Home » Eclipse Projects » Standard Widget Toolkit (SWT) » swt OleClientSite and excel problem
swt OleClientSite and excel problem [message #371862] Sun, 20 July 2003 21:31 Go to next message
Originally posted by: kkidd.163.com
1.I open a excel using ms-excel.
2.I open a excel using OleClientSite.
only one excel window can be edit(excel 2),the excel 1 cant be edit
I am using swt-2.1-win32.
the ApplicationWindow have some problems if i use swt-2.1.1-win32.
(i am poor in english,can you understand my question)
Re: swt OleClientSite and excel problem [message #371916 is a reply to message #371862] Wed, 23 July 2003 13:50 Go to previous messageGo to next message
Originally posted by: veronika_irvine.oti.com
I just tried this on Windows XP with Eclipse 2.1.0 build 200306051737.
If I open an excel file in Eclipse first and then open Excel externally,
everything is fine. But if I open Excel externally first and then open
Excel within Eclipse I get the error:
-2147417846 (8001010A) The message
filter indicated that the application is busy.
Please enter a bug report against Platform SWT.
"kkidd" <kkidd@163.com> wrote in message news:bfffqc$9j5$1@eclipse.org...
OleClientSite Excel questions [message #393802 is a reply to message #371862] Mon, 01 December 2003 00:14 Go to previous messageGo to next message
When I open an Excel sheet using OleClientSite, I notice that
1. The 'Save' Button is always disabled, despite changes
2. The scroll bar of excel spread sheet cannot be seen
Can anyone throw light on why it is so,
thanks in advance,
Rahul.
Re: OleClientSite Excel questions [message #393960 is a reply to message #393802] Wed, 03 December 2003 08:57 Go to previous messageGo to next message
1. In VB I think the following would work:
Application.CommandBars("Standard").Controls("Save").Enabled = true
When I get a moment, I will try this and post what it would like in SWT.
2. There was a fix - see OleClientSite.QueryInterface support for
iOleDocumentSite. However, the fix had bad side effects which I have not
yet worked around. See:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=35493
"Rahul Gudla" <rush2rahul@hotmail.com> wrote in message
news:bqeiei$4k3$1@eclipse.org...
> thanks in advance,
> Rahul.
Re: OleClientSite Excel questions [message #395591 is a reply to message #393960] Fri, 05 December 2003 07:37 Go to previous messageGo to next message
Thx, I have another question (I have looked up the bug CVS without success):
When I open a .xls file in OleFrame, I do not see the row or column
headers. When I drag the same file into IE6, I see that the document
opens up as it does in Excel with all the headers.
Shall I raise it as a bug?
thx
Rahul.
>>Hi,
>>thanks in advance,
>>Rahul.
Re: OleClientSite Excel questions [message #397432 is a reply to message #395591] Wed, 10 December 2003 09:10 Go to previous message
Please enter a bug report.
news:bqpts9$3fd$1@eclipse.org...
success):
> thx
> Rahul.
not
> >>Hi,
> >>thanks in advance,
> >>Rahul.
Previous Topic:How to get rid of phantom column in SWT Table?
Next Topic:FieldEditors and PreferenceStore
Current Time: Mon Nov 03 10:23:30 EST 2025
Powered by FUDForum. Page generated in 0.07337 seconds
