Home » Eclipse Projects » Nebula » SWT Ribbon
SWT Ribbon [message #38241] |
Sun, 12 August 2007 20:17 |
Emil Crumhorn Messages: 169 Registered: July 2009 |
In my spare time, which has been a little more than usual lately, I've
gotten a "see if it would be possible to do" SWT Ribbon control a little
further than I had originally planned, and since it's gotten so far I
figured I might as well ask and see what people would like to see in it to
make it more useful. As I have not released any code yet (and I would like
to see it in Nebula if it passes IP review and Trademark checks and
what-not - hence me posting in the Nebula group).
I would like some feedback on what from the "Office Ribbon" people would
like to see and what makes the Office Ribbon great that could be
implemented. It seems it's a pretty popular creation from Microsoft's side
as far as those things go.
I do want to point out that this does not use any native API whatsoever, all
is pure SWT. There are native Ribbon API hooks, which of course would be
ideal, but they're not cross-platform. Microsoft's ribbon API is open
otherwise and quite impressive feature-wise as well.
To make things a little easier, I created a page with some feature details
and a bunch of screenshots showing various things, located here:
http://www.hexapixel.com/ribbon/
So, any feedback will be good feedback, if you feel up for it.
Thanks!
Emil
Re: SWT Ribbon [message #38274 is a reply to message #38241] |
Mon, 13 August 2007 06:07 |
Thomas Schindl Messages: 6651 Registered: July 2009 |
Quite impressive. One more cool nebula addon :-)
Tom
> Thanks!
> Emil
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: SWT Ribbon [message #38306 is a reply to message #38241] |
Mon, 13 August 2007 15:16 |
Originally posted by: zx.us.ibm.com
Awesome stuff, I definately for seeing this type of work done within Nebula.
Looks great!
~ Chris
Re: SWT Ribbon [message #38339 is a reply to message #38241] |
Tue, 14 August 2007 08:48 |
Originally posted by: diego.guidi.inwind.it
only a word... wow!!!
"Emil Crumhorn" <emil.crumhorn@gmail.com> ha scritto nel messaggio
news:f9npsn$mqv$1@build.eclipse.org...
> all is pure SWT. There are native Ribbon API hooks, which of course would
> be ideal, but they're not cross-platform. Microsoft's ribbon API is open
> Thanks!
> Emil
Re: SWT Ribbon [message #38372 is a reply to message #38241] |
Tue, 14 August 2007 14:54 |
Chris Gross Messages: 253 Registered: July 2009 |
Hi Emil,
As I said in email... this is really awesome. My one suggestion might
be to break down the widget into smaller pieces that could be reused
individually. For example, the tab part of the ribbon could be used on
its own. I might want to use individual buttons somewhere outside of a
full ribbon, especially considering the extra features a ribbon button
can have (the way it can be layed out, drop downs, etc). This may or
may not be easy depending on how you've designed the widget. So its
only a suggestion.
-Chris
> Thanks!
> Emil
Re: SWT Ribbon [message #38563 is a reply to message #38372] |
Wed, 15 August 2007 01:12 |
Matthew Hall Messages: 368 Registered: July 2009 |
I second Chris's suggestion. It would be sweet to have all these
controls and be able to use them individually for finer-grained situations.
Matthew
Chris Gross wrote:
> Hi Emil,
> only a suggestion.
> Regards,
> -Chris
>> little further than I had originally planned, and since it's gotten so
>> far I figured I might as well ask and see what people would like to
>> see in it to make it more useful. As I have not released any code yet
>> (and I would like to see it in Nebula if it passes IP review and
>> Trademark checks and what-not - hence me posting in the Nebula group).
>> would like to see and what makes the Office Ribbon great that could be
>> side as far as those things go.
>> whatsoever, all is pure SWT. There are native Ribbon API hooks, which
>> of course would be ideal, but they're not cross-platform. Microsoft's
>> ribbon API is open otherwise and quite impressive feature-wise as well.
>> details and a bunch of screenshots showing various things, located here:
>> Thanks!
>> Emil
Re: SWT Ribbon [message #38678 is a reply to message #38563] |
Wed, 15 August 2007 20:29 |
Hmm, well, let me think.
Off the top of my head, it would right now be able to use the TabFolder
seperately. The buttons currently require a "RibbonGroup" parent, due to the
nature of the ribbon, but the parent is not a composite, in fact, the top
composite for any button, checkbox or sub-component below the TabFolder is a
private class that extends a plain composite that then draws a gradient
background on itself, and has a layout to properly layout the groups (it's
quite a simple class). So, in essence, even groups and buttons are fairly
standalone as they do go onto a parent.
However, these buttons are not controls! So if you were hoping to simply
instantate them like a Combo onto a Composite, that would definitely need
some re-working.
The draw class is a seperate (abstract) class to allow extending and method
overloading (as most of my widgets - if the user so wishes).
In any case, certainly an interesting proposal and suggestion, and I agree,
although I'm not sure how well the non-native look and feel (which is true
for Office as well) would look next to your typical native widget?
"Matthew Hall" <matthall@woodcraftmill.com> wrote in message
news:f9tjul$oet$1@build.eclipse.org...
>I second Chris's suggestion. It would be sweet to have all these controls
> Matthew
> Chris Gross wrote:
>> Hi Emil,
>> As I said in email... this is really awesome. My one suggestion might be
>> can have (the way it can be layed out, drop downs, etc). This may or may
>> not be easy depending on how you've designed the widget. So its only a
>> suggestion.
>> Regards,
>> -Chris
>>> to make it more useful. As I have not released any code yet (and I would
>>> like to see it in Nebula if it passes IP review and Trademark checks and
>>> would be ideal, but they're not cross-platform. Microsoft's ribbon API
>>> Thanks!
>>> Emil
Re: SWT Ribbon [message #38706 is a reply to message #38437] |
Wed, 15 August 2007 20:55 |
A few questions there =) Let's see, I'll reply question by question. And
just to point out, most of these aren't actual answers, I do ask a few more
questions as well and I'm more or less thinking aloud.
> Have you tried running this on any other platforms?
Nope. I'm currently on the road with nothing but a (Windows XP) laptop to
work on, so I due to no-access-to-other-machines I have not tried it.
However, in my experience GC draws more or less the same on the 3 main
platforms, so a hopeful guess would be that it should be fine. But that
needs testing of course. Also, as someone pointed out, it would be quite
funny to see the Ribbon on GTK, so that's an incentive on my end to make
sure it looks fine :)
>How does it determine what colors to render?
It doesn't. My test version uses the Blue theme based on the same colors.
Office 2007 comes with three themes. Blue, Silver and Black. Now, the amount
of colors used to draw the ribbon is quite staggering, but that doesn't mean
it can't be themed, it's just a question of "does any user feel like
changing 200 colors to create a new theme?". That said, if there was a
surefire way of pulling an OS color and picking the correct gradients for
all the other colors, that would make life easier and I would welcome it. I
tried it for my other widgets and it wasn't possible at the time. Another
thing here is that even if you switch from Blue to Black, some colors remain
the same (selections are still orange-yellow-gradient) etc. It's a bit of a
thinker for sure. In my other widgets, I implemented the three main themes
and had the widget do an educated guess from picking a basic OS color to see
which theme was active. However, Office 2007 default is blue even if your OS
theme is Olive... And what about custom themes, custom colors, etc?
>How do the colors look when they're displayed along with the Forms toolkit
>and CTabFolder gradients? (and PShelf)
No idea right now, they would probably look strange. Which I guess is one
reason why Microsoft did not stick all-native (or any native) controls into
its ribbon or others around it. I think the idea of the ribbon is to be used
as a menu system, and to basically replace it, hence, it's not really built
to mix well with other tabfolders and such. This is also a bit of a
"theming" question as colors do play a part here as well. Perhaps there
could be a way to dumb-down the ribbon to look more native, and hence let it
blend better, I'm not sure. Seems like it's pushing into a realm where it
doesn't really want to live.
>Have you thought about how this might fit into a typical RCP workbench?
I have given that a thought, and it's basically the same as the previous
question. I think it would look odd, personally, depending on how it was
used.
>Does the Ribbon manage the layout of items within each group, or does the
>client code?
The chain of "command" is as follows. RibbonTabFolder (extends Composite) ->
RibbonTab -> RibbonTabComposite (private, created on tab creation, exends
Composite) -> RibbonGroup -> various AbstractRibbonItem(s). The
RibbonTabComposite handles the layout of the groups, and the RibbonTabFolder
handles the layout of the Tabs. So the answer is, the Ribbon has its own
layouts to control how things are shown and where they are drawn.
Perhaps IContributionItem.fill(Composite) will be sufficient. Do the
concepts of "group marker" and "separator" still make sense for a Ribbon?
Hmm, well, not sure here. Perhaps it would be. I think it would make sense,
but I need to think some more here, I haven't taken it that far in my head
yet. I think it's a real question of "what is the Ribbon replacing?"...
>Also, how does the tooltip API compare to the new custom tooltips in JFace
>for 3.3?
Well, using JFace is a bit non-Nebula, no? I can't say I'm sure what the
deal there truly is, but from what I gather, Nebula widgets need to be SWT
only. Right now, the tooltip API is completely custom and has nothing to do
with what the JFace 3.3 API has to offer. I haven't gotten to fully play
with the new 3.3 Tooltip API either, but if we're sticking to SWT only I'm
not sure I can even use it.
Phew, ok, hope that answered some stuff at least. Hoping to have some sample
package up soon so people can give it a go. Feel free to leave more feedback
of course =)
Emil
"Peter Centgraf" <peter@centgraf.net> wrote in message
news:f9svqn$f2b$1@build.eclipse.org...
> Very cool! I can't wait to play with this myself.
> Now the torrent of questions...
> Have you tried running this on any other platforms? How does it feel to
> use this under GTK or OS X? How does it determine what colors to render?
> and CTabFolder gradients? How about when using the PShelf presentation?
> Visually, it could replace the current CoolBar/ToolBar setup. Is the
> IContributionManager API sufficient? It already supports the concept of
> named groups, but the names are not intended for display. If the
> implementation is extended to support I18n, the current names could be
> used as keys. We would also need something akin to ICoolBarManager to
> manage the top row of tabs. Does the Ribbon manage the layout of items
> within each group, or does the client code? Perhaps
> IContributionItem.fill(Composite) will be sufficient. Do the concepts of
> for 3.3? CellLabelProvider seems to expose an API based on CLabel, which
> does not support styled text. Do we need yet another tooltip API for
> Ribbon?
> Thanks again for showing us this work in progress. It has definitely
> gotten me thinking....
> Peter
Re: SWT Ribbon [message #38821 is a reply to message #38706] |
Thu, 16 August 2007 20:12 |
Peter Centgraf Messages: 52 Registered: July 2009 |
Member |
So, to sum up your responses (please correct me if necessary):
By nature, the ribbon is a strange component that does lots of custom
graphical rendering, and Microsoft has apparently made no effort to
integrate it with other widgets. This makes the whole question of
"native" L&F quite difficult, since Microsoft itself is totally
inconsistent in its visual language. (Why am I not surprised?)
On a detail level, the colors for the ribbon are specified individually
-- not generated from some few base colors by an algorithm. In order to
match it to a platform's color scheme, you need to specify 200 colors
one-by-one. This is so difficult in practice that not even Microsoft
bothered to try -- they just supply 3 pre-configured themes. You've
implemented the default one for your ribbon.
If I would like the ribbon to look visually consistent with the rest of
my application, I would need to spend a lot of time tweaking individual
color settings. In the best case, it would either look good in my
application but inconsistent with MS Office, or consistent with Office
but not the rest of my application.
I think it would be useful to keep the colors externalized from the
code, so if someone gets really ambitious, they could create their own
theme. Perhaps I'll do this myself, or perhaps we could convince one of
the Eclipse designers to take a crack at it. You could perhaps keep the
colors in a Java properties file and contribute themes via plugin
fragments, similar to the way L10n works in Eclipse.
I was thinking that the ribbon could easily replace the function of a
coolbar in an RCP app, but it would really need to replace both menu and
coolbar. It would be quite strange to have a menu and a ribbon right
next to each other. That's not a problem for new RCP apps, but it does
make a conversion from previous apps more difficult. For example, it
would probably look terrible if the crowded Eclipse IDE menus were
translated into separate buttons on the ribbon, but the coolbars are
sparsely populated and incomplete.
I don't think there's a hard-and-fast rule about not depending on JFace.
I think the idea is to keep the JFace stuff separate from the SWT
stuff, so that clients can work at either level. You make a good point,
though. The rollover popups are a pretty fundamental part of the
widget, so it doesn't make sense for it to be dependent on JFace.
Perhaps it would still be worth the time to make the APIs consistent
with each other, even if they aren't directly compatible.
One last issue: A major feature of the Office ribbon is to provide
visual feedback of changes when you roll over an option, rather than
waiting to do/undo/try again. Do the buttons on your ribbon provide
ArmEvents so an application could implement this live preview behavior?
Peter
Re: SWT Ribbon [message #583895 is a reply to message #38241] |
Tom
> Thanks!
> Emil
Re: SWT Ribbon [message #583927 is a reply to message #38241] |
Diego Guidi Messages: 20 Registered: July 2009 |
> Thanks!
> Emil
Re: SWT Ribbon [message #583945 is a reply to message #38241] |
Chris Gross Messages: 471 Registered: July 2009 |
Hi Emil,
only a suggestion.
-Chris
> Thanks!
> Emil
Re: SWT Ribbon [message #584040 is a reply to message #38372] |
Matthew
Chris Gross wrote:
> Hi Emil,
> only a suggestion.
> Regards,
> -Chris
>> Thanks!
>> Emil
Re: SWT Ribbon [message #584075 is a reply to message #38563] |
some re-working.
> Matthew
> Chris Gross wrote:
>> Hi Emil,
>> suggestion.
>> Regards,
>> -Chris
>>> Thanks!
>>> Emil
Re: SWT Ribbon [message #584095 is a reply to message #38437] |
used.
>client code?
>for 3.3?
of course =)
Emil
> Ribbon?
> Peter
Re: SWT Ribbon [message #584153 is a reply to message #38706] |
Member |
Peter
Current Time: Sat Sep 21 03:01:44 GMT 2024
Powered by FUDForum. Page generated in 0.06679 seconds
