Re: UML22Measure build failure [message #563352 is a reply to message #374183] |
Mon, 17 November 2008 10:33 |
Hugo Bruneliere Messages: 674 Registered: July 2009 |
Hi Jerome,
Jerome a écrit :
> Hi all,
> I'm using the old AM3 distribution (0.2.0.200706221611) on Eclipse 3.4.1
> (modeling tools included), EMF2.4.0 and ATL 2.0.1.
> When running the build.xml ant script of the project "UML22Measure"
> taken from the zoo, I receive the following error message:
> BUILD FAILED
> ...........\build.xml:28: Problem: failed to create task or type
> am3.loadModel
> Cause: The name is undefined.
> Action: Check the spelling.
> Action: Check that any custom tasks/types have been declared.
> Action: Check that any <presetdef>/<macrodef> declarations have taken
> place.
> In the build config the option "Run in the same JRE as the workspace" is
> checked.
> The AM3 plugin seems to be properly installed as I can open the AM3
> perspective. Problem seems similar to Mark Melia's one.
> Thank you for your help.
Due to some recent major modifications of the ATL HEAD version, the old
AM3 plugins (available as explained from
http://wiki.eclipse.org/AM3/How_Install_AM3_From_SVN) are currently not
compatible with this ATL version.
You have to checkout the sources of compatible ATL plugins from the
development branch as explained from
http://wiki.eclipse.org/ATL/How_Install_ATL_(Dev)_From_CVS
Hugo
Hugo Bruneliere - R&D Engineer
AtlanMod research team (INRIA & EMN) - Room B206
École des Mines de Nantes
4, rue Alfred Kastler
44307 Nantes Cedex 3 - France
EMail: hugo.bruneliere@inria.fr
Hugo Bruneliere, PhD
NaoMod team (IMT Atlantique & LS2N-CNRS)
Nantes - France
FUDForum. Page generated in 0.03238 seconds
