Home » Archived » Test and Performance Tools Platform (TPTP) » unknown classes and methods when profiling with Java 6, Eclipse 3.5, TPTP 4.6
unknown classes and methods when profiling with Java 6, Eclipse 3.5, TPTP 4.6 [message #373469] |
Wed, 29 July 2009 14:40 |
Originally posted by: khilan.doc.ic.ac.uk
Dear all,
I'm a newbie to TPTP and have run into a problem with unknown classes and
methods. I'm using Eclipse 3.5 with Java 6 and TPTP 4.6 on Ubuntu Jaunty
9.04 to profile a simple application:
System.out.println();
I profile this as a Java Application and am performing an Execution Time
Analysis with "Collect method CPU time information" unchecked and "Show
execution flow graphical details" checked. Furthermore, I have defined a
filter "No Filter" which contains the single rule "Classes: *, Methods: *,
Rule: INCLUDE".
In the profiler output, the following packages appear:
default
java.net
java.nio
java.nio.charset
java.util
sun.jkernel
sun.misc
sun.net.www
sun.net.www.protocol.file
sun.security.provider
sun.security.util
This gives me confidence that the filter is working. However, the java.io
package doesn't appear and instead there are a number of "unknown" classes
listed in the default package. Also, when looking at the call tree, there
are "unknown" methods too, which I'm guessing belong to these unknown
classes.
I've also tried using Java 5 (with Eclipse 3.5 and TPTP 4.6) but I still
get the same problem.
Any help would be appreciated,
Khilan
Re: unknown classes and methods when profiling with Java 6, Eclipse 3.5, TPTP 4.6 [message #375031 is a reply to message #373469] |
Wed, 29 July 2009 17:39 |
Eugene Chan Messages: 287 Registered: July 2009 |
Hi Khilan,
Even tho you have specify your profiling session to collect all data, there
are certain classes in the JRE being filtered out by default with the
limitation of the profiler. Unknown methods may result with method defintion
or method entry events being missed by the profiler before the profiler
starts collecting.
Eugene
"Khilan" <khilan@doc.ic.ac.uk> wrote in message
news:085f5c89b9bc18a601999426ba607a0c$1@www.eclipse.org...
> Dear all,
> public static void main(String[] args) {
> Rule: INCLUDE".
> default
> java.net
> java.nio
> java.nio.charset
> java.util
> sun.jkernel
> sun.misc
> sun.net.www
> sun.security.util
> classes.
> Khilan
Re: unknown classes and methods when profiling with Java 6, Eclipse 3.5, TPTP 4.6 [message #376839 is a reply to message #375031] |
Wed, 29 July 2009 20:21 |
Hi Eugene,
Thanks for the reply. I modified the program to accept a keystroke before
calling println():
System.in.read();
I was hoping this would give the profiler some time before it had to
collect the data for println(), however I'm still getting unknown classes
and methods. This seems to be the story with eclipse 3.5 and tptp 4.6.
The funny thing is that I tried using Eclipse 3.4 with TPTP 4.5.2.1 and
both java 1.5 and 1.6 and the profiling works in this case (java.io
classes and their methods are there).
Seems like either a problem with eclipse 3.5 or tptp 4.6.
Khilan
Eugene Chan wrote:
> Hi Khilan,
> starts collecting.
> Eugene
>> Dear all,
>> Rule: INCLUDE".
>> default
>> java.net
>> java.nio
>> java.nio.charset
>> java.util
>> sun.jkernel
>> sun.misc
>> sun.net.www
>> sun.security.util
>> classes.
>> Thanks,
>> Khilan
Re: unknown classes and methods when profiling with Java 6, Eclipse 3.5, TPTP 4.6 [message #445981 is a reply to message #376839] |
Fri, 31 July 2009 20:45 |
Hi Khilan,
This sounds like a bug to me, I have reproduced the problem and opened bug
285330 for the problem.
Eugene
news:0c19e55e651d7212aedb9e068d0a09ae$1@www.eclipse.org...
> Hi Eugene,
> calling println():
> System.in.read();
> Khilan
> Eugene Chan wrote:
>> Hi Khilan,
>> there are certain classes in the JRE being filtered out by default with
>> the limitation of the profiler. Unknown methods may result with method
>> defintion or method entry events being missed by the profiler before the
>> profiler starts collecting.
>> Eugene
>>> Dear all,
>>> and methods. I'm using Eclipse 3.5 with Java 6 and TPTP 4.6 on Ubuntu
>>> Jaunty 9.04 to profile a simple application:
>>> *, Rule: INCLUDE".
>>> default
>>> java.net
>>> java.nio
>>> java.nio.charset
>>> java.util
>>> sun.jkernel
>>> sun.misc
>>> sun.net.www
>>> sun.security.util
>>> java.io package doesn't appear and instead there are a number of
>>> "unknown" classes listed in the default package. Also, when looking at
>>> the call tree, there are "unknown" methods too, which I'm guessing
>>> belong to these unknown classes.
>>> Thanks,
>>> Khilan
Current Time: Wed Sep 25 18:33:24 GMT 2024
Powered by FUDForum. Page generated in 0.03687 seconds
