Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Error calling Help in Eclipse eclipse-SDK-2.1-linux-gtk
Error calling Help in Eclipse eclipse-SDK-2.1-linux-gtk [message #371176] Mon, 23 June 2003 04:30 Go to next message
Originally posted by: thelade.web.de
Hi guys
I've problemes to get the Help-System running.
I use eclipse-SDK-2.1-linux-gtk under SuSE 8.1.
When I call up the Help-System, the following error occurs:
Apache Tomcat/4.0.6 - HTTP Status 500 - Internal Server Error
type Exception report
message Internal Server Error
description The server encountered an internal error (Internal Server
Error) that prevented it from fulfilling this request.
exception
org.apache.jasper.JasperException: Unable to compile class for JSP
org.apache.jasper.servlet.JspServlet.loadJSP(JspServlet.java :580)
org.apache.jasper.servlet.JspServlet$JspServletWrapper.loadI fNecessary(JspServlet.java:176)
org.apache.jasper.servlet.JspServlet$JspServletWrapper.servi ce(JspServlet.java:188)
org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServl et.java:381)
org.apache.jasper.servlet.JspServlet.service(JspServlet.java :473)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:853)
org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:247)
org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:193)
org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:243)
org.apache.catalina.core.StandardPipeline.invokeNext(Standar dPipeline.java:566)
org.apache.catalina.core.StandardPipeline.invoke(StandardPip eline.java:472)
org.apache.catalina.core.ContainerBase.invoke(ContainerBase. java:943)
org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:190)
org.apache.catalina.core.StandardContext.invoke(StandardCont ext.java:2347)
org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:180)
org.apache.catalina.valves.ErrorDispatcherValve.invoke(Error DispatcherValve.java:170)
org.apache.catalina.core.StandardPipeline.invokeNext(Standar dPipeline.java:564)
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:170)
org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:174)
org.apache.catalina.connector.http.HttpProcessor.process(Htt pProcessor.java:1027)
org.apache.catalina.connector.http.HttpProcessor.run(HttpPro cessor.java:1125)
at java.lang.Thread.run(Thread.java:479)
root cause
java.lang.ClassNotFoundException: org.apache.jsp.index$jsp
org.apache.jasper.servlet.JasperLoader.loadClass(JasperLoade r.java:210)
org.apache.jasper.servlet.JasperLoader.loadClass(JasperLoade r.java:132)
org.apache.jasper.servlet.JspServlet.loadJSP(JspServlet.java :577)
Can anybody tell me what's going wrong.
Thanks a lot.
RM
Re: Error calling Help in Eclipse eclipse-SDK-2.1-linux-gtk [message #371260 is a reply to message #371176] Thu, 26 June 2003 10:40 Go to previous message
Originally posted by: birsan.nospam.ca.ibm.com
All the help jsp's are precompiled, so there is no need to have them
compiled at runtime.
Perhaps your installation is corrupt or you are using an old JDK that has
some problems with static strings.
Check bugzilla for a bug report regarding the JDK issue.
-Dorian
"Reto" <thelade@web.de> wrote in message news:bd6dqi$sae$1@rogue.oti.com...
> Hi guys
> exception
> at
> at
rvlet.java:176)
> at
va:188)
> at
> at
> at
> at
ain.java:193)
> at
va:243)
> at
66)
> at
> at
> at
va:190)
> at
66)
> at
> at
> at
> at
> at
66)
> at
java:170)
> at
64)
> at
> at
64)
> at
> at
> at
:174)
> at
66)
> at
> at
> at
1027)
> at
> root cause
> at
> at
> at
> at
rvlet.java:176)
> at
va:188)
> at
> at
> at
> at
ain.java:193)
> at
va:243)
> at
66)
> at
> at
> at
va:190)
> at
66)
> at
> at
> at
> at
> at
66)
> at
java:170)
> at
64)
> at
> at
64)
> at
> at
> at
:174)
> at
66)
> at
> at
> at
1027)
> at
> Thanks a lot.
> RM
Previous Topic:xml editor composite
Next Topic:[SWT] Table with different cells
Current Time: Fri Nov 07 20:51:21 EST 2025
Powered by FUDForum. Page generated in 0.46672 seconds
