Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Help: Why I cannot run swt example?
Help: Why I cannot run swt example? [message #373421] Wed, 10 September 2003 03:35 Go to next message
Originally posted by: StephenLiu.oval-tech.com
I have already configured build path and VM arguments. But when I run
"controlexample", system notice me an error message:
The instruction at "0x18493768" referenced memory at "0x00000000". The
memory could not be "read".
What's the matter?
My operating system is windows2000 sp4, and the version of eclipse is 2.1.1.
Thanks.
Re: Help: Why I cannot run swt example? [message #373427 is a reply to message #373421] Wed, 10 September 2003 04:22 Go to previous messageGo to next message
Originally posted by: jmordax.terra.es
Which JDK? Make sure it is 1.3.1 which is the supported one (although I
have tested R2.1.1 with 1.4.2 and it works).
Hope this helps,
Chemi.
>What's the matter?
>Thanks.
Re: Help: Why I cannot run swt example? [message #373474 is a reply to message #373427] Thu, 11 September 2003 01:03 Go to previous messageGo to next message
JDK 1.4.2. And the error message is:
java.lang.RuntimeException: Unable to load resources
org.eclipse.swt.examples.controlexample.ControlExample.initR esources(Control
Example.java:270)
org.eclipse.swt.examples.controlexample.ControlExample.<init >(ControlExample
..java:62)
org.eclipse.swt.examples.controlexample.CustomControlExample . <init>(CustomCo
ntrolExample.java:26)
org.eclipse.swt.examples.controlexample.CustomControlExample .main(CustomCont
rolExample.java:51)
Thank you!
"Chemi" <jmordax@terra.es> wrote in message news:bjmn5r$15u$1@eclipse.org...
> Hope this helps,
> Chemi.
> >What's the matter?
2.1.1.
> >Thanks.
Re: Help: Why I cannot run swt example? [message #373479 is a reply to message #373474] Thu, 11 September 2003 04:07 Go to previous messageGo to next message
--------------090301010003020306050408
Content-Type: text/plain; charset=us-ascii; format=flowed
Have you tried to reinstall the examples? It seems it doesn't find
something......
Hope this helps,
Chemi.
> at
>Example.java:270)
> at
>.java:62)
> at
> at
>rolExample.java:51)
>Thank you!
>>Hope this helps,
>> Chemi.
>>>What's the matter?
>2.1.1.
>>>Thanks.
Content-Type: text/html; charset=us-ascii
<html>
<head>
<meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-1">
<title></title>
</head>
<body text="#000000" bgcolor="#ffffff">
something......<br>
<br>
Hope this helps,<br>
<br>
&nbsp;&nbsp;&nbsp;&nbsp; Chemi.<br>
<br>
StephenLiu wrote:<br>
<blockquote type="cite" cite="midbjovgn$99t$1@eclipse.org">
<pre wrap="">JDK 1.4.2. And the error message is:
Example.java:270)
org.eclipse.swt.examples.controlexample.ControlExample.& lt;init&gt;(ControlExample
..java:62)
org.eclipse.swt.examples.controlexample.CustomControlExample .&lt;init&gt;(CustomCo
rolExample.java:51)
Thank you!
"Chemi" <a class="moz-txt-link-rfc2396E" href="mailto:jmordax@terra.es">&lt;jmordax@terra.es&gt;</a> wrote in message <a class="moz-txt-link-freetext" href="news:bjmn5r$15u$1@eclipse.org">news:bjmn5r$15u$1@eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Which JDK? Make sure it is 1.3.1 which is the supported one (although I
Hope this helps,
Chemi.
StephenLiu wrote:
</pre>
<pre wrap="">I have already configured build path and VM arguments. But when I run
What's the matter?
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->2.1.1.
</pre>
<pre wrap="">Thanks.</pre>
</blockquote>
</blockquote>
</blockquote>
</body>
</html>
--------------090301010003020306050408--
Re: Help: Why I cannot run swt example? [message #373507 is a reply to message #373479] Thu, 11 September 2003 21:41 Go to previous message
It has no effect:-(
Strangely, it works well on an other machine whose operating system is
winXP. Maybe it's caused by win2000?
Now I decide to view the source only.
Thank you!
"Chemi" <jmordax@terra.es> wrote in message news:bjpanr$itd$1@eclipse.org...
something......
Hope this helps,
Chemi.
Example.java:270)
..java:62)
rolExample.java:51)
Thank you!
Hope this helps,
Chemi.
What's the matter?
2.1.1.
Thanks.
Previous Topic:How to auto-activate edition in a TableViewer
Next Topic:new SWT article: Taking a look at SWT Images
Current Time: Tue Sep 23 09:09:08 EDT 2025
Powered by FUDForum. Page generated in 0.04928 seconds
