STP Europa on a Intel MacBook Pro [message #374113] |
Wed, 18 July 2007 03:11 |
Originally posted by: rnmixon.custco.biz
I saw one earlier posting about someone having problems with a mac, but no
real resolution.
I have tried to follow the instructions at:
http://wiki.eclipse.org/STP_Service_Creation_getting_started
First, is there an updated set of instructions for trying to use STP with
Europa? These were create April 28 using milestone builds it looks like.
Things have changed a bit since them. It would be nice to have a set of
instructions that work with update manager.
On to solving the problem. I'm trying to use Europa as the basis. I have
tried numerous ways - using the update function and trying to scrounge
equivalent downloaded packages to the one in the Wiki article.
This works fine on Windows Vista, but on my MacBook Pro, no matter how I
do it, I end up with the following error when I try and generate WSDL:
!ENTRY org.eclipse.stp.common 4 0 2007-07-17 19:41:13.188
!MESSAGE Celtix Java To Wsdl Generation failure
!STACK 0
java.lang.LinkageError: loader constraints violated when linking
javax/xml/namespace/QName class
at
com.sun.xml.bind.v2.model.impl.RuntimeBuiltinLeafInfoImpl.<clinit >(RuntimeBuiltinLeafInfoImpl.java:186)
at
com.sun.xml.bind.v2.model.impl.RuntimeTypeInfoSetImpl.<init >(RuntimeTypeInfoSetImpl.java:25)
at
com.sun.xml.bind.v2.model.impl.RuntimeModelBuilder.createTyp eInfoSet(RuntimeModelBuilder.java:84)
at
com.sun.xml.bind.v2.model.impl.RuntimeModelBuilder.createTyp eInfoSet(RuntimeModelBuilder.java:41)
at
com.sun.xml.bind.v2.model.impl.ModelBuilder.<init>(ModelBuilder.java:104)
at
com.sun.xml.bind.v2.model.impl.RuntimeModelBuilder.<init>(RuntimeModelBuilder.java:49)
at
com.sun.xml.bind.v2.runtime.JAXBContextImpl.getTypeInfoSet(J AXBContextImpl.java:372)
at
com.sun.xml.bind.v2.runtime.JAXBContextImpl.<init>(JAXBContextImpl.java:236)
at
com.sun.xml.bind.v2.ContextFactory.createContext(ContextFact ory.java:76)
at
com.sun.xml.bind.v2.ContextFactory.createContext(ContextFact ory.java:55)
at
at
at java.lang.reflect.Method.invoke(Method.java:585)
at javax.xml.bind.ContextFinder.newInstance(ContextFinder.java: 210)
at javax.xml.bind.ContextFinder.find(ContextFinder.java:366)
at javax.xml.bind.JAXBContext.newInstance(JAXBContext.java:574)
at
org.apache.cxf.jaxb.JAXBDataBinding.createJAXBContext(JAXBDa taBinding.java:397)
at
org.apache.cxf.jaxb.JAXBDataBinding.initialize(JAXBDataBindi ng.java:267)
at
org.apache.cxf.service.factory.ReflectionServiceFactoryBean. buildServiceFromClass(ReflectionServiceFactoryBean.java:220)
at
org.apache.cxf.service.factory.ReflectionServiceFactoryBean. initializeServiceModel(ReflectionServiceFactoryBean.java:248 )
at
org.apache.cxf.service.factory.ReflectionServiceFactoryBean. create(ReflectionServiceFactoryBean.java:136)
at
org.apache.cxf.frontend.AbstractEndpointFactory.createEndpoi nt(AbstractEndpointFactory.java:83)
at
org.apache.cxf.frontend.AbstractServiceFactory.createService (AbstractServiceFactory.java:29)
at
org.apache.cxf.tools.java2wsdl.processor.JavaToProcessor.pro cess(JavaToProcessor.java:87)
at
org.eclipse.stp.sc.cxf.generators.CeltixJavaToWsdlGenerator. run(CeltixJavaToWsdlGenerator.java:102)
at
org.eclipse.stp.sc.jaxws.builders.ScJavaToWsdlBuilder.genera te(ScJavaToWsdlBuilder.java:85)
at
org.eclipse.stp.sc.jaxws.builders.ScJavaToWsdlBuilder.buildO neJavaFile(ScJavaToWsdlBuilder.java:57)
at
org.eclipse.stp.sc.common.builders.ScJavaBuilder.visitResour ceFile(ScJavaBuilder.java:124)
at
org.eclipse.stp.sc.common.builders.ScJavaBuilder.access$0(Sc JavaBuilder.java:112)
at
org.eclipse.stp.sc.common.builders.ScJavaBuilder$ScBuildDelt aVisitor.visit(ScJavaBuilder.java:185)
at
org.eclipse.core.internal.events.ResourceDelta.accept(Resour ceDelta.java:67)
at
org.eclipse.core.internal.events.ResourceDelta.accept(Resour ceDelta.java:76)
at
Any ideas on how to fix this?
Thank you - Richard
Re: STP Europa on a Intel MacBook Pro [message #374114 is a reply to message #374113] |
Wed, 18 July 2007 03:42 |
> !STACK 0 java.lang.LinkageError: loader constraints violated when
> linking javax/xml/namespace/QName class
> at
I am pretty sure this problem is linked to the JRE you use.
In the JDK 6, the JSR173 is integrated with the JRE. So the
javax.xml.* classes are already present in the class path,
when the plugin tries to load a new bundle that contain the same classes.
What JDK do you use on your machines ?
Antoine
Intalio, the Open Source BPMS Company
<a href="http://www.intalio.com">http://www.intalio.com</a>
<a href="http://bpms.intalio.com">Community website</a>
Re: STP Europa on a Intel MacBook Pro [message #374116 is a reply to message #374115] |
Wed, 18 July 2007 15:31 |
BTW, I do have the option "-Dorg.osgi.framework.bootdelegation=*" in my
eclipse/eclipse.ini file.
Is any change in this option needed in order to work correctly on Mac OsX?
Re: STP Europa on a Intel MacBook Pro [message #374117 is a reply to message #374116] |
Thu, 19 July 2007 06:07 |
OK, maybe a different approach can work.
Can someone that is using an Intel Mac please give me the OsX version,
Java version they are using and what plugins they are using to get STP to
work?
Thanks much - Richard
Re: STP Europa on a Intel MacBook Pro [message #374118 is a reply to message #374117] |
Thu, 19 July 2007 06:21 |
Rich,
not sure if that will fix the problem, but you could try running over
the Sun JDK 6. The Europa release is compatible with this version of the
JDK, and some plugins from JDT actually require it.
If that doesn't work, please let us know. Anybody on Mac around here ?
> to work?
Re: STP Europa on a Intel MacBook Pro [message #374119 is a reply to message #374118] |
Thu, 19 July 2007 17:09 |
Unfortunately upgrading to the 1.6.0 release of Java for Mac OsX Tiger
(10.4) did not help. I still get the LinkageError (see way down below).
There are some additional messages complaining about bundles that have
been already installed - but I doubt this is related, as I have
consistently gotten the LinkageError even when I updated using the Update
service. On this install, I updated from a local update source to add the
STP components. The source was an extension location for my Windows Vista
setup that works correctly.
So how else can you resolve classloader issues?
Thanks again - Richard
!SESSION 2007-07-19 08:00:49.397
eclipse.buildId=I20070625-1500
java.version=1.6.0-dp
java.vendor=Apple Computer, Inc.
BootLoader constants: OS=macosx, ARCH=x86, WS=carbon, NL=en_US
Command-line arguments: -os macosx -ws carbon -arch x86
!ENTRY org.eclipse.update.configurator 2007-07-19 08:00:51.759
!MESSAGE Could not install bundle
../eclipsePlugins/eclipse/plugins/javax.wsdl_1.4.0.v20070611 1329.jar
Bundle "javax.wsdl" version "1.4.0.v200706111329" has already been
installed from: update@plugins/javax.wsdl_1.4.0.v200706111329.jar
!ENTRY org.eclipse.update.configurator 2007-07-19 08:00:51.768
../eclipsePlugins/eclipse/plugins/org.apache.xerces_2.8.0.v2 00705301630.jar
Bundle "org.apache.xerces" version "2.8.0.v200705301630" has already
been installed from:
update@plugins/org.apache.xerces_2.8.0.v200705301630.jar
!ENTRY org.eclipse.update.configurator 2007-07-19 08:00:51.770
../eclipsePlugins/eclipse/plugins/org.apache.xml.resolver_1. 1.0.v200705310020.jar
Bundle "org.apache.xml.resolver" version "1.1.0.v200705310020" has
already been installed from:
update@plugins/org.apache.xml.resolver_1.1.0.v200705310020.jar
!ENTRY org.eclipse.update.configurator 2007-07-19 08:00:51.771
../eclipsePlugins/eclipse/plugins/org.eclipse.datatools.conn ectivity.db.generic.ui_1.0.0.200706071.jar
Bundle "org.eclipse.datatools.connectivity.db.generic.ui" version
"1.0.0.200706071" has already been installed from:
update@plugins /org.eclipse.datatools.connectivity.db.generic.ui_1.0.0.2007 06071.jar
!ENTRY org.eclipse.update.configurator 2007-07-19 08:00:51.772
../eclipsePlugins/eclipse/plugins/org.eclipse.datatools.conn ectivity.db.generic_1.0.0.200706071.jar
Bundle "org.eclipse.datatools.connectivity.db.generic" version
update@plugins /org.eclipse.datatools.connectivity.db.generic_1.0.0.2007060 71.jar
!ENTRY org.eclipse.update.configurator 2007-07-19 08:00:51.773
../eclipsePlugins/eclipse/plugins/org.eclipse.datatools.conn ectivity.dbdefinition.genericJDBC_1.0.0.200706071.jar
Bundle "org.eclipse.datatools.connectivity.dbdefinition.genericJDBC "
version "1.0.0.200706071" has already been installed from:
update@plugins /org.eclipse.datatools.connectivity.dbdefinition.genericJDBC _1.0.0.200706071.jar
!ENTRY org.eclipse.update.configurator 2007-07-19 08:00:51.774
../eclipsePlugins/eclipse/plugins/org.eclipse.datatools.help _1.5.0.200706181.jar
Bundle "org.eclipse.datatools.help" version "1.5.0.200706181" has
update@plugins/org.eclipse.datatools.help_1.5.0.200706181.jar
!ENTRY org.eclipse.update.configurator 2007-07-19 08:00:51.775
../eclipsePlugins/eclipse/plugins/org.eclipse.datatools.sqlt ools.db.generic_1.0.0.200706131.jar
Bundle "org.eclipse.datatools.sqltools.db.generic" version
"1.0.0.200706131" has already been installed from:
update@plugins /org.eclipse.datatools.sqltools.db.generic_1.0.0.200706131.j ar
!ENTRY org.eclipse.update.configurator 2007-07-19 08:00:51.778
../eclipsePlugins/eclipse/plugins/org.eclipse.draw2d_3.2.100 .v20070529.jar
Bundle "org.eclipse.draw2d" version "3.2.100.v20070529" has already been
installed from: update@plugins/org.eclipse.draw2d_3.2.100.v20070529.jar
!ENTRY org.eclipse.update.configurator 2007-07-19 08:00:51.779
../eclipsePlugins/eclipse/plugins/org.eclipse.emf.commonj.sd o_2.3.0.v200706262000.jar
Bundle "org.eclipse.emf.commonj.sdo" version "2.3.0.v200706262000" has
update@plugins/org.eclipse.emf.commonj.sdo_2.3.0.v200706262000.jar
!ENTRY org.eclipse.update.configurator 2007-07-19 08:00:51.780
../eclipsePlugins/eclipse/plugins/org.eclipse.emf.ecore.sdo_ 2.3.0.v200706262000.jar
Bundle "org.eclipse.emf.ecore.sdo" version "2.3.0.v200706262000" has
update@plugins/org.eclipse.emf.ecore.sdo_2.3.0.v200706262000.jar
!ENTRY org.eclipse.update.configurator 2007-07-19 08:00:51.783
../eclipsePlugins/eclipse/plugins/org.eclipse.gef_3.2.100.v2 0070620.jar
Bundle "org.eclipse.gef" version "3.2.100.v20070620" has already been
installed from: update@plugins/org.eclipse.gef_3.2.100.v20070620.jar
!ENTRY org.eclipse.stp.common 4 0 2007-07-19 08:01:36.391
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at java.lang.reflect.Method.invoke(Method.java:589)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Re: STP Europa on a Intel MacBook Pro [message #374120 is a reply to message #374119] |
Thu, 19 July 2007 17:48 |
Rich, at this point googling for the error message is the best
alternative. I found one other occurence of this error for the Corona guys:
http://dev.eclipse.org/mhonarc/lists/corona-dev/msg00782.htm l
You could also consider addressing the problem on the Celtix mailing list.
Antoine
> Update service. On this install, I updated from a local update source to
> add the STP components. The source was an extension location for my
> Windows Vista setup that works correctly.
> ./eclipsePlugins/eclipse/plugins/javax.wsdl_1.4.0.v200706111 329.jar
> ./eclipsePlugins/eclipse/plugins/org.apache.xerces_2.8.0.v20 0705301630.jar
> ./eclipsePlugins/eclipse/plugins/org.apache.xml.resolver_1.1 .0.v200705310020.jar
> ./eclipsePlugins/eclipse/plugins/org.eclipse.datatools.conne ctivity.db.generic.ui_1.0.0.200706071.jar
> ./eclipsePlugins/eclipse/plugins/org.eclipse.datatools.conne ctivity.db.generic_1.0.0.200706071.jar
> ./eclipsePlugins/eclipse/plugins/org.eclipse.datatools.conne ctivity.dbdefinition.genericJDBC_1.0.0.200706071.jar
> ./eclipsePlugins/eclipse/plugins/org.eclipse.datatools.help_ 1.5.0.200706181.jar
> ./eclipsePlugins/eclipse/plugins/org.eclipse.datatools.sqlto ols.db.generic_1.0.0.200706131.jar
> ./eclipsePlugins/eclipse/plugins/org.eclipse.draw2d_3.2.100. v20070529.jar
> ./eclipsePlugins/eclipse/plugins/org.eclipse.emf.commonj.sdo _2.3.0.v200706262000.jar
> ./eclipsePlugins/eclipse/plugins/org.eclipse.emf.ecore.sdo_2 .3.0.v200706262000.jar
> ./eclipsePlugins/eclipse/plugins/org.eclipse.gef_3.2.100.v20 070620.jar
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: STP Europa on a Intel MacBook Pro [message #374207 is a reply to message #374206] |
Fri, 27 July 2007 05:56 |
Johnson Ma Messages: 17 Registered: July 2009 |
Hi Rich,
I missed your previous post that you already set the
Dorg.osgi.framework.bootdelegation=* flag.
I don't have an mac here. Can you add -verbose:class jvm flag before
starting eclipse? Then we can know which class and jar caused this
LinkError.
For the JVM version, 5.0 is good so far. I think cxf has some problem to run
on jdk6.
Johnson
"johnson ma" <johnson.ma@iona.com> wrote in message
news:f8c0rc$sa2$1@build.eclipse.org...
> Hi Rich,
> We also meet the java.lang.LinkageError for javax/xml/namespace/QName
> during development.
> After tracking the class loading process, i found that QName was defined
> in two places in that case:
> jre/lib/rt.jar and stax-api-1.0.jar (comes from Apache CXF plugin). and
> there are
> different versions. Both of them have been loaded to jvm during j2w, which
> caused the QName link error for JVM.
> Please read the wiki page on detail reason and work around
> (-Dorg.osgi.framework.bootdelegation=*)
> http://wiki.eclipse.org/Eclisep_3.3_runtime_options_for_STP. SC
> Regards
> Johnson
> "Rich" <rnmixon@custco.biz> wrote in message
> news:ffa152fec79ade0aa0f24cfad9550dd2$1@www.eclipse.org...
>>real resolution.
>> !STACK 0 java.lang.LinkageError: loader constraints violated when linking
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Thank you - Richard
Re: STP Europa on a Intel MacBook Pro [message #374211 is a reply to message #374207] |
Tue, 31 July 2007 05:48 |
Johnson,
Thanks for noticing :) I was away for a few days.
While trying to get the -verbose:class to work (never did as far as I can
tell). I finally realized (I think) that on Mac Os X, the
~/tools/eclipse/eclipse.ini file is not used. Instead I have to open the
Eclipse.app launcher and use the Contents/MacOS/eclipse.ini file. Once I
modified that with the "-Dorg.osgi.framework.bootdelegation=*" property,
the WSDL generation now seems to be working without the QName LinkageError
exception.
One note, it does require me to pre-create the package structure under the
WSDL directory in the example (e.g. wsdl/com/ibm/dw/scicalc) which took a
bit of figuring out.
Thank you again for your help/ear. I can try this STP things out a bit
more now.
- Richard
Re: STP Europa on a Intel MacBook Pro [message #589678 is a reply to message #374113] |
> at
Antoine
Re: STP Europa on a Intel MacBook Pro [message #589725 is a reply to message #374117] |
Rich,
> to work?
Re: STP Europa on a Intel MacBook Pro [message #589746 is a reply to message #374119] |
Antoine
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: STP Europa on a Intel MacBook Pro [message #592867 is a reply to message #374206] |
Hi Rich,
LinkError.
on jdk6.
Johnson
> Hi Rich,
> during development.
> there are
> Regards
> Johnson
>>real resolution.
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Thank you - Richard
