Home » Archived » Service Oriented Architecture Tools Platform (STP) » STP Getting started
Re: STP Getting started [message #374209 is a reply to message #374123] |
Sat, 28 July 2007 23:52 |
Originally posted by: matthew_bennetts.yahoo.com.au
Hi Johnson,
Here's the contents of my log:
!SESSION 2007-07-29 09:39:40.663
eclipse.buildId=I20070625-1500
java.version=1.6.0_01
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_AU
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.stp.common 4 0 2007-07-29 09:48:13.490
!MESSAGE Celtix Java To Wsdl Generation failure
!STACK 0
java.lang.NoClassDefFoundError:
org/apache/cxf/tools/java2wsdl/processor/JavaToProcessor
org.eclipse.stp.sc.cxf.generators.CeltixJavaToWsdlGenerator. run(CeltixJavaToWsdlGenerator.java:58)
org.eclipse.stp.sc.jaxws.builders.ScJavaToWsdlBuilder.genera te(ScJavaToWsdlBuilder.java:85)
org.eclipse.stp.sc.jaxws.builders.ScJavaToWsdlBuilder.buildO neJavaFile(ScJavaToWsdlBuilder.java:57)
org.eclipse.stp.sc.common.builders.ScJavaBuilder.visitResour ceFile(ScJavaBuilder.java:124)
org.eclipse.stp.sc.common.builders.ScJavaBuilder.access$0(Sc JavaBuilder.java:112)
org.eclipse.stp.sc.common.builders.ScJavaBuilder$ScBuildDelt aVisitor.visit(ScJavaBuilder.java:185)
org.eclipse.core.internal.events.ResourceDelta.accept(Resour ceDelta.java:67)
org.eclipse.core.internal.events.ResourceDelta.accept(Resour ceDelta.java:76)
org.eclipse.core.internal.events.ResourceDelta.accept(Resour ceDelta.java:48)
org.eclipse.stp.sc.common.builders.ScJavaBuilder.incremental Build(ScJavaBuilder.java:83)
org.eclipse.stp.sc.common.builders.ScJavaBuilder.build(ScJav aBuilder.java:59)
org.eclipse.core.internal.events.BuildManager$2.run(BuildMan ager.java:624)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:166)
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:197)
org.eclipse.core.internal.events.BuildManager$1.run(BuildMan ager.java:246)
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:249)
org.eclipse.core.internal.events.BuildManager.basicBuildLoop (BuildManager.java:302)
org.eclipse.core.internal.events.BuildManager.build(BuildMan ager.java:334)
org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBu ildJob.java:137)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJ ob.java:235)
!MESSAGE java.lang.NullPointerException
!ENTRY org.eclipse.stp.common 4 0 2007-07-29 09:48:29.393
!STACK 0
Matt
johnson ma wrote:
> Hi Matt,
> Can you see if any errors in your log view from (Windows->Show View->PDE
> Runtime
> ->Error Log)?
> Thanks
> Johnson
> "Matt.B" <matthew_bennetts@yahoo.com.au> wrote in message
> news:f86bes$s5c$1@build.eclipse.org...
>> I'm trying to follow the "STP Service Creation getting started" guide at
>> http://wiki.eclipse.org/STP_Service_Creation_getting_started but can't get
>> Eclipse to automagically generate the wsdl files as it seems to do so in
>> the Flash movie demo. When I save the interface the wsdl folder is created
>> but there's no wsdl file in it. Any ideas?
>> I'm using:
>> * Eclipse 3.3.0 with SOA installed from Europa Discovery site
>> * Apache CXF runtime (apache-cxf-2.0-incubator.zip)
>> * Apache CXF Eclipse plug-in 2.0.0 from
>> http://people.apache.org/~jliu/updatesites/cxf
>> * Apache Tuscany runtime (apache-tuscany-sca-0.91-incubating.zip)
>> * Apache Tuscany Eclipse plug-in 1.0.0 from
>> http://people.apache.org/~jliu/updatesites/tuscany
>> TIA,
>> Matt
Re: STP Getting started [message #374210 is a reply to message #374209] |
Mon, 30 July 2007 07:52 |
Johnson Ma Messages: 17 Registered: July 2009 |
Junior Member |
Hi Matt,
From the log file, the apache cxf plugin is not loaded for unknown reason.
To solve those kind of environment problems, we created an stp-all-in-one
zip.
That zip file contains stp plugins and all its dependencies (including wtp,
dtp, gmf, cxf... plugins).
You can copy it to your Eclipse 3.3 installation and try those jaxws
functions.
http://www.eclipse.org/downloads/download.php?file=/stp/down loads/drops/I-I200707260606-200707260606/stp-all-in-one-I-I2 00707260606-200707260606.zip
Johnson
news:46ABD6BD.6010703@yahoo.com.au...
> Hi Johnson,
> !SESSION 2007-07-29
> 09:39:40.663 -----------------------------------------------
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Matt
> johnson ma wrote:
>> Hi Matt,
>> Runtime
>> ->Error Log)?
>> Thanks
>> Johnson
>>> Hi,
>>> get Eclipse to automagically generate the wsdl files as it seems to do
>>> so in the Flash movie demo. When I save the interface the wsdl folder is
>>> created but there's no wsdl file in it. Any ideas?
>>> I'm using:
>>> TIA,
>>> Matt
Re: STP Getting started [message #374212 is a reply to message #374210] |
Thu, 09 August 2007 15:17 |
Chandra Messages: 30 Registered: July 2009 |
Member |
Hi Johnson,
I downloaded the zip and added this to my Eclipse 3.3 extensions. I
then created a JAX-WS project, added an interface. However i am unable
to add any annotations to either the method or the interface. There are
no errors logged in the error Log view.
However when i restart eclipse, the following gets logged.
Any ideas ?
thanks
chandra
!ENTRY org.eclipse.osgi 2 0 2007-08-09 20:34:40.165
!MESSAGE While loading class
"org.eclipse.mylyn.internal.tasks.ui.ITaskHighlighter", thread
"Thread[Worker-1,5,main]" timed out waiting (5000ms) for thread
"Thread[Worker-0,5,main]" to finish starting bundle
"update@plugins/org.eclipse.mylyn.tasks.ui_2.0.0.v20070627-1400.jar
[140]". To avoid deadlock, thread "Thread[Worker-1,5,main]" is
proceeding but "org.eclipse.mylyn.internal.tasks.ui.ITaskHighlighter"
may not be fully initialized.
!STACK 0
org.osgi.framework.BundleException: State change in progress for bundle
"update@plugins/org.eclipse.mylyn.tasks.ui_2.0.0.v20070627-1400.jar" by
thread "Worker-0".
org.eclipse.osgi.framework.internal.core.AbstractBundle.begi nStateChange(AbstractBundle.java:1141)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:258)
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:417)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:189)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:340)
org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:37)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:405)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:369)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:319 )
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:23 57)
at java.lang.Class.getConstructor0(Class.java:2671)
at java.lang.Class.newInstance0(Class.java:321)
at java.lang.Class.newInstance(Class.java:303)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:136)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:970)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:260)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:408)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:289)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1269)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:160)
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:788)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:243)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:49)
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:239)
org.eclipse.ui.internal.decorators.LightweightDecoratorDefin ition$1.run(LightweightDecoratorDefinition.java:117)
at org.eclipse.core.runtime.Platform.run(Platform.java:857)
org.eclipse.ui.internal.decorators.LightweightDecoratorDefin ition.internalGetDecorator(LightweightDecoratorDefinition.ja va:113)
org.eclipse.ui.internal.decorators.LightweightDecoratorDefin ition.decorate(LightweightDecoratorDefinition.java:241)
org.eclipse.ui.internal.decorators.LightweightDecoratorManag er$LightweightRunnable.run(LightweightDecoratorManager.java: 71)
org.eclipse.ui.internal.decorators.LightweightDecoratorManag er.decorate(LightweightDecoratorManager.java:336)
org.eclipse.ui.internal.decorators.LightweightDecoratorManag er.getDecorations(LightweightDecoratorManager.java:322)
org.eclipse.ui.internal.decorators.DecorationScheduler$1.ens ureResultCached(DecorationScheduler.java:369)
org.eclipse.ui.internal.decorators.DecorationScheduler$1.run (DecorationScheduler.java:329)
Caused by:
org.eclipse.osgi.framework.internal.core.AbstractBundle$Bund leStatusException
... 56 more
johnson ma wrote:
> Hi Matt,
> zip.
> functions.
> Regards
> Johnson
Re: STP Getting started [message #374213 is a reply to message #374212] |
Thu, 09 August 2007 17:33 |
Member |
Hi Johnson,
I noticed that when i create a new JAX-WS Web Service project it gives
a warning dialog " You must specify a valid installation location for
your selected runtime provider in JAX-WS preferences"
I have specified 'org.apache.cxf_2.1-incubator-SNAPSHOT" in the
preferences for Apache CXF.
The resulting project shows Java Nature ( icon for project has a J)
and not a SOA Tools Nature.
thanks,
chandra
Chandra wrote:
> Hi Johnson,
> I then created a JAX-WS project, added an interface. However i am
> unable to add any annotations to either the method or the interface.
> There are no errors logged in the error Log view.
> Any ideas ?
> thanks
> chandra
> !STACK 0
> thread "Worker-0".
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Caused by:
> ... 56 more
> johnson ma wrote:
>> Hi Matt,
>> reason.
>> stp-all-in-one zip.
>> wtp, dtp, gmf, cxf... plugins).
>> functions.
>> Regards
>> Johnson
Re: STP Getting started [message #592890 is a reply to message #374123] |
Hi Johnson,
!STACK 0
!STACK 0
Matt
johnson ma wrote:
> Hi Matt,
> Runtime
> ->Error Log)?
> Thanks
> Johnson
>> I'm using:
>> TIA,
>> Matt
Re: STP Getting started [message #592898 is a reply to message #374209] |
Junior Member |
Hi Matt,
zip.
functions.
Johnson
> Hi Johnson,
> !SESSION 2007-07-29
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Matt
> johnson ma wrote:
>> Hi Matt,
>> Runtime
>> ->Error Log)?
>> Thanks
>> Johnson
>>> Hi,
>>> I'm using:
>>> TIA,
>>> Matt
Re: STP Getting started [message #592921 is a reply to message #374210] |
Member |
Hi Johnson,
Any ideas ?
thanks
chandra
!STACK 0
thread "Worker-0".
Caused by:
... 56 more
johnson ma wrote:
> Hi Matt,
> zip.
> functions.
> Regards
> Johnson
Re: STP Getting started [message #592931 is a reply to message #374212] |
Member |
Hi Johnson,
thanks,
chandra
Chandra wrote:
> Hi Johnson,
> Any ideas ?
> thanks
> chandra
> !STACK 0
> thread "Worker-0".
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Caused by:
> ... 56 more
> johnson ma wrote:
>> Hi Matt,
>> reason.
>> stp-all-in-one zip.
>> functions.
>> Regards
>> Johnson
Current Time: Fri Apr 26 18:27:32 GMT 2024
Powered by FUDForum. Page generated in 0.04612 seconds
