mzfQ3 9cGgXYakO9F4
1/JAtDsvJDuPTrfZjL7lN6Pm3+/qfDFqCAy9ATS83deabcMz+AN49nj8G1BL AwQKAAAAAACS
iU04MOCHD0wAAABMAAAAQwAAAHdvcmtzcGFjZS8ubWV0YWRhdGEvLnBsdWdp bnMvb3JnLmVj
bGlwc2UuamR0LnVpL09wZW5UeXBlSGlzdG9yeS54bWw8P3htbCB2ZXJzaW9u PSIxLjAiIGVu
Y29kaW5nPSJVVEYtOCIgc3RhbmRhbG9uZT0ibm8iPz4NCjx0eXBlSW5mb0hp c3Ryb3kvPg0K
UEsDBAoAAAAAAJKJTTjBjYi4VQAAAFUAAABMAAAAd29ya3NwYWNlLy5tZXRh ZGF0YS8ucGx1
Z2lucy9vcmcuZWNsaXBzZS5qZHQudWkvUXVhbGlmaWVkVHlwZU5hbWVIaXN0 b3J5LnhtbDw/
eG1sIHZlcnNpb249IjEuMCIgZW5jb2Rpbmc9IlVURi04IiBzdGFuZGFsb25l PSJubyI/Pg0K
PHF1YWxpZmllZFR5cGVOYW1lSGlzdHJveS8+DQpQSwMECgAAAAAAm3xNOAAA AAAAAAAAAAAA
ADIAAAB3b3Jrc3BhY2UvLm1ldGFkYXRhLy5wbHVnaW5zL29yZy5lY2xpcHNl LnBkZS5jb3Jl
L1BLAwQKAAAAAACcfE04AAAAAAAAAAAAAAAASAAAAHdvcmtzcGFjZS8ubWV0 YWRhdGEvLnBs
dWdpbnMvb3JnLmVjbGlwc2UucGRlLmNvcmUvLTEyMjczMTQ2Mzk1NzgudGFy Z2V0L1BLAwQU
AAAACACcfE04blPa4/cbAgCL4RAATQAAAHdvcmtzcGFjZS8ubWV0YWRhdGEv LnBsdWdpbnMv
b3JnLmVjbGlwc2UucGRlLmNvcmUvLTEyMjczMTQ2Mzk1NzgudGFyZ2V0Ly5s YXp53F0HmNu2
FQbv5MR2hh3HOzt2dqxIuvPKaIazR9uM7rQuT+LpeJZEhaRuuHvvnWbH2Xvv vdOVdKZ7t+lM
90jTtOniD5ISRYIiAKpWPun7/N9ZR74feAAeHoAHgBBCFHLUugNP14oVvW5p pxn1ompppdPr
lUZZr1mnG2Y5OzlUzJaMataaKGcto2EWtfX5bD6by04UcrnVuVX5fH51YZiI fBSFHM3LWtUr
LdpcKtoBhRzBQVu0rKylFh26oTBddlw1PUlk8CyFzAm9o1CNOn9z+bwnffKt p1ZoZzT0muH8
1Ab/63wUMntqhV6zNbOmVgbw6uDZClkUkpod0yp1zbRSSg9qYgDpB5zdrp+Z xxdOPWqFk3OF
LFx35Drnt9wBRxuNWkm1daOG/4aVOshXg/ysNIsyoluhoswo5PgEVtv70vnF qGzQbVYtWlsY
zq8tRPLU8TNDIet4qa3SBhafX424P1twZFcvm7qj48bIhFNVnMLCr+7z2ep0 Zbq2vkAT4lEr
qGvnKGQPrndpZdtCorLNVshSMHgpzxYNU8uamlsUFsQqe6NSL44+1KjZelWj zH/GIwuCj9ia
WqXPUREr8PflSTlpPp7F47snPd7Q8fDgGjy8bZDb/YPyFP6wS/APVFUOTbXu tJYRvaLb01TV
ZMfoU7ZqbbDcJNFHlsY94rDRB5YwHoAS3L/jEaT2HL/CUM1S3VEF0WzT7HhJ RwXwG/vKcHXb
UiHHJlS3qmHaI+p0dlyz7Wm/aa10+oV8PkWznqmQNQnE442abq8fyq7JFoJE Q2u8hJPBcxWy
FX0qq07aDd23mDNRc2l1milqk89TyFxXojZlazVUFKsLYs93OhBX7KipVrVJ w9zQBakXOM+5
Up0mVNPMLoi8UCHbuCKtSb1W7opONylk+zaZWb3YHbVe1FSA7RRX6sQG2wVa 0LmA8wDnAy4A
XAjYBLgo8HigiQ2Fa/oshezHU9OH1w87XWUer2yNzF0cUxUzXiYVmsFZojq7 hF0VU0q9lFEV
U4q8jFG4KUVerpBZTX13Qd4VCpnXlJf1/5ZOMO2ur1TIDlHBTnd6RkOz7JTV gDJc5XVEYQZa
et0guNqpvi2CrtWKaxSyU1hstqrW9HqjQj3XLnBcy+KoGbY+qhe7xXGdQrYL c6Rt3oHP1rBQ
FwMuAVwKuAxwOeAKwJWAqwBXA64BXAu4LiCnk+/geHyH8hg232eI6cm5P1sl jz98r2nKKvms
BRjVplO+KpcTdFS2TnbIg6xVtV53OjlKm2unTRoLdNL1Ngo5WTwVWa2k24bZ 7cRsq5BTBBKj
US/f6fIdz9upqt1OzZzksb6fmknLpoO0Vi0s5IbyK4UHaXMVchw/JVVCQ3eY C62amM8XCsMF
n3kIJuF6hezFfrVln9Ui7A8dTiEV7ofXJN+gkL0TCUpq3flVkuFGx9dJZrDT ZeMmhezLQ1LS
LL1ck+O4WSEr+TmyJd3UijZamxzdLQoZFqADUV01bUkF3qqQA2XYnKFgSavI cd6mkNWinEZF
L+qaZCZvV0hBgHBULzdMWa47uBqWnZWvIHdy1nnX4Mtx3MXJMaoW1ZImx3E3 p4EwGnZFr0mS
3KOQLA9J3TTqTpckXcXu5cyMPV3XJvSNciT3cTZWj6Qr9fl+Oc6KOu2UmyTn AxxtqGhUHVe/
JMnwIEe1AINRS9c/PaSQAzh50mXoYYUcxEnUqur4dUIvSXfxj3DUjSippaXR 6KOOiyfPmaXO
8Kghx/2Y4+ul584WG5ZtVOWS8DiHnfGS0LB1yQ76MwrJJZF0x/34rEJWiTKl cT0+p5AhEb5U
bsfnOYxMN0z0F/h5UpnlJzgGJSVdrRhlSYInFbJnEkEar+aLCtmfT747LS3H 8iWFrOBksTTV
LI7J0XyZw0WrqRN6mU5TyXF8haNAapa8K/tVDmtWN7VRzdRqRdnm8TUOb8Lh cPp52Xr1FIe9
9BnS+RNf5/AnmkyO0tSqpN/8DY4hU5PIss1G0W6Yklzf5GgwTS75Xu1bIrqb 1DeqZkmO6Nsc
rSZNy/8Oh7135aerbN/1ltc78WA9Rk769zikyxf2970ghyTpkqr5AYfxnVAr eimF8f0hR3c7
qZfKmmx//iMuArQDCQLv0UWhtuDIntC1SSvoINvqyIhWQpLoaoe7eKH4CyA+ p/PVMx2DRpIF
uCElu4fz7PvLpo4YlcqEZtJ3/X+eKKUpmX5FFobFWDR7Sus1QjQSkkQl7BjJ hv86spPAjR87
4ZsdYrLBKWNPZiKmqhVeAdszlQABISWUmEqYFwlvCRaFzpGA3SMJGHeMt0ZN Ekdl+gRenxN8
vayNJr83cCbeWxaq01g6H3F8lDHK7np3HGn4KWTNC8lyBuQcr/4uEj+kVUe9 9RXwK762AiIG
20WcEBHRHqjFkQoaxjU/ssrDx38cXl4UyYLzsl8BOr4/sCmSflShltnlacW7 Bl+v2Bt8Fbhu
gF4rcyjhSQjaOSzIKUkhMYNz2S3S0Sdni9wuUptcL4CDm7alrZzWl9VHnH/F RvOdDP3HyvZG
+tsQXr8ecAPgRsBNgJsBtwBuBdwGuB1wB+BOwF2AuwH3AO4F3Ae4H/AA4EHA Q4CHAY8AHgU8
Bngc8BnAZwGfA3we8AXAE4AnAV8EfAnwZcBXAF8FfA3wFODrgG8Avgn4FuDb gO8Avgv4HuD7
gB8Afgj4kaeQBbR/on0MNfHUTFM7S20ltXjUaFHTQ+0INQC0KdPGOODF7inH 0bpNKxatFrRo
aSH5Wu+0BLqdQk4SXI9E9aLR3YWcvya5Or+6kBte5a9JIgh08McK2Yf9utPp 12w6K9N0HNwK
6XcBg2yHYdbUilFT12olN8iZ1Z1Qd4QRM/GTGB+YmZiWH9lMEa+P9FOF7Ban s82W2adjBkht
iYgMlP+PCfpZzERKe4JCDrCw7n8esxIax+I/KM7mPTrjxeNdzgn1qazucKCV BFiGNV3x6FL1
p8SNQR78MeAnABi4wacBPwP83K+SvqVU1njMQaMWicqZp5ATRIwadUJpeMdQ LibMYhlq2C9i
PVjXRxWoQ7Rd/DIUG96S124r5gk1zYEOTTPyh5Id02Z/xRrttaetbbqgF2n8 NWuqLpzGhm00
Zxx7kchnOBRZVG3Mg/csjb9hxayw0+hOdWc1bJhZmetZin/LWpnpmGJjZDy/ qmfp/Z14eifM
Hqb39ywfIpxe13lSLUu3ete+/sBy7dgpDYaG9CKpf2RNA0aSapruCnDPkvkn DosVXLjrRRr/
HJpUYaaxVupZ+v7CWqoKp89ojFTwQHFDz9L5V9biQyidgTXUXiTxWdZAMpTE sem6Zjptu3eK
/BuHIgNrn71I4nMcdTI8KuxFOv/OYSbrpjHeYzP5PF8yg3GCvUjmP7hK3ZjQ sU2shwOOf3I4
86ZWdlwNc7pniXyBo5UH1mp7kcR/cZhLS6v0uPH8m7XgGk6lPV3pnbP2Hw49 2qrTgdum1rtU
/pfDV7PVcjOIsQdpzBAeTWrVekW1e2cnMworwCCSyqmedd+ZAY4ENmeue5HA QY4OMTTJ24tk
ZhSylj+Z7qyuZppYl+thI5rB0dCD0Re9SOMW8a6GG8XRaRzOOWma2TJeEeFQ EXEC7zMn1TL7
/NCrNFkcLz/dhQiFbkYa9DpkJXSgCkeyn+pSiMKLZVkn9fJM+oiZlAETmzu+ YBle/wXgl4Bf
AX4NwGL74G8AvwVgEX3w94A/AP4I+BMAq0yDfwH8FfAs4G+A5wB/BzwP+Afg n4AXAP8C/Bvw
H8B/B5A+AE7cyeAorQwWsTIZwAwAVr4yW3oZ2GbAX9h/esBb8aeL/a3IAOWp ARI4rceNEdh9
IGadP7Iktr3gOr9Xz0Lr/GudX4eG8v6iWAH2eCZrydt7vX0Za3uhLim8uur3 PLT6x3dKcSFm
HUJl+FeyM7NiXNn2Nebgck4fZHp2zOoQM9ORuYQ+UMBWfKVe0dRao94vmd6a tUshmmmnP3E8
Oq2i4Ue/5H0bvhrflves7oxg+0UB28oooDn47AMFzIlZVQwroBU+1i85nxsz PI7PeVat1Qy7
NajvAyVsx4ol66yEEdXSi/2S/3msjbad8+/GLk/3iwa2Z20c76yBVsxR37WH +Qo5WlYb9L9n
NDRzup96yAUKOVhWI/3UUS4U7y5aFaJflLBIIeukldA6pLNf1LFYIYdIq6Of jMSSmKi/Doro
J9uwNCaIkJl9nAjULxnfIWYlrD3jJaPY6KdR845c0yRadbTgfNsvmd6Jq6i1 WtEo6bW+mRLc
mWt4TC3amForVTSzX3K+C2svEzvnfeXi7BoTnhXaVKaaVv+U9W5cU6Bunmls mr8Zpg/yvjtX
3x0OF+2DjC+LCWIIZ9yoq2XV7huXZTlneffd4s4erFMJO2W8L2d99+QaxjO0 0E9u+15cs55B
JfSbC78317x3UAOjhllV+yb/+7DOMeuY/2ZIaB/kfl+uAVyfOTr7cTm2gaD+ Psjz/lydvXco
XD9NyK1QSJ47445dK4710aA9y2XcvMw7+StusIpq30xKH8A6zzGae0vrv7F7 LiZkuj3r9CrB
fslyPmajVijLfdR5F7gmppDjrNmo9M94fYhrAtaLWu6bocowV2mHdtv0Qb5X cnXgoe07/ZL5
VVyD9PDepYpRLveRF7Oaa4gac8xXH+R/jUIOFcs/9q65l0joG/vKGKz1bltk qiLatwtsANvG
u2NRravFMS07pTV3D+GRmfQZxhmj5HGlG7uHurCD6f+1AUl0D1fbXrhxrUrj G5QQTUiR9JuU
+44Ej7odaKkRKjyBmQJPhY40jtzvgW+XsFMxVWWeVxtKxEH4NjJkaSWitbUP 1bds8ulG6c5R
0FKbswrY8jQTMAswG7AVAHeOZrAHKrMtYA4AB5lmcJBpBiehZrDfKTMfgLNT MwsBiwCLAUsA
SwE7ALBrKoNdU5mdAbsAdgXsBsCGqQw2imWWA/YA4NzVzF4AbLHK7APYF7Af YH8A7kfP4H70
zAGAHCAPoNnCwbaZYcBKwCrAagBOLMys9XQxixoJ2tAH/O1cdHfXCbTO0GKn OvaV1mlP13yF
HCOwp2vScm+wzA35u7lyKwuF/Fp/N9dSmNQDGdVj0mrfxzVfwKCiMmQOYtij gFCv/snJPjh0
KHNYtmMyVDnJhzCOqAhLbq0BCYt/CePwx6B4v/sSFnwoY+gbEuzdCS4n/zBG 7EdQvhvHNpHP
tR/XIsxzOCN4rjNPa6pSmOwIcbJmpJ4w2TrG9GsMma3XStqUHM2RjPm+jjQp 9HeUMJe8+o7m
roC2OmXUjKpkBTyGu074PCkUeKw4mbwGj+MurUYJF9SmacbHM65vTeZKockT 5AjltXki4yzC
dsJa8wA9YeEnJfSdbm8vJ/uljHnhNtmh6B5hgpcxjqwJEqSrWS9P6PrlS/Tk hHRPWqMwYpJF
ekpCuict2XSfmijZlHAqvEfndWFkG3GoXBbN9htJ+yAEn1HmCSPP4n8RT9XS TGdgyylDuQL/
i+jLu1g1q9UmooKix50Q5jEbOIaGhgW2vR292oZEzlnBKNH1h5OHiOR5vD57 XJ1QpxzKUqUp
PtN6hc7eBNiC8xqoacPjSihBrDQKTkn4o0ESmJJgDjs9TfMoOXLKhDdsHTXV qobBsMUxeF0e
KS6aGf82XY56fE+n6RUnK7pp1BASxFPyC5jzAwkFTyJZEJ9ZIB2uDBhsL8ZW 1t0rA0Rnlkrs
CZr50SYTqL/xBbiQ/kaH+gcCMFzOHAw4BPASwKGAwwCHA44ArAMcCTgKcDTg GMCxAFyikjke
gIF45kTASYCXAl4GeDngZMApgFO9nMz2B/PkWWpTaLNsju2X0xrjD+vd2wsW krZhfeRKlgUK
OVZoWO9eXZDPrfTG9avyzhg/v9If1y9Hz3CaQnZkvNk+sF8g2t+8gjlEDp6+ 78D0Rq+jFBb/
SkajbxPfXNwRFv0qxqphRHTK5L+asVYVz4GAylG9LEf1GkbkYiJVy8cW5nst I2gqyheY1xFm
eB1zjMxmSJGR07nqQVuYpzDH6xnTuPEcKTLzhqTm6K8Hyolfz6UreoOBdBbe yAhBjHIER1TC
FCpjV0csRapWOcI4RSWJKYXuily6q5vGqF6RNJsl5tRLDEWKrGjM2ZA4Hm9p SLZCjCpkjQRZ
iuyVFXK4LCN8TK1i1CVLcEwhh0lTVzXLUsuSzDpjVzg3M6Zq5GjH09DCKZWj 3cDVQ5pa3TAl
u5UKVw/pMqSoq1XmckKYpjnXIiy/xiVfviAMLnMP+VnbVJ3RiyXrDde5+kfK 5Iy35DjO4Ori
/f3VwuJNri4EMRYloypHYXFpCRTj6lRdjsNmRMexOazimFZV5VgaSWWRzm2c YE4rt92GIG88
JpNKwQ+YlGx53qNbd2HOMO28UVdm+LoUT9OFaTTGonGpkuZUXldGwnQVnTSW mG2cDSZ03t40
o5+KTGtiKqjmOYHJSXVKb6UqMCnVyoj7jngoimxwF/2NxoycBngF4JWAVwFe DXgN4LWA1wFO
B7we8AbAesAbASpgBFAElAAaYBRQBowBdMA4YAMAEWqZKqAGMAB1wBkAE2AB bEADMAGY9HIx
w5+scmen5lN9+FlTOoSaLFTIcUJzUqUKPTo4n8v5VwQXcvlCftiflEJQXmYq ZhrQnegTMDc0
GnCaOVvktI0RvYazN7Jjtl2XE72REXMaEd2ynWWtppnN8YgIG7XNb2LOF8Sy NV07YaI3ixE1
fTxhorckFU3V6Q/kiuatSXmA6G4o621iRPLKenuSsixDlazH70iqxxDdtXr8 ziSNtbPJF827
xIjki+bdjLMhKFFTthdcNaJXdHtajuQ9zFX5IEnKcnkvc16aSRA6m06Y6n3M 6IUglXypv585
VgnLpl8Nj8tRfCAx+fJ16YPMZeOSpEi/o94yzaKi7C3iXYhXF3QrUw8qZB1A ychnGr08BZgG
wOfKvAnwZsBbAG8FvA3wdsA7AO8EvAvwbsB7AO8FvA/wfsAHAB/0CGcMeIuM gYsiHvdT0cm/
W6SQ4wX9uyy9Mr2QjbkwfW/U8Q8xRl/eu+0rj4tEW8+HmdNr7ZLb7icXZvhI nHlpYyipdedX
cQraHX80zhCzKKRzQ6k+FtdFMqlaZ1kLE32cGVoYR+THXchxfYK5vhLHZdW1 ou4MkzdqJTm6
TwoVF04I8btoYapPMQPQwlSWZEbOZE6PRaWnq3KfjnOWwiwlzdLLNTmSs5jB nrEkWGSraWly
dTZzpT2eEBGmRbt5768w3zlcdbzFB6a6atqS2TtXIQdJ0WVbWyGESc9jLsAl kBoVvejf8SbM
eD5zfTGecVQvN0xZsgsEySrqtNGQLcALeVvdqFpUS5ocySZeAxK86U+Y5SLe atG68S9rpWrc
F3P1+diO6vvowhSX8FBId4vUc7mUxzcqOV2hUZZkuIy58hFikLd5l/PU4dA2 JmGSK+KG2UGS
Ub1ia+J9OFXSlcyFzRCBXpR2UK9iLmyG5FfUEc07sKwk7adeHTdtxL7qPGUj vIan9J1O1agV
9Yps4VzL0wxNzb3URI7iOp4KFjhXTJjgeh6f3jvOKdVQ6Aae8qdzbG3HDEiy 3chjXJq7+4XF
38QjXsq+U/E38xhf2bEBZbiFhyF4FbAww608o48pidGH/+geXZkzEtg3EZrI eV4s+D4UBp+P
zJWVtdHkRA+c2Zx48t+j9/tyTFndG8mu+M3AkrfpLmx/jfbqhslTRi9EVpo3 4zXKy0Ivp7kH
OfUhGJETTcQuUpaMPWjOCbtfdeEu4NTXEccdBxNUBDv2YB7v/DRry0qKvSbi p2UMtCXAPS0j
7kibds5QsAP9dm4k/dRSxRxjEsr8UXh5Eetln7zj+wObIpP7SLtYqIngxL5M dEu4ordNOVfs
DX734jpzeq3M0fCfhKCdw4IcQyIkZnCubIBKDxc49mTZ3aB7b6sjI1qJQ4nP xLYfVvhWdJMm
ifQgjFgltuGcH6kIspFfC6L8fLZ7cST1IvefOx96Es2HAB8GfATwUcDHAB8H 4KLwzCcBnwKc
Cfg04CzA2YBzAOcCzgOcD7gAcCFgE+AiwMWASwCXAi4DXA7AlrbMlYCrAFcD rgFcC7gOcD3g
BsCNgJsANwNuAdzq5WyXAX9him6Qy1OfiLo31EmhLgd1HKgLQLty2gfTfpT2 hrQnor0J7ROo
gaeGmlpaai+p3aPGizZj2ghpq6Itg1ZyWjVpJaHF5Cu80/rYYtH1MXd1LHja zppCoZAvrPLX
x2bC0b4tZGO8d1vDEDfmfbGoA397whEwTqv2moKc/DsSjsZx5AfOJRAWfycz OLVdfOhoAmGO
uxK2+DscGASKS6dzGHcnHFECj9TqQi7uSThJpsnjG285mnsTTrigNF4ospBw 79GZ0sOTzX3W
HisiN9KEg91MYldBeDq5DgG53dsWn/IcAumhHioA+onbALcD7gDcCbgLcDcA u6gz93pvbul3
FqFoVnfD9fO+4E4mfYlCThQz6dpUveJUENMz7Cvbj1GDzBloLPclWBZfDFXK EtGmeH+CZfGl
Z0fVCcdLtb0mL8zzAHMWlsETMPTCJA8mGPoWiVFv1OU4HuJVmG2qNau5o0KI x3t00YvDHrWJ
GNMqdWccUHePRmm+g58lEpJIfzxH+CaLAsykC9Zj80etvSj2lfS270h3bk2q aZXNcmpNt3af
BBI2QIKfbna/kU4jIil5qo7+r0uH03Rpy5PM7AfHmPuJuDE3ccMgM/cB7gc8 AHgQ8JD3cvPQ
FtdzeK7pNKxpOhILfW/CHTkuJm3eROTQlqWCh7ZoI97+mEIzfNIZH+Zy/vAw g67rYcb51o4r
P64VbYRvaG5PtVSgp6KDk0dYZ8FoI+0RmSJSaT/7KGtZKiA1W9KcjnZaHfHv nhBmeIw1qg0y
YJDTOuBcSL736LZdWZhK7QR0z6ikTkr6s7JSTiB3/QRsVtcvcXCc3MnmHQq3 apQaFY1zOWVZ
Op8pEvvgpaHNunAucSj7y5r5rnRUkA3b/vD/2LsOOEmK6t19d7uzF8kgOWdu mJndvb0lH3cH
HDlnOHpnenfnbhITNqCAgAoiWTJKEJAgGUQwkoOiCKa/WVQEEREBBZXw7686 V1d3V1XPHkcY
f3zu7U5/r7rq1atXr15VAR4EPAR42PrbVMfK/9OZH5KfyKlc5LiujclLWKWK tPJrq8peYlbe
jAPC0Nt58nMyfdk53Y6hh+mZ8ghr4YM87DfKa4ua+kdZOSh+Yl+qgJAA6zNz +bCZkgGkBAvU
y6HrtwqjsTkKsVZ77VJA5ZjWJfyN3PVP9a2JsVaBiY81AFBOJtP8TzqqjU62 rAnHL2DmsJgx
5VHrN9N8ts5cTHnZsXprObbuLdvg4VUiDd46YgbPzGsg8bFuzzUDc7Lwcy2D tyns0mOhSRHk
PdcRtXOPMwxow+rQXgPqEHNdejNZ5mYb/utrnmD0FKrQvry95arwTzJWHujC W1dEa41GsdFc
/l7h+4zIYMgrePPYl6t3+AEjNTPkHTwr+HQ3Wx7e5ClGLDj4JvW6mVu8/JX/ h4w1Ubr8BX2g
NbT8Ff1HHIaooNeLI9bOueWq8E8z/AO68GbKk53Tu1wV/8eMoAar+Fa28HJV 9mcYa0SBslfy
VXIGw/Joc57l0R3fCQjLVfF/wqE7g9V6WVsOB9+fclT98LgxYBnj7tLlr/g/ 46h6Y7itLI9q
83OObktnpixXL/ALDsfN8wLLpen5Pw53x5rfLpe255d85femHS1X5f8VYx83 o/zYqVNlbDdc
rt7l14zjhPneJT1Q17WltWqxshwOEb9h7O2Peq3l2mb9lmOi5n0Z39VIy9Wb /I5xDEbUmzSa
46XlcOb8ew4HxNlluvwV/w+MQwVCi0+dkL5cvchzHJ6UZ5fsclX2P3LoUEMv La9j+J8YS/aB
4tf0Usm+Pn65Kv2fOaIWTW2oWBmsLn+Ff56x6BMovL3Hebkq+V8Yax90yZdH h/sFjhpfPkNE
L3LM17BJK62P6JXmcuj7/DX8BczNZVFRdt4loJfCzQG9g01cgPWZmWi9OOEG bl/CCYkkp3mW
uScdGZAtto1bpVfJRbaxSa/Lt3MDd6Kd5Il3f7c3JRwlEEugSpiYLXXeJW6y n/IY4HHAE4An
Ad8HYFfelKcAPwT8CPA04MeAZwBYu57yE8BPAT8D/BzwC8D/AX4J+BXg14Df AH4L+B3g94A/
ALB/cAp2Ek75E+DPgOcBfwG8AHgRgC2BU16yXmWGvXZO9iVOOpL0BKLTzsr6 c0RFSDPbS+5m
EmncYZvrqso+govqUBuSR5RzE0b9y+rrwwb+LUJdTYUUtaovM/JCbEb/0rpD zTXipBglxYhD
OpbAYGSdpBBxNEH4ABZ8phFagNCx7e8hUwBfBaXzJV2rWDtYPqIV9UpIwNBf Ub4rUz6iNfUP
rpqyF9Y+yjX1KiM9OLymXPf+I1pd/2Qc28iorrG8XnOzjj6idfVaSH6Tv65w Z9xAa3DQPlrv
I1pZr4cEkqjKcpeiP6L19AbjcOxgPeGkGXKa7rBWKdgnHH5Ea+xfXCYLNWbu W/wo19W/QyIg
/rpyz2n+iFbTmyHZA4xq+rgDTnmLy7R/3Pn+w+Uv0EvUH9HK+i9nZTmLyB/l yvpfSKZKaGV9
PIk2au3tkHyL8FrzrJ58ROvsHcaB+zF19vFc0ai3d0NyMcLr7SPvhL0nXGVN rbH0o6xlHQrX
5NFXZXYCwUe0xlSuCdFHXrEmhWRgUdX0EVemyVyRCNRSut4qfaT9+44pXBrV qhSqH+Va6uCr
pY/2okVHJ9dqmJUSoX+UayrFOC7Kqamg+eZMAejoYpxS59C6Z+QK804NicOF 71v+qDau9Um1
5aCVFb0UnPlnJ6ntyGNaJ0DgWT7jKMVjUeduCJ5K934kReH88yl/AyCxaMrf Aa8A/gF4FYAk
oimvAV4HvAH4FwBH1E15E4AUoyn/AfwXgKSkKW8D3gG8C3hvEqYLABWAg0I6 JgNwUFIHTsfr
6ATgFN0OHL3bMdUqbOck6wQR9SQ7p0l9jDuxaT2xI3WHm2XrFuGMJ69pbq4/ l8k6eU24BLtj
Re: .log file [message #375605 is a reply to message #375604] |
Thu, 14 February 2008 08:54   |
Originally posted by: johnmc.cs.clemson.edu
--------------000504090505070809060109
It is attached.
John
> Hi John,
> Thanks for helping. I'm still out of luck. I open your workspace, find
> two closed projects. I open the demo cquery and materialize without
> problems. I even tried downloading the 3.4M3 (i.e. the Build Id
> I20071101-2000 that you are using) but I still cannot provoke the error.
> Can you please attach a copy of the content from your "Help" -> "About
> Eclipse SDK" -> "Configuration Details"? Our configurations must differ
> in some way.
> Thomas Hallgren
>> Thomas,
>> John
name="eclipseConfig.txt"
Content-Disposition: inline;
filename="eclipseConfig.txt"
*** Date: Thursday, February 14, 2008 8:51:18 AM ET
*** Platform Details:
*** System properties:
awt.toolkit=3Dsun.awt.windows.WToolkit
eclipse.buildId=3DI20071101-2000
eclipse.commands=3D-os
win32
-ws
win32
-arch
x86
-showsplash
C:\eclipseTopcased\\plugins\org.eclipse.platform_3.3.100.v20 070807\splash=
=2Ebmp
-launcher
C:\eclipseTopcased\eclipse.exe
-name
Eclipse
--launcher.library
C:\eclipseTopcased\plugins\org.eclipse.equinox.launcher.win3 2.win32.x86_1=
=2E0.0.v20070523\eclipse_1017a.dll
-startup
C:\eclipseTopcased\plugins\org.eclipse.equinox.launcher_1.0. 100.v20071029=
=2Ejar
-vm
C:\Program Files\Java\jre1.6.0_02\bin\client\jvm.dll
eclipse.ee.install.verify=3Dfalse
eclipse.product=3Dorg.eclipse.sdk.ide
eclipse.startTime=3D1202959847140
eclipse.vm=3DC:\Program Files\Java\jre1.6.0_02\bin\client\jvm.dll
eclipse.vmargs=3D-Xms40m
-Xmx256m
-XX:MaxPermSize=3D256m
-Djava.class.path=3DC:\eclipseTopcased\plugins\org.eclipse.e quinox.launch=
er_1.0.100.v20071029.jar
eof=3Deof
file.encoding=3DCp1252
file.encoding.pkg=3Dsun.io
file.separator=3D\
java.awt.graphicsenv=3Dsun.awt.Win32GraphicsEnvironment
java.awt.printerjob=3Dsun.awt.windows.WPrinterJob
java.class.path=3DC:\eclipseTopcased\plugins\org.eclipse.equ inox.launcher=
java.class.version=3D50.0
java.endorsed.dirs=3DC:\Program Files\Java\jre1.6.0_02\lib\endorsed
java.ext.dirs=3DC:\Program Files\Java\jre1.6.0_02\lib\ext;C:\WINDOWS\Sun\=
Java\lib\ext
java.home=3DC:\Program Files\Java\jre1.6.0_02
java.io.tmpdir=3DC:\DOCUME~1\johnmc\LOCALS~1\Temp\
java.library.path=3DC:\eclipseTopcased;.;C:\WINDOWS\Sun\Java \bin;C:\WINDO=
WS\system32;C:\WINDOWS;C:\Program Files\Java\jre1.6.0_02\bin\client;C:\Pr=
ogram Files\Java\jre1.6.0_02\bin;C:\Program Files\CollabNet Subversion Se=
rver;C:\Program Files\CollabNet Subversion Server\httpd\bin;c:\ruby\bin;C=
:\texmf\miktex\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS \System32\Wbe=
m;C:\Program Files\Rational\common;C:\Program Files\ImageConverter Plus;C=
:\Program Files\Common Files\GTK\2.0\bin;C:\Program Files\MATLAB\R2007b\b=
in;C:\Program Files\MATLAB\R2007b\bin\win32;"C:\Program Files\Graphviz2.1=
6\Bin";C:\Program Files\OpenDX\bin_intelnt;C:\Program Files\Mozilla Firef=
ox;C:\Program Files\CollabNet Subversion Server;C:\Program Files\CollabNe=
t Subversion Server\httpd\bin;c:\ruby\bin;C:\texmf\miktex\bin;C:\WINDOWS\ =
system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\Rational\co=
mmon;C:\Program Files\ImageConverter Plus;C:\Program Files\Common Files\G=
TK\2.0\bin;C:\Program Files\MATLAB\R2007b\bin;C:\Program Files\MATLAB\R20=
07b\bin\win32;c:\jre1.5.0_04;C:\Program Files\SSH Communications Security=
\SSH Secure Shell;c:\ant\bin;C:\Program Files\ImageConverter Plus;;C:\Tul=
ip_3.0.0B6;C:\Tulip_3.0.0B6\lib
java.runtime.name=3DJava(TM) SE Runtime Environment
java.runtime.version=3D1.6.0_02-b06
java.specification.name=3DJava Platform API Specification
java.specification.vendor=3DSun Microsystems Inc.
java.specification.version=3D1.6
java.vendor=3DSun Microsystems Inc.
java.vendor.url=3Dhttp://java.sun.com/
java.vendor.url.bug=3Dhttp://java.sun.com/cgi-bin/bugreport.cgi
java.version=3D1.6.0_02
java.vm.info=3Dmixed mode
java.vm.name=3DJava HotSpot(TM) Client VM
java.vm.specification.name=3DJava Virtual Machine Specification
java.vm.specification.vendor=3DSun Microsystems Inc.
java.vm.specification.version=3D1.0
java.vm.vendor=3DSun Microsystems Inc.
java.vm.version=3D1.6.0_02-b06
line.separator=3D
org.eclipse.equinox.launcher.splash.location=3DC:\eclipseTop cased\\plugin=
org.osgi.framework.executionenvironment=3DOSGi/Minimum-1.0,O SGi/Minimum-1=
=2E1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5,JavaSE-1.6
org.osgi.framework.language=3Den
org.osgi.framework.os.name=3DWindowsXP
org.osgi.framework.os.version=3D5.1.0
org.osgi.framework.processor=3Dx86
org.osgi.framework.system.packages=3Djavax.accessibility,jav ax.activation=
,javax.activity,javax.annotation,javax.annotation.processing ,javax.crypto=
,javax.crypto.interfaces,javax.crypto.spec,javax.imageio,jav ax.imageio.ev=
ent,javax.imageio.metadata,javax.imageio.plugins.bmp,javax.i mageio.plugin=
s.jpeg,javax.imageio.spi,javax.imageio.stream,javax.jws,java x.jws.soap,ja=
vax.lang.model,javax.lang.model.element,javax.lang.model.typ e,javax.lang.=
model.util,javax.management,javax.management.loading,javax.m anagement.mod=
elmbean,javax.management.monitor,javax.management.openmbean, javax.managem=
ent.relation,javax.management.remote,javax.management.remote .rmi,javax.ma=
nagement.timer,javax.naming,javax.naming.directory,javax.nam ing.event,jav=
ax.naming.ldap,javax.naming.spi,javax.net,javax.net.ssl,java x.print,javax=
=2Eprint.attribute,javax.print.attribute.standard,javax.prin t.event,javax=
=2Ermi,javax.rmi.CORBA,javax.rmi.ssl,javax.script,javax.secu rity.auth,jav=
ax.security.auth.callback,javax.security.auth.kerberos,javax .security.aut=
h.login,javax.security.auth.spi,javax.security.auth.x500,jav ax.security.c=
ert,javax.security.sasl,javax.sound.midi,javax.sound.midi.sp i,javax.sound=
=2Esampled,javax.sound.sampled.spi,javax.sql,javax.sql.rowse t,javax.sql.r=
owset.serial,javax.sql.rowset.spi,javax.swing,javax.swing.bo rder,javax.sw=
ing.colorchooser,javax.swing.event,javax.swing.filechooser,j avax.swing.pl=
af,javax.swing.plaf.basic,javax.swing.plaf.metal,javax.swing .plaf.multi,j=
avax.swing.plaf.synth,javax.swing.table,javax.swing.text,jav ax.swing.text=
=2Ehtml,javax.swing.text.html.parser,javax.swing.text.rtf,ja vax.swing.tre=
e,javax.swing.undo,javax.tools,javax.transaction,javax.trans action.xa,jav=
ax.xml,javax.xml.bind,javax.xml.bind.annotation,javax.xml.bi nd.annotation=
=2Eadapters,javax.xml.bind.attachment,javax.xml.bind.helpers ,javax.xml.bi=
nd.util,javax.xml.crypto,javax.xml.crypto.dom,javax.xml.cryp to.dsig,javax=
=2Exml.crypto.dsig.dom,javax.xml.crypto.dsig.keyinfo,javax.x ml.crypto.dsi=
g.spec,javax.xml.datatype,javax.xml.namespace,javax.xml.pars ers,javax.xml=
=2Esoap,javax.xml.stream,javax.xml.stream.events,javax.xml.s tream.util,ja=
vax.xml.transform,javax.xml.transform.dom,javax.xml.transfor m.sax,javax.x=
ml.transform.stax,javax.xml.transform.stream,javax.xml.valid ation,javax.x=
ml.ws,javax.xml.ws.handler,javax.xml.ws.handler.soap,javax.x ml.ws.http,ja=
vax.xml.ws.soap,javax.xml.ws.spi,javax.xml.xpath,org.ietf.jg ss,org.omg.CO=
RBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.portable,org.omg.COR BA.DynAnyPack=
age,org.omg.CORBA.ORBPackage,org.omg.CORBA.portable,org.omg. CORBA.TypeCod=
ePackage,org.omg.CosNaming,org.omg.CosNaming.NamingContextEx tPackage,org.=
omg.CosNaming.NamingContextPackage,org.omg.Dynamic,org.omg.D ynamicAny,org=
=2Eomg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny.Dy nAnyPackage,o=
rg.omg.IOP,org.omg.IOP.CodecFactoryPackage,org.omg.IOP.Codec Package,org.o=
mg.Messaging,org.omg.PortableInterceptor,org.omg.PortableInt erceptor.ORBI=
nitInfoPackage,org.omg.PortableServer,org.omg.PortableServer .CurrentPacka=
ge,org.omg.PortableServer.POAManagerPackage,org.omg.Portable Server.POAPac=
kage,org.omg.PortableServer.portable,org.omg.PortableServer. ServantLocato=
rPackage,org.omg.SendingContext,org.omg.stub.java.rmi,org.w3 c.dom,org.w3c=
=2Edom.bootstrap,org.w3c.dom.events,org.w3c.dom.ls,org.xml.s ax,org.xml.sa=
x.ext,org.xml.sax.helpers
org.osgi.framework.vendor=3DEclipse
org.osgi.framework.version=3D1.4.0
org.osgi.supports.framework.extension=3Dtrue
org.osgi.supports.framework.fragment=3Dtrue
org.osgi.supports.framework.requirebundle=3Dtrue
os.arch=3Dx86
os.name=3DWindows XP
os.version=3D5.1
osgi.arch=3Dx86
osgi.bundles=3Dorg.eclipse.equinox.common@2:start, org.eclipse.update.con=
figurator@3:start, org.eclipse.core.runtime@start
osgi.bundlestore=3DC:\eclipseTopcased\configuration\org.ecli pse.osgi\bund=
les
osgi.compatibility.bootdelegation=3Dtrue
osgi.configuration.area=3Dfile:/C:/eclipseTopcased/configura tion/
osgi.framework=3Dfile:/c:/eclipseTopcased/plugins/org.eclips e.osgi_3.4.0.=
v20071031.jar
osgi.framework.beginningstartlevel=3D1
osgi.framework.shape=3Djar
osgi.framework.version=3D3.4.0.v20071031
osgi.install.area=3Dfile:/C:/eclipseTopcased/
osgi.instance.area=3Dfile:/C:/Documents and Settings/johnmc/workspace/
osgi.instance.area.default=3Dfile:/C:/Documents and Settings/johnmc/works=
pace/
osgi.logfile=3DC:\Documents and Settings\johnmc\workspace\.metadata\.log
osgi.manifest.cache=3DC:\eclipseTopcased\configuration\org.e clipse.osgi\m=
anifests
osgi.nl=3Den_US
osgi.os=3Dwin32
osgi.splashLocation=3DC:\eclipseTopcased\\plugins\org.eclips e.platform_3.=
osgi.splashPath=3Dplatform:/base/plugins/org.eclipse.platfor m
osgi.syspath=3Dc:\eclipseTopcased\plugins
osgi.ws=3Dwin32
path.separator=3D;
sun.arch.data.model=3D32
sun.boot.class.path=3DC:\Program Files\Java\jre1.6.0_02\lib\resources.jar=
;C:\Program Files\Java\jre1.6.0_02\lib\rt.jar;C:\Program Files\Java\jre1.=
6.0_02\lib\sunrsasign.jar;C:\Program Files\Java\jre1.6.0_02\lib\jsse.jar;=
C:\Program Files\Java\jre1.6.0_02\lib\jce.jar;C:\Program Files\Java\jre1.=
6.0_02\lib\charsets.jar;C:\Program Files\Java\jre1.6.0_02\classes
sun.boot.library.path=3DC:\Program Files\Java\jre1.6.0_02\bin
sun.cpu.endian=3Dlittle
sun.cpu.isalist=3Dpentium_pro+mmx pentium_pro pentium+mmx pentium i486 i3=
86 i86
sun.desktop=3Dwindows
sun.io.unicode.encoding=3DUnicodeLittle
sun.jnu.encoding=3DCp1252
sun.management.compiler=3DHotSpot Client Compiler
sun.os.patch.level=3DService Pack 2
user.country=3DUS
user.dir=3DC:\eclipseTopcased
user.home=3DC:\Documents and Settings\johnmc
user.language=3Den
user.name=3Djohnmc
user.timezone=3DAmerica/New_York
user.variant=3D
*** Features:
edu.cmu.sei.osate-frontend (1.5.3) "Aadl OSATE"
edu.cmu.sei.osate-frontend.source (1.5.3) "pluginName"
edu.cmu.sei.osate-plugins (1.5.2) "Aadl OSATE"
edu.cmu.sei.osate-plugins.source (1.5.2) "pluginName"
fr.obeo.acceleo (2.1.0.200707131240) "Acceleo Generator Ui Plug-in"
org.eclipse.cvs (1.0.100.v20070824-7C79Do9EI99hAWDX) "Eclipse CVS Client"=
org.eclipse.cvs.source (1.0.100.v20070824-7C79Do9EI99hAWDX) "Eclipse CVS =
Client SDK"
org.eclipse.datatools.connectivity.feature (1.6.0.200712121) "Data Tools =
Platform Connectivity Plug-in"
org.eclipse.datatools.connectivity.oda.designer.feature (1.6.0.200712121)=
"DTP ODA Designer UI Framework Plug-in"
org.eclipse.datatools.connectivity.oda.feature (1.6.0.200712121) "DTP Ope=
n Data Access"
org.eclipse.datatools.doc.user (1.6.0.200712121) "Data Tools Platform Use=
r Guide"
org.eclipse.datatools.enablement.apache.derby.feature (1.6.0.200712121) "=
High-level Sybase Enablement Plug-in"
org.eclipse.datatools.enablement.feature (1.6.0.200712121) "Eclipse Data =
Tools Platform Enablement"
org.eclipse.datatools.enablement.hsqldb.feature (1.6.0.200712121) "Eclips=
e Data Tools Platform Enablement"
org.eclipse.datatools.enablement.ibm.feature (1.6.0.200712121) "Eclipse D=
org.eclipse.datatools.enablement.jdbc.feature (1.6.0.200712121) "High-lev=
org.eclipse.datatools.enablement.msft.feature (1.6.0.200712121) "Eclipse =
org.eclipse.datatools.enablement.mysql.feature (1.6.0.200712121) "Eclipse=
org.eclipse.datatools.enablement.oda.designer.feature (1.6.0.200712121) "=
Eclipse Data Tools Platform XML ODA Designer"
org.eclipse.datatools.enablement.oda.feature (1.6.0.200712121) "Eclipse D=
ata Tools Platform XML ODA Runtime Driver"
org.eclipse.datatools.enablement.oracle.feature (1.6.0.200712121) "Eclips=
org.eclipse.datatools.enablement.postgresql.feature (1.6.0.200712121) "Ec=
lipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.sybase.feature (1.6.0.200712121) "High-l=
org.eclipse.datatools.intro (1.6.0.200712121) "Eclipse Data Tools Platfor=
m Intro Plug-in"
org.eclipse.datatools.modelbase.feature (1.6.0.200712121) "Eclipse Data T=
ools Platform SQLModel Plug-in"
org.eclipse.datatools.sqldevtools.feature (1.6.0.200712121) "Eclipse Data=
Tools Platform SQL Tools Common UI Plug-in"
org.eclipse.emf (2.3.1.v200709260024) "Eclipse Modeling Framework (EMF)"
org.eclipse.emf.codegen (2.3.1.v200709260024) "EMF Template Code Generato=
r"
org.eclipse.emf.codegen.ecore (2.3.1.v200709260024) "EMF Ecore Code Gener=
ation"
org.eclipse.emf.codegen.ecore.ui (2.3.0.v200709260024) "EMF Ecore Code Ge=
neration UI"
org.eclipse.emf.codegen.ui (2.3.0.v200709260024) "EMF Template Code Gener=
ator UI"
org.eclipse.emf.common (2.3.0.v200709260024) "EMF Common"
org.eclipse.emf.common.ui (2.3.1.v200709260024) "EMF Common UI"
org.eclipse.emf.converter (2.3.1.v200709260024) "EMF Model Convert Suppor=
t"
org.eclipse.emf.doc (2.3.1.v200709260024) "Eclipse Modeling Framework (EM=
F) Programmers Guide"
org.eclipse.emf.ecore (2.4.0.v200709260024) "EMF Ecore"
org.eclipse.emf.ecore.edit (2.3.0.v200709260024) "EMF Ecore Edit Support"=
org.eclipse.emf.ecore.editor (2.3.1.v200709260024) "Sample Ecore Editor"
org.eclipse.emf.ecore.sdo (2.3.0.v200709260024) "EMF Service Data Objects=
(SDO)"
org.eclipse.emf.ecore.sdo.doc (2.3.1.v200709260024) "EMF Service Data Obj=
ects (SDO) Programmers Guide"
org.eclipse.emf.ecore.sdo.edit (2.3.0.v200709260024) "EMF Service Data Ob=
jects (SDO) Edit Support"
org.eclipse.emf.ecore.sdo.editor (2.3.0.v200709260024) "EMF Service Data =
Objects (SDO) Editor"
org.eclipse.emf.ecore.sdo.source (2.3.0.v200709260024) "EMF Service Data =
Objects (SDO) Source"
org.eclipse.emf.edit (2.3.1.v200709260024) "EMF Edit"
org.eclipse.emf.edit.ui (2.3.1.v200709260024) "EMF Edit UI"
org.eclipse.emf.mapping (2.3.0.v200709260024) "EMF Mapping "
org.eclipse.emf.mapping.ecore (2.3.0.v200709260024) "Eclipse Modeling Fra=
mework (EMF) - org.eclipse.emf.mapping.ecore"
org.eclipse.emf.mapping.ecore.editor (2.3.0.v200709260024) "Eclipse Model=
ing Framework (EMF) - org.eclipse.emf.mapping.ecore.editor"
org.eclipse.emf.mapping.ui (2.3.0.v200709260024) "EMF Mapping UI"
org.eclipse.emf.ocl (1.1.1.v200709211511-1007w31181_322622) "Object Const=
raint Language (OCL) 2.0 Compatibility API"
org.eclipse.emf.ocl.doc (1.1.0.v200706071450-10-7w311817182561) "Object C=
onstraint Language (OCL) 2.0 Compatibility API Documentation"
org.eclipse.emf.ocl.source (1.1.1.v200709211511-1007w31181_322622) "Objec=
t Constraint Language (OCL) 2.0 Compatibility Source"
org.eclipse.emf.query (1.1.0.v200706071712-10-7w311817182823) "EMF Model =
Query"
org.eclipse.emf.query.doc (1.1.100.v200709201851-218Y8s733G3H5_5H96) "EMF=
Model Query Documentation"
org.eclipse.emf.query.ocl (1.1.0.v200706071712-10-7w311817182823) "EMF Mo=
del Query OCL Integration"
org.eclipse.emf.query.ocl.source (1.1.0.v200706071712-10-7w311817182823) =
"EMF Model Query OCL Integration Source"
org.eclipse.emf.query.source (1.1.0.v200706071712-10-7w311817182823) "EMF=
Model Query Source"
org.eclipse.emf.search (0.6.0.v200710151101) "Model Search Core (Incubati=
on)"
org.eclipse.emf.search.common (0.6.0.v200710151101) "Model Search Common =
(Incubation)"
org.eclipse.emf.search.doc (0.6.0.v200710151101) "Model Search Documentat=
ion (Incubation)"
org.eclipse.emf.search.ecore.ocl (0.6.0.v200710151101) "Ecore OCL Model S=
earch (Incubation)"
org.eclipse.emf.search.ocl (0.6.0.v200710151101) "Ecore Model Search OCL =
(Incubation)"
org.eclipse.emf.source (2.3.1.v200709260024) "Eclipse Modeling Framework =
(EMF) Source"
org.eclipse.emf.transaction (1.1.1.v200708242200-208Z8s733G3G5D6B56) "EMF=
Model Transaction Core"
org.eclipse.emf.transaction.doc (1.1.0.v200706071723-208Y8s733G3E3G5G79) =
"EMF Model Transaction Documentation"
org.eclipse.emf.transaction.source (1.1.1.v200708242200-208Z8s733G3G5D6B5=
6) "EMF Model Transaction Source"
org.eclipse.emf.validation (1.1.100.v200709201856-31_79oA55P5P7I8MDA) "EM=
F Validation Framework Core"
org.eclipse.emf.validation.doc (1.1.0.v200706071520-21-8s733G3E4C5_88) "E=
MF Validation Framework Documentation"
org.eclipse.emf.validation.ocl (1.1.0.v200706071520-10-7w311817182631) "E=
MF Validation Framework OCL Integration"
org.eclipse.emf.validation.ocl.source (1.1.0.v200706071520-10-7w311817182=
631) "EMF Validation Framework OCL Integration Source"
org.eclipse.emf.validation.source (1.1.100.v200709201856-31_79oA55P5P7I8M=
DA) "EMF Validation Framework Source"
org.eclipse.emf.workspace (1.1.1.v200708242200-208Z8s733G3G5D6B56) "EMF M=
odel Transaction Workbench Integration Core"
org.eclipse.emf.workspace.doc (1.1.0.v200706071723-10-7w311817182834) "EM=
F Model Transaction Workbench Integration Documentation"
org.eclipse.emf.workspace.source (1.1.1.v200708242200-208Z8s733G3G5D6B56)=
"EMF Model Transaction Workbench Integration Source"
org.eclipse.eodm (0.9.1.v200710090302) "pluginName (Incubation)"
org.eclipse.eodm.doc (0.9.1.v200710090302) "Plugin.name (Incubation)"
org.eclipse.eodm.source (0.9.1.v200710090302) "EODM Source"
org.eclipse.gef (3.4.0.v20071002) "Graphical Editing Framework"
org.eclipse.gef.examples (3.4.0.v20071002) "Graphical Editing Framework E=
xamples Source"
org.eclipse.gef.sdk (3.4.0.v20071002) "Graphical Editing Framework Develo=
per Resources"
org.eclipse.gef.source (3.4.0.v20071002) "Graphical Editing Framework Dev=
eloper Resources"
org.eclipse.gmf (1.0.100.v20071003-0000-7d-EThEYjiMWQfJO_f7DRjypkm71) "Gr=
aphical Modeling Framework"
org.eclipse.gmf.doc (1.1.0.v20070330-1300-1--7w3118211401111) "Graphical =
Modeling Framework Documentation"
org.eclipse.gmf.examples.pde (1.1.0.v20070511-1500-2-8Y8s733G3E3515A33) "=
Graphical Modeling Framework Examples"
org.eclipse.gmf.sdk (2.0.1.v20071003-0000-7f79DpEMnX9yDv8yP0619I7NmnN3) "=
Graphical Modeling Framework SDK"
org.eclipse.gmf.sdk.source (2.0.1.v20071003-0000) "Graphical Modeling Fra=
mework SDK Developer Resources"
org.eclipse.gmf.source (1.0.100.v20071003-0000-7d-EThEYjiMWQfJO_f7DRjypkm=
71) "Graphical Modeling Framework Runtime Developer Resources"
org.eclipse.gmt.am3 (0.2.0) "ATLAS MetaModel Management"
org.eclipse.jdt (3.4.0.v20071031-1800-7o7qEDfEFpPqgSlo52CiReK) "Eclipse J=
ava Development Tools"
org.eclipse.jdt.source (3.4.0.v20071031-1800-7o7qEDfEFpPqgSlo52CiReK) "Ec=
lipse Java Development Tools SDK"
org.eclipse.m2m.atl.engine (2.0.0) "ATLAS Transformation Language (ATL)"
org.eclipse.ocl (1.2.0.v200709262202-3309oA55P5R_F_DAU) "Object Constrain=
t Language (OCL) 2.0 Parser/Interpreter"
org.eclipse.ocl.doc (1.1.0.v200706071450-21-8s733G3E3G5AC3) "Object Const=
raint Language (OCL) 2.0 Documentation"
org.eclipse.ocl.source (1.2.0.v200709262202-3309oA55P5R_F_DAU) "Object Co=
nstraint Language (OCL) 2.0 Source"
org.eclipse.ocl.uml (1.2.0.v200709262202-11-7w31181_322622) "OCL 2.0 Bind=
ing for UML"
org.eclipse.ocl.uml.source (1.2.0.v200709262202-11-7w31181_322622) "OCL 2=
=2E0 Binding for UML Source"
org.eclipse.pde (3.4.0.v20071005-7O7R-E7QYGHELqUn7Fz0GE) "Eclipse Plug-in=
Development Environment"
org.eclipse.pde.source (3.4.0.v20071005-7O7R-E7QYGHELqUn7Fz0GE) "Eclipse =
Plug-in Development Environment Developer Resources"
org.eclipse.platform (3.4.0.v20071029-9y9jFD8Ezbubi1dkPqGiKXN6F4h9) "Ecli=
pse Platform"
org.eclipse.platform.source (3.4.0.v20071029-9y9jFD8Ezbubi1dkPqGiKXN6F4h9=
) "Eclipse Platform Plug-in Developer Resources"
org.eclipse.rcp (3.4.0.v20071029-9297EcdEgYiT6nsE3g8ONGHr) "Eclipse RCP"
org.eclipse.rcp.source (3.4.0.v20071029-9297EcdEgYiT6nsE3g8ONGHr) "Eclips=
e RCP Plug-in Developer Resources"
org.eclipse.sdk (3.4.0.v20070824-7M7Q_7BIkmNVnZYd-MDVKnOz0LFr) "Eclipse P=
roject SDK"
org.eclipse.team.extras (3.1.100.v20061012-7K3CF1UE77UABAS) "Eclipse FTP =
and WebDAV Support"
org.eclipse.tptp.monitoring (4.4.1.v200707080100-7c7KEFJ7IYGHEHWXBQ5xe) "=
TPTP Monitoring"
org.eclipse.tptp.monitoring.doc.isv (4.3.101.v200709261752-328Z-w31181_37=
2863) "TPTP Monitoring Tools ISV Documentation"
org.eclipse.tptp.monitoring.doc.user (4.3.101.v200709261752-774Ai0r733G3K=
7E5GC7) "TPTP Monitoring Project Documentation"
org.eclipse.tptp.monitoring.examples (4.3.101.v200709261752-328Z-w31181_3=
72863) "User examples for the TPTP Monitoring Tools Plugins"
org.eclipse.tptp.monitoring.examples.isv (4.4.1.v200709261752-330-w31181_=
372863) "Samples for the TPTP Monitoring Tools Plugins"
org.eclipse.tptp.monitoring.instrumentation (4.3.1.v200709261752-7A7921mA=
55P5VAM8PJA) "TPTP Instrumentation Monitoring "
org.eclipse.tptp.monitoring.la.core (4.4.1.v200707080100-7A78_91mA55P5S7N=
7_CE) "Monitoring Log Analyzer Core"
org.eclipse.tptp.monitoring.la.core.source (4.4.1.v200707080100-7A78_91mA=
55P5S7N7_CE) "Monitoring Log Analyzer Core"
org.eclipse.tptp.monitoring.managedagent (4.4.1.v200709261752-7E7D8c2hE77=
Y7gEUAYQE) "Managed Agent Plugin"
org.eclipse.tptp.monitoring.managedagent.agents (4.4.1.v200709261752-330-=
w31181_372863) "JMX Managed Agent"
org.eclipse.tptp.monitoring.managedagent.agents.source (4.4.1.v2007092617=
52-330-w31181_372863) "Managed Agent Agents Source"
org.eclipse.tptp.monitoring.managedagent.source (4.4.1.v200709261752-7E7D=
8c2hE77Y7gEUAYQE) "Managed Agent Source"
org.eclipse.tptp.monitoring.mx4j.jmx (4.4.1.v200709261752-2-2-w31181_3728=
63) "MX4J"
org.eclipse.tptp.monitoring.profile.server (4.2.101.v200709261752-318Z-w3=
1181_372863) "TPTP Profile On Server Logging Utility"
org.eclipse.tptp.monitoring.profile.server.source (4.2.101.v200709261752-=
318Z-w31181_372863) "TPTP Server Log Import Source"
org.eclipse.tptp.monitoring.report.birt (4.4.1.v200707080100-7A798b1mA55P=
5V_P8KID) "BIRT Monitor Reports for TPTP Branding Plugin"
org.eclipse.tptp.monitoring.report.birt.source (4.4.1.v200707080100-7A798=
b1mA55P5V_P8KID) "BIRT Reporting for TPTP Feature Source"
org.eclipse.tptp.monitoring.source (4.4.1.v200707080100-7c7KEFJ7IYGHEHWXB=
Q5xe) "TPTP Monitoring Source"
org.eclipse.tptp.platform.analysis (4.4.1.v200709191245-7E7_CI2hE77Y7gCaA=
OOK) "TPTP Analysis"
org.eclipse.tptp.platform.analysis.codereview.java (4.4.100.v200709191245=
-777710r733G3K5K57AC) "Java Code Review Plug-in"
org.eclipse.tptp.platform.analysis.codereview.java.source (4.4.100.v20070=
9191245-777710r733G3K5K57AC) "Java Code Review Source"
org.eclipse.tptp.platform.analysis.engine (4.3.101.v200709261752-773CG0r7=
33G3K7E5GC7) "TPTP Analysis Engine"
org.eclipse.tptp.platform.analysis.engine.source (4.3.101.v200709261752-7=
73CG0r733G3K7E5GC7) "TPTP Analysis Engine Source"
org.eclipse.tptp.platform.analysis.source (4.4.1.v200709191245-7E7_CI2hE7=
7Y7gCaAOOK) "TPTP Analysis Feature Source"
org.eclipse.tptp.platform.core (4.4.1.v200707090100-8Q82ENLJEPilAlvO15vQb=
) "TPTP Platform"
org.eclipse.tptp.platform.core.doc.isv (4.3.101.v200709261752-774CG0r733G=
3K7E5GC7) "TPTP Platform Project ISV Documentation"
org.eclipse.tptp.platform.core.doc.user (4.3.101.v200709261752-7A6CH1mA55=
P5VAM8PJA) "TPTP Platform Project Documentation"
org.eclipse.tptp.platform.core.source (4.4.1.v200707090100-8Q82ENLJEPilAl=
vO15vQb) "TPTP Core Source"
org.eclipse.tptp.platform.doc.isv (4.3.101.v200709261752-328Z-885DH1s844H=
4L8F6HD8) "TPTP Platform Project ISV Documentation"
org.eclipse.tptp.platform.doc.user (4.3.101.v200709261752-7A77CH08IIrT11I=
GIcOfKRIYPB) "TPTP Platform Project Documentation"
org.eclipse.tptp.platform.examples (4.3.101.v200709261752-328Z-w31181_372=
863) "TPTP Platform Examples"
org.eclipse.tptp.platform.examples.isv (4.3.101.v200709261752-328Z-w31181=
_372863) "TPTP Platform Logging ISV Examples"
org.eclipse.tptp.platform.instrumentation.ui (4.2.1.v200709261752-320-w31=
181_372863) "Instrument Core UI"
org.eclipse.tptp.platform.instrumentation.ui.source (4.2.1.v200709261752-=
320-w31181_372863) "Instrument Core UI Source"
org.eclipse.tptp.platform.integration.pde (4.4.1.v200709261752-330-w31181=
_372863) "TPTP Platform Integration PDE"
org.eclipse.tptp.platform.integration.pde.source (4.4.1.v200709261752-330=
-w31181_372863) "TPTP Platform Integration PDE"
org.eclipse.tptp.platform.jvmti (4.3.1.v200709261752-777710r733G3K7E5GC7)=
"TPTP JVMTI Profiler Client"
org.eclipse.tptp.platform.jvmti.source (4.3.1.v200709261752-777710r733G3K=
7E5GC7) "TPTP JVMTI Profiler Client"
org.eclipse.tptp.platform.la.core (4.3.101.v200707090100-328Z-w31181_2_23=
56) "Log Analysis Core"
org.eclipse.tptp.platform.la.core.source (4.3.101.v200707090100-328Z-w311=
81_2_2356) "Log Analysis Core"
org.eclipse.tptp.platform.lta (4.3.101.v200707090100-773Ai0r733G3K6H5BB_)=
"TPTP Log and Trace Analyzer"
org.eclipse.tptp.platform.lta.source (4.3.101.v200707090100-773Ai0r733G3K=
6H5BB_) "TPTP Log and Trace Analyzer Source"
org.eclipse.tptp.platform.probekit (4.3.101.v200709261752-7E5EAY2hE77Y7gE=
UAYQE) "TPTP ProbeKit"
org.eclipse.tptp.platform.probekit.doc.user (4.3.101.v200709261752-318Z-w=
31181_372863) "Probekit User Documentation"
org.eclipse.tptp.platform.probekit.source (4.3.101.v200709261752-7E5EAY2h=
E77Y7gEUAYQE) "TPTP ProbeKit Source"
org.eclipse.tptp.platform.profile.server (4.3.1.v200709261752-7E798c2hE77=
Y7gEUAYQE) "TPTP Profile on Server"
org.eclipse.tptp.platform.profile.server.source (4.3.1.v200709261752-7E79=
8c2hE77Y7gEUAYQE) "TPTP Profile on Server Source"
org.eclipse.tptp.platform.report (4.2.101.v200709261752-7A5CH1mA55P5VAM8P=
JA) "TPTP Charting Service"
org.eclipse.tptp.platform.report.birt (4.3.101.v200709261752-777710r733G3=
K7E5GC7) "BIRT Reporting for TPTP Branding plugin"
org.eclipse.tptp.platform.report.birt.source (4.3.101.v200709261752-77771=
0r733G3K7E5GC7) "BIRT Reporting for TPTP Feature Source"
org.eclipse.tptp.platform.report.source (4.2.101.v200709261752-7A5CH1mA55=
P5VAM8PJA) "TPTP Charting Service Source"
org.eclipse.tptp.platform.samples (4.3.101.v200709261752-7A4Dr1mA55P5VAM8=
PJA) "TPTP Platform Samples"
org.eclipse.tptp.platform.samples.source (4.3.101.v200709261752-7A4Dr1mA5=
5P5VAM8PJA) "TPTP Platform Samples Source"
org.eclipse.tptp.platform.statistical.report.birt (4.4.1.v200709261752-77=
7710r733G3K7E5GC7) "BIRT Statistical Reports for TPTP Branding Plugin"
org.eclipse.tptp.platform.statistical.report.birt.source (4.4.1.v20070926=
1752-777710r733G3K7E5GC7) "BIRT Statistical Reporting for TPTP Feature So=
urce"
org.eclipse.tptp.platform.statistical.ui (4.1.301.v200709261752-772CG0r73=
3G3K7E5GC7) "TPTP Statistical UI"
org.eclipse.tptp.platform.statistical.ui.source (4.1.301.v200709261752-77=
2CG0r733G3K7E5GC7) "TPTP Statistical UI Source"
org.eclipse.tptp.platform.trace (4.3.101.v200707090100-7E7AAk2hE77Y7gDXAT=
PH) "TPTP Platform Trace"
org.eclipse.tptp.platform.trace.source (4.3.101.v200707090100-7E7AAk2hE77=
Y7gDXATPH) "TPTP Platform Trace Source"
org.eclipse.tptp.test (4.3.101.v200709261752-7I7ACJ3cI99h9rIcDhXI) "TPTP =
Test"
org.eclipse.tptp.test.doc.isv (4.3.1.v200709261752-320-w31181_372863) "Te=
st Tools ISV Documentation"
org.eclipse.tptp.test.doc.user (4.3.101.v200709261752-320-w31181_372863) =
"Test Tools User Documentation"
org.eclipse.tptp.test.report.birt (4.3.101.v200709261752-7A7A21mA55P5VAM8=
PJA) "BIRT Test Reports for TPTP Branding Plugin"
org.eclipse.tptp.test.report.birt.source (4.3.101.v200709261752-7A7A21mA5=
5P5VAM8PJA) "BIRT Reporting for TPTP Feature Source"
org.eclipse.tptp.test.samples (4.2.1.v200709261752-310-w31181_372863) "TP=
TP Test Samples"
org.eclipse.tptp.test.samples.source (4.2.1.v200709261752-310-w31181_3728=
63) "TPTP Test Samples Source"
org.eclipse.tptp.test.source (4.3.101.v200709261752-7I7ACJ3cI99h9rIcDhXI)=
"TPTP Test Source"
org.eclipse.tptp.test.tools (4.3.101.v200709261752-7E7C31vNDHT9HNTErQiBN9=
QKB) "TPTP Test Tools"
org.eclipse.tptp.test.tools.junit (4.4.1.v200709261752-7A7A21mA55P5VAM8PJ=
A) "TPTP JUnit Plugin Test Tools"
org.eclipse.tptp.test.tools.source (4.3.101.v200709261752-7E7C31vNDHT9HNT=
ErQiBN9QKB) "TPTP Test Tools Source"
org.eclipse.tptp.trace (4.2.1.v200709261752-771E9y0r733G3K7E5GC7) "TPTP T=
race"
org.eclipse.tptp.trace.arm (4.2.1.v200709261752-77210r733G3K7E5GC7) "TPTP=
ARM Monitoring "
org.eclipse.tptp.trace.arm.ui (4.3.1.v200709261752-77510r733G3K7E5GC7) "I=
nstrument ARM UI"
org.eclipse.tptp.trace.jvmti (4.2.1.v200709261752-330-w31181_372863) "TPT=
P Trace JVMTI Client"
org.eclipse.tptp.trace.jvmti.source (4.2.1.v200709261752-330-w31181_37286=
3) "TPTP Trace JVMTI Client"
org.eclipse.tptp.trace.report.birt (4.4.1.v200709261752-7A7A21mA55P5VAM8P=
JA) "BIRT Trace Reports for TPTP Branding Plugin"
org.eclipse.tptp.trace.report.birt.source (4.4.1.v200709261752-7A7A21mA55=
org.eclipse.tptp.trace.source (4.2.1.v200709261752-771E9y0r733G3K7E5GC7) =
"TPTP Trace Source"
org.eclipse.uml2 (2.2.0.v200710031301) "UML2"
org.eclipse.uml2.diagram (0.7.100.v200710031549) "UML2 Diagramming Plug-i=
n (Incubation)"
org.eclipse.uml2.diagram.source (0.7.100.v200710031549) "UML2 Diagramming=
Source"
org.eclipse.uml2.doc (2.2.0.v200709210944) "UML2 Documentation"
org.eclipse.uml2.examples (2.1.0.v200706251652) "UML2 Examples"
org.eclipse.uml2.examples.source (2.1.0.v200706251652) "UML2 Examples Sou=
rce"
org.eclipse.uml2.source (2.2.0.v200710031301) "UML2 Source"
org.eclipse.uml2tools (0.8.0.v200710031549) "UML2 Tools Plug-in (Incubati=
on)"
org.eclipse.uml2tools.doc (0.7.0.v200710031549) "UML2 Tools Documentation=
Plug-in"
org.eclipse.wst (2.1.0.v200709160540-7C48Z8k0eckgZku40g28LZvh8q0R) "Web S=
tandard Tools (WST)"
org.eclipse.xsd (2.3.1.v200709260024) "XML Schema Infoset Model (XSD)"
org.eclipse.xsd.doc (2.3.1.v200709260024) "XML Schema Infoset Model (XSD)=
Programmers Guide"
org.eclipse.xsd.ecore.converter (2.3.1.v200709260024) "XML Schema Infoset=
Model (XSD) - org.eclipse.xsd.ecore.converter"
org.eclipse.xsd.edit (2.3.0.v200709260024) "XML Schema Edit Framework"
org.eclipse.xsd.editor (2.3.0.v200709260024) "XML Schema Editor"
org.eclipse.xsd.mapping (2.3.0.v200709260024) "XML Schema Infoset Model (=
XSD) - org.eclipse.xsd.mapping"
org.eclipse.xsd.mapping.editor (2.3.0.v200709260024) "XML Schema Infoset =
Model (XSD) - org.eclipse.xsd.mapping.editor"
org.eclipse.xsd.source (2.3.1.v200709260024) "XML Schema Infoset Model (X=
SD) Source"
org.topcased.sdk (1.0.0.v200709241920) "Topcased SDK"
org.topcased.toolkit (1.0.0.v200709241920) "Topcased Toolkit"
org.topcased.toolkit.source (1.0.0.v200709241920) "Topcased Source"
*** Plug-in Registry:
ca.ecliptical.emf.xpath (1.0.0) "EMF XPath Plug-in" [Starting]
ca.uwaterloo.gp.fmp (0.6.6) "Feature Modeling Plug-in" [Starting]
com.ibm.icu (3.6.1.v20070906) "International Components for Unicode for J=
ava (ICU4J)" [Active]
com.ibm.icu.source (3.6.1.v20070906) "International Components for Unicod=
e for Java (ICU4J) source plug-in" [Resolved]
com.jcraft.jsch (0.1.31) "JSch" [Resolved]
com.pnp.xfeature (2.1.3) "XFeature Plug-in" [Starting]
edu.cmu.sei.aadl (1.5.3) "Aadl OSATE" [Starting]
edu.cmu.sei.aadl.annex (1.4.2) "Annex Plug-in" [Active]
edu.cmu.sei.aadl.architecture (1.4.5) "Architecture Checker" [Starting]
edu.cmu.sei.aadl.flowanalysis (1.4.7) "Flow Analysis" [Starting]
edu.cmu.sei.aadl.help (1.5.3) "SAE AADL Online Help" [Starting]
edu.cmu.sei.aadl.instance (1.5.3) "Instance Plug-in" [Starting]
edu.cmu.sei.aadl.model (1.5.3) "Aadl Model" [Active]
edu.cmu.sei.aadl.model.edit (1.4.3) "Aadl Edit Support" [Starting]
edu.cmu.sei.aadl.model.editor (1.4.4) "Aadl Object Editor" [Starting]
edu.cmu.sei.aadl.parser (1.4.9) "Aadl Parser" [Active]
edu.cmu.sei.aadl.properties.SEI (1.0.4) "SEI Plug-in" [Starting]
edu.cmu.sei.aadl.resourcebudgets (1.4.6) "Resource Analysis Plug-in" [Sta=
rting]
edu.cmu.sei.aadl.resourcemanagement (1.4.8) "Resource Management" [Starti=
ng]
edu.cmu.sei.aadl.security (1.4.4) "Security Checker" [Starting]
edu.cmu.sei.aadl.texteditor (1.4.4) "Aadl Text Editor" [Active]
edu.cmu.sei.aadl.toMetaH (1.4.7) "Aadl To MetaH Converter" [Starting]
edu.cmu.sei.aadl.unparser (1.4.5) "Aadl Unparser" [Active]
edu.cmu.sei.osate-frontend.source (1.5.3) "pluginName" [Resolved]
edu.cmu.sei.osate-plugins.source (1.5.2) "pluginName" [Resolved]
edu.cmu.sei.osate.core (1.4.7) "AADL Core Plugin" [Active]
edu.cmu.sei.osate.pluginsupport (1.4.2) "OSATE Plugin Support Plugin" [Ac=
tive]
edu.cmu.sei.osate.propertyview (1.4.7) "Aadl Property Value View" [Starti=
ng]
edu.cmu.sei.osate.reporter (1.4.2) "Reporter Plug-in" [Starting]
edu.cmu.sei.osate.ui (1.4.6) "AADL UI Plugin" [Active]
edu.cmu.sei.osate.wizards (1.4.0) "AADL Wizards" [Starting]
edu.cmu.sei.osate.workspace (1.4.5) "Workspace Plug-in" [Active]
edu.cmu.sei.timeweaver.binpacking (1.4.2) "Binpacking Library" [Starting]=
edu.xvcl.workbench (1.0.0) "XVCL Workbench" [Active]
fr.obeo.acceleo.bridge (2.1.0.200707131240) "Acceleo Bridge Plug-in" [Sta=
rting]
fr.obeo.acceleo.bridge.ui (2.1.0.200707131240) "Acceleo Uml14 Ui Plug-in"=
[Starting]
fr.obeo.acceleo.chain (2.1.0.200707131240) "Acceleo Chain Model" [Startin=
g]
fr.obeo.acceleo.chain.edit (2.1.0.200707131240) "Acceleo Chain Edit Suppo=
rt" [Starting]
fr.obeo.acceleo.chain.editor (2.1.0.200707131240) "Acceleo Chain Editor" =
[Starting]
fr.obeo.acceleo.chain.ui (2.1.0.200707131240) "Acceleo Chain Ui Plug-in" =
[Starting]
fr.obeo.acceleo.ecore (2.1.0.200707131240) "Acceleo Ecore Plug-in" [Start=
ing]
fr.obeo.acceleo.ecore.ui (2.1.0.200707131240) "Acceleo Ecore Ui Plug-in" =
[Starting]
fr.obeo.acceleo.gen (2.1.0.200707131240) "Acceleo Generator Plug-in" [Sta=
rting]
fr.obeo.acceleo.gen.debug.ui (2.1.0.200707131240) "Acceleo Gen Debug Ui P=
lug-in" [Starting]
fr.obeo.acceleo.gen.ui (2.1.0.200707131240) "Acceleo Generator Ui Plug-in=
" [Starting]
fr.obeo.acceleo.gen.ui.help (2.1.0.200707131240) "Acceleo Ecore Gen Ui He=
lp Plug-in" [Starting]
fr.obeo.acceleo.tools (2.1.0.200707131240) "Acceleo Tools Plug-in" [Start=
ing]
fr.obeo.acceleo.tools.ui (2.1.0.200707131240) "Acceleo Tools Ui Plug-in" =
[Starting]
fr.obeo.acceleo.uml13 (2.1.0.200707131240) "Acceleo Uml13 Model" [Startin=
g]
fr.obeo.acceleo.uml14 (2.1.0.200707131240) "Acceleo Uml14 Model" [Startin=
g]
fr.obeo.acceleo.uml14.mof (2.1.0.200707131240) "Acceleo Uml14 Mof Plug-in=
" [Starting]
fr.obeo.acceleo.uml14.ui (2.1.0.200707131240) "Acceleo Uml14 Ui Plug-in" =
[Starting]
javax.servlet (2.4.0.v200706111738) "Servlet API Bundle" [Resolved]
javax.servlet.jsp (2.0.0.v200706191603) "Java Server Pages API Bundle" [R=
esolved]
javax.servlet.jsp.source (2.0.0.v200706191603) "Java Server Pages API Sou=
rce Bundle" [Resolved]
javax.servlet.source (2.4.0.v200706111738) "Servlet API Source Bundle" [R=
esolved]
net.sourceforge.lpg.lpgjavaruntime (1.1.0.v200706111738) "SourceForge LPG=
" [Resolved]
net.sourceforge.lpg.lpgjavaruntime.source (1.1.0.v200706111738) "SourceFo=
rge LPG Source Bundle" [Resolved]
net.sourceforge.texlipse (1.1.0) "TeXlipse Plug-in" [Starting]
org.apache.ant (1.7.0.v200706080842) "Apache Ant" [Resolved]
org.apache.ant.source (1.7.0.v200706080842) "Apache Ant Source" [Resolved=
org.apache.batik.bridge (1.6.0.v200706111724) "Apache Batik Bridge/GVT/Sc=
ripting" [Resolved]
org.apache.batik.bridge.source (1.6.0.v200706111724) "Apache Batik Bridge=
/GVT/Scripting Source Bundle" [Resolved]
org.apache.batik.css (1.6.0.v200706111724) "Apache Batik CSS" [Resolved]
org.apache.batik.css.source (1.6.0.v200706111724) "Apache Batik CSS Sourc=
org.apache.batik.dom (1.6.0.v200706111724) "Apache Batik DOM" [Resolved]
org.apache.batik.dom.source (1.6.0.v200706111724) "Apache Batik DOM Sourc=
org.apache.batik.dom.svg (1.6.0.v200706111724) "Apache Batik SVG DOM" [Re=
solved]
org.apache.batik.dom.svg.source (1.6.0.v200706111724) "Apache Batik SVG D=
OM Source Bundle" [Resolved]
org.apache.batik.ext.awt (1.6.0.v200706111724) "Apache Batik AWT Utilitie=
s" [Resolved]
org.apache.batik.ext.awt.source (1.6.0.v200706111724) "Apache Batik AWT U=
tilities Source Bundle" [Resolved]
org.apache.batik.extension (1.6.0.v200706111724) "Apache Batik Extension"=
[Resolved]
org.apache.batik.parser (1.6.0.v200706111724) "Apache Batik Parser" [Reso=
lved]
org.apache.batik.parser.source (1.6.0.v200706111724) "Apache Batik Parser=
org.apache.batik.pdf (1.6.0.v200706111329) "Bundle-Name" [Resolved]
org.apache.batik.svggen (1.6.0.v200706111724) "Apache Batik SVG Generatio=
n" [Resolved]
org.apache.batik.svggen.source (1.6.0.v200706111724) "Apache Batik SVG Ge=
neration Source Bundle" [Resolved]
org.apache.batik.swing (1.6.0.v200706111724) "Apache Batik Swing" [Resolv=
ed]
org.apache.batik.transcoder (1.6.0.v200706111724) "Apache Batik Transcode=
r" [Resolved]
org.apache.batik.transcoder.source (1.6.0.v200706111724) "Apache Batik Tr=
anscoder Source Bundle" [Resolved]
org.apache.batik.util (1.6.0.v200706111724) "Apache Batik Utilities" [Res=
olved]
org.apache.batik.util.gui (1.6.0.v200706111724) "Apache Batik GUI Utiliti=
es" [Resolved]
org.apache.batik.util.gui.source (1.6.0.v200706111724) "Apache Batik GUI =
Utilities Source Bundle" [Resolved]
org.apache.batik.util.source (1.6.0.v200706111724) "Apache Batik Utilitie=
org.apache.batik.xml (1.6.0.v200706111724) "Apache Batik XML" [Resolved]
org.apache.batik.xml.source (1.6.0.v200706111724) "Apache Batik XML Sourc=
org.apache.commons.el (1.0.0.v200706111724) "Apache Commons JSP 2.0 Expre=
ssion Language Interpreter" [Resolved]
org.apache.commons.el.source (1.0.0.v200706111724) "Apache Commons JSP 2.=
0 Expression Language Interpreter Source" [Resolved]
org.apache.commons.logging (1.0.4.v200706111724) "Apache Commons Logging =
Plug-in" [Resolved]
org.apache.commons.logging.source (1.0.4.v200706111724) "Apache Commons L=
ogging Plug-in Source" [Resolved]
org.apache.fop (0.20.5) "Apache FOP Plug-in" [Resolved]
org.apache.jasper (5.5.17.v200706111724) "Apache Jasper 2 Plug-in" [Resol=
ved]
org.apache.jasper.source (5.5.17.v200706111724) "Apache Jasper 2 Source P=
lug-in" [Resolved]
org.apache.log4j (1.2.13.v200706111418) "Apache Jakarta log4j Plug-in" [R=
esolved]
org.apache.lucene (1.9.1.v200706111724) "Apache Lucene" [Resolved]
org.apache.lucene.analysis (1.9.1.v200706181610) "Apache Lucene Analysis"=
[Resolved]
org.apache.lucene.analysis.source (1.9.1.v200706181610) "Apache Lucene An=
alysis Source" [Resolved]
org.apache.lucene.source (1.9.1.v200706111724) "Apache Lucene Source" [Re=
solved]
org.apache.xerces (2.8.0.v200705301630) "Apache Xerces-J" [Resolved]
org.apache.xml.resolver (1.1.0.v200705310020) "Apache XmlResolver" [Resol=
ved]
org.atl.eclipse.adt.builder (2.0.0) "ATL Builder" [Starting]
org.dbunit (2.2.0.200706071) "org.dbunit Plug-in" [Resolved]
org.eclipse.am3.core (0.2.0) "AM3 Core Plug-in" [Active]
org.eclipse.am3.tools.tge (0.2.0) "AM3 - Textual Generic Editor Plug-in" =
[Active]
org.eclipse.am3.ui (0.2.0) "AM3 Ui Plug-in" [Starting]
org.eclipse.ant.core (3.1.300.v20071004) "Ant Build Tool Core" [Starting]=
org.eclipse.ant.ui (3.2.200.v20071004) "Ant UI" [Starting]
org.eclipse.buckminster.ant (1.0.0.r08888) "Buckminster Ant Plug-in" [Ins=
talled]
org.eclipse.buckminster.ant (1.0.0.r08901) "Buckminster Ant Plug-in" [Sta=
rting]
org.eclipse.buckminster.ant (0.2.0.r6358) "Buckminster Ant Plug-in (Incub=
ation)" [Installed]
org.eclipse.buckminster.cmdline (1.0.0.r08888) "Buckminster Headless Laun=
cher" [Starting]
org.eclipse.buckminster.cmdline (0.2.0.r2217) "Buckminster Headless Launc=
her (Incubation)" [Installed]
org.eclipse.buckminster.core (1.0.0.r08893) "Buckminster Core" [Installed=
org.eclipse.buckminster.core (1.0.0.r08922) "Buckminster Core" [Active]
org.eclipse.buckminster.core (0.2.0.r6845) "Buckminster Core (Incubation)=
" [Installed]
org.eclipse.buckminster.cvs (1.0.0.r08888) "Buckminster CVS Plug-in" [Ins=
talled]
org.eclipse.buckminster.cvs (1.0.0.r08915) "Buckminster CVS Plug-in" [Act=
ive]
org.eclipse.buckminster.cvs (0.2.0.r6358) "Buckminster CVS Plug-in (Incub=
ation)" [Installed]
org.eclipse.buckminster.installer (1.0.0.r08888) "Installer Plug-in" [Res=
olved]
org.eclipse.buckminster.installer (0.2.0.r2230) "Installer Plug-in (Incub=
ation)" [Installed]
org.eclipse.buckminster.jdt (1.0.0.r08888) "Buckminster JDT Plug-in" [Ins=
talled]
org.eclipse.buckminster.jdt (1.0.0.r08904) "Buckminster JDT Plug-in" [Sta=
rting]
org.eclipse.buckminster.jdt (0.2.0.r6358) "Buckminster JDT Plug-in (Incub=
ation)" [Installed]
org.eclipse.buckminster.maven (1.0.0.r08888) "Buckminster Maven Plug-in" =
[Installed]
org.eclipse.buckminster.maven (1.0.0.r08905) "Buckminster Maven Plug-in" =
[Active]
org.eclipse.buckminster.maven (0.2.0.r6358) "Buckminster Maven Plug-in (I=
org.eclipse.buckminster.p4 (1.0.0.r08888) "Buckminster Perforce Plug-in" =
[Installed]
org.eclipse.buckminster.p4 (1.0.0.r08906) "Buckminster Perforce Plug-in" =
[Active]
org.eclipse.buckminster.p4 (0.2.0.r6358) "Buckminster Perforce Plug-in (I=
org.eclipse.buckminster.p4.ui (1.0.0.r08888) "Buckminster Perforce UI Plu=
g-in" [Installed]
org.eclipse.buckminster.p4.ui (1.0.0.r08907) "Buckminster Perforce UI Plu=
g-in" [Starting]
org.eclipse.buckminster.p4.ui (0.2.0.r6358) "Buckminster Perforce UI Plug=
-in (Incubation)" [Installed]
org.eclipse.buckminster.pde (1.0.0.r08888) "Buckminster PDE Plug-in" [Ins=
talled]
org.eclipse.buckminster.pde (1.0.0.r08915) "Buckminster PDE Plug-in" [Act=
ive]
org.eclipse.buckminster.pde (0.2.0.r6745) "Buckminster PDE Plug-in (Incub=
ation)" [Installed]
org.eclipse.buckminster.pde.ui (1.0.0.r08888) "Ui Plug-in for the PDE ext=
ension" [Resolved]
org.eclipse.buckminster.remote (1.0.0.r08888) "Buckminster Remote" [Insta=
lled]
org.eclipse.buckminster.remote (1.0.0.r08909) "Buckminster Remote" [Insta=
lled]
org.eclipse.buckminster.runtime (1.0.0.r08888) "Buckminster Runtime Plug-=
in" [Installed]
org.eclipse.buckminster.runtime (1.0.0.r08915) "Buckminster Runtime Plug-=
in" [Active]
org.eclipse.buckminster.runtime (0.2.0.r6247) "Buckminster Runtime Plug-i=
org.eclipse.buckminster.sax (1.0.0.r08888) "Buckminster SAX Parser utilit=
ies" [Resolved]
org.eclipse.buckminster.sax (0.2.0.r6358) "Buckminster SAX Parser utiliti=
es (Incubation)" [Resolved]
org.eclipse.buckminster.slf4j (1.0.0) "Slf4j implementation using the Buc=
kminster logger" [Resolved]
org.eclipse.buckminster.subclipse (1.0.0.r08888) "Buckminster Subversive =
Support Plug-in" [Installed]
org.eclipse.buckminster.subclipse (1.0.0.r08919) "Buckminster Subversive =
Support Plug-in" [Starting]
org.eclipse.buckminster.subversive (1.0.0.r08888) "Buckminster Subversive=
org.eclipse.buckminster.subversive (1.0.0.r08919) "Buckminster Subversive=
org.eclipse.buckminster.svn (0.2.0.r6358) "Buckminster Subversion Plug-in=
(Incubation)" [Active]
org.eclipse.buckminster.ui (1.0.0.r08888) "Buckminster UI Plug-in" [Insta=
lled]
org.eclipse.buckminster.ui (1.0.0.r08922) "Buckminster UI Plug-in" [Activ=
e]
org.eclipse.buckminster.ui (0.2.0.r6460) "Buckminster UI Plug-in (Incubat=
ion)" [Installed]
org.eclipse.compare (3.4.0.I20071023) "Compare Support" [Active]
org.eclipse.core.boot (3.1.100.v20060603) "Core Boot" [Starting]
org.eclipse.core.commands (3.3.100.I20071023-0800) "Commands" [Resolved]
org.eclipse.core.contenttype (3.2.200.v20070910) "Eclipse Content Mechani=
sm" [Active]
org.eclipse.core.databinding (1.1.0.I20071029-1800b) "JFace Data Binding"=
[Active]
org.eclipse.core.databinding.beans (1.0.100.I20071029-1800b) "JFace Data =
Binding for JavaBeans" [Resolved]
org.eclipse.core.expressions (3.3.100.v20071031-1800) "Expression Languag=
e" [Active]
org.eclipse.core.filebuffers (3.3.100.v20071031-1800) "File Buffers" [Act=
ive]
org.eclipse.core.filesystem (1.2.0.v20070916) "Core File Systems" [Active=
org.eclipse.core.filesystem.win32.x86 (1.1.0.v20070510) "Core File System=
for Windows" [Resolved]
org.eclipse.core.jobs (3.3.100.v20071026) "Eclipse Jobs Mechanism" [Activ=
e]
org.eclipse.core.net (1.0.100.I20070709) "Internet Connection Management"=
[Active]
org.eclipse.core.resources (3.3.100.v20071026) "Core Resource Management"=
[Active]
org.eclipse.core.resources.compatibility (3.2.100.v20070502) "Core Resour=
ce Management Compatibility Fragment" [Resolved]
org.eclipse.core.resources.win32 (3.3.0.v20070226) "Core Resource Managem=
ent Win32 Fragment" [Resolved]
org.eclipse.core.runtime (3.4.0.v20070827) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.2.0.v20071008) "Core Runtime Pl=
ug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.100.v20070502) "Authoriz=
ation Compatibility Plug-in" [Active]
org.eclipse.core.runtime.compatibility.registry (3.2.200.v20070717) "Ecli=
pse Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.2.0.v20070910) "Core Variables" [Active]
org.eclipse.cvs (1.0.0.v20070606) "Eclipse CVS Client" [Starting]
Client SDK" [Resolved]
org.eclipse.datatools.connectivity (1.0.1.200711131) "Data Tools Platform=
Connectivity Plug-in" [Starting]
org.eclipse.datatools.connectivity.apache.derby (1.0.0.200710151) "Eclips=
e Data Tools Platform Derby Plug-in" [Starting]
org.eclipse.datatools.connectivity.apache.derby.dbdefinition (1.0.0.20071=
0151) "Eclipse Data Tools Platform Apache Derby Database Definition" [Sta=
rting]
org.eclipse.datatools.connectivity.apache.derby.ui (1.0.0.200712071) "Ecl=
ipse Data Tools Platform Apache Derby UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.db.generic (1.0.0.200711011) "Eclipse =
Data Tools Platform Generic DB Connectivity Plug-in" [Starting]
org.eclipse.datatools.connectivity.db.generic.ui (1.0.1.200711011) "Eclip=
se Data Tools Platform Generic DB UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.dbdefinition.genericJDBC (1.0.0.200706=
071) "Eclipse Data Tools Platform DBDefinition Generic JDBC Plug-in" [Sta=
rting]
org.eclipse.datatools.connectivity.oda (3.1.2.200712051) "DTP Open Data A=
ccess" [Starting]
org.eclipse.datatools.connectivity.oda.consumer (3.1.2.200710011) "DTP OD=
A Consumer Helper Component Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.design (3.0.6.200711191) "DTP ODA =
Design Session Model" [Starting]
org.eclipse.datatools.connectivity.oda.design.ui (3.0.6.200712121) "DTP O=
DA Designer UI Framework Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.flatfile (3.0.5.200711091) "Eclips=
e Data Tools Platform Flat File ODA Runtime Driver" [Starting]
org.eclipse.datatools.connectivity.oda.flatfile.ui (3.0.5.200711291) "Ecl=
ipse Data Tools Platform Flat File ODA Designer" [Starting]
org.eclipse.datatools.connectivity.oda.profile (3.0.6.200710181) "DTP ODA=
Connection Profile Framework Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.template.ui (3.0.6.200710261) "DTP=
ODA New Plug-in Template Wizard" [Starting]
org.eclipse.datatools.connectivity.sqm.core (1.0.1.200712041) "Eclipse Da=
ta Tools Platform SQM Core Plug-in" [Starting]
org.eclipse.datatools.connectivity.sqm.core.ui (1.0.1.200711072) "Eclipse=
Data Tools Platform SQM UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.sqm.fe.ui (1.0.0.200706071) "Eclipse D=
ata Tools Platform FE UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.sqm.fe.ui.actions (1.0.0.200706071) "E=
clipse Data Tools Platform FE Ui Actions Plug-in" [Starting]
org.eclipse.datatools.connectivity.sqm.server.ui (1.0.0.200711091) "Eclip=
se Data Tools Platform Server UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.ui (1.1.0.200712121) "Data Tools Platf=
orm Connectivity UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.ui.dse (1.0.1.200710251) "Eclipse Data=
Tools Platform Data Source Explorer Plug-in" [Starting]
org.eclipse.datatools.doc.user (1.0.0.200706071) "Data Tools Platform Use=
r Guide" [Starting]
org.eclipse.datatools.enablement.finfo (1.5.1.200708161) "Eclipse Data To=
ols Platform Enablement" [Starting]
org.eclipse.datatools.enablement.hsqldb (1.0.0.200710293) "Eclipse Data T=
ools Platform HSQLDB Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries (1.0.0.200710041) "Eclip=
se Data Tools Platform IBM DB2 UDB iSeries Plug-in" [Resolved]
org.eclipse.datatools.enablement.ibm.db2.iseries.dbdefinitio n (1.0.0.2007=
09101) "DB2 UDB iSeries Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries.ui (1.0.0.200712061) "Ec=
lipse Data Tools Platform IBM DB2 UDB UI iSeries Plug-in" [Resolved]
org.eclipse.datatools.enablement.ibm.db2.luw (1.0.0.200710041) "Eclipse D=
ata Tools Platform IBM DB2 UDB LUW Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.luw.dbdefinition (1.0.0.20070910=
1) "Eclipse Data Tools Platform DB2 UDB Database Definition Plug-in" [Sta=
rting]
org.eclipse.datatools.enablement.ibm.db2.luw.ui (1.0.0.200712062) "Eclips=
e Data Tools Platform IBM DB2 UDB LUW UI Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries (1.0.0.200712111) "Eclip=
se Data Tools Platform IBM DB2 UDB zSeries Plug-in" [Resolved]
org.eclipse.datatools.enablement.ibm.db2.zseries.dbdefinitio n (1.0.0.2007=
09101) "DB2 UDB Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries.ui (1.0.0.200712061) "Ec=
lipse Data Tools Platform IBM DB2 UDB zSeries UI Plug-in" [Resolved]
org.eclipse.datatools.enablement.ibm.informix (1.0.0.200712041) "Eclipse =
Data Tools Platform Informix Plug-in" [Resolved]
org.eclipse.datatools.enablement.ibm.informix.dbdefinition (1.0.0.2007060=
71) "Eclipse Data Tools Platform Informix Database Definition Plug-in" [S=
tarting]
org.eclipse.datatools.enablement.ibm.informix.ui (1.0.0.200712062) "Eclip=
se Data Tools Platform Informix UI Plug-in" [Resolved]
org.eclipse.datatools.enablement.ibm.ui (1.0.0.200711301) "pluginName" [R=
esolved]
org.eclipse.datatools.enablement.jdt.classpath (1.0.1.200710171) "Data To=
ols Platform Connectivity JDT Extension Plug-in" [Starting]
org.eclipse.datatools.enablement.jdt.dbunit (1.0.1.200710251) "Eclipse Da=
taTools JDT DbUnit Plug-in" [Starting]
org.eclipse.datatools.enablement.msft.sqlserver (1.0.1.200710051) "Eclips=
e Data Tools Platform Microsoft SQL Server Plug-in" [Starting]
org.eclipse.datatools.enablement.msft.sqlserver.dbdefinition (1.0.0.20070=
6071) "Eclipse Data Tools Platform SQL Server Database Definition Plug-in=
" [Starting]
org.eclipse.datatools.enablement.msft.sqlserver.ui (1.0.0.200712062) "Ecl=
ipse Data Tools Platform Microsoft SQL Server UI Plug-in" [Starting]
org.eclipse.datatools.enablement.mysql (1.0.0.200710311) "Eclipse Data To=
ols Platform MySQL Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.mysql.dbdefinition (1.0.1.200709181) "Ec=
lipse Data Tools Platform MySQL Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.mysql.ui (1.0.0.200711021) "pluginName" =
[Starting]
org.eclipse.datatools.enablement.oda.ws (1.0.1.200712071) "Eclipse Data T=
ools Platform Web Services ODA Runtime Driver" [Installed]
org.eclipse.datatools.enablement.oda.ws.ui (1.0.2.200712071) "Eclipse Dat=
a Tools Platform Web Services ODA Designer" [Installed]
org.eclipse.datatools.enablement.oda.xml (1.0.3.200712071) "Eclipse Data =
Tools Platform XML ODA Runtime Driver" [Starting]
org.eclipse.datatools.enablement.oda.xml.ui (1.0.3.200711191) "Eclipse Da=
ta Tools Platform XML ODA Designer" [Starting]
org.eclipse.datatools.enablement.oracle (1.0.0.200712041) "Eclipse Data T=
ools Platform Oracle Plug-in" [Starting]
org.eclipse.datatools.enablement.oracle.dbdefinition (1.0.0.200706071) "E=
clipse Data Tools Platform Oracle Database Definition Plug-in" [Starting]=
org.eclipse.datatools.enablement.oracle.ui (1.0.0.200712061) "Eclipse Dat=
a Tools Platform Oracle UI Plug-in" [Starting]
org.eclipse.datatools.enablement.postgresql (1.0.1.200711121) "PostgreSQL=
Connection Profile and Driver Template Plug-in" [Starting]
org.eclipse.datatools.enablement.postgresql.dbdefinition (1.0.0.200706071=
) "PostgreSQL DB Definition" [Resolved]
org.eclipse.datatools.enablement.postgresql.ui (1.0.0.200711021) "Postgre=
SQL Connection Profile and Driver Template UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase (1.0.1.200710311) "High-level Syb=
ase Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.asa (1.0.0.200710291) "Sybase ASA=
Plug-in" [Starti
Re: .log file [message #375677 is a reply to message #375606] |
Thu, 20 March 2008 14:00  |
I just ran into and resolved this problem (which I believe has also been
discussed under the buckminster-dev list under the title "Error Resolving
Buckminster"). I got the same stack trace and everything. Here is what I did
to install buckminster and subclipse when it wasn't working:
1) Add the subclipse site (http://subclipse.tigris.org/update_1.2.x)
2) Check both the Europa Discovery Site an the new subclipse site in the
update menu 3) Install all the buckminster things (specifically, the core and
the features) from the Europa discovery site 4) Installed subversion **and
the subversion integration that is provided at the subclipse discovery site**
<-- important
5) Downloaded the sample cquery:
http://www.eclipse.org/buckminster/samples/queries/demo.cque ry 6) Ran it
7) Experienced stack overflow
In order to resolve this, I used the instructions here:
http://wiki.eclipse.org/index.php/Getting_started_with_Buckm inster , which
results in a different subversion integration (the one provided by
buckminster and not subclipse). After that, the sample worked like a charm.
I hope this helps someone!
-Matt
On 2/14/2008 4:18:02 PM, Thomas Hallgren wrote:
> Hi John,
> I looked at your configuration. Your Buckminster installation doesn't look
> to good. There are no Buckminster features installed, yet you have about
> three versions of each plug-in. You also have both Subversive and
> Subclipse support and the latter in two combinations since we changed the
> name of that plug-in from svn to subclipse a while back.
> I would strongly recommend that you do the following:
> 1. Close your IDE.
> 2. Remove all *buckminster* files under c:\eclipseTopcased\plugins and
> c:\eclipseTopcased\features 3. Start the IDE and re-install Buckminster
> from the update manager. Please do not install all optional features. In
> particular, do not install both subversive and subclipse support.
> Please let me know if that helps.
> Thomas Hallgren
> John McGregor wrote:
>> It is attached.
>> John
>>> Hi John,
>>> differ in some way.
>>> Thanks,
>>> Thomas Hallgren
>>>> Thomas,
>>>> I have cleared the metadata. I have tried two workspaces. I have
>>>> attached a small workspace. It takes longer to overflow but it does.
>>>> John
Current Time: Fri Sep 26 05:40:49 EDT 2025
Powered by FUDForum. Page generated in 0.29003 seconds
