Home » Archived » Service Oriented Architecture Tools Platform (STP) » Further information BPMN Modeler
| Further information BPMN Modeler [message #374350] |
Tue, 27 November 2007 17:05  |
Originally posted by: weissbrot.gmail.com
Hello!
I am writing some paper for baccalaureate about the BPMN Modeler. I am
looking for some References about the SOA tools and especially about the
Modeler.
I am searching for 2 weeks now, but can't find utilisable books about The
SOA Project.
my only references for SOA are at the moment (i have others about BPM in
general):
http://wiki.eclipse.org/STP_BPMN_Presentation
http://www.eclipse.org/stp/bpmn/
and that's not quite a lot for a paper that should contain about 40-50
pages.
I want to describe the modeler's:
- functionality (what can i do with it?)
- design / construction (how is it developed?)
- community (forums, wikis about the modeler - or this section..)
- documentation (notes for activities / documentation about the modeler)
- import/export (describes itself ;))
for the technical part i should write some xslt-transformation to exchange
Models between Eclipse STP BPMN Modeler and Adonis -->
http://www.boc-group.com/jumpto.jsp?goto=ADONIS&lg=en
it would be very nice, if anybody could help me find some more
information, about just 1 point :)
thx a lot
Pascal
| Re: Further information BPMN Modeler [message #374351 is a reply to message #374350] |
Wed, 28 November 2007 02:34   |
Originally posted by: atoulme.intalio.com
please see comments inline:
Pascal wrote:
> Hello!
> Modeler.
> The SOA Project.
> general):
> pages.
You can design BPMN diagrams, they represent business processes graphically.
It is developed using the GMF, EMF and GEF technologies.
You cited all the resources.
We have no documentation so far - we need help.
Export to image.
> exchange Models between Eclipse STP BPMN Modeler and Adonis -->
Pascal, we need help to get the modeler complete, help to get it
documented. Feel free to help us out!
> thx a lot
> Pascal
Antoine
Intalio, the Open Source BPMS Company
<a href="http://www.intalio.com">http://www.intalio.com</a>
<a href="http://bpms.intalio.com">Community website</a>
| Re: Further information BPMN Modeler [message #374361 is a reply to message #374352] |
Thu, 06 December 2007 11:44   |
Sorry Pascal,
I was away for some time.
The modeler is based on a xsd, that is translated into an ecore file,
that is used to generate the bpmn classes.
You can find it in the model folder of the bpmn plugin.
I hope this helps you.
Antoine
Pascal wrote:
> Hy Antoine,
> Thx for your fast post. I already thought, that there are no more
> resources, otherwise i would already have found one. I don't know if my
> work helps you, because i am writing it in german. But Maybe i can do
> something on the wiki, but at the moment i have no time for this, and i
> dont really know much about the modeler so far. But i will try to help
> you get it documented!
> but can you give me an advice for the xsl-part? is there an XSD for the
> modeler or a DTD?
> thank you
> Pascal
| Re: Further information BPMN Modeler [message #374500 is a reply to message #374361] |
Sun, 20 January 2008 17:26   |
pascal wrote:
> Hey Antoine,
> thank you very much for your help.
> I just tried to find out the best way to transform Adonis-XML into files
> that can be interpreted by the eclipse modeler. Now i tried to find out,
> if it is possible to change the IDs in an .bpmn and .bpmn_diagram file
> to other strings (like the IDs from AdonisXML) but if i do so i always
> get some nullpointer Exceptions when i open the .bpmn_diagram file. so i
> wanted to ask you what you think is the best way to make this work.
I don't know what a Adonis-XML file is to begin with. I don't think this
is a question for me, you should ask the Adonis guys. I think you are
having an issue with the namespace used by the ID attribute, which
requires the ecore definition to be loaded somehow into your tool.
> should i transform Adonis-XML into a .bpel and import the .bpel into
> eclipse? But transforming data two times could create more new problems.
> Also i think that i wont get the bpel2bpmn generator working. but thats
> an other problem ;)
I can help on that, to some extent.
i am now updating my hole Eclipse Europa and hope
> that it helps a little. in The Eclipse Europa is there the BPEL2BPMN
> Generator included?
No, this is a sample to show off our nice generation API, coupled with
an even nicer drag and drop system that kicks ass, if I may say.
> Here you can find a "simple" BPM from Adonis saved as XML:
> http://www.unet.univie.ac.at/~a0507761/xslt_test_Adonis.xml
> this is how the bpm should look like in Eclipse:
> http://www.unet.univie.ac.at/~a0507761/Adonis_BPM.jpg
> and here you find the DTD for Adonis.xml:
> http://www.unet.univie.ac.at/~a0507761/adoxml.dtd
I'll take a look for sure.
Antoine
> cheers,
> Pascal
| Re: Further information BPMN Modeler [message #374502 is a reply to message #374501] |
Sun, 20 January 2008 18:26   |
pascal wrote:
> hey antoine,
> quite impressive, how fast you reply on questions :)
As I said in a different thread before, just try out our professional
support!
> i think i am gonna try to make some valid .bpel from the adonis xml.
> this should avoid problems in the eclipse modeler.
Well, our BPEL generator is very limited. It's an example of what you
can do with our generation API.
> now i just have to find out how to install the bpel2bpmn generator. i
> already tried to drag and drop some .bpel file, but that does not really
> work for me.
What's your current configuration ? JDT+PDE ? In that case you can
import the bpel2bpmn plugin:
svn co
http://dev.eclipse.org/svnroot/stp/trunk/org.eclipse.stp.bpm n/org.eclipse.stp.bpmn.samples/
bpel2bpmn
Then you can import it into the workspace. You can then build it, and
run an Eclipse instance. In the Eclipse instance, select a bpel file
that is present in the same project as the bpmn diagram, and drop it
into the diagram. It should create a basic pool and some activities.
> how can i find out if the bpmn generator is installed,
You can find if a plugin is launched in a number of ways that add to the
fun.
Easiest: Help>About>Plugin details and see if the plugin name is present.
Hardest (but more fun): run your eclipse instance with the -console
argument. In the console you can ask for its status: status
org.eclipse.stp.bpmn.samples.
You can even start it yourself: start org.eclipse.stp.bpmn.samples
As I said, fun fun fun!
if not, where do
> i find the generator and maybe some help for it. like the API or a how-to
You should look at the bpel2bpmn code, and here is the API :
http://dev.eclipse.org/svnroot/stp/trunk/org.eclipse.stp.bpm n/org.eclipse.stp.bpmn.diagram/customsrc/org/eclipse/stp/bpm n/diagram/generation/impl/BPMNVisual2ProcessGenerator.java
> thx a lot!
Hope this helps.
Antoine
| Re: Further information BPMN Modeler [message #374507 is a reply to message #374506] |
Mon, 21 January 2008 06:40  |
>> svn co
>> bpel2bpmn
> i installed SVN Plugin now, imported the files from the svn repository
> ( http://dev.eclipse.org/svnroot/stp/trunk/org.eclipse.stp.bpm n/)
> i just downloaded PDE and updated Eclipse - so JDT and PDE should be
> installed. In the plugins folder there are plenty of JDT and PDE
> folders. so i think it should work.
> but so far i have the problem, that i dont know how to build the
> project, because there is no main-method. I didnt do java-programming
> for a while :(
You should follow this webinar scheduled on the 22:
http://live.eclipse.org/node/406
To run Eclipse, just go to Run>Open Run dialog, create a new eclipse
instance configuration and run it.
> so far:
> PDE + JDT installed (i hope it is working)
> SVN installed
> org.eclipse.stp.bpmn folder added as a project
No, you need to add the four projects present in that folder.
> found some bpel on the web i want to transform into a BPMN - but how? i
> just dont find out how to build the project. sorry for that dumb
> questions...
> Did i understand that correct:
> Import stp.bpmn from svn --> build it (how?)
Ctrl+B ?
--> open project with
> existing bpmn diagram + bpel file --> drag the bpel file into the
> bpmn-diagram file
> thx a lot
> pascal
| Re: Further information BPMN Modeler [message #602540 is a reply to message #374350] |
Pascal wrote:
> Hello!
> Modeler.
> The SOA Project.
> general):
> pages.
Export to image.
> thx a lot
> Pascal
Antoine
| Re: Further information BPMN Modeler [message #602543 is a reply to message #374351] |
Wed, 28 November 2007 04:04  |
Hy Antoine,
dont really know much about the modeler so far. But i will try to help you
get it documented!
modeler or a DTD?
thank you
Pascal
| Re: Further information BPMN Modeler [message #605685 is a reply to message #374352] |
Sorry Pascal,
Antoine
Pascal wrote:
> Hy Antoine,
> modeler or a DTD?
> thank you
> Pascal
| Re: Further information BPMN Modeler [message #608559 is a reply to message #374361] |
Sat, 19 January 2008 17:31  |
Hy Antoine,
I have been away some time too :) but now i have to finish my paper and so
i will be quite motivated to do good work ;)
but i just cant find the xsd file. is it possible that there is no xsd
file but just the ecore?
i am pretty unsure how to start the exchange between the two filetypes. I
thought that i will transform the Adonis-XML into a XML-File that is
conform to the xsd of the Modeler. Therefore i need the xsd to check if
the file is valid. Then i would change the filetype from .xml to .bpmn and
it should work.
could you tell me please where i get this xsd, i am searching now for
hours, but cant find anything.
thx a lot!
pascal
Antoine Toulme wrote:
> Sorry Pascal,
> Antoine
> Pascal wrote:
>> Hy Antoine,
>> modeler or a DTD?
>> thank you
>> Pascal
| Re: Further information BPMN Modeler [message #608566 is a reply to message #608564] |
Sun, 20 January 2008 07:42  |
Hey Antoine,
now another problem occured. I tried to load the bpmn.xsd, ecore.xsd and
the xmi.xsd into altova xml spy. I made an example bpm an wanted to
validate the example.bpmn with those xsd files.
When in want to validate the file, this error occures (i translated it
from german;))
"The ComplexType Definition 'bpmn:SubProcess' already has attribute
'acitivity Type'
Details:
<a
href=" http://www.w3.org/TR/2004/REC-xmlschema-1-20041028/#ct-props -correct">ct-props-correct.4</a>:
The ComplexType Definition already has attribute 'acitivity Type'
would be very nice if you could help me with that!
thx a lot
pascal
This is the Part of the bpmn.xsd where the error occurs:
<!-- sub process are vertex amongst the enclosing sub process or pool
and at the same time they are also a graph
they also holds a lits of event handlers shape -->
<xsd:complexType name="SubProcess" ecore:implements="bpmn:Graph">
<xsd:complexContent>
<xsd:extension base="bpmn:Activity">
<xsd:sequence>
<xsd:element name="eventHandlers" type="bpmn:Activity" minOccurs="0"
maxOccurs="unbounded" ecore:opposite="eventHandlerFor"/>
</xsd:sequence>
<xsd:attribute name="isTransaction" type="xsd:boolean"/>
<!-- here is the failure: -->
<xsd:attribute name="activityType" type="bpmn:ActivityType"
fixed="SubProcess"/>
</xsd:extension>
<!-- intermediate events on the border of the shape -->
<!-- should it carry the transaction decoration?
Note: we do _not_ define the type of loop here.
That belongs to the data-editor that is specific to the target
language -->
<!-- defaults the type of activity -->
<!-- the state: collapsed, expanded or maximized is in the notation
model -->
</xsd:complexContent>
</xsd:complexType>
| Re: Further information BPMN Modeler [message #608569 is a reply to message #608566] |
Sun, 20 January 2008 12:40  |
Pascal wrote:
> Hey Antoine,
> from german;))
Hey Pascal, I can help you with anything that has to do with the BPMN
modeler. XML Spy is out of scope.
If anyone is having experiences with this tool, feel free to jump in and
help Pascal!
Antoine
> 'acitivity Type'
> Details:
> <a
> thx a lot
> pascal
> <xsd:sequence>
> type="bpmn:Activity" minOccurs="0" maxOccurs="unbounded"
> </xsd:sequence>
> </xsd:extension>
> the target language -->
> notation model -->
> </xsd:complexType>
| Re: Further information BPMN Modeler [message #608570 is a reply to message #608569] |
Sun, 20 January 2008 17:14  |
Hey Antoine,
if it is possible to change the IDs in an .bpmn and .bpmn_diagram file to
other strings (like the IDs from AdonisXML) but if i do so i always get
Also i think that i wont get the bpel2bpmn generator working. but thats an
other problem ;) i am now updating my hole Eclipse Europa and hope that it
helps a little. in The Eclipse Europa is there the BPEL2BPMN Generator
included?
cheers,
Pascal
| Re: Further information BPMN Modeler [message #608571 is a reply to message #608570] |
pascal wrote:
> Hey Antoine,
> an other problem ;)
> Generator included?
Antoine
> cheers,
> Pascal
| Re: Further information BPMN Modeler [message #608572 is a reply to message #374500] |
Sun, 20 January 2008 17:47  |
hey antoine,
i think i am gonna try to make some valid .bpel from the adonis xml. this
work for me.
how can i find out if the bpmn generator is installed, if not, where do i
thx a lot!
| Re: Further information BPMN Modeler [message #610552 is a reply to message #374501] |
pascal wrote:
> hey antoine,
support!
> work for me.
svn co
bpel2bpmn
fun.
if not, where do
> thx a lot!
Hope this helps.
Antoine
| Re: Further information BPMN Modeler [message #610557 is a reply to message #374502] |
Mon, 21 January 2008 05:51  |
> svn co
> bpel2bpmn
installed. In the plugins folder there are plenty of JDT and PDE folders.
but so far i have the problem, that i dont know how to build the project,
because there is no main-method. I didnt do java-programming for a while :(
so far:
SVN installed
questions...
Import stp.bpmn from svn --> build it (how?) --> open project with
bpmn-diagram file
thx a lot
pascal
| Re: Further information BPMN Modeler [message #610558 is a reply to message #374506] |
>> svn co
>> bpel2bpmn
> for a while :(
> so far:
> SVN installed
> questions...
Ctrl+B ?
> bpmn-diagram file
> thx a lot
> pascal
Current Time: Thu Nov 06 15:17:41 EST 2025
Powered by FUDForum. Page generated in 0.15966 seconds
